| 1 |
#!/usr/bin/perl |
| 2 |
| 3 |
# Make an interactive preview of a luminaire |
| 4 |
| 5 |
# This script is based on Radiance's objview.pl plus |
| 6 |
# Rob Guglielmetti's ltview extension to his objview.rb |
| 7 |
| 8 |
# Written by Axel Jacobs <[email protected]> |
| 9 |
| 10 |
use strict; |
| 11 |
use warnings; |
| 12 |
use Math::Trig; |
| 13 |
use File::Temp qw/ tempdir /; |
| 14 |
| 15 |
my $td = tempdir( CLEANUP => 1 ); |
| 16 |
my $oct = "$td/ltview.oct"; |
| 17 |
my $room = "$td/room.rad"; |
| 18 |
my $box; # Overall box dimensions |
| 19 |
my $rif = "$td/ltview.rif"; |
| 20 |
my $lumi = "$td/lumi.rad"; # Fitting as given on cmd line, or generated by ies2rad |
| 21 |
my $lumi2 = "$td/lumi2.rad"; # Fitting centred at origin |
| 22 |
my $raddev = "x11"; # Default output device. Overwrite with -o |
| 23 |
my $is_ies = 0; # Input file is IES photometry, not a Radiance luminaire |
| 24 |
| 25 |
while (@ARGV) { |
| 26 |
$_ = $ARGV[0]; |
| 27 |
if (m/-i/) { |
| 28 |
$is_ies = 1; |
| 29 |
} elsif (m/-o/) { # output device (rvu -devices) |
| 30 |
$raddev = $ARGV[1]; |
| 31 |
shift @ARGV; |
| 32 |
} elsif (m/-b/) { |
| 33 |
$box = $ARGV[1]; # Box dimensions |
| 34 |
shift @ARGV; |
| 35 |
} elsif (m/^-\w/) { |
| 36 |
die("ltview: Bad option: '$_'\n"); |
| 37 |
} else { |
| 38 |
last; |
| 39 |
| 40 |
shift @ARGV; |
| 41 |
| 42 |
| 43 |
# We need exactly one Radiance luminaires or IES file |
| 44 |
if ( !$#ARGV == 0 ) { |
| 45 |
die("ltview: Need one Radiance luminaire or IES file.\n"); |
| 46 |
} elsif ( $is_ies == 0 ) { |
| 47 |
| 48 |
# Input file is a Radiance luminaire |
| 49 |
$lumi = $ARGV[0]; |
| 50 |
} else { |
| 51 |
| 52 |
# Input file is IES photometry |
| 53 |
system qq[ ies2rad -p $td -o lumi "$ARGV[0]" ]; |
| 54 |
| 55 |
| 56 |
# Work out centre of luminaire |
| 57 |
my $dimstr = `getbbox -h "$lumi"`; |
| 58 |
chomp $dimstr; |
| 59 |
| 60 |
# Values returned by getbbox are indented and delimited with multiple spaces. |
| 61 |
$dimstr =~ s/^\s+//; # remove leading spaces |
| 62 |
my @dims = split( /\s+/, $dimstr ); # convert to array |
| 63 |
| 64 |
# Find largest axes-aligned luminaire dimension |
| 65 |
# The box will be ten times as large, unless overwritten with -b option. |
| 66 |
my @diffs = reverse sort { $a <=> $b } |
| 67 |
( $dims[1] - $dims[0], $dims[3] - $dims[2], $dims[5] - $dims[4] ); |
| 68 |
my $lsize = $diffs[0]; |
| 69 |
| 70 |
# Centre fitting at origin |
| 71 |
my $xtrans = -1.0 * ( $dims[0] + $dims[1] ) / 2; |
| 72 |
my $ytrans = -1.0 * ( $dims[2] + $dims[3] ) / 2; |
| 73 |
my $ztrans = -1.0 * ( $dims[4] + $dims[5] ) / 2; |
| 74 |
system qq[ xform -t $xtrans $ytrans $ztrans "$lumi" > $lumi2 ]; |
| 75 |
| 76 |
# Make the enclosing box |
| 77 |
my $b2; |
| 78 |
if ( defined $box ) { |
| 79 |
| 80 |
# Room dimensions are giving explicitly. |
| 81 |
$b2 = $box / 2; |
| 82 |
} else { |
| 83 |
| 84 |
# Box dimensions are ten times largest luminaire bbox dimensions. |
| 85 |
$b2 = $lsize * 10.0 / 2.0; |
| 86 |
| 87 |
| 88 |
open( FH, ">$room" ) |
| 89 |
or die("ltview: Can't write to temporary file '$room'\n"); |
| 90 |
print FH <<EndOfRoom; |
| 91 |
void plastic wall_mat 0 0 5 .2 .2 .2 0 0 |
| 92 |
| 93 |
# Don't generate -y face so we can look into the box |
| 94 |
#wall_mat polygon box.1540 0 0 12 $b2 -$b2 -$b2 $b2 -$b2 $b2 -$b2 -$b2 $b2 -$b2 -$b2 -$b2 |
| 95 |
wall_mat polygon box.4620 0 0 12 -$b2 -$b2 $b2 -$b2 $b2 $b2 -$b2 $b2 -$b2 -$b2 -$b2 -$b2 |
| 96 |
wall_mat polygon box.2310 0 0 12 -$b2 $b2 -$b2 $b2 $b2 -$b2 $b2 -$b2 -$b2 -$b2 -$b2 -$b2 |
| 97 |
wall_mat polygon box.3267 0 0 12 $b2 $b2 -$b2 -$b2 $b2 -$b2 -$b2 $b2 $b2 $b2 $b2 $b2 |
| 98 |
wall_mat polygon box.5137 0 0 12 $b2 -$b2 $b2 $b2 -$b2 -$b2 $b2 $b2 -$b2 $b2 $b2 $b2 |
| 99 |
wall_mat polygon box.6457 0 0 12 -$b2 $b2 $b2 -$b2 -$b2 $b2 $b2 -$b2 $b2 $b2 $b2 $b2 |
| 100 |
EndOfRoom |
| 101 |
close(FH); |
| 102 |
| 103 |
my $scene = "$room $lumi2"; |
| 104 |
| 105 |
# Make this work under Windoze |
| 106 |
if ( $^O =~ /MSWin32/ ) { |
| 107 |
$scene =~ s{\\}{/}g; |
| 108 |
$oct =~ s{\\}{/}g; |
| 109 |
$raddev = "qt"; |
| 110 |
| 111 |
| 112 |
# Tweak scene bounding box so we get a nice view covering all of the box, without |
| 113 |
# having a wasteful black border around it. Must work for arbitrary box dims. |
| 114 |
my $zone = 1.1 * $b2 * ( 1 + 1 / tan( 22.5 * pi / 180 ) ); |
| 115 |
| 116 |
open( FH, ">$rif" ) |
| 117 |
or die("ltview: Can't write to temporary file '$rif'\n"); |
| 118 |
print FH <<EndOfRif; |
| 119 |
scene= $scene |
| 120 |
ZONE= Interior -$zone $zone -$zone $zone -$zone $zone |
| 121 |
UP= Z |
| 122 |
view= y |
| 123 |
OCTREE= $oct |
| 124 |
oconv= -f |
| 125 |
render= -av 0 0 0 |
| 126 |
INDIRECT= 0 |
| 127 |
QUALITY= Med |
| 128 |
DETAIL= Low |
| 129 |
VARIABILITY= Med |
| 130 |
EndOfRif |
| 131 |
close(FH); |
| 132 |
| 133 |
exec "rad -o $raddev $rif"; |
| 134 |
| 135 |
#EOF |
