root/radiance/src/util/findglare.c
Revision: 2.10
Committed: Mon Jul 21 22:30:19 2003 UTC (22 years, 3 months ago) by schorsch
2 static const char RCSid[] = "$Id: findglare.c,v 2.9 2003/02/22 02:07:30 greg Exp $";
5 * Find glare sources in a scene or image.
6 *
7 * Greg Ward March 1991
8 */
9
10 #include "glare.h"
11
12 #define FEQ(a,b) ((a)-(b)<=FTINY&&(b)-(a)<=FTINY)
13 #define VEQ(v1,v2) (FEQ((v1)[0],(v2)[0])&&FEQ((v1)[1],(v2)[1]) \
14 &&FEQ((v1)[2],(v2)[2]))
15
16 char *rtargv[64] = {"rtrace", "-h-", "-ov", "-fff", "-ld-", "-i-", "-I-"};
17 int rtargc = 7;
18
19 VIEW ourview = STDVIEW; /* our view */
20 VIEW pictview = STDVIEW; /* picture view */
21 VIEW leftview, rightview; /* leftmost and rightmost views */
22
23 char *picture = NULL; /* picture file name */
24 char *octree = NULL; /* octree file name */
25
26 int verbose = 0; /* verbose reporting */
27 char *progname; /* global argv[0] */
28
29 double threshold = 0.; /* glare threshold */
30
31 int sampdens = SAMPDENS; /* sample density */
32 ANGLE glarang[180] = {AEND}; /* glare calculation angles */
33 int nglarangs = 0;
34 double maxtheta; /* maximum angle (in radians) */
35 int hsize; /* horizontal size */
36
37 struct illum *indirect; /* array of indirect illuminances */
38
39 long npixinvw; /* number of pixels in view */
40 long npixmiss; /* number of pixels missed */
41
42
43 main(argc, argv)
44 int argc;
45 char *argv[];
46 {
47 int combine = 1;
48 int gotview = 0;
49 int rval, i;
50 char *err;
51
52 progname = argv[0];
53 /* process options */
54 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
55 /* expand arguments */
56 while ((rval = expandarg(&argc, &argv, i)) > 0)
57 ;
58 if (rval < 0) {
59 fprintf(stderr, "%s: cannot expand '%s'",
60 argv[0], argv[i]);
61 exit(1);
62 }
63 rval = getviewopt(&ourview, argc-i, argv+i);
64 if (rval >= 0) {
65 i += rval;
66 gotview++;
67 continue;
68 }
69 switch (argv[i][1]) {
70 case 't':
71 threshold = atof(argv[++i]);
72 break;
73 case 'r':
74 sampdens = atoi(argv[++i])/2;
75 break;
76 case 'v':
77 if (argv[i][2] == '\0') {
78 verbose++;
79 break;
80 }
81 if (argv[i][2] != 'f')
82 goto userr;
83 rval = viewfile(argv[++i], &ourview, NULL);
84 if (rval < 0) {
85 fprintf(stderr,
86 "%s: cannot open view file \"%s\"\n",
87 progname, argv[i]);
88 exit(1);
89 } else if (rval == 0) {
90 fprintf(stderr,
91 "%s: bad view file \"%s\"\n",
92 progname, argv[i]);
93 exit(1);
94 } else
95 gotview++;
96 break;
97 case 'g':
98 if (argv[i][2] != 'a')
99 goto userr;
100 if (setscan(glarang, argv[++i]) < 0) {
101 fprintf(stderr, "%s: bad angle spec \"%s\"\n",
102 progname, argv[i]);
103 exit(1);
104 }
105 break;
106 case 'p':
107 picture = argv[++i];
108 break;
109 case 'c':
110 combine = !combine;
111 break;
112 case 'd':
113 rtargv[rtargc++] = argv[i];
114 if (argv[i][2] != 'v')
115 rtargv[rtargc++] = argv[++i];
116 break;
117 case 'l':
118 if (argv[i][2] == 'd')
119 break;
120 /* FALL THROUGH */
121 case 's':
122 case 'P':
123 rtargv[rtargc++] = argv[i];
124 rtargv[rtargc++] = argv[++i];
125 break;
126 case 'w':
127 rtargv[rtargc++] = argv[i];
128 break;
129 case 'a':
130 rtargv[rtargc++] = argv[i];
131 if (argv[i][2] == 'v') {
132 rtargv[rtargc++] = argv[++i];
133 rtargv[rtargc++] = argv[++i];
134 }
135 rtargv[rtargc++] = argv[++i];
136 break;
137 default:
138 goto userr;
139 }
140 }
141 /* get octree */
142 if (i < argc-1)
143 goto userr;
144 if (i == argc-1) {
145 rtargv[rtargc++] = octree = argv[i];
146 rtargv[rtargc] = NULL;
147 }
148 /* get view */
149 if (picture != NULL) {
150 rval = viewfile(picture, &pictview, NULL);
151 if (rval < 0) {
152 fprintf(stderr, "%s: cannot open picture file \"%s\"\n",
153 progname, picture);
154 exit(1);
155 } else if (rval == 0) {
156 fprintf(stderr,
157 "%s: cannot get view from picture \"%s\"\n",
158 progname, picture);
159 exit(1);
160 }
161 if (pictview.type == VT_PAR) {
162 fprintf(stderr, "%s: %s: cannot use parallel view\n",
163 progname, picture);
164 exit(1);
165 }
166 if ((err = setview(&pictview)) != NULL) {
167 fprintf(stderr, "%s: %s\n", picture, err);
168 exit(1);
169 }
170 }
171 if (!gotview) {
172 if (picture == NULL) {
173 fprintf(stderr, "%s: must have view or picture\n",
174 progname);
175 exit(1);
176 }
177 ourview = pictview;
178 } else if (picture != NULL && !VEQ(ourview.vp, pictview.vp)) {
179 fprintf(stderr, "%s: picture must have same viewpoint\n",
180 progname);
181 exit(1);
182 }
183 ourview.type = VT_HEM;
184 ourview.horiz = ourview.vert = 180.0;
185 ourview.hoff = ourview.voff = 0.0;
186 fvsum(ourview.vdir, ourview.vdir, ourview.vup,
187 -DOT(ourview.vdir,ourview.vup));
188 if ((err = setview(&ourview)) != NULL) {
189 fprintf(stderr, "%s: %s\n", progname, err);
190 exit(1);
191 }
192 if (octree == NULL && picture == NULL) {
193 fprintf(stderr,
194 "%s: must specify at least one of picture or octree\n",
195 progname);
196 exit(1);
197 }
198 init(); /* initialize program */
199 if (threshold <= FTINY)
200 comp_thresh(); /* compute glare threshold */
201 analyze(); /* analyze view */
202 if (combine)
203 absorb_specks(); /* eliminate tiny sources */
204 cleanup(); /* tidy up */
205 /* print header */
206 newheader("RADIANCE", stdout);
207 printargs(argc, argv, stdout);
208 fputs(VIEWSTR, stdout);
209 fprintview(&ourview, stdout);
210 printf("\n");
211 fputformat("ascii", stdout);
212 printf("\n");
213 printsources(); /* print glare sources */
214 printillum(); /* print illuminances */
215 exit(0);
216 userr:
217 fprintf(stderr,
218 "Usage: %s [view options][-ga angles][-p picture][[rtrace options] octree]\n",
219 progname);
220 exit(1);
221 }
222
223
224 int
225 angcmp(ap1, ap2) /* compare two angles */
226 ANGLE *ap1, *ap2;
227 {
228 register int a1, a2;
229
230 a1 = *ap1;
231 a2 = *ap2;
232 if (a1 == a2) {
233 fprintf(stderr, "%s: duplicate glare angle (%d)\n",
234 progname, a1);
235 exit(1);
236 }
237 return(a1-a2);
238 }
239
240
241 init() /* initialize global variables */
242 {
243 double d;
244 register int i;
245
246 if (verbose)
247 fprintf(stderr, "%s: initializing data structures...\n",
248 progname);
249 /* set direction vectors */
250 for (i = 0; glarang[i] != AEND; i++)
251 ;
252 qsort(glarang, i, sizeof(ANGLE), angcmp);
253 if (i > 0 && (glarang[0] <= 0 || glarang[i-1] > 180)) {
254 fprintf(stderr, "%s: glare angles must be between 1 and 180\n",
255 progname);
256 exit(1);
257 }
258 nglarangs = i;
259 /* nglardirs = 2*nglarangs + 1; */
260 /* vsize = sampdens - 1; */
261 if (nglarangs > 0)
262 maxtheta = (PI/180.)*glarang[nglarangs-1];
263 else
264 maxtheta = 0.0;
265 hsize = hlim(0) + sampdens - 1;
266 if (hsize > (int)(PI*sampdens))
267 hsize = PI*sampdens;
268 indirect = (struct illum *)calloc(nglardirs, sizeof(struct illum));
269 if (indirect == NULL)
270 memerr("indirect illuminances");
271 npixinvw = npixmiss = 0L;
272 leftview = ourview;
273 rightview = ourview;
274 spinvector(leftview.vdir, ourview.vdir, ourview.vup, maxtheta);
275 spinvector(rightview.vdir, ourview.vdir, ourview.vup, -maxtheta);
276 setview(&leftview);
277 setview(&rightview);
278 indirect[nglarangs].lcos =
279 indirect[nglarangs].rcos = cos(maxtheta);
280 indirect[nglarangs].rsin =
281 -(indirect[nglarangs].lsin = sin(maxtheta));
282 indirect[nglarangs].theta = 0.0;
283 for (i = 0; i < nglarangs; i++) {
284 d = (glarang[nglarangs-1] - glarang[i])*(PI/180.);
285 indirect[nglarangs-i-1].lcos =
286 indirect[nglarangs+i+1].rcos = cos(d);
287 indirect[nglarangs+i+1].rsin =
288 -(indirect[nglarangs-i-1].lsin = sin(d));
289 d = (glarang[nglarangs-1] + glarang[i])*(PI/180.);
290 indirect[nglarangs-i-1].rcos =
291 indirect[nglarangs+i+1].lcos = cos(d);
292 indirect[nglarangs-i-1].rsin =
293 -(indirect[nglarangs+i+1].lsin = sin(d));
294 indirect[nglarangs-i-1].theta = (PI/180.)*glarang[i];
295 indirect[nglarangs+i+1].theta = -(PI/180.)*glarang[i];
296 }
297 /* open picture */
298 if (picture != NULL) {
299 if (verbose)
300 fprintf(stderr, "%s: opening picture file \"%s\"...\n",
301 progname, picture);
302 open_pict(picture);
303 }
304 /* start rtrace */
305 if (octree != NULL) {
306 if (verbose) {
307 fprintf(stderr,
308 "%s: starting luminance calculation...\n\t",
309 progname);
310 printargs(rtargc, rtargv, stderr);
311 }
312 fork_rtrace(rtargv);
313 }
314 }
315
316
317 cleanup() /* close files, wait for children */
318 {
319 if (verbose)
320 fprintf(stderr, "%s: cleaning up... \n", progname);
321 if (picture != NULL)
322 close_pict();
323 if (octree != NULL)
324 done_rtrace();
325 if (npixinvw < 100*npixmiss)
326 fprintf(stderr, "%s: warning -- missing %d%% of samples\n",
327 progname, (int)(100L*npixmiss/npixinvw));
328 }
329
330
331 compdir(vd, x, y) /* compute direction for x,y */
332 FVECT vd;
333 int x, y;
334 {
335 int hl;
336 FVECT org; /* dummy variable */
337
338 hl = hlim(y);
339 if (x <= -hl) { /* left region */
340 if (x <= -hl-sampdens)
341 return(-1);
342 return(viewray(org, vd, &leftview,
343 (double)(x+hl)/(2*sampdens)+.5,
344 (double)y/(2*sampdens)+.5));
345 }
346 if (x >= hl) { /* right region */
347 if (x >= hl+sampdens)
348 return(-1);
349 return(viewray(org, vd, &rightview,
350 (double)(x-hl)/(2*sampdens)+.5,
351 (double)y/(2*sampdens)+.5));
352 }
353 /* central region */
354 if (viewray(org, vd, &ourview, .5, (double)y/(2*sampdens)+.5) < 0)
355 return(-1);
356 spinvector(vd, vd, ourview.vup, h_theta(x,y));
357 return(0);
358 }
359
360
361 double
362 pixsize(x, y) /* return the solid angle of pixel at (x,y) */
363 int x, y;
364 {
365 register int hl, xo;
366 double disc;
367
368 hl = hlim(y);
369 if (x < -hl)
370 xo = x+hl;
371 else if (x > hl)
372 xo = x-hl;
373 else
374 xo = 0;
375 disc = 1. - (double)((long)xo*xo + (long)y*y)/((long)sampdens*sampdens);
376 if (disc <= FTINY*FTINY)
377 return(0.);
378 return(1./(sampdens*sampdens*sqrt(disc)));
379 }
380
381
382 memerr(s) /* malloc failure */
383 char *s;
384 {
385 fprintf(stderr, "%s: out of memory for %s\n", progname, s);
386 exit(1);
387 }
388
389
390 printsources() /* print out glare sources */
391 {
392 register struct source *sp;
393
394 printf("BEGIN glare source\n");
395 for (sp = donelist; sp != NULL; sp = sp->next)
396 printf("\t%f %f %f\t%f\t%f\n",
397 sp->dir[0], sp->dir[1], sp->dir[2],
398 sp->dom, sp->brt);
399 printf("END glare source\n");
400 }
401
402
403 printillum() /* print out indirect illuminances */
404 {
405 register int i;
406
407 printf("BEGIN indirect illuminance\n");
408 for (i = 0; i < nglardirs; i++)
409 if (indirect[i].n > FTINY)
410 printf("\t%.0f\t%f\n", (180.0/PI)*indirect[i].theta,
411 PI * indirect[i].sum / indirect[i].n);
412 printf("END indirect illuminance\n");
413 }
