root/radiance/src/util/glrad.c
Revision: 3.29
Committed: Tue Jun 3 21:31:51 2025 UTC (4 months, 2 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 3.28: +3 -4 lines
2 static const char RCSid[] = "$Id: glrad.c,v 3.28 2024/06/03 18:55:51 greg Exp $";
5 * Program to display Radiance scene using OpenGL.
6 */
7
8 #include <sys/types.h>
9 #include <GL/glx.h>
10 #ifndef NOSTEREO
11 #include <X11/extensions/SGIStereo.h>
12 #endif
13 #include <ctype.h>
14 #include <string.h>
15 #include <time.h>
16
17 #include "radogl.h"
18 #include "view.h"
19 #include "paths.h"
20 #include "glradicon.h"
21 #include "rtprocess.h"
22
23 #ifndef MAXVIEW
24 #define MAXVIEW 63 /* maximum number of standard views */
25 #endif
26 #ifndef MAXSCENE
27 #define MAXSCENE 127 /* maximum number of scene files */
28 #endif
29
30 #define ZOOMPCT 9 /* percent to zoom for +/- */
31 #define WZOOMPCT 3 /* percent to zoom for mouse wheel */
32
33 #define MOVPCT 4 /* percent distance to move /frame */
34 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
35 #define MOVDEG (-1.5) /* degrees to orbit CW/down /frame */
36 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
37
38 #define BORWIDTH 5 /* border width */
39
40 #define ourscreen DefaultScreen(ourdisplay)
41 #define ourroot RootWindow(ourdisplay,ourscreen)
42 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
43 ButtonPressMask|ButtonReleaseMask)
44
45 #define levptr(etype) ((etype *)&currentevent)
46
47 XEvent currentevent; /* current event */
48
49 int mapped = 0; /* window is mapped? */
50 unsigned long ourblack=0, ourwhite=~0;
51
52 Display *ourdisplay = NULL; /* our display */
53 XVisualInfo *ourvinf; /* our visual information */
54 Window gwind = 0; /* our graphics window */
55 int hres, vres; /* rendering window dimensions */
56 int maxhres, maxvres; /* maximum given dimensions */
57 GLXContext gctx; /* our GLX context */
58
59 double pwidth, pheight; /* pixel dimensions (mm) */
60
61 int headlocked = 0; /* lock vertical motion */
62
63 struct {
64 char *nam; /* view name (NULL if none) */
65 VIEW *v; /* parameters (NULL term.) */
66 } vwl[MAXVIEW+1]; /* our list of views */
67
68 int currentview = 0; /* current view number */
69 VIEW thisview = STDVIEW; /* displayed view */
70 double eyedist = 1; /* interocular distance */
71 VIEW lastview; /* last recorded view */
72
73 char *radfile; /* rad input file */
74 char *scene[MAXSCENE+1]; /* material and scene file list */
75 int nscenef = 0; /* number of scene files */
76 char *octree; /* octree name (NULL if unnec.) */
77
78 SUBPROC rtpd = SP_INACTIVE; /* rtrace process descriptors */
79
80 int silent = 0; /* run rad silently? */
81 int backvis = 1; /* back faces visible? */
82 int stereo = 0; /* do stereo? */
83
84 #ifdef NOSTEREO
85 #define setstereobuf(bid)
86 #else
87 #define setstereobuf(bid) (glXWaitGL(), \
88 XSGISetStereoBuffer(ourdisplay, gwind, bid), \
89 glXWaitX())
90 #endif
91
92 int displist; /* our scene display list */
93
94 int no_render = 0; /* don't rerender */
95
96 extern int nowarn; /* turn warnings off? */
97
98 static void startrtrace(char *octname);
99 static void runrad(int ac, char **av);
100 static int findvw(char *nm);
101 static int varmatch(char *s, char *vn);
102 static char * scan4var(char *buf, int buflen, char *vname, FILE *fp);
103 static void dev_open(char *id);
104 static void dev_close(void);
105 static int dev_view(VIEW *nv);
106 static int dev_input(int nsecs);
107 static void render(void);
108 static int moveview(int dx, int dy, int mov, int orb);
109 static void waitabit(void);
110 static void getmove(XButtonPressedEvent *ebut);
111 static int getintersect(FVECT wp, FVECT org, FVECT dir, double md);
112 static void setglpersp(VIEW *vp);
113 static int getkey(XKeyPressedEvent *ekey);
114 static void zoomview(int pct, int dx, int dy);
115 static void gotoview(int vwnum);
116 static void appendview(char *nm, VIEW *vp);
117 static void copylastv(char *cause);
118 static void fixwindow(XExposeEvent *eexp);
119 static void resizewindow(XConfigureEvent *ersz);
120
121
122 int
123 main(
124 int argc,
125 char *argv[]
126 )
127 {
128 char *viewsel = NULL;
129 long vwintvl = 0;
130 int i;
131 /* set global progname */
132 fixargv0(argv[0]);
133 for (i = 1; i < argc && argv[i][0] == '-'; i++)
134 switch (argv[i][1]) {
135 case 'v':
136 viewsel = argv[++i];
137 break;
138 case 'w':
139 nowarn = !nowarn;
140 break;
141 case 's':
142 silent = !silent;
143 break;
144 case 'S':
145 stereo = !stereo;
146 break;
147 case 'c':
148 vwintvl = atoi(argv[++i]);
149 break;
150 case 'b':
151 backvis = !backvis;
152 break;
153 default:
154 goto userr;
155 }
156 if (i >= argc)
157 goto userr;
158 #ifdef NOSTEREO
159 if (stereo)
160 error(INTERNAL, "stereo not supported in this version");
161 #endif
162 /* run rad and get views */
163 runrad(argc-i, argv+i);
164 /* check view */
165 if (viewsel != NULL) {
166 if (viewsel[0] == '-') {
167 char *ve = viewsel;
168 if (!sscanview(&thisview, viewsel) ||
169 (ve = setview(&thisview)) != NULL) {
170 fprintf(stderr, "%s: bad view: %s\n",
171 progname, ve);
172 quit(1);
173 }
174 currentview = -1;
175 } else if ((currentview = findvw(viewsel)) < 0) {
176 fprintf(stderr, "%s: no such view: %s\n",
177 progname, viewsel);
178 quit(1);
179 }
180 }
181 /* open GL */
182 dev_open(radfile = argv[i]);
183 /* load octree or scene files */
184 if (octree != NULL) {
185 displist = rgl_octlist(octree, NULL, NULL, NULL);
186 startrtrace(octree);
187 } else
188 displist = rgl_filelist(nscenef, scene, NULL);
189 /* set initial view */
190 dev_view(currentview < 0 ? &thisview : vwl[currentview].v);
191 /* input/render loop */
192 while (dev_input(vwintvl))
193 ;
194 /* all done */
195 quit(0);
196 userr:
197 fprintf(stderr,
198 "Usage: %s [-w][-s][-b][-S][-v view] rfile [VAR=value]..\n",
199 argv[0]);
200 quit(1);
201 return 1; /* pro forma return */
202 }
203
204
205 void
206 quit( /* exit gracefully */
207 int code
208 )
209 {
210 if (ourdisplay != NULL)
211 dev_close();
212 /* if (rtpd.pid > 0) { */
213 if (rtpd.flags & PF_RUNNING) {
214 if (close_process(&rtpd) > 0)
215 wputs("bad exit status from rtrace\n");
216 /* rtpd.pid = 0; */
217 }
218 exit(code);
219 }
220
221
222 static void
223 startrtrace( /* start rtrace on octname */
224 char *octname
225 )
226 {
227 static char *av[12] = {"rtrace", "-h", "-fff", "-ld+",
228 "-opL", "-x", "1"};
229 int ac = 7;
230
231 if (nowarn) av[ac++] = "-w-";
232 av[ac++] = octname;
233 av[ac] = NULL;
234 if (open_process(&rtpd, av) <= 0)
235 error(SYSTEM, "cannot start rtrace process");
236 }
237
238
239 static void
240 runrad( /* run rad and load variables */
241 int ac,
242 char **av
243 )
244 {
245 static char optfile[] = TEMPLATE;
246 int nvn = 0, nvv = 0;
247 FILE *fp;
248 char *cp;
249 char radcomm[256], buf[128], nam[32];
250 /* set rad commmand */
251 strcpy(radcomm, "rad -w -v 0 "); /* look out below! */
252 cp = radcomm + 19;
253 if (silent) {
254 strcpy(cp, "-s ");
255 cp += 3;
256 }
257 while (ac--) {
258 strcpy(cp, *av++);
259 while (*cp) cp++;
260 *cp++ = ' ';
261 }
262 strcpy(cp, "OPTFILE="); /* create temporary options file */
263 strcpy(cp+8, mktemp(optfile));
264 if (system(radcomm)) /* update octree */
265 error(USER, "error executing rad command");
266 /* replace "-v 0" with "-n -e -s -V" */
267 strcpy(radcomm+7, "-n -e -s -V");
268 radcomm[18] = ' ';
269 if ((fp = popen(radcomm, "r")) == NULL)
270 error(SYSTEM, "cannot start rad command");
271 buf[0] = '\0'; /* read variables alphabetically */
272 /* get exposure */
273 if ((cp = scan4var(buf, sizeof(buf), "EXPOSURE", fp)) != NULL) {
274 expval = atof(cp);
275 if ((*cp == '-') | (*cp == '+'))
276 expval = pow(2., expval);
277 expval *= 0.5; /* compensate for local shading */
278 }
279 /* look for eye separation */
280 if ((cp = scan4var(buf, sizeof(buf), "EYESEP", fp)) != NULL)
281 eyedist = atof(cp);
282 /* look for materials */
283 while ((cp = scan4var(buf, sizeof(buf), "materials", fp)) != NULL) {
284 nscenef += wordstring(scene+nscenef, MAXSCENE-nscenef, cp);
285 buf[0] = '\0';
286 }
287 /* look for octree */
288 if ((cp = scan4var(buf, sizeof(buf), "OCTREE", fp)) != NULL)
289 octree = savqstr(cp);
290 /* look for scene files */
291 while ((cp = scan4var(buf, sizeof(buf), "scene", fp)) != NULL) {
292 nscenef += wordstring(scene+nscenef, MAXSCENE-nscenef, cp);
293 buf[0] = '\0';
294 }
295 /* load view names */
296 while ((cp = scan4var(buf, sizeof(buf), "view", fp)) != NULL) {
297 if (nvn >= MAXVIEW)
298 error(INTERNAL, "too many views in rad file");
299 vwl[nvn++].nam = *cp == '-' ? (char *)NULL :
300 savqstr(atos(nam, sizeof(nam), cp));
301 buf[0] = '\0';
302 }
303 /* load actual views */
304 do
305 if (isview(buf)) {
306 vwl[nvv].v = (VIEW *)bmalloc(sizeof(VIEW));
307 *(vwl[nvv].v) = stdview;
308 sscanview(vwl[nvv].v, buf);
309 if ((cp = setview(vwl[nvv++].v)) != NULL) {
310 fprintf(stderr, "%s: bad view %d - %s\n",
311 progname, nvv, cp);
312 quit(1);
313 }
314 }
315 while (fgets(buf, sizeof(buf), fp) != NULL);
316 if (nvv != nvn)
317 error(INTERNAL, "view miscount in runrad");
318 pclose(fp);
319 /* open options file */
320 if ((fp = fopen(optfile, "r")) == NULL)
321 error(SYSTEM, "cannot open options file");
322 /* get relevant options */
323 while (fgets(buf, sizeof(buf), fp) != NULL)
324 if (!strncmp(buf, "-av ", 4))
325 setcolor(ambval, atof(buf+4),
326 atof(sskip2(buf+4,1)),
327 atof(sskip2(buf+4,2)));
328 else if (backvis && !strncmp(buf, "-bv", 3) &&
329 (!buf[3] || strchr("0-FfNn \n",buf[3])!=NULL))
330 backvis = 0;
331 fclose(fp);
332 unlink(optfile); /* delete options file */
333 }
334
335
336 static int
337 findvw( /* find named view */
338 char *nm
339 )
340 {
341 int n;
342
343 if ((*nm >= '1') & (*nm <= '9') &&
344 (n = atoi(nm)-1) <= MAXVIEW && vwl[n].v != NULL)
345 return(n);
346 for (n = 0; vwl[n].v != NULL; n++)
347 if (vwl[n].nam != NULL && !strcmp(nm, vwl[n].nam))
348 return(n);
349 return(-1);
350 }
351
352
353 static int
354 varmatch( /* match line to variable */
355 char *s,
356 char *vn
357 )
358 {
359 int c;
360
361 for ( ; *vn && *s == *vn; s++, vn++)
362 ;
363 while (isspace(*s))
364 s++;
365 if (*s == '=')
366 return(*vn);
367 while (!(c = toupper(*s++) - toupper(*vn)) && *vn++)
368 ;
369 return(c);
370 }
371
372
373 static char *
374 scan4var( /* scan for variable from fp */
375 char *buf,
376 int buflen,
377 char *vname,
378 FILE *fp
379 )
380 {
381 int cval;
382 char *cp;
383 /* search out matching line */
384 while ((cval = varmatch(buf, vname))) {
385 if (cval > 0) /* gone too far? */
386 return(NULL);
387 buf[0] = '\0'; /* else get next line */
388 if (fgetline(buf, buflen, fp) == NULL)
389 return(NULL);
390 }
391 /* skip variable name and '=' */
392 for (cp = buf; *cp++ != '='; )
393 ;
394 while (isspace(*cp)) cp++;
395 return(cp);
396 }
397
398
399 static void
400 dev_open( /* initialize GLX driver */
401 char *id
402 )
403 {
404 static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,4,
405 GLX_GREEN_SIZE,4, GLX_BLUE_SIZE,4,
406 GLX_DOUBLEBUFFER, GLX_DEPTH_SIZE,15, None};
407 XSetWindowAttributes ourwinattr;
408 XWMHints ourxwmhints;
409 /* open display server */
410 ourdisplay = XOpenDisplay(NULL);
411 if (ourdisplay == NULL)
412 error(USER, "cannot open X-windows; DISPLAY variable set?\n");
413 /* find a usable visual */
414 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
415 if (ourvinf == NULL)
416 error(USER, "no suitable visuals available");
417 /* get a context */
418 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
419 /* open window */
420 ourwinattr.background_pixel = ourblack;
421 ourwinattr.border_pixel = ourblack;
422 ourwinattr.event_mask = ourmask;
423 /* this is stupid */
424 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
425 ourvinf->visual, AllocNone);
426 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
427 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
428 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
429 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
430 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
431 if (gwind == 0)
432 error(SYSTEM, "cannot create window\n");
433 XStoreName(ourdisplay, gwind, id);
434 #ifndef NOSTEREO
435 if (stereo) /* check if stereo working */
436 switch (XSGIQueryStereoMode(ourdisplay, gwind)) {
437 case STEREO_TOP:
438 case STEREO_BOTTOM:
439 break;
440 case STEREO_OFF:
441 error(USER,
442 "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
443 case X_STEREO_UNSUPPORTED:
444 error(USER, "stereo not supported on this screen");
445 default:
446 error(INTERNAL, "unknown stereo mode");
447 }
448 #endif
449 /* set window manager hints */
450 ourxwmhints.flags = InputHint|IconPixmapHint;
451 ourxwmhints.input = True;
452 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay, gwind,
453 (char *)glradicon_bits, glradicon_width, glradicon_height);
454 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
455 /* set GLX context */
456 glXMakeCurrent(ourdisplay, gwind, gctx);
457 glEnable(GL_DEPTH_TEST);
458 glDepthFunc(GL_LESS);
459 glShadeModel(GL_SMOOTH);
460 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
461 glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
462 glEnable(GL_LIGHTING);
463 glFrontFace(GL_CCW);
464 glCullFace(GL_BACK);
465 if (backvis)
466 glDisable(GL_CULL_FACE);
467 else
468 glEnable(GL_CULL_FACE);
469 glDrawBuffer(GL_BACK);
470 /* figure out sensible view */
471 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
472 DisplayWidth(ourdisplay, ourscreen);
473 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
474 DisplayHeight(ourdisplay, ourscreen);
475 if (stereo) { /* set stereo mode */
476 setstereobuf(STEREO_BUFFER_LEFT);
477 pheight *= 2.;
478 }
479 /* map the window */
480 XMapWindow(ourdisplay, gwind);
481 no_render++;
482 do
483 dev_input(0); /* get resize event */
484 while ((hres == 0) & (vres == 0));
485 no_render--;
486 rgl_checkerr("initializing GLX");
487 }
488
489
490 static void
491 dev_close(void) /* close our display and free resources */
492 {
493 glXMakeCurrent(ourdisplay, None, NULL);
494 glXDestroyContext(ourdisplay, gctx);
495 XDestroyWindow(ourdisplay, gwind);
496 gwind = 0;
497 XCloseDisplay(ourdisplay);
498 ourdisplay = NULL;
499 }
500
501
502 static int
503 dev_view( /* assign new driver view */
504 VIEW *nv
505 )
506 {
507 int newhres = hres, newvres = vres;
508 double wa, va;
509 /* check view legality */
510 if (nv->type != VT_PER) {
511 error(COMMAND, "illegal view type");
512 nv->type = VT_PER;
513 }
514 if ((nv->horiz > 160.) | (nv->vert > 160.)) {
515 error(COMMAND, "illegal view angle");
516 if (nv->horiz > 160.)
517 nv->horiz = 160.;
518 if (nv->vert > 160.)
519 nv->vert = 160.;
520 }
521 if ((hres != 0) & (vres != 0)) {
522 wa = (vres*pheight)/(hres*pwidth);
523 va = viewaspect(nv);
524 if (va > wa+.05) {
525 newvres = (pwidth/pheight)*va*newhres + .5;
526 if (newvres > maxvres) {
527 newvres = maxvres;
528 newhres = (pheight/pwidth)/va*newvres + .5;
529 }
530 } else if (va < wa-.05) {
531 newhres = (pheight/pwidth)/va*newvres + .5;
532 if (newhres > maxhres) {
533 newhres = maxhres;
534 newvres = (pwidth/pheight)*va*newhres + .5;
535 }
536 }
537 if ((newhres != hres) | (newvres != vres)) {
538 no_render++;
539 XResizeWindow(ourdisplay, gwind, newhres, newvres);
540 do
541 dev_input(0); /* get resize event */
542 while ((newhres != hres) & (newvres != vres));
543 no_render--;
544 }
545 }
546 thisview = *nv;
547 setglpersp(&thisview);
548 render();
549 return(1);
550 }
551
552
553 static int
554 dev_input( /* get next input event */
555 int nsecs
556 )
557 {
558 #if 0
559 static time_t lasttime = 0;
560 time_t thistime;
561
562 if (nsecs > 0) {
563 thistime = time(0);
564 nsecs -= (long)(thistime - lasttime);
565 lasttime = thistime;
566 }
567 if (nsecs > 0)
568 alarm(nsecs);
569 #endif
570 XNextEvent(ourdisplay, levptr(XEvent));
571 switch (levptr(XEvent)->type) {
572 case ConfigureNotify:
573 resizewindow(levptr(XConfigureEvent));
574 break;
575 case UnmapNotify:
576 mapped = 0;
577 break;
578 case MapNotify:
579 mapped = 1;
580 break;
581 case Expose:
582 fixwindow(levptr(XExposeEvent));
583 break;
584 case KeyPress:
585 return(getkey(levptr(XKeyPressedEvent)));
586 case ButtonPress:
587 switch (levptr(XButtonPressedEvent)->button) {
588 case Button4: /* wheel up */
589 zoomview(100+WZOOMPCT, levptr(XButtonPressedEvent)->x,
590 vres-1-levptr(XButtonPressedEvent)->y);
591 break;
592 case Button5: /* wheel down */
593 zoomview(100-WZOOMPCT, levptr(XButtonPressedEvent)->x,
594 vres-1-levptr(XButtonPressedEvent)->y);
595 break;
596 default:
597 getmove(levptr(XButtonPressedEvent));
598 break;
599 }
600 break;
601 }
602 return(1);
603 }
604
605
606 static void
607 render(void) /* render our display list and swap buffers */
608 {
609 double d;
610
611 if (!mapped | no_render)
612 return;
613 glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT);
614 glCallList(displist);
615 if (stereo) { /* do right eye for stereo */
616 setstereobuf(STEREO_BUFFER_RIGHT);
617 glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT);
618 glMatrixMode(GL_MODELVIEW);
619 glPushMatrix();
620 d = -eyedist / sqrt(thisview.hn2);
621 glTranslated(d*thisview.hvec[0], d*thisview.hvec[1],
622 d*thisview.hvec[2]);
623 glCallList(displist);
624 glMatrixMode(GL_MODELVIEW);
625 glPopMatrix();
626 setstereobuf(STEREO_BUFFER_LEFT);
627 }
628 glXSwapBuffers(ourdisplay, gwind); /* calls glFlush() */
629 rgl_checkerr("rendering display list");
630 }
631
632
633 static int
634 moveview( /* move our view */
635 int dx,
636 int dy,
637 int mov,
638 int orb
639 )
640 {
641 VIEW nv;
642 FVECT odir, v1, wp;
643 double d;
644 /* start with old view */
645 nv = thisview;
646 /* change view direction */
647 if ((d = viewray(v1, odir, &thisview,
648 (dx+.5)/hres, (dy+.5)/vres)) < -FTINY)
649 return(0); /* outside view */
650 if (mov | orb) {
651 if (!getintersect(wp, v1, odir, d))
652 return(0);
653 VSUM(odir, wp, nv.vp, -1.);
654 } else
655 VCOPY(nv.vdir, odir);
656 if (orb && mov) { /* orbit left/right */
657 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
658 VSUM(nv.vp, wp, odir, -1.);
659 spinvector(nv.vdir, nv.vdir, nv.vup, d);
660 } else if (orb) { /* orbit up/down */
661 if (geodesic(odir, odir, nv.vup,
662 d=MOVDEG*PI/180.*orb, GEOD_RAD) == 0.0)
663 return(0);
664 VSUM(nv.vp, wp, odir, -1.);
665 geodesic(nv.vdir, nv.vdir, nv.vup, d, GEOD_RAD);
666 } else if (mov) { /* move forward/backward */
667 d = MOVPCT/100. * mov;
668 VSUM(nv.vp, nv.vp, odir, d);
669 }
670 if (!mov ^ !orb && headlocked) { /* restore head height */
671 VSUM(v1, thisview.vp, nv.vp, -1.);
672 d = DOT(v1, thisview.vup);
673 VSUM(nv.vp, nv.vp, thisview.vup, d);
674 }
675 if (setview(&nv) != NULL)
676 return(0); /* illegal view */
677 dev_view(&nv);
678 return(1);
679 }
680
681
682 static void
683 waitabit(void) /* pause a moment */
684 {
685 struct timespec ts;
686 ts.tv_sec = 0;
687 ts.tv_nsec = 50000000;
688 nanosleep(&ts, NULL);
689 }
690
691
692 static void
693 getmove( /* get view change */
694 XButtonPressedEvent *ebut
695 )
696 {
697 int movdir = MOVDIR(ebut->button);
698 int movorb = MOVORB(ebut->state);
699 int moved = 0;
700 Window rootw, childw;
701 int rootx, rooty, wx, wy;
702 unsigned int statemask;
703
704 copylastv( movorb ? (movdir ? "left/right" : "up/down") :
705 (movdir ? "fore/back" : "rotate") );
706 XNoOp(ourdisplay);
707
708 while (!XCheckMaskEvent(ourdisplay,
709 ButtonReleaseMask, levptr(XEvent))) {
710 /* pause so as not to move too fast */
711 waitabit();
712
713 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
714 &rootx, &rooty, &wx, &wy, &statemask))
715 break; /* on another screen */
716
717 if (!moveview(wx, vres-1-wy, movdir, movorb)) {
718 sleep(1);
719 continue;
720 } else
721 moved++;
722 }
723 if (!moved) { /* do final motion */
724 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
725 wx = levptr(XButtonReleasedEvent)->x;
726 wy = levptr(XButtonReleasedEvent)->y;
727 moveview(wx, vres-1-wy, movdir, movorb);
728 }
729 }
730
731
732 static int
733 getintersect( /* intersect ray with scene geometry */
734 FVECT wp, /* returned world intersection point */
735 FVECT org,
736 FVECT dir,
737 double md
738 )
739 {
740 float fbuf[6];
741 /* check to see if rtrace is running */
742 /* if (rtpd.pid <= 0) */
743 if (!(rtpd.flags & PF_RUNNING))
744 return(0);
745 /* assign origin */
746 fbuf[0] = org[0]; fbuf[1] = org[1]; fbuf[2] = org[2];
747 /* compute clipping distance */
748 if (md <= FTINY) md = FHUGE;
749 fbuf[3] = dir[0]*md; fbuf[4] = dir[1]*md; fbuf[5] = dir[2]*md;
750 /* trace that ray */
751 if (process(&rtpd, fbuf, fbuf,
752 4*sizeof(float), 6*sizeof(float)) != 4*sizeof(float))
753 error(INTERNAL, "error getting data back from rtrace process");
754 if (fbuf[3] >= .99*FHUGE)
755 return(0); /* missed local objects */
756 wp[0] = fbuf[0]; wp[1] = fbuf[1]; wp[2] = fbuf[2];
757 return(1); /* else return world intersection */
758 }
759
760
761 static void
762 setglpersp( /* set perspective view in GL */
763 VIEW *vp
764 )
765 {
766 double d, xmin, xmax, ymin, ymax, zmin, zmax;
767
768 zmin = 0.1;
769 zmax = 1000.;
770 if (thisview.vfore > FTINY)
771 zmin = thisview.vfore;
772 if (thisview.vaft > FTINY)
773 zmax = thisview.vaft;
774 xmax = zmin * tan(PI/180./2. * thisview.horiz);
775 xmin = -xmax;
776 d = thisview.hoff * (xmax - xmin);
777 xmin += d; xmax += d;
778 ymax = zmin * tan(PI/180./2. * thisview.vert);
779 ymin = -ymax;
780 d = thisview.voff * (ymax - ymin);
781 ymin += d; ymax += d;
782 /* set view matrix */
783 glMatrixMode(GL_PROJECTION);
784 glLoadIdentity();
785 glFrustum(xmin, xmax, ymin, ymax, zmin, zmax);
786 gluLookAt(thisview.vp[0], thisview.vp[1], thisview.vp[2],
787 thisview.vp[0] + thisview.vdir[0],
788 thisview.vp[1] + thisview.vdir[1],
789 thisview.vp[2] + thisview.vdir[2],
790 thisview.vup[0], thisview.vup[1], thisview.vup[2]);
791 rgl_checkerr("setting perspective view");
792 }
793
794
795 static int
796 getkey( /* get input key */
797 XKeyPressedEvent *ekey
798 )
799 {
800 int n;
801 char buf[8];
802
803 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
804 if (n != 1)
805 return(1);
806 switch (buf[0]) {
807 case 'h': /* turn on height motion lock */
808 headlocked = 1;
809 break;
810 case 'H': /* turn off height motion lock */
811 headlocked = 0;
812 break;
813 case 'l': /* retrieve last (premouse) view */
814 if (lastview.type) {
815 VIEW vtmp;
816 vtmp = thisview;
817 dev_view(&lastview);
818 lastview = vtmp;
819 } else
820 XBell(ourdisplay, 0);
821 break;
822 case 'n': /* move to next standard view */
823 gotoview(currentview+1);
824 break;
825 case 'p': /* move to last standard view */
826 gotoview(currentview-1);
827 break;
828 case '+': /* zoom in */
829 zoomview(100+ZOOMPCT, ekey->x, vres-1-ekey->y);
830 break;
831 case '-': /* zoom out */
832 zoomview(100-ZOOMPCT, ekey->x, vres-1-ekey->y);
833 break;
834 case 'v': /* spit current view to stdout */
835 fputs(VIEWSTR, stdout);
836 fprintview(&thisview, stdout);
837 fputc('\n', stdout);
838 break;
839 case 'V': /* append view to rad file */
840 appendview(NULL, &thisview);
841 break;
842 case 'Q':
843 case 'q': /* quit the program */
844 return(0);
845 default:
846 XBell(ourdisplay, 0);
847 break;
848 }
849 return(1);
850 }
851
852
853 static void
854 zoomview( /* zoom in or out around (dx,dy) */
855 int pct,
856 int dx,
857 int dy
858 )
859 {
860 double h, v;
861
862 if ((pct == 100) | (pct <= 0))
863 return;
864 copylastv("zooming");
865 h = (dx+.5)/hres - 0.5;
866 v = (dy+.5)/vres - 0.5;
867 h *= (1. - 100./pct);
868 v *= (1. - 100./pct);
869 thisview.vdir[0] += h*thisview.hvec[0] + v*thisview.vvec[0];
870 thisview.vdir[1] += h*thisview.hvec[1] + v*thisview.vvec[1];
871 thisview.vdir[2] += h*thisview.hvec[2] + v*thisview.vvec[2];
872 thisview.horiz = 2.*180./PI * atan( 100./pct *
873 tan(PI/180./2.*thisview.horiz) );
874 thisview.vert = 2.*180./PI * atan( 100./pct *
875 tan(PI/180./2.*thisview.vert) );
876 setview(&thisview);
877 dev_view(&thisview);
878 }
879
880
881 static void
882 gotoview( /* go to specified view number */
883 int vwnum
884 )
885 {
886 if (vwnum < 0)
887 for (vwnum = currentview; vwl[vwnum+1].v != NULL; vwnum++)
888 ;
889 else if (vwnum >= MAXVIEW || vwl[vwnum].v == NULL)
890 vwnum = 0;
891 copylastv("standard view");
892 dev_view(vwl[currentview=vwnum].v);
893 }
894
895
896 static void
897 appendview( /* append standard view */
898 char *nm,
899 VIEW *vp
900 )
901 {
902 FILE *fp;
903 /* check if already in there */
904 if (!memcmp(&thisview, vwl[currentview].v, sizeof(VIEW))) {
905 error(COMMAND, "view already in standard list");
906 return;
907 }
908 /* append to file */
909 if ((fp = fopen(radfile, "a")) == NULL) {
910 error(COMMAND, "cannot append rad input file");
911 return;
912 }
913 fputs("view=", fp);
914 if (nm != NULL) {
915 fputc(' ', fp); fputs(nm, fp);
916 }
917 fprintview(vp, fp); fputc('\n', fp);
918 fclose(fp);
919 /* append to our list */
920 while (vwl[currentview].v != NULL)
921 currentview++;
922 if (currentview >= MAXVIEW)
923 error(INTERNAL, "too many views in appendview");
924 vwl[currentview].v = (VIEW *)bmalloc(sizeof(VIEW));
925 *(vwl[currentview].v) = thisview;
926 if (nm != NULL)
927 vwl[currentview].nam = savqstr(nm);
928 }
929
930
931 static void
932 copylastv( /* copy last view position */
933 char *cause
934 )
935 {
936 static char *lastvc;
937
938 if (cause == lastvc)
939 return; /* only record one view per cause */
940 lastvc = cause;
941 lastview = thisview;
942 }
943
944
945 static void
946 fixwindow( /* repair damage to window */
947 XExposeEvent *eexp
948 )
949 {
950 if ((hres == 0) | (vres == 0)) { /* first exposure */
951 resizewindow((XConfigureEvent *)eexp);
952 return;
953 }
954 if (eexp->count) /* wait for final exposure */
955 return;
956 /* rerender everything */
957 render();
958 }
959
960
961 static void
962 resizewindow( /* resize window */
963 XConfigureEvent *ersz
964 )
965 {
966 static char resizing[] = "resizing window";
967 double wa, va;
968
969 glViewport(0, 0, hres=ersz->width, vres=ersz->height);
970 if (hres > maxhres) maxhres = hres;
971 if (vres > maxvres) maxvres = vres;
972 if (no_render)
973 return;
974 wa = (vres*pheight)/(hres*pwidth);
975 va = viewaspect(&thisview);
976 if (va > wa+.05) {
977 copylastv(resizing);
978 thisview.vert = 2.*180./PI *
979 atan( tan(PI/180./2. * thisview.horiz) * wa );
980 } else if (va < wa-.05) {
981 copylastv(resizing);
982 thisview.horiz = 2.*180./PI *
983 atan( tan(PI/180./2. * thisview.vert) / wa );
984 } else
985 return;
986 setview(&thisview);
987 dev_view(&thisview);
988 }
