root/radiance/src/util/getinfo.c
Thu Mar 16 17:16:05 2023 UTC (2 years, 7 months ago) by greg
Diff to previous 2.25
fix(getinfo): error message clean-up
Wed Apr 13 15:43:06 2022 UTC (3 years, 6 months ago) by greg
Changes since 2.24: +5 -3 lines
Diff to previous 2.24
fix(getinfo): More consistent behavior using -r option
Mon Mar 21 17:11:29 2022 UTC (3 years, 6 months ago) by greg
Changes since 2.23: +5 -1 lines
Diff to previous 2.23
perf(getinfo): Added a couple of missing calls to flockfile()
Mon Mar 21 00:21:13 2022 UTC (3 years, 6 months ago) by greg
Changes since 2.22: +120 -66 lines
Diff to previous 2.22
feat(getinfo): Added getinfo -r option (similar to -a but with remove/replace)
Thu Mar 3 22:54:49 2022 UTC (3 years, 7 months ago) by greg
Changes since 2.21: +9 -3 lines
Diff to previous 2.21
feat(getinfo): Now preserves byte alignment with -a and -c options
Wed Jul 24 17:27:54 2019 UTC (6 years, 2 months ago) by greg
Changes since 2.20: +23 -10 lines
Diff to previous 2.20
Improved error reporting for bad/illegal headers
Fri Jul 19 17:37:56 2019 UTC (6 years, 2 months ago) by greg
Changes since 2.19: +2 -4 lines
Diff to previous 2.19
Tue Jul 16 17:07:35 2019 UTC (6 years, 3 months ago) by greg
Changes since 2.18: +24 -13 lines
Diff to previous 2.18
Created getinfo +d option for additional flexibility
Sat Jul 6 14:08:07 2019 UTC (6 years, 3 months ago) by greg
Changes since 2.17: +22 -6 lines
Diff to previous 2.17
Made getinfo -d option useful for header-skip ('-') and command ('-c') options
Sun Jun 9 18:22:44 2019 UTC (6 years, 4 months ago) by greg
Changes since 2.16: +14 -8 lines
Diff to previous 2.16
Added error-checking
Tue Mar 20 18:18:39 2018 UTC (7 years, 6 months ago) by greg
Diff to previous 2.15
Added redefine of getc()
Tue Mar 20 17:48:16 2018 UTC (7 years, 6 months ago) by greg
Changes since 2.14: +3 -7 lines
Diff to previous 2.14
Replaced write() call with writebuf()
Tue Aug 30 06:10:12 2016 UTC (9 years, 1 month ago) by greg
Changes since 2.13: +15 -1 lines
Diff to previous 2.13
Added -a option to getinfo for adding lines to header
Sun Mar 6 01:13:18 2016 UTC (9 years, 7 months ago) by schorsch
Diff to previous 2.12
Mon Sep 8 18:21:39 2014 UTC (11 years, 1 month ago) by greg
Turned off input buffering for -c option to avoid issues with lost data
Mon Jul 28 20:12:20 2014 UTC (11 years, 2 months ago) by greg
CVS Tags: rad4R2
Changes since 2.10: +3 -2 lines
Fixes for Windows
Mon Jul 28 17:25:03 2014 UTC (11 years, 2 months ago) by greg
Changes since 2.9: +31 -16 lines
Sat Jun 9 04:24:16 2012 UTC (13 years, 4 months ago) by greg
Changes since 2.8: +9 -1 lines
Changed character i/o calls to unlocked versions
Fri Jan 2 11:44:24 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 2.7: +26 -14 lines
Mon Jul 21 22:30:19 2003 UTC (22 years, 3 months ago) by schorsch
Thu Jun 5 19:29:35 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.5: +6 -13 lines
Sat Feb 22 02:07:30 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.4: +1 -4 lines
Tue Oct 27 08:47:17 1998 UTC (26 years, 11 months ago) by gwlarson
Thu Nov 12 10:06:11 1992 UTC (32 years, 11 months ago) by greg
Changes since 2.2: +8 -4 lines
Changes for 32-bit PC port
Mon Sep 21 12:13:25 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.1: +10 -2 lines
Changes for PC port
Tue Nov 12 16:05:05 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.3
Thu Apr 18 14:35:06 1991 UTC (34 years, 6 months ago) by greg
Diff to previous 1.2
Thu Jun 28 16:39:32 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.1: +13 -0 lines
Diff to previous 1.1
added - option to elide header
Thu Feb 2 10:49:19 1989 UTC (36 years, 8 months ago) by greg
