root/radiance/src/util/genBSDF.pl
Revision: 2.61
Committed: Wed Aug 26 02:27:09 2015 UTC (10 years, 1 month ago) by greg
Minor correction to error message
# User Rev Content
1 greg 2.1 #!/usr/bin/perl -w
2 greg 2.61 # RCSid $Id: genBSDF.pl,v 2.60 2015/05/29 08:13:46 greg Exp $
3 greg 2.1 #
4     # Compute BSDF based on geometry and material description
5     #
6     # G. Ward
7     #
8     use strict;
9 greg 2.47 my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64");
10 greg 2.13 use File::Temp qw/ :mktemp /;
11 greg 2.1 sub userror {
12 greg 2.57 print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-W][-t{3|4} Nlog2][-r \"ropts\"][-s \"x=string;y=string\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}C][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n";
13 greg 2.1 exit 1;
14     }
15 greg 2.49 my ($td,$radscn,$mgfscn,$octree,$fsender,$bsender,$receivers,$facedat,$behinddat,$rmtmp);
16     my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz);
17 greg 2.47 if ($windoz) {
18     my $tmploc = `echo \%TMP\%`;
19     chomp($tmploc);
20     $td = mkdtemp("$tmploc\\genBSDF.XXXXXX");
21     $radscn = "$td\\device.rad";
22     $mgfscn = "$td\\device.mgf";
23     $octree = "$td\\device.oct";
24 greg 2.49 $fsender = "$td\\fsender.rad";
25     $bsender = "$td\\bsender.rad";
26     $receivers = "$td\\receivers.rad";
27     $facedat = "$td\\face.dat";
28     $behinddat = "$td\\behind.dat";
29     $tf = "$td\\tf.dat";
30     $rf = "$td\\rf.dat";
31     $tb = "$td\\tb.dat";
32     $rb = "$td\\rb.dat";
33     $tfx = "$td\\tfx.dat";
34     $rfx = "$td\\rfx.dat";
35     $tbx = "$td\\tbx.dat";
36     $rbx = "$td\\rbx.dat";
37     $tfz = "$td\\tfz.dat";
38     $rfz = "$td\\rfz.dat";
39     $tbz = "$td\\tbz.dat";
40     $rbz = "$td\\rbz.dat";
41 greg 2.47 chomp $td;
42     $rmtmp = "rmdir /S /Q $td";
43 greg 2.49 } else {
44 greg 2.47 $td = mkdtemp("/tmp/genBSDF.XXXXXX");
45     chomp $td;
46     $radscn = "$td/device.rad";
47     $mgfscn = "$td/device.mgf";
48     $octree = "$td/device.oct";
49 greg 2.49 $fsender = "$td/fsender.rad";
50     $bsender = "$td/bsender.rad";
51     $receivers = "$td/receivers.rad";
52     $facedat = "$td/face.dat";
53     $behinddat = "$td/behind.dat";
54     $tf = "$td/tf.dat";
55     $rf = "$td/rf.dat";
56     $tb = "$td/tb.dat";
57     $rb = "$td/rb.dat";
58     $tfx = "$td/tfx.dat";
59     $rfx = "$td/rfx.dat";
60     $tbx = "$td/tbx.dat";
61     $rbx = "$td/rbx.dat";
62     $tfz = "$td/tfz.dat";
63     $rfz = "$td/rfz.dat";
64     $tbz = "$td/tbz.dat";
65     $rbz = "$td/rbz.dat";
66 greg 2.47 $rmtmp = "rm -rf $td";
67     }
68 greg 2.20 my @savedARGV = @ARGV;
69 greg 2.53 my $rfluxmtx = "rfluxmtx -ab 5 -ad 700 -lw 3e-6";
70 greg 2.49 my $wrapper = "wrapBSDF";
71 greg 2.15 my $tensortree = 0;
72     my $ttlog2 = 4;
73 greg 2.25 my $nsamp = 2000;
74 greg 2.1 my $mgfin = 0;
75     my $geout = 1;
76     my $nproc = 1;
77 greg 2.49 my $docolor = 0;
78 greg 2.9 my $doforw = 0;
79     my $doback = 1;
80 greg 2.33 my $pctcull = 90;
81 greg 2.41 my $gunit = "meter";
82 greg 2.49 my $curspec = "Visible";
83 greg 2.1 my @dim;
84     # Get options
85     while ($#ARGV >= 0) {
86     if ("$ARGV[0]" =~ /^[-+]m/) {
87     $mgfin = ("$ARGV[0]" =~ /^\+/);
88 greg 2.10 } elsif ("$ARGV[0]" eq "-r") {
89 greg 2.49 $rfluxmtx .= " $ARGV[1]";
90 greg 2.10 shift @ARGV;
91 greg 2.1 } elsif ("$ARGV[0]" =~ /^[-+]g/) {
92     $geout = ("$ARGV[0]" =~ /^\+/);
93 greg 2.22 $gunit = $ARGV[1];
94     if ($gunit !~ /^(?i)(meter|foot|inch|centimeter|millimeter)$/) {
95     die "Illegal geometry unit '$gunit': must be meter, foot, inch, centimeter, or millimeter\n";
96     }
97     shift @ARGV;
98 greg 2.49 } elsif ("$ARGV[0]" =~ /^[-+]C/) {
99     $docolor = ("$ARGV[0]" =~ /^\+/);
100 greg 2.9 } elsif ("$ARGV[0]" =~ /^[-+]f/) {
101     $doforw = ("$ARGV[0]" =~ /^\+/);
102     } elsif ("$ARGV[0]" =~ /^[-+]b/) {
103     $doback = ("$ARGV[0]" =~ /^\+/);
104 greg 2.27 } elsif ("$ARGV[0]" eq "-t") {
105 greg 2.33 # Use value < 0 for rttree_reduce bypass
106 greg 2.27 $pctcull = $ARGV[1];
107 greg 2.55 if ($pctcull >= 100) {
108     die "Illegal -t culling percentage, must be < 100\n";
109     }
110 greg 2.27 shift @ARGV;
111 greg 2.15 } elsif ("$ARGV[0]" =~ /^-t[34]$/) {
112     $tensortree = substr($ARGV[0], 2, 1);
113     $ttlog2 = $ARGV[1];
114     shift @ARGV;
115 greg 2.55 } elsif ("$ARGV[0]" eq "-s") {
116 greg 2.49 $wrapper .= " -f \"$ARGV[1]\"";
117     shift @ARGV;
118     } elsif ("$ARGV[0]" eq "-W") {
119     $wrapper .= " -W";
120 greg 2.1 } elsif ("$ARGV[0]" eq "-c") {
121     $nsamp = $ARGV[1];
122     shift @ARGV;
123     } elsif ("$ARGV[0]" eq "-n") {
124     $nproc = $ARGV[1];
125     shift @ARGV;
126     } elsif ("$ARGV[0]" =~ /^-d/) {
127     userror() if ($#ARGV < 6);
128 greg 2.8 @dim = @ARGV[1..6];
129 greg 2.1 shift @ARGV for (1..6);
130     } elsif ("$ARGV[0]" =~ /^[-+]./) {
131     userror();
132     } else {
133     last;
134     }
135     shift @ARGV;
136     }
137 greg 2.9 # Check that we're actually being asked to do something
138 greg 2.15 die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback);
139 greg 2.48 # Issue warning for unhandled reciprocity case
140 greg 2.49 print STDERR "Warning: recommend both +forward and +backward with -t3\n" if
141 greg 2.48 ($tensortree==3 && !($doforw && $doback));
142 greg 2.49 $wrapper .= $tensortree ? " -a t$tensortree" : " -a kf -c";
143     $wrapper .= " -u $gunit";
144 greg 2.1 # Get scene description and dimensions
145     if ( $mgfin ) {
146 greg 2.49 system "mgf2rad @ARGV > $radscn";
147 greg 2.1 die "Could not load MGF input\n" if ( $? );
148     } else {
149 greg 2.13 system "xform -e @ARGV > $radscn";
150 greg 2.1 die "Could not load Radiance input\n" if ( $? );
151     }
152     if ($#dim != 5) {
153 greg 2.7 @dim = split ' ', `getbbox -h $radscn`;
154 greg 2.1 }
155     print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5);
156 greg 2.49 $wrapper .= ' -f "t=' . ($dim[5] - $dim[4]) . ';w=' . ($dim[1] - $dim[0]) .
157     ';h=' . ($dim[3] - $dim[2]) . '"';
158 greg 2.1 # Generate octree
159     system "oconv -w $radscn > $octree";
160     die "Could not compile scene\n" if ( $? );
161 greg 2.49 # Add MGF description if requested
162 greg 2.15 if ( $geout ) {
163 greg 2.49 open(MGFSCN, "> $mgfscn");
164     printf MGFSCN "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
165     close MGFSCN;
166     if ( $mgfin ) {
167     system qq{mgfilt "#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus" @ARGV >> $mgfscn};
168     } else {
169     system "rad2mgf $radscn >> $mgfscn";
170     }
171     open(MGFSCN, ">> $mgfscn");
172     print MGFSCN "xf\n";
173 greg 2.15 close MGFSCN;
174 greg 2.49 $wrapper .= " -g $mgfscn";
175 greg 2.15 }
176 greg 2.49 # Create receiver & sender surfaces (rectangular)
177 greg 2.56 my $FEPS = 1e-5;
178 greg 2.46 my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + 1);
179     my $ny = int($nsamp/$nx + 1);
180 greg 2.15 $nsamp = $nx * $ny;
181     my $ns = 2**$ttlog2;
182 greg 2.49 open(RADSCN, "> $receivers");
183 greg 2.56 print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=-sc$ns\n" : "h=-kf\n");
184     print RADSCN '#@rfluxmtx ' . "u=-Y o=$facedat\n\n";
185 greg 2.49 print RADSCN "void glow receiver_face\n0\n0\n4 1 1 1 0\n\n";
186     print RADSCN "receiver_face source f_receiver\n0\n0\n4 0 0 1 180\n\n";
187 greg 2.56 print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=+sc$ns\n" : "h=+kf\n");
188     print RADSCN '#@rfluxmtx ' . "u=-Y o=$behinddat\n\n";
189 greg 2.49 print RADSCN "void glow receiver_behind\n0\n0\n4 1 1 1 0\n\n";
190     print RADSCN "receiver_behind source b_receiver\n0\n0\n4 0 0 -1 180\n";
191     close RADSCN;
192     # Finish rfluxmtx command and prepare sender surfaces
193     $rfluxmtx .= " -n $nproc -c $nsamp";
194     if ( $tensortree != 3 ) { # Isotropic tensor tree is exception
195     open (RADSCN, "> $fsender");
196 greg 2.56 print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=-sc$ns\n\n" : "h=-kf\n\n");
197 greg 2.49 print RADSCN "void polygon fwd_sender\n0\n0\n12\n";
198 greg 2.56 printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[4]-$FEPS;
199     printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[4]-$FEPS;
200     printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[4]-$FEPS;
201     printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[4]-$FEPS;
202 greg 2.49 close RADSCN;
203     open (RADSCN, "> $bsender");
204 greg 2.56 print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=+sc$ns\n\n" : "h=+kf\n\n");
205 greg 2.55 print RADSCN "void polygon bwd_sender\n0\n0\n12\n";
206 greg 2.56 printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[5]+$FEPS;
207     printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[5]+$FEPS;
208     printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[5]+$FEPS;
209     printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[5]+$FEPS;
210 greg 2.49 close RADSCN;
211     }
212 greg 2.53 # Calculate CIE (u',v') from Radiance RGB:
213     my $CIEuv = 'Xi=.5141*Ri+.3239*Gi+.1620*Bi;' .
214     'Yi=.2651*Ri+.6701*Gi+.0648*Bi;' .
215     'Zi=.0241*Ri+.1229*Gi+.8530*Bi;' .
216     'den=Xi+15*Yi+3*Zi;' .
217     'uprime=4*Xi/den;vprime=9*Yi/den;' ;
218 greg 2.15 # Create data segments (all the work happens here)
219     if ( $tensortree ) {
220     do_tree_bsdf();
221     } else {
222     do_matrix_bsdf();
223     }
224 greg 2.49 # Output XML
225     # print STDERR "Running: $wrapper\n";
226 greg 2.60 system "$wrapper -C 'Created by: genBSDF @savedARGV'";
227 greg 2.49 die "Could not wrap BSDF data\n" if ( $? );
228 greg 2.15 # Clean up temporary files and exit
229 greg 2.53 exec $rmtmp;
230 greg 2.16
231 greg 2.15 #-------------- End of main program segment --------------#
232
233     #++++++++++++++ Tensor tree BSDF generation ++++++++++++++#
234     sub do_tree_bsdf {
235 greg 2.49
236     # Run rfluxmtx processes to compute each side
237     do_ttree_dir(0) if ( $doback );
238     do_ttree_dir(1) if ( $doforw );
239 greg 2.36
240 greg 2.15 } # end of sub do_tree_bsdf()
241
242 greg 2.49 # Call rfluxmtx and process tensor tree BSDF for the given direction
243     sub do_ttree_dir {
244 greg 2.15 my $forw = shift;
245 greg 2.47 my $cmd;
246 greg 2.15 if ( $tensortree == 3 ) {
247     # Isotropic BSDF
248 greg 2.36 my $ns2 = $ns / 2;
249 greg 2.47 if ($windoz) {
250     $cmd = "cnt $ns2 $ny $nx " .
251     qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } .
252     qq{-e "r2=rand(-5.37138*recno+67.1737811)" } .
253     qq{-e "r3=rand(+3.17603772*recno+83.766771)" } .
254     qq{-e "Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)" } .
255     qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
256     qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
257     qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } .
258     qq{-e "\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz" } .
259     qq{-e "\$4=Dx;\$5=Dy;\$6=myDz" } .
260 greg 2.49 "| $rfluxmtx -fa -y $ns2 - $receivers -i $octree";
261 greg 2.47 } else {
262     $cmd = "cnt $ns2 $ny $nx " .
263     qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } .
264     qq{-e "r2=rand(-5.37138*recno+67.1737811)" } .
265     qq{-e "r3=rand(+3.17603772*recno+83.766771)" } .
266     qq{-e "Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)" } .
267     qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
268     qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
269     qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } .
270     qq{-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' } .
271     qq{-e '\$4=Dx;\$5=Dy;\$6=myDz' -of } .
272 greg 2.49 "| $rfluxmtx -h -ff -y $ns2 - $receivers -i $octree";
273 greg 2.47 }
274 greg 2.15 } else {
275     # Anisotropic BSDF
276 greg 2.49 my $sender = ($bsender,$fsender)[$forw];
277 greg 2.47 if ($windoz) {
278 greg 2.49 $cmd = "$rfluxmtx -fa $sender $receivers -i $octree";
279 greg 2.47 } else {
280 greg 2.49 $cmd = "$rfluxmtx -h -ff $sender $receivers -i $octree";
281 greg 2.47 }
282 greg 2.15 }
283 greg 2.49 # print STDERR "Starting: $cmd\n";
284     system $cmd;
285     die "Failure running rfluxmtx" if ( $? );
286 greg 2.36 ttree_out($forw);
287 greg 2.49 } # end of do_ttree_dir()
288 greg 2.15
289 greg 2.49 # Simplify and store tensor tree results
290 greg 2.15 sub ttree_out {
291     my $forw = shift;
292 greg 2.49 my ($refldat,$transdat);
293     if ( $forw ) {
294     $transdat = $facedat;
295     $refldat = $behinddat;
296 greg 2.47 } else {
297 greg 2.49 $transdat = $behinddat;
298     $refldat = $facedat;
299 greg 2.47 }
300 greg 2.49 # Only output one transmitted anisotropic distribution, preferring backwards
301     if ( !$forw || !$doback || $tensortree==3 ) {
302     my $ttyp = ("tb","tf")[$forw];
303     ttree_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
304     if ( $docolor ) {
305 greg 2.53 ttree_comp($ttyp, "CIE-u", $transdat, ($tbx,$tfx)[$forw]);
306     ttree_comp($ttyp, "CIE-v", $transdat, ($tbz,$tfz)[$forw]);
307 greg 2.49 }
308 greg 2.47 }
309 greg 2.49 # Output reflection
310     my $rtyp = ("rb","rf")[$forw];
311     ttree_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
312     if ( $docolor ) {
313 greg 2.53 ttree_comp($rtyp, "CIE-u", $refldat, ($rbx,$rfx)[$forw]);
314     ttree_comp($rtyp, "CIE-v", $refldat, ($rbz,$rfz)[$forw]);
315 greg 2.34 }
316 greg 2.49 } # end of ttree_out()
317
318     # Call rttree_reduce on the given component
319     sub ttree_comp {
320     my $typ = shift;
321     my $spec = shift;
322     my $src = shift;
323     my $dest = shift;
324     my $cmd;
325 greg 2.47 if ($windoz) {
326 greg 2.49 if ("$spec" eq "Visible") {
327     $cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } .
328 greg 2.53 q{-e "Ri=$1;Gi=$2;Bi=$3" } .
329     qq{-e "$CIEuv" } .
330     q{-e "$1=Yi/Omega"};
331     } elsif ("$spec" eq "CIE-u") {
332 greg 2.54 $cmd = q{rcalc -e "Ri=$1;Gi=$2;Bi=$3" } .
333 greg 2.53 qq{-e "$CIEuv" } .
334 greg 2.54 q{-e "$1=uprime"};
335 greg 2.53 } elsif ("$spec" eq "CIE-v") {
336 greg 2.54 $cmd = q{rcalc -e "Ri=$1;Gi=$2;Bi=$3" } .
337 greg 2.53 qq{-e "$CIEuv" } .
338 greg 2.54 q{-e "$1=vprime"};
339 greg 2.49 }
340 greg 2.47 } else {
341 greg 2.49 if ("$spec" eq "Visible") {
342     $cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
343 greg 2.53 q{-e 'Ri=$1;Gi=$2;Bi=$3' } .
344     "-e '$CIEuv' " .
345     q{-e '$1=Yi/Omega'};
346     } elsif ("$spec" eq "CIE-u") {
347 greg 2.54 $cmd = q{rcalc -if3 -e 'Ri=$1;Gi=$2;Bi=$3' } .
348 greg 2.53 "-e '$CIEuv' " .
349 greg 2.54 q{-e '$1=uprime'};
350 greg 2.53 } elsif ("$spec" eq "CIE-v") {
351 greg 2.54 $cmd = q{rcalc -if3 -e 'Ri=$1;Gi=$2;Bi=$3' } .
352 greg 2.53 "-e '$CIEuv' " .
353 greg 2.54 q{-e '$1=vprime'};
354 greg 2.49 }
355 greg 2.47 }
356 greg 2.49 if ($pctcull >= 0) {
357     my $avg = ( "$typ" =~ /^r[fb]/ ) ? " -a" : "";
358 greg 2.53 my $pcull = ("$spec" eq "Visible") ? $pctcull :
359 greg 2.55 (100 - (100-$pctcull)*.25) ;
360 greg 2.49 if ($windoz) {
361     $cmd = "rcollate -ho -oc 1 $src | " .
362     $cmd .
363 greg 2.53 " | rttree_reduce$avg -h -fa -t $pcull -r $tensortree -g $ttlog2";
364 greg 2.49 } else {
365     $cmd .= " -of $src " .
366 greg 2.53 "| rttree_reduce$avg -h -ff -t $pcull -r $tensortree -g $ttlog2";
367 greg 2.49 }
368     # print STDERR "Running: $cmd\n";
369     system "$cmd > $dest";
370     die "Failure running rttree_reduce" if ( $? );
371 greg 2.47 } else {
372 greg 2.49 if ($windoz) {
373     $cmd = "rcollate -ho -oc 1 $src | " . $cmd ;
374     } else {
375     $cmd .= " $src";
376     }
377     open(DATOUT, "> $dest");
378     print DATOUT "{\n";
379     close DATOUT;
380     # print STDERR "Running: $cmd\n";
381     system "$cmd >> $dest";
382     die "Failure running rcalc" if ( $? );
383     open(DATOUT, ">> $dest");
384     for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) {
385     print DATOUT "0\n";
386     }
387     print DATOUT "}\n";
388     close DATOUT;
389 greg 2.47 }
390 greg 2.49 if ( "$spec" ne "$curspec" ) {
391 greg 2.51 $wrapper .= " -s $spec";
392 greg 2.49 $curspec = $spec;
393 greg 2.34 }
394 greg 2.49 $wrapper .= " -$typ $dest";
395     } # end of ttree_comp()
396 greg 2.15
397     #------------- End of do_tree_bsdf() & subroutines -------------#
398
399     #+++++++++++++++ Klems matrix BSDF generation +++++++++++++++#
400     sub do_matrix_bsdf {
401 greg 2.49
402     # Run rfluxmtx processes to compute each side
403     do_matrix_dir(0) if ( $doback );
404     do_matrix_dir(1) if ( $doforw );
405
406     } # end of sub do_matrix_bsdf()
407
408     # Call rfluxmtx and process tensor tree BSDF for the given direction
409     sub do_matrix_dir {
410     my $forw = shift;
411     my $cmd;
412     my $sender = ($bsender,$fsender)[$forw];
413     $cmd = "$rfluxmtx -fd $sender $receivers -i $octree";
414     # print STDERR "Starting: $cmd\n";
415     system $cmd;
416     die "Failure running rfluxmtx" if ( $? );
417     matrix_out($forw);
418     } # end of do_matrix_dir()
419
420     sub matrix_out {
421     my $forw = shift;
422     my ($refldat,$transdat);
423     if ( $forw ) {
424     $transdat = $facedat;
425     $refldat = $behinddat;
426 greg 2.47 } else {
427 greg 2.49 $transdat = $behinddat;
428     $refldat = $facedat;
429 greg 2.47 }
430 greg 2.49 # Output transmission
431     my $ttyp = ("tb","tf")[$forw];
432     matrix_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
433     if ( $docolor ) {
434     matrix_comp($ttyp, "CIE-X", $transdat, ($tbx,$tfx)[$forw]);
435     matrix_comp($ttyp, "CIE-Z", $transdat, ($tbz,$tfz)[$forw]);
436     }
437     # Output reflection
438     my $rtyp = ("rb","rf")[$forw];
439     matrix_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
440     if ( $docolor ) {
441     matrix_comp($rtyp, "CIE-X", $refldat, ($rbx,$rfx)[$forw]);
442     matrix_comp($rtyp, "CIE-Z", $refldat, ($rbz,$rfz)[$forw]);
443     }
444     } # end of matrix_out()
445
446     # Transpose matrix component data and save to file
447     sub matrix_comp {
448     my $typ = shift;
449     my $spec = shift;
450     my $src = shift;
451     my $dest = shift;
452     my $cmd = "rmtxop -fa -t";
453     if ("$spec" eq "Visible") {
454 greg 2.55 $cmd .= " -c 0.2651 0.6701 0.0648";
455 greg 2.49 } elsif ("$spec" eq "CIE-X") {
456 greg 2.55 $cmd .= " -c 0.5141 0.3239 0.1620";
457 greg 2.49 } elsif ("$spec" eq "CIE-Z") {
458 greg 2.55 $cmd .= " -c 0.0241 0.1229 0.8530";
459 greg 2.49 }
460 greg 2.52 $cmd .= " $src | rcollate -ho -oc 145";
461 greg 2.49 # print STDERR "Running: $cmd\n";
462     system "$cmd > $dest";
463 greg 2.61 die "Failure running rmtxop" if ( $? );
464 greg 2.49 if ( "$spec" ne "$curspec" ) {
465 greg 2.51 $wrapper .= " -s $spec";
466 greg 2.49 $curspec = $spec;
467 greg 2.47 }
468 greg 2.49 $wrapper .= " -$typ $dest";
469     } # end of matrix_comp()
470 greg 2.47
471 greg 2.49 #------------- End of do_matrix_bsdf() & subroutines --------------#
