root/radiance/src/util/getfile.tcl
Revision: 2.2
Committed: Sat Feb 22 02:07:30 2003 UTC (22 years, 7 months ago) by greg
Content type: application/x-tcl
CVS Tags: rad3R7P2, rad3R7P1, rad4R1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9
# User Rev Content
1 greg 2.2 # RCSid: $Id$
2 greg 2.1 #
3     # Usage: getfile [-win w] [-grab] [-perm] [-glob pattern] [-view proc] [-send proc]
4     #
5     # Create a dialog box (in window w if given) to get file name.
6     # If -grab option is given, then getfile does a local grab on its window.
7     # Normally, a single file name and return as value.
8     # If perm switch is given, keep window up for multiple file entries.
9     # If pattern is given, start with list of all the specified files,
10     # breaking the string into directory and file match parts.
11     # If a view procedure is given, a separate "View" button appears
12     # for allowing the user to preview a selected file.
13     # If a send procedure is given, a file name is sent upon
14     # each double-click, and no File entry is displayed.
15     #
16
17     proc getfile args { # get filename interactively
18     # Create necessary globals
19     global curdir curfile curpat
20     # Set defaults
21     set w .fpwin
22     set topwin 1
23     set dograb 0
24     set curdir .
25     set curpat *
26     set curfile {}
27     set transient 1
28     # Get options
29     while {[llength $args]} {
30     switch -glob -- [lindex $args 0] {
31     -win* {
32     set w [lindex $args 1]
33     set topwin 0
34     set args [lreplace $args 1 1]
35     }
36     -grab {
37     set dograb 1
38     }
39     -perm* {
40     set transient 0
41     }
42     -glob {
43     set curdir [file dirname [lindex $args 1]]
44     set curpat [file tail [lindex $args 1]]
45     set args [lreplace $args 1 1]
46     }
47     -vi* {
48     set viewproc [lindex $args 1]
49     set args [lreplace $args 1 1]
50     }
51     -send {
52     set sendproc [lindex $args 1]
53     set args [lreplace $args 1 1]
54     }
55     default { error "bad argument to getfile: [lindex $args 0]" }
56     }
57     set args [lreplace $args 0 0]
58     }
59     # Save initial directory
60     set startdir [pwd]
61     # Create widgets
62     catch {destroy $w}
63     if $topwin {
64     toplevel $w -width 400 -height 410
65     wm title $w "File Picker"
66     wm iconname $w "Files"
67     wm minsize $w 400 300
68     } else {
69     frame $w -width 400 -height 410
70     pack $w
71     }
72     if $dograb { grab $w }
73     $w configure -cursor top_left_arrow
74     label $w.dt -text Directory:
75     place $w.dt -relx .025 -rely .03125
76     helplink $w.dt file directory intro
77     button $w.ls -text List -command "update_dir $w"
78     place $w.ls -relx .025 -rely .125 -relwidth .15 -relheight .0625
79     helplink $w.ls file directory list
80     entry $w.de -textvariable curdir -relief sunken
81     place $w.de -relx .25 -rely .03125 -relwidth .6875 -relheight .0625
82     focus $w.de
83     helplink $w.de file directory intro
84     bind $w.de <Return> "update_dir $w"
85     entry $w.pw -relief sunken -textvariable curpat
86     place $w.pw -relx .25 -rely .125 -relwidth .34375 -relheight .0625
87     bind $w.pw <Return> "update_dir $w"
88     helplink $w.pw file directory match
89     frame $w.fm
90     scrollbar $w.fm.sb -relief sunken -command "$w.fm.fl yview"
91     listbox $w.fm.fl -relief sunken -yscroll "$w.fm.sb set" \
92     -selectmode browse
93     pack $w.fm.sb -side right -fill y
94     pack $w.fm.fl -side left -expand yes -fill both
95     place $w.fm -relx .25 -rely .21875 -relwidth .6875 -relheight .625
96     helplink $w.fm.fl file file intro
97     if [info exists sendproc] {
98     bind $w.fm.fl <Double-Button-1> "set_curfile $w $sendproc"
99     if {$transient} {
100     bind $w.fm.fl <Double-Button-1> \
101     "+if {\$curfile > {}} {destroy $w}"
102     }
103     } else {
104     bind $w.fm.fl <Double-Button-1> "set_curfile $w"
105     label $w.fl -text File:
106     place $w.fl -relx .10625 -rely .875
107     entry $w.fn -relief sunken -textvariable curfile
108     place $w.fn -relx .25 -rely .875 \
109     -relwidth .6875 -relheight .0625
110     focus $w.fn
111     helplink $w.fn file file entry
112     if $transient {
113     bind $w.fn <Return> "destroy $w"
114     } else {
115     bind $w.fn <Return> {}
116     }
117     }
118     if {$transient != [info exists sendproc]} {
119     button $w.ok -text OK -command "destroy $w"
120     place $w.ok -relx .025 -rely .28125 \
121     -relwidth .15 -relheight .0625
122     }
123     if {$transient || [info exists sendproc]} {
124     button $w.cancel -text Cancel \
125     -command "destroy $w; unset curdir"
126     place $w.cancel -relx .025 -rely .375 \
127     -relwidth .15 -relheight .0625
128     }
129     if [info exists viewproc] {
130     button $w.vi -text View -state disabled \
131     -command "$viewproc \[$w.fm.fl get \[$w.fm.fl curselection\]\]"
132     place $w.vi -relx .025 -rely .46875 \
133     -relwidth .15 -relheight .0625
134     bind $w.fm.fl <ButtonRelease-1> "+chk_select $w"
135     helplink $w.vi file file view
136     }
137     # Load current directory
138     update_dir $w
139     if $transient {
140     tkwait window $w
141     cd $startdir
142     if [info exists sendproc] {
143     return [info exists curdir]
144     }
145     if [info exists curdir] {
146     return $curdir/$curfile
147     }
148     return
149     } elseif {[info exists sendproc]} {
150     tkwait window $w
151     cd $startdir
152     if [info exists curdir] {
153     return 1
154     }
155     return 0
156     }
157     # Else return the dialog window
158     return $w
159     }
160
161
162     proc update_dir w { # Update working directory
163     global curdir curpat
164     if {"$curpat" == {}} {
165     set curpat *
166     }
167     if {"$curdir" == {}} {set curdir {~}}
168     if [catch {cd $curdir} curdir] {
169     set oldcol [lindex [$w.de config -foreground] 4]
170     $w.de config -foreground Red
171     update idletasks
172     after 1500
173     $w.de config -foreground $oldcol
174     }
175     set curdir [pwd]
176     set offset [expr [string length $curdir] - 32]
177     if {$offset > 0} {
178     $w.de xview [expr $offset + \
179     [string first / [string range $curdir $offset end]] \
180     + 1]
181     }
182     $w.fm.fl delete 0 end
183     set ls ../
184     foreach f [glob -nocomplain *] {
185     if [file isdirectory $f] {
186     lappend ls $f/
187     }
188     }
189     foreach f [eval glob -nocomplain [split $curpat]] {
190     if [file isfile $f] {
191     lappend ls $f
192     }
193     }
194     eval $w.fm.fl insert end [lsort $ls]
195     }
196
197
198     proc set_curfile {w {sp {}}} { # change current file selection
199     global curdir curfile
200     set f [$w.fm.fl get [$w.fm.fl curselection]]
201     if [string match */ $f] {
202     set curdir [string range $f 0 [expr [string length $f]-2]]
203     update_dir $w
204     } else {
205     set curfile $f
206     if {"$sp" != {}} {
207     $sp $curdir/$curfile
208     }
209     }
210     }
211
212
213     proc chk_select w { # check if current selection is file
214     set s [$w.fm.fl curselection]
215     if {"$s" != {} && [file isfile [$w.fm.fl get $s]]} {
216     $w.vi configure -state normal
217     } else {
218     $w.vi configure -state disabled
219     }
220     }
