| 1 |
greg |
2.1 |
#!/usr/bin/perl -w |
| 2 |
greg |
2.12 |
# RCSid $Id: genklemsamp.pl,v 2.11 2011/05/16 23:56:32 greg Exp $ |
| 3 |
greg |
2.1 |
| 4 |
# Sample Klems (full) directions impinging on surface(s) |
| 5 |
| 6 |
greg |
2.2 |
# G. Ward |
| 7 |
| 8 |
greg |
2.3 |
use strict; |
| 9 |
greg |
2.11 |
my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64"); |
| 10 |
greg |
2.10 |
use File::Temp qw/ :mktemp /; |
| 11 |
greg |
2.1 |
if ($#ARGV < 0) { |
| 12 |
greg |
2.4 |
print STDERR "Usage: genklemsamp [-c N ][-f{a|f|d}] [view opts] [geom.rad ..]\n"; |
| 13 |
greg |
2.1 |
exit 1; |
| 14 |
| 15 |
my $nsamp = 1000; |
| 16 |
my $fmt = "a"; |
| 17 |
my @vopts="-vo 1e-5"; |
| 18 |
while ($#ARGV >= 0) { |
| 19 |
if ("$ARGV[0]" eq "-c") { |
| 20 |
shift @ARGV; |
| 21 |
$nsamp = $ARGV[0]; |
| 22 |
} elsif ("$ARGV[0]" =~ /^-f[afd]$/) { |
| 23 |
$fmt = substr($ARGV[0], 2, 1); |
| 24 |
} elsif ("$ARGV[0]" =~ /^-v[pdu]$/) { |
| 25 |
push @vopts, "@ARGV[0..3]"; |
| 26 |
shift @ARGV; shift @ARGV; shift @ARGV; |
| 27 |
} elsif ("$ARGV[0]" =~ /^-v[fhvo]$/) { |
| 28 |
push @vopts, "@ARGV[0..1]"; |
| 29 |
shift @ARGV; |
| 30 |
} elsif ("$ARGV[0]" =~ /^-v./) { |
| 31 |
greg |
2.4 |
print STDERR "Unsupported view option: $ARGV[0]\n"; |
| 32 |
greg |
2.1 |
exit 1; |
| 33 |
} elsif ("$ARGV[0]" =~ /^-./) { |
| 34 |
greg |
2.4 |
print STDERR "Unknown option: $ARGV[0]\n"; |
| 35 |
greg |
2.1 |
exit 1; |
| 36 |
} else { |
| 37 |
last; |
| 38 |
| 39 |
shift @ARGV; |
| 40 |
| 41 |
my $ofmt = ""; |
| 42 |
$ofmt = "-o$fmt" if ("$fmt" ne "a"); |
| 43 |
# Require parallel view and compile settings |
| 44 |
push @vopts, "-vtl"; |
| 45 |
my $vwset = `vwright @vopts V`; |
| 46 |
greg |
2.11 |
chomp $vwset; |
| 47 |
greg |
2.1 |
$_ = $vwset; s/^.*Vhn://; s/;.*$//; |
| 48 |
my $width = $_; |
| 49 |
$_ = $vwset; s/^.*Vvn://; s/;.*$//; |
| 50 |
my $height = $_; |
| 51 |
my $sca = sqrt($nsamp/($width*$height)); |
| 52 |
# Kbin is input to get direction in full Klems basis with (x1,x2) randoms |
| 53 |
greg |
2.11 |
my $tcal = 'DEGREE : PI/180;' . |
| 54 |
'Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);' . |
| 55 |
'Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);' . |
| 56 |
'Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);' . |
| 57 |
'Kmax : Kaccum(Knaz(0));' . |
| 58 |
'Kfindrow(r, rem) : if(rem-Knaz(r)-.5, Kfindrow(r+1, rem-Knaz(r)), r);' . |
| 59 |
'Krow = if(Kbin-(Kmax+.5), 0, Kfindrow(1, Kbin));' . |
| 60 |
'Kcol = Kbin - Kaccum(Krow-1) - 1;' . |
| 61 |
'Kazi = 360*DEGREE * (Kcol + .5 - x2) / Knaz(Krow);' . |
| 62 |
'Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1));' . |
| 63 |
'sin_kpol = sin(Kpol);' . |
| 64 |
'K0 = cos(Kazi)*sin_kpol;' . |
| 65 |
'K1 = sin(Kazi)*sin_kpol;' . |
| 66 |
'K2 = sqrt(1 - sin_kpol*sin_kpol);' ; |
| 67 |
greg |
2.1 |
my $ndiv = 145; |
| 68 |
greg |
2.11 |
my ($td, $inchk, $rmtmp, $orgcnt); |
| 69 |
if ($windoz) { |
| 70 |
my $tmploc = `echo \%TMP\%`; |
| 71 |
chomp($tmploc); |
| 72 |
$td = mkdtemp("$tmploc\\genklemsamp.XXXXXX"); |
| 73 |
chomp $td; |
| 74 |
$inchk = "rtrace -w -h -opLN $td\\surf.oct " . |
| 75 |
q{| rcalc -e "cond=and(5e9-$4,nOK);$1=$1;$2=$2;$3=$3" } . |
| 76 |
"-e \"and(a,b):if(a,b,a);sq(x):x*x\" -e \"$vwset\" " . |
| 77 |
q{-e "nOK=sq(Vdx*$5+Vdy*$6+Vdz*$7)-.999" } . |
| 78 |
" > $td\\origins.txt"; |
| 79 |
$rmtmp = "rmdir /S /Q $td"; |
| 80 |
} else { |
| 81 |
$td = mkdtemp("/tmp/genklemsamp.XXXXXX"); |
| 82 |
chomp $td; |
| 83 |
$inchk = "rtrace -w -h -faf -opLN $td/surf.oct " . |
| 84 |
q{| rcalc -e 'cond=and(5e9-$4,nOK);$1=$1;$2=$2;$3=$3' } . |
| 85 |
"-e 'and(a,b):if(a,b,a);sq(x):x*x' -e '$vwset' " . |
| 86 |
q{-e 'nOK=sq(Vdx*$5+Vdy*$6+Vdz*$7)-.999' } . |
| 87 |
"-if7 -of > $td/origins.flt"; |
| 88 |
$rmtmp = "rm -rf $td"; |
| 89 |
| 90 |
sub GetNOrigins { |
| 91 |
if ($windoz) { |
| 92 |
my $count = 0; |
| 93 |
open(FILE, "< $td\\origins.txt"); |
| 94 |
$count++ while <FILE>; |
| 95 |
close(FILE); |
| 96 |
return $count; |
| 97 |
| 98 |
return (-s "$td/origins.flt") / (4*3); |
| 99 |
| 100 |
greg |
2.1 |
# Do we have any Radiance input files? |
| 101 |
if ($#ARGV >= 0) { |
| 102 |
greg |
2.12 |
system "xform -m void @ARGV | oconv - > $td/surf.oct"; |
| 103 |
greg |
2.1 |
# Set our own view center and size based on bounding cube |
| 104 |
$_ = $vwset; s/^.*Vdx://; s/;.*$//; |
| 105 |
my @vd = $_; |
| 106 |
$_ = $vwset; s/^.*Vdy://; s/;.*$//; |
| 107 |
push @vd, $_; |
| 108 |
$_ = $vwset; s/^.*Vdz://; s/;.*$//; |
| 109 |
push @vd, $_; |
| 110 |
greg |
2.8 |
my @bcube = split ' ', `getinfo -d < $td/surf.oct`; |
| 111 |
greg |
2.1 |
$width = $bcube[3]*sqrt(3); |
| 112 |
$height = $width; |
| 113 |
push @vopts, ("-vp", $bcube[0]+$bcube[3]/2-$width/2*$vd[0], |
| 114 |
$bcube[1]+$bcube[3]/2-$width/2*$vd[1], |
| 115 |
$bcube[2]+$bcube[3]/2-$width/2*$vd[2]); |
| 116 |
greg |
2.7 |
push @vopts, ("-vh", $width, "-vv", $height); |
| 117 |
greg |
2.1 |
| 118 |
greg |
2.6 |
| 119 |
greg |
2.1 |
my $xres; |
| 120 |
my $yres; |
| 121 |
greg |
2.4 |
my $ntot = 0; |
| 122 |
greg |
2.1 |
# This generally passes through the loop twice to get density right |
| 123 |
greg |
2.4 |
while ($ntot < $nsamp) { |
| 124 |
greg |
2.1 |
$xres = int($width*$sca) + 1; |
| 125 |
$yres = int($height*$sca) + 1; |
| 126 |
greg |
2.11 |
system "vwrays -x $xres -y $yres -pa 0 -pj .7 @vopts | $inchk"; |
| 127 |
$ntot = GetNOrigins(); |
| 128 |
greg |
2.1 |
if ($ntot == 0) { |
| 129 |
greg |
2.6 |
if ($nsamp < 200) { |
| 130 |
greg |
2.4 |
$sca = sqrt(200/($width*$height)); |
| 131 |
redo; |
| 132 |
| 133 |
print STDERR "View direction does not correspond to any surfaces\n"; |
| 134 |
greg |
2.1 |
exit 1; |
| 135 |
| 136 |
$sca *= 1.05 * sqrt($nsamp/$ntot); |
| 137 |
greg |
2.4 |
| 138 |
greg |
2.1 |
# All set to produce our samples |
| 139 |
greg |
2.4 |
for (my $k = 1; $k <= $ndiv; $k++) { |
| 140 |
greg |
2.1 |
my $rn = rand(10); |
| 141 |
my $r1 = rand; my $r2 = rand; |
| 142 |
# Chance of using = (number_still_needed)/(number_left_avail) |
| 143 |
greg |
2.11 |
if ($windoz) { |
| 144 |
system "rcalc $ofmt -e \"$tcal\" -e \"$vwset\" " . |
| 145 |
"-e \"cond=($nsamp-outno+1)/($ntot-recno+1)-rand($rn+recno)\" " . |
| 146 |
"-e \"Kbin=$k;x1=rand($r1+recno);x2=rand($r2+recno)\" " . |
| 147 |
q{-e "$1=$1+Vo*Vdx; $2=$2+Vo*Vdy; $3=$3+Vo*Vdz" } . |
| 148 |
q{-e "$4=-K0*Vhx-K1*Vvx+K2*Vdx" } . |
| 149 |
q{-e "$5=-K0*Vhy-K1*Vvy+K2*Vdy" } . |
| 150 |
q{-e "$6=-K0*Vhz-K1*Vvz+K2*Vdz" } . |
| 151 |
"$td\\origins.txt"; |
| 152 |
} else { |
| 153 |
system "rcalc $ofmt -e '$tcal' -e '$vwset' " . |
| 154 |
greg |
2.1 |
"-e 'cond=($nsamp-outno+1)/($ntot-recno+1)-rand($rn+recno)' " . |
| 155 |
"-e 'Kbin=$k;x1=rand($r1+recno);x2=rand($r2+recno)' " . |
| 156 |
q{-e '$1=$1+Vo*Vdx; $2=$2+Vo*Vdy; $3=$3+Vo*Vdz' } . |
| 157 |
greg |
2.9 |
q{-e '$4=-K0*Vhx-K1*Vvx+K2*Vdx' } . |
| 158 |
q{-e '$5=-K0*Vhy-K1*Vvy+K2*Vdy' } . |
| 159 |
q{-e '$6=-K0*Vhz-K1*Vvz+K2*Vdz' } . |
| 160 |
greg |
2.1 |
"-if3 $td/origins.flt"; |
| 161 |
greg |
2.11 |
| 162 |
greg |
2.1 |
| 163 |
} else { |
| 164 |
# No Radiance input files, so just sample over parallel view |
| 165 |
my $xres = int($width*$sca) + 1; |
| 166 |
my $yres = int($height*$sca) + 1; |
| 167 |
my $ntot = $xres * $yres; |
| 168 |
greg |
2.4 |
| 169 |
greg |
2.1 |
| 170 |
| 171 |
my $r3 = rand; my $r4 = rand; |
| 172 |
| 173 |
greg |
2.11 |
if ($windoz) { |
| 174 |
system "cnt $yres $xres | rcalc $ofmt -e \"$tcal\" -e \"$vwset\" " . |
| 175 |
"-e \"xc=\$2;yc=\$1\" ". |
| 176 |
| 177 |
| 178 |
"-e \"hpos=Vhn*((xc+rand($r3+recno))/$xres - .5)\" " . |
| 179 |
"-e \"vpos=Vvn*((yc+rand($r4+recno))/$yres - .5)\" " . |
| 180 |
q{-e "$1=Vpx+Vo*Vdx+hpos*Vhx+vpos*Vvx" } . |
| 181 |
q{-e "$2=Vpy+Vo*Vdy+hpos*Vhy+vpos*Vvy" } . |
| 182 |
q{-e "$3=Vpz+Vo*Vdz+hpos*Vhz+vpos*Vvz" } . |
| 183 |
| 184 |
| 185 |
q{-e "$6=-K0*Vhz-K1*Vvz+K2*Vdz" } ; |
| 186 |
} else { |
| 187 |
system "cnt $yres $xres | rcalc $ofmt -e '$tcal' -e '$vwset' " . |
| 188 |
greg |
2.1 |
q{-e 'xc=$2;yc=$1' } . |
| 189 |
| 190 |
| 191 |
"-e 'hpos=Vhn*((xc+rand($r3+recno))/$xres - .5)' " . |
| 192 |
"-e 'vpos=Vvn*((yc+rand($r4+recno))/$yres - .5)' " . |
| 193 |
q{-e '$1=Vpx+Vo*Vdx+hpos*Vhx+vpos*Vvx' } . |
| 194 |
q{-e '$2=Vpy+Vo*Vdy+hpos*Vhy+vpos*Vvy' } . |
| 195 |
q{-e '$3=Vpz+Vo*Vdz+hpos*Vhz+vpos*Vvz' } . |
| 196 |
greg |
2.9 |
| 197 |
| 198 |
q{-e '$6=-K0*Vhz-K1*Vvz+K2*Vdz' } ; |
| 199 |
greg |
2.11 |
| 200 |
greg |
2.1 |
| 201 |
| 202 |
greg |
2.11 |
system $rmtmp; |
