root/radiance/src/util/eplus_idf.h
Revision: 2.8
Committed: Sun Mar 6 01:13:18 2016 UTC (9 years, 8 months ago) by schorsch
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, HEAD
# User Rev Content
1 schorsch 2.8 /* RCSid $Id: eplus_idf.h,v 2.7 2014/02/12 17:40:07 greg Exp $ */
2 greg 2.1 /*
3     * eplus_idf.h
4     *
5     * EnergyPlus Input Data File i/o declarations
6     *
7     * Created by Greg Ward on 1/31/14.
8     */
9
10     #ifndef _RAD_EPLUS_IDF_H_
11     #define _RAD_EPLUS_IDF_H_
12
13 schorsch 2.8 #include "platform.h"
14 greg 2.1 #include "lookup.h"
15
16     #ifdef __cplusplus
17     extern "C" {
18     #endif
19
20     #define IDF_MAXLINE 512 /* maximum line length */
21 greg 2.2 #define IDF_MAXARGL 104 /* maximum argument length */
22 greg 2.1
23 greg 2.7 /* Input Data File object argument list */
24 greg 2.1 typedef struct s_idf_field {
25 greg 2.7 struct s_idf_field *next; /* next in object list */
26 greg 2.1 char *rem; /* string following argument */
27 greg 2.6 char val[2]; /* value (extends struct) */
28 greg 2.1 } IDF_FIELD;
29
30 greg 2.7 /* Input Data File object */
31     typedef struct s_idf_object {
32     const char *pname; /* object name (type) */
33     struct s_idf_object *pnext; /* next object same type */
34     struct s_idf_object *dnext; /* next object in IDF */
35 greg 2.5 int nfield; /* field count */
36 greg 2.1 IDF_FIELD *flist; /* field list */
37     char rem[1]; /* comment (extends struct) */
38 greg 2.7 } IDF_OBJECT;
39 greg 2.1
40     /* Input Data File w/ dictionary */
41     typedef struct {
42     char *hrem; /* header remarks */
43 greg 2.7 IDF_OBJECT *pfirst; /* first object in file */
44     IDF_OBJECT *plast; /* last object loaded */
45     LUTAB ptab; /* object hash table */
46 greg 2.1 } IDF_LOADED;
47
48 greg 2.7 /* Create a new object with empty field list (comment & prev optional) */
49     extern IDF_OBJECT *idf_newobject(IDF_LOADED *idf, const char *pname,
50     const char *comm, IDF_OBJECT *prev);
51 greg 2.1
52 greg 2.7 /* Add a field to the given object and follow with the given text */
53     extern int idf_addfield(IDF_OBJECT *param, const char *fval,
54 greg 2.1 const char *comm);
55
56 greg 2.7 /* Retrieve the indexed field from object (first field index is 1) */
57     extern IDF_FIELD *idf_getfield(IDF_OBJECT *param, int fn);
58 greg 2.3
59 greg 2.7 /* Delete the specified object from the IDF */
60     extern int idf_delobject(IDF_LOADED *idf, IDF_OBJECT *param);
61 greg 2.1
62 greg 2.7 /* Move the specified object to the given position in the IDF */
63     extern int idf_movobject(IDF_LOADED *idf, IDF_OBJECT *param,
64     IDF_OBJECT *prev);
65 greg 2.4
66 greg 2.7 /* Get a named object list */
67     extern IDF_OBJECT *idf_getobject(IDF_LOADED *idf, const char *pname);
68 greg 2.1
69 greg 2.7 /* Read a object and fields from an open file and add to end of list */
70     extern IDF_OBJECT *idf_readobject(IDF_LOADED *idf, FILE *fp);
71 greg 2.1
72     /* Initialize an IDF struct */
73     extern IDF_LOADED *idf_create(const char *hdrcomm);
74
75 greg 2.4 /* Add comment(s) to header */
76     extern int idf_add2hdr(IDF_LOADED *idf, const char *hdrcomm);
77
78 greg 2.1 /* Load an Input Data File */
79     extern IDF_LOADED *idf_load(const char *fname);
80
81 greg 2.7 /* Write a object and fields to an open file */
82     int idf_writeparam(IDF_OBJECT *param, FILE *fp,
83 greg 2.4 int incl_comm);
84 greg 2.1
85     /* Write out an Input Data File */
86 greg 2.4 extern int idf_write(IDF_LOADED *idf, const char *fname,
87     int incl_comm);
88 greg 2.1
89     /* Free a loaded IDF */
90     extern void idf_free(IDF_LOADED *idf);
91
92     #ifdef __cplusplus
93     }
94     #endif
95     #endif /* ! _RAD_EPLUS_IDF_H_ */
