| 1 |
#!/bin/csh -f |
| 2 |
# RCSid: $Id$ |
| 3 |
| 4 |
# Interactive program for calculating glare values |
| 5 |
| 6 |
set fgargs=(-v) |
| 7 |
set nofile="none" |
| 8 |
set octree=$nofile |
| 9 |
set picture=$nofile |
| 10 |
set glarefile=$nofile |
| 11 |
if ($#argv >= 1) then |
| 12 |
set glarefile=$argv[1] |
| 13 |
if ($#argv >= 2) then |
| 14 |
set picture=$argv[2] |
| 15 |
if ($#argv >= 3) then |
| 16 |
set octree=$argv[3] |
| 17 |
endif |
| 18 |
endif |
| 19 |
endif |
| 20 |
set rtargs= |
| 21 |
set view= |
| 22 |
set threshold=300 |
| 23 |
set maxangle=0 |
| 24 |
set stepangle=10 |
| 25 |
| 26 |
set gndxfile="glr$$.ndx" |
| 27 |
set plotfile="glr$$.plt" |
| 28 |
set tempfiles=($gndxfile $plotfile) |
| 29 |
| 30 |
alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"' |
| 31 |
| 32 |
onintr quit |
| 33 |
| 34 |
cat <<_EOF_ |
| 35 |
This script provides a convenient interface to the glare calculation |
| 36 |
and analysis programs. It works on a single output file from findglare, |
| 37 |
which you must either create here or have created already before. |
| 38 |
_EOF_ |
| 39 |
while ( $glarefile == $nofile ) |
| 40 |
echo "" |
| 41 |
echo "Please specify a glare file, or use ^C to exit." |
| 42 |
readvar glarefile |
| 43 |
end |
| 44 |
if ( ! -f $glarefile ) then |
| 45 |
echo "" |
| 46 |
echo -n "The glare file '$glarefile' doesn't exist -- shall we create it? " |
| 47 |
if ("$<" =~ [nN]*) exit 0 |
| 48 |
cat <<_EOF_ |
| 49 |
| 50 |
A glare file can be created from a wide-angle Radiance picture (preferably |
| 51 |
a fisheye view), an octree, or both. Computing glare source locations |
| 52 |
from a finished image is faster, but using an octree is more reliable |
| 53 |
since all of the scene information is there. Whenever it is possible, |
| 54 |
you should use both a picture and an octree to compute the glare file. |
| 55 |
| 56 |
You must also have a viewpoint and direction for the glare calculation. |
| 57 |
If the viewpoint is not the same as the picture, an error will result. |
| 58 |
If no view is specified, the view parameters are taken from the picture, |
| 59 |
so the view specification is optional unless you are starting from an |
| 60 |
octree. |
| 61 |
| 62 |
_EOF_ |
| 63 |
if ( $picture == $nofile ) then |
| 64 |
readvar picture |
| 65 |
endif |
| 66 |
if ( $octree == $nofile ) then |
| 67 |
readvar octree |
| 68 |
endif |
| 69 |
readvar view |
| 70 |
if ( $picture == $nofile && $octree == $nofile ) then |
| 71 |
echo "You must specify a picture or an octree" |
| 72 |
exit 1 |
| 73 |
endif |
| 74 |
if ( $picture == $nofile && "$view" == "" ) then |
| 75 |
echo "You must give a view if there is no picture" |
| 76 |
exit 1 |
| 77 |
endif |
| 78 |
if ( $picture != $nofile ) then |
| 79 |
if ( ! -r $picture ) then |
| 80 |
echo "Cannot read $picture" |
| 81 |
exit 1 |
| 82 |
endif |
| 83 |
set fgargs=($fgargs -p $picture) |
| 84 |
if ( "$view" != "" ) then |
| 85 |
set view=(-vf $picture $view) |
| 86 |
endif |
| 87 |
endif |
| 88 |
set fgargs=($fgargs $view) |
| 89 |
if ( $octree != $nofile ) then |
| 90 |
if ( ! -r $octree ) then |
| 91 |
echo "Cannot read $octree" |
| 92 |
exit 1 |
| 93 |
endif |
| 94 |
cat <<_EOF_ |
| 95 |
| 96 |
With an octree, you should give the same options for -av, -ab and |
| 97 |
so forth as are used to render the scene. Please enter them below. |
| 98 |
| 99 |
_EOF_ |
| 100 |
if ($picture != $nofile) then |
| 101 |
echo "These are the parameters from the picture:" |
| 102 |
getinfo $picture |
| 103 |
endif |
| 104 |
readvar rtargs |
| 105 |
set fgargs=($fgargs $rtargs $octree) |
| 106 |
endif |
| 107 |
echo "" |
| 108 |
echo -n "Do you expect glare sources in the scene to be small? " |
| 109 |
if ("$<" =~ [yY]) then |
| 110 |
echo -n "Very small? " |
| 111 |
| 112 |
set fgargs=(-r 400 $fgargs) |
| 113 |
else |
| 114 |
set fgargs=(-r 250 $fgargs) |
| 115 |
endif |
| 116 |
echo -n "Are these sources relatively bright? " |
| 117 |
if ("$<" =~ [nN]*) then |
| 118 |
set fgargs=(-c $fgargs) |
| 119 |
endif |
| 120 |
endif |
| 121 |
cat <<_EOF_ |
| 122 |
| 123 |
Glare sources are determined by a threshold level. Any part of the |
| 124 |
view that is above this threshold is considered to be part of a glare |
| 125 |
source. If you do not choose a threshold value, it will be set auto- |
| 126 |
matically to 7 times the average field luminance (in candelas/sq.meter). |
| 127 |
| 128 |
_EOF_ |
| 129 |
echo -n "Do you wish to set the glare threshold manually? " |
| 130 |
| 131 |
readvar threshold |
| 132 |
set fgargs=(-t $threshold $fgargs) |
| 133 |
endif |
| 134 |
cat <<_EOF_ |
| 135 |
| 136 |
It is often desirable to know how glare changes as a function of |
| 137 |
viewing direction. If you like, you can compute glare for up |
| 138 |
to 180 degrees to the left and right of the view center. Enter |
| 139 |
the maximum angle that you would like to compute below. |
| 140 |
| 141 |
_EOF_ |
| 142 |
readvar maxangle |
| 143 |
if ( $maxangle >= $stepangle ) then |
| 144 |
set fgargs=(-ga $stepangle-$maxangle\:$stepangle $fgargs) |
| 145 |
endif |
| 146 |
echo "" |
| 147 |
echo "Starting calculation..." |
| 148 |
echo findglare $fgargs |
| 149 |
findglare $fgargs > $glarefile |
| 150 |
if ($status) then |
| 151 |
echo "Uh-oh. Something went wrong with findglare\!" |
| 152 |
rm $glarefile |
| 153 |
exit 1 |
| 154 |
endif |
| 155 |
endif |
| 156 |
if ($?DISPLAY && $picture != $nofile) then |
| 157 |
echo "" |
| 158 |
echo "Displaying glare sources in '$picture'..." |
| 159 |
xglaresrc $picture $glarefile |
| 160 |
endif |
| 161 |
set ndxnam=("Guth Visual Comfort Probability" "Guth Disability Glare Ratio" "CIE Glare Index" "BRS Glare Index" "Unified Glare Rating" "Daylight Glare Index") |
| 162 |
set ndxcom=("glarendx -t guth_vcp" "glarendx -t guth_dgr" "glarendx -t cie_cgi" "glarendx -t brs_gi" "glarendx -t ugr" "glarendx -t dgi") |
| 163 |
set bcdlvl=(50 124 18.5 18.5 18.5 21.7) |
| 164 |
while ( 1 ) |
| 165 |
echo "" |
| 166 |
echo " 0. Quit" |
| 167 |
set i=1 |
| 168 |
while ($i <= $#ndxnam) |
| 169 |
echo " $i. $ndxnam[$i]" |
| 170 |
@ i++ |
| 171 |
end |
| 172 |
echo "" |
| 173 |
set choice=0 |
| 174 |
readvar choice |
| 175 |
if ($choice < 1 || $choice > $#ndxcom) goto quit |
| 176 |
$ndxcom[$choice] $glarefile > $gndxfile |
| 177 |
echo "" |
| 178 |
echo $ndxnam[$choice] |
| 179 |
echo "Angle Value" |
| 180 |
getinfo - < $gndxfile |
| 181 |
echo "" |
| 182 |
set save_file=$nofile |
| 183 |
readvar save_file |
| 184 |
if ($save_file != $nofile) then |
| 185 |
cp -i $gndxfile $save_file |
| 186 |
endif |
| 187 |
if ( `getinfo - < $gndxfile | wc -l` > 4 ) then |
| 188 |
echo "" |
| 189 |
echo -n "Do you want to plot this data? " |
| 190 |
if ( "$<" =~ [yY]* ) then |
| 191 |
set subtitle="$view" |
| 192 |
| 193 |
set subtitle="$picture $subtitle" |
| 194 |
else if ($octree != $nofile) then |
| 195 |
set subtitle="$subtitle $octree" |
| 196 |
endif |
| 197 |
if ( "$subtitle" == "" ) then |
| 198 |
set subtitle="`getinfo < $glarefile | grep findglare`" |
| 199 |
endif |
| 200 |
cat <<_EOF_ > $plotfile |
| 201 |
include=line.plt |
| 202 |
include=polar.plt |
| 203 |
title="$ndxnam[$choice]" |
| 204 |
subtitle="$subtitle" |
| 205 |
Bdata= |
| 206 |
0 $bcdlvl[$choice] |
| 207 |
360 $bcdlvl[$choice] |
| 208 |
| 209 |
Blabel="BCD level" |
| 210 |
Adata= |
| 211 |
_EOF_ |
| 212 |
getinfo - < $gndxfile >> $plotfile |
| 213 |
igraph $plotfile |
| 214 |
endif |
| 215 |
endif |
| 216 |
end |
| 217 |
quit: |
| 218 |
rm -f $tempfiles |
| 219 |
exit 0 |
