root/radiance/src/util/eplus_adduvf.c
Revision: 2.20
Committed: Fri Jan 17 17:33:48 2020 UTC (5 years, 8 months ago) by greg
Changes since 2.19: +10 -1 lines
Added warning about incompatible input versions
2 static const char RCSid[] = "$Id: eplus_adduvf.c,v 2.19 2019/12/13 16:00:33 greg Exp $";
5 * Add User View Factors to EnergyPlus Input Data File
6 *
7 * G.Ward for LBNL
8 */
9
10 #include <stdlib.h>
11 #include "platform.h"
12 #include "rtio.h"
13 #include "rtmath.h"
14 #include "random.h"
15 #include "eplus_idf.h"
16 #include "triangulate.h"
17 #include "rtprocess.h"
18
19 #ifndef NSAMPLES
20 #define NSAMPLES 80000 /* default number of samples */
21 #endif
22
23 #define SURF_EPS 0.0005 /* surface testing epsilon */
24
25 char *progname; /* global argv[0] */
26
27 int nsamps = NSAMPLES; /* number of samples to use */
28
29 char temp_octree[128]; /* temporary octree */
30
31 const char UVF_PNAME[] =
32 "ZoneProperty:UserViewFactors:bySurfaceName";
33
34 const char SUBSURF_PNAME[] =
35 "FenestrationSurface:Detailed";
36
37 const char ADD_HEADER[] =
38 "\n!+++ User View Factors computed by Radiance +++!\n\n";
39
40 #define NAME_FLD 1 /* name field always first? */
41
42 #define SS_BASE_FLD 4 /* subsurface base surface */
43 #define SS_VERT_FLD 10 /* subsurface vertex count */
44
45 typedef struct {
46 const char *pname; /* object type name */
47 short zone_fld; /* zone field index */
48 short vert_fld; /* vertex field index */
49 } SURF_PTYPE; /* surface type we're interested in */
50
51 const SURF_PTYPE surf_type[] = {
52 {"BuildingSurface:Detailed", 4, 10},
53 {"Floor:Detailed", 3, 9},
54 {"RoofCeiling:Detailed", 3, 9},
55 {"Wall:Detailed", 3, 9},
56 {NULL}
57 }; /* IDF surface types */
58
59 typedef struct s_zone {
60 const char *zname; /* zone name */
61 struct s_zone *next; /* next zone in list */
62 int nsurf; /* surface count */
63 int ntotal; /* surfaces+subsurfaces */
64 IDF_OBJECT *pfirst; /* first matching object */
65 IDF_OBJECT *plast; /* last before subsurfaces */
66 float *area_redu; /* subsurface area per surf. */
67 } ZONE; /* a list of collected zone surfaces */
68
69 ZONE *zone_list = NULL; /* our list of zones */
70
71 LUTAB zonesurf_lut = /* zone surface lookup table */
72 LU_SINIT(NULL,NULL);
73
74 IDF_LOADED *our_idf = NULL; /* loaded/modified IDF */
75
76 typedef struct {
77 FVECT norm; /* surface normal */
78 double area; /* surface area */
79 int nv; /* number of vertices */
80 FVECT vl[3]; /* vertex list (extends struct) */
81 } SURFACE; /* a polygonal surface */
82
83 typedef struct {
84 FVECT sdir[3]; /* UVW unit sampling vectors */
85 double poff; /* W-offset for plane of polygon */
86 double area_left; /* area left to sample */
87 int samp_left; /* remaining samples */
88 int wd; /* output file descriptor */
89 } POLYSAMP; /* structure for polygon sampling */
90
91 /* Create a new zone and push to top of our list */
92 static ZONE *
93 new_zone(const char *zname, IDF_OBJECT *param)
94 {
95 ZONE *znew = (ZONE *)malloc(sizeof(ZONE));
96
97 if (znew == NULL)
98 return(NULL);
99 znew->zname = zname; /* assumes static */
100 znew->next = zone_list;
101 znew->pfirst = znew->plast = param;
102 znew->ntotal = znew->nsurf = 1;
103 znew->area_redu = NULL;
104 return(zone_list = znew);
105 }
106
107 /* Add the detailed surface (polygon) to the named zone */
108 static ZONE *
109 add2zone(IDF_OBJECT *param, const char *zname)
110 {
111 IDF_FIELD *nfp = idf_getfield(param, NAME_FLD);
112 ZONE *zptr;
113 LUENT *lep;
114
115 if (nfp == NULL) {
116 fputs(progname, stderr);
117 fputs(": surface missing name field!\n", stderr);
118 return(NULL);
119 }
120 for (zptr = zone_list; zptr != NULL; zptr = zptr->next)
121 if (!strcmp(zptr->zname, zname))
122 break;
123 if (zptr == NULL) {
124 zptr = new_zone(zname, param);
125 } else { /* keep surfaces together */
126 if (!idf_movobject(our_idf, param, zptr->plast))
127 return(NULL);
128 zptr->plast = param;
129 zptr->nsurf++;
130 zptr->ntotal++;
131 }
132 /* add to lookup table */
133 lep = lu_find(&zonesurf_lut, nfp->val);
134 if (lep == NULL)
135 return(NULL);
136 if (lep->data != NULL) {
137 fputs(progname, stderr);
138 fputs(": duplicate surface name '", stderr);
139 fputs(nfp->val, stderr);
140 fputs("'\n", stderr);
141 return(NULL);
142 }
143 lep->key = nfp->val;
144 lep->data = (char *)zptr;
145 return(zptr);
146 }
147
148 /* Add a subsurface by finding its base surface and the corresponding zone */
149 static ZONE *
150 add_subsurf(IDF_OBJECT *param)
151 {
152 IDF_FIELD *bfp = idf_getfield(param, SS_BASE_FLD);
153 ZONE *zptr;
154 LUENT *lep;
155
156 if (bfp == NULL) {
157 fputs(progname, stderr);
158 fputs(": missing base field name in subsurface!\n", stderr);
159 return(NULL);
160 }
161 lep = lu_find(&zonesurf_lut, bfp->val); /* find base zone */
162 if (lep == NULL || lep->data == NULL) {
163 fputs(progname, stderr);
164 fputs(": cannot find referenced base surface '", stderr);
165 fputs(bfp->val, stderr);
166 fputs("'\n", stderr);
167 return(NULL);
168 }
169 zptr = (ZONE *)lep->data; /* add this subsurface */
170 if (!idf_movobject(our_idf, param, zptr->plast))
171 return(NULL);
172 zptr->ntotal++;
173 return(zptr);
174 }
175
176 /* Return field for vertices in the given object */
177 static IDF_FIELD *
178 get_vlist(IDF_OBJECT *param, const char *zname)
179 {
180 #define itm_len (sizeof(IDF_FIELD)+6)
181 static char fld_buf[4*itm_len];
182 static char *next_fbp = fld_buf;
183 int i;
184 IDF_FIELD *res;
185 /* check if subsurface */
186 if (!strcmp(param->pname, SUBSURF_PNAME)) {
187 if (zname != NULL) {
188 LUENT *lep = lu_find(&zonesurf_lut,
189 idf_getfield(param,SS_BASE_FLD)->val);
190 if (strcmp((*(ZONE *)lep->data).zname, zname))
191 return(NULL);
192 }
193 res = idf_getfield(param, SS_VERT_FLD);
194 } else {
195 i = 0; /* check for surface type */
196 while (strcmp(surf_type[i].pname, param->pname))
197 if (surf_type[++i].pname == NULL)
198 return(NULL);
199
200 if (zname != NULL) { /* matches specified zone? */
201 IDF_FIELD *fptr = idf_getfield(param, surf_type[i].zone_fld);
202 if (fptr == NULL || strcmp(fptr->val, zname))
203 return(NULL);
204 }
205 res = idf_getfield(param, surf_type[i].vert_fld);
206 }
207 if (!res->val[0]) { /* hack for missing #vert */
208 IDF_FIELD *fptr;
209 if (next_fbp >= fld_buf+sizeof(fld_buf))
210 next_fbp = fld_buf;
211 i = 0; /* count vertices */
212 for (fptr = res->next; fptr != NULL; fptr = fptr->next)
213 ++i;
214 if (i % 3)
215 return(NULL);
216 fptr = res->next;
217 res = (IDF_FIELD *)next_fbp; next_fbp += itm_len;
218 res->next = fptr;
219 res->rem = "";
220 sprintf(res->val, "%d", i/3);
221 }
222 return(res);
223 #undef itm_len
224 }
225
226 /* Get/allocate surface polygon */
227 static SURFACE *
228 get_surface(IDF_FIELD *fptr)
229 {
230 SURFACE *surf;
231 int nv;
232 FVECT e1, e2, vc;
233 int i, j;
234 /* get number of vertices */
235 if (fptr == NULL || (nv = atoi(fptr->val)) < 3) {
236 fputs(progname, stderr);
237 fputs(": bad vertex count for surface!\n", stderr);
238 return(NULL);
239 }
240 surf = (SURFACE *)malloc(sizeof(SURFACE)+sizeof(FVECT)*(nv-3));
241 if (surf == NULL)
242 return(NULL);
243 surf->nv = nv;
244 for (i = nv; i--; ) /* reverse vertex order/orientation */
245 for (j = 0; j < 3; j++) {
246 fptr = fptr->next;
247 if (fptr == NULL) {
248 fputs(progname, stderr);
249 fputs(": missing vertex in get_surface()\n", stderr);
250 free(surf);
251 return(NULL);
252 }
253 if ((surf->vl[i][j] = atof(fptr->val)) == 0 &&
254 !isflt(fptr->val)) {
255 fputs(progname, stderr);
256 fputs(": bad vertex in get_surface()\n", stderr);
257 free(surf);
258 return(NULL);
259 }
260 }
261 /* compute area and normal */
262 surf->norm[0] = surf->norm[1] = surf->norm[2] = 0;
263 VSUB(e1, surf->vl[1], surf->vl[0]);
264 for (i = 2; i < nv; i++) {
265 VSUB(e2, surf->vl[i], surf->vl[0]);
266 fcross(vc, e1, e2);
267 surf->norm[0] += vc[0];
268 surf->norm[1] += vc[1];
269 surf->norm[2] += vc[2];
270 VCOPY(e1, e2);
271 }
272 surf->area = .5 * normalize(surf->norm);
273 if (surf->area == 0) {
274 fputs(progname, stderr);
275 fputs(": degenerate polygon in get_surface()\n", stderr);
276 free(surf);
277 return(NULL);
278 }
279 return(surf);
280 }
281
282 /* Convert surface to Radiance with modifier based on unique name */
283 static int
284 rad_surface(IDF_OBJECT *param, FILE *ofp)
285 {
286 const char *sname = idf_getfield(param,NAME_FLD)->val;
287 IDF_FIELD *fptr = get_vlist(param, NULL);
288 const char **fargs;
289 int nvert, i, j;
290
291 if (fptr == NULL || (nvert = atoi(fptr->val)) < 3) {
292 fprintf(stderr, "%s: bad surface '%s'\n", progname, sname);
293 return(0);
294 }
295 fargs = (const char **)malloc(sizeof(const char *)*3*nvert);
296 if (fargs == NULL)
297 return(0);
298 fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname);
299 fprintf(ofp, "\n'%s' polygon 's_%s'\n0\n0\n%d\n", sname, sname, 3*nvert);
300 for (j = nvert; j--; ) { /* get arguments in reverse */
301 for (i = 0; i < 3; i++) {
302 fptr = fptr->next;
303 if (fptr == NULL || !isflt(fptr->val)) {
304 fprintf(stderr,
305 "%s: missing/bad vertex for %s '%s'\n",
306 progname, param->pname, sname);
307 return(0);
308 }
309 fargs[3*j + i] = fptr->val;
310 }
311 }
312 for (j = 0; j < nvert; j++) { /* output reversed verts */
313 for (i = 0; i < 3; i++) {
314 fputc('\t', ofp);
315 fputs(fargs[3*j + i], ofp);
316 }
317 fputc('\n', ofp);
318 }
319 free(fargs);
320 return(!ferror(ofp));
321 }
322
323 /* Convert subsurface to Radiance with modifier based on unique name */
324 static double
325 rad_subsurface(IDF_OBJECT *param, FILE *ofp)
326 {
327 const char *sname = idf_getfield(param,NAME_FLD)->val;
328 SURFACE *surf = get_surface(get_vlist(param, NULL));
329 double area;
330 int i;
331
332 if (surf == NULL) {
333 fprintf(stderr, "%s: bad subsurface '%s'\n", progname, sname);
334 return(-1.);
335 }
336 fprintf(ofp, "\nvoid glow '%s'\n0\n0\n4 1 1 1 0\n", sname);
337 fprintf(ofp, "\n'%s' polygon 'ss_%s'\n0\n0\n%d\n",
338 sname, sname, 3*surf->nv);
339 for (i = 0; i < surf->nv; i++) { /* offset vertices */
340 FVECT vert;
341 VSUM(vert, surf->vl[i], surf->norm, 2.*SURF_EPS);
342 fprintf(ofp, "\t%.12f %.12f %.12f\n", vert[0], vert[1], vert[2]);
343 }
344 area = surf->area;
345 free(surf);
346 if (ferror(ofp))
347 return(-1.);
348 return(area);
349 }
350
351 /* Start rcontrib process */
352 static int
353 start_rcontrib(SUBPROC *pd, ZONE *zp)
354 {
355 #define BASE_AC 6
356 static char *base_av[BASE_AC] = {
357 "rcontrib", "-V+", "-fff", "-h", "-x", "1"
358 };
359 char cbuf[300];
360 char **av;
361 FILE *ofp;
362 IDF_OBJECT *pptr;
363 IDF_FIELD *fptr;
364 int i, j, n;
365 /* start oconv command */
366 sprintf(cbuf, "oconv - > \"%s\"", temp_octree);
367 if ((ofp = popen(cbuf, "w")) == NULL) {
368 fputs(progname, stderr);
369 fputs(": cannot open oconv process\n", stderr);
370 return(0);
371 }
372 /* allocate argument list */
373 av = (char **)malloc(sizeof(char *)*(BASE_AC+4+2*(zp->ntotal)));
374 if (av == NULL)
375 return(0);
376 for (i = 0; i < BASE_AC; i++)
377 av[i] = base_av[i];
378 sprintf(cbuf, "%d", nsamps);
379 av[i++] = "-c";
380 av[i++] = cbuf; /* add modifiers & surfaces */
381 for (n = 0, pptr = zp->pfirst; n < zp->nsurf; n++, pptr = pptr->dnext) {
382 fptr = idf_getfield(pptr,NAME_FLD);
383 if (fptr == NULL || !fptr->val[0]) {
384 fputs(progname, stderr);
385 fputs(": missing name for surface object\n", stderr);
386 return(0);
387 }
388 if (!rad_surface(pptr, ofp)) /* add surface to octree */
389 return(0);
390 av[i++] = "-m";
391 av[i++] = fptr->val;
392 }
393 /* now subsurfaces */
394 if (zp->ntotal > zp->nsurf) {
395 if (zp->area_redu != NULL)
396 memset(zp->area_redu, 0, sizeof(float)*zp->ntotal);
397 else if ((zp->area_redu = (float *)calloc(zp->ntotal,
398 sizeof(float))) == NULL)
399 return(0);
400 }
401 for ( ; n < zp->ntotal; n++, pptr = pptr->dnext) {
402 double ssarea;
403 const char *bname;
404 IDF_OBJECT *pptr1;
405 fptr = idf_getfield(pptr,NAME_FLD);
406 if (fptr == NULL || !fptr->val[0]) {
407 fputs(progname, stderr);
408 fputs(": missing name for subsurface object\n", stderr);
409 return(0);
410 }
411 /* add subsurface to octree */
412 if ((ssarea = rad_subsurface(pptr, ofp)) < 0)
413 return(0);
414 /* mark area for subtraction */
415 bname = idf_getfield(pptr,SS_BASE_FLD)->val;
416 for (j = 0, pptr1 = zp->pfirst;
417 j < zp->nsurf; j++, pptr1 = pptr1->dnext)
418 if (!strcmp(idf_getfield(pptr1,NAME_FLD)->val, bname)) {
419 zp->area_redu[j] += ssarea;
420 break;
421 }
422 av[i++] = "-m";
423 av[i++] = fptr->val;
424 }
425 if (pclose(ofp) != 0) { /* finish oconv */
426 fputs(progname, stderr);
427 fputs(": error running oconv process\n", stderr);
428 return(0);
429 }
430 av[i++] = temp_octree; /* add final octree argument */
431 av[i] = NULL;
432 if (open_process(pd, av) <= 0) { /* start process */
433 fputs(progname, stderr);
434 fputs(": cannot start rcontrib process\n", stderr);
435 return(0);
436 }
437 free(av); /* all done -- clean up */
438 return(1);
439 #undef BASE_AC
440 }
441
442 /* Initialize polygon sampling */
443 static Vert2_list *
444 init_poly(POLYSAMP *ps, IDF_FIELD *f0)
445 {
446 SURFACE *surf;
447 Vert2_list *vl2;
448 int i;
449 /* get 3-D polygon vertices */
450 if ((surf = get_surface(f0)) == NULL)
451 return(NULL);
452 vl2 = polyAlloc(surf->nv);
453 if (vl2 == NULL)
454 return(NULL);
455 /* create X & Y axes */
456 VCOPY(ps->sdir[2], surf->norm);
457 VSUB(ps->sdir[0], surf->vl[1], surf->vl[0]);
458 if (normalize(ps->sdir[0]) == 0)
459 return(NULL);
460 fcross(ps->sdir[1], ps->sdir[2], ps->sdir[0]);
461 /* compute plane offset */
462 ps->poff = DOT(surf->vl[0], ps->sdir[2]);
463 /* assign 2-D vertices */
464 for (i = 0; i < surf->nv; i++) {
465 vl2->v[i].mX = DOT(surf->vl[i], ps->sdir[0]);
466 vl2->v[i].mY = DOT(surf->vl[i], ps->sdir[1]);
467 }
468 ps->area_left = surf->area;
469 free(surf); /* it's ready! */
470 vl2->p = (void *)ps;
471 return(vl2);
472 }
473
474 /* Generate samples on 2-D triangle */
475 static int
476 sample_triangle(const Vert2_list *vl2, int a, int b, int c)
477 {
478 POLYSAMP *ps = (POLYSAMP *)vl2->p;
479 float *samp;
480 FVECT orig;
481 FVECT ab, ac;
482 double area;
483 int i, j, ns;
484 /* compute sampling axes */
485 for (i = 3; i--; ) {
486 orig[i] = vl2->v[a].mX*ps->sdir[0][i] +
487 vl2->v[a].mY*ps->sdir[1][i] +
488 (ps->poff+SURF_EPS)*ps->sdir[2][i];
489 ab[i] = (vl2->v[b].mX - vl2->v[a].mX)*ps->sdir[0][i] +
490 (vl2->v[b].mY - vl2->v[a].mY)*ps->sdir[1][i];
491 ac[i] = (vl2->v[c].mX - vl2->v[a].mX)*ps->sdir[0][i] +
492 (vl2->v[c].mY - vl2->v[a].mY)*ps->sdir[1][i];
493 }
494 /* compute number of samples to take */
495 area = .5*(vl2->v[a].mX*vl2->v[b].mY - vl2->v[b].mX*vl2->v[a].mY +
496 vl2->v[b].mX*vl2->v[c].mY - vl2->v[c].mX*vl2->v[b].mY +
497 vl2->v[c].mX*vl2->v[a].mY - vl2->v[a].mX*vl2->v[c].mY);
498 if (area < .0) {
499 fputs(progname, stderr);
500 fputs(": negative triangle area in sample_triangle()\n", stderr);
501 return(0);
502 }
503 if (area >= ps->area_left) {
504 ns = ps->samp_left;
505 ps->area_left = 0;
506 } else {
507 ns = (ps->samp_left*area/ps->area_left + .5);
508 ps->samp_left -= ns;
509 ps->area_left -= area;
510 }
511 if (ns <= 0) /* XXX should be error? */
512 return(1);
513 /* buffer sample rays */
514 samp = (float *)malloc(sizeof(float)*6*ns);
515 if (samp == NULL)
516 return(0);
517 for (i = ns; i--; ) { /* stratified Monte Carlo sampling */
518 double sv[4];
519 FVECT dv;
520 multisamp(sv, 4, (i+frandom())/(double)ns);
521 sv[0] *= sv[1] = sqrt(sv[1]);
522 sv[1] = 1. - sv[1];
523 for (j = 3; j--; )
524 samp[i*6 + j] = orig[j] + sv[0]*ab[j] + sv[1]*ac[j];
525 sv[2] = sqrt(sv[2]);
526 sv[3] *= 2.*PI;
527 dv[0] = tcos(sv[3]) * sv[2];
528 dv[1] = tsin(sv[3]) * sv[2];
529 dv[2] = sqrt(1. - sv[2]*sv[2]);
530 for (j = 3; j--; )
531 samp[i*6 + 3 + j] = dv[0]*ps->sdir[0][j] +
532 dv[1]*ps->sdir[1][j] +
533 dv[2]*ps->sdir[2][j] ;
534 }
535 /* send to our process */
536 writebuf(ps->wd, (char *)samp, sizeof(float)*6*ns);
537 free(samp); /* that's it! */
538 return(1);
539 }
540
541 /* Sample the given surface */
542 static double
543 sample_surface(IDF_OBJECT *param, int wd)
544 {
545 POLYSAMP psamp;
546 double area;
547 int nv;
548 Vert2_list *vlist2;
549 /* set up our polygon sampler */
550 if ((vlist2 = init_poly(&psamp, get_vlist(param, NULL))) == NULL) {
551 fprintf(stderr, "%s: bad polygon %s '%s'\n",
552 progname, param->pname,
553 idf_getfield(param,NAME_FLD)->val);
554 return(-1.);
555 }
556 psamp.samp_left = nsamps; /* assign samples & destination */
557 psamp.wd = wd;
558 /* hack for subsurface sampling */
559 psamp.poff += 2.*SURF_EPS * !strcmp(param->pname, SUBSURF_PNAME);
560
561 area = psamp.area_left; /* remember starting surface area */
562 /* sample each subtriangle */
563 if (!polyTriangulate(vlist2, &sample_triangle))
564 return(-1.);
565 polyFree(vlist2); /* clean up and return */
566 return(area);
567 }
568
569 /* Compute User View Factors using open rcontrib process */
570 static int
571 compute_uvfs(SUBPROC *pd, ZONE *zp)
572 {
573 IDF_OBJECT *pptr, *pout, *pptr1;
574 float *uvfa;
575 char uvfbuf[24];
576 int n, m;
577 /* create output object */
578 pout = idf_newobject(our_idf, UVF_PNAME,
579 " ! computed by Radiance\n ", our_idf->plast);
580 if (pout == NULL) {
581 fputs(progname, stderr);
582 fputs(": cannot create new IDF object\n", stderr);
583 return(0);
584 }
585 if (!idf_addfield(pout, zp->zname,
586 " !- Zone Name\n ")) {
587 fputs(progname, stderr);
588 fputs(": cannot add zone name field\n", stderr);
589 return(0);
590 }
591 /* allocate read buffer */
592 uvfa = (float *)malloc(sizeof(float)*3*zp->ntotal);
593 if (uvfa == NULL)
594 return(0);
595 /* UVFs from each surface */
596 for (n = 0, pptr = zp->pfirst; n < zp->ntotal; n++, pptr = pptr->dnext) {
597 double vfsum = 0;
598 double adj_factor;
599 /* send samples to rcontrib */
600 if ((adj_factor = sample_surface(pptr, pd->w)) < 0)
601 return(0);
602 if (zp->area_redu == NULL)
603 adj_factor = 1.;
604 else /* comp. for subsurface area */
605 adj_factor /= adj_factor - zp->area_redu[n];
606 /* read results */
607 if (readbuf(pd->r, (char *)uvfa, sizeof(float)*3*zp->ntotal) !=
608 sizeof(float)*3*zp->ntotal) {
609 fputs(progname, stderr);
610 fputs(": read error from rcontrib process\n", stderr);
611 return(0);
612 }
613 /* append UVF fields */
614 for (m = 0, pptr1 = zp->pfirst;
615 m < zp->ntotal; m++, pptr1 = pptr1->dnext) {
616 const double uvf = uvfa[3*m + 1] * adj_factor;
617 vfsum += uvf;
618 if (pptr1 == pptr && uvf > .001)
619 fprintf(stderr,
620 "%s: warning - non-zero self-VF (%.1f%%) for surface '%s'\n",
621 progname, 100.*uvf,
622 idf_getfield(pptr,NAME_FLD)->val);
623 sprintf(uvfbuf, "%.4f", uvf);
624 if (!idf_addfield(pout,
625 idf_getfield(pptr,NAME_FLD)->val, NULL) ||
626 !idf_addfield(pout,
627 idf_getfield(pptr1,NAME_FLD)->val, NULL) ||
628 !idf_addfield(pout, uvfbuf,
629 (n+m < 2*zp->ntotal-2) ?
630 "\n " : "\n\n")) {
631 fputs(progname, stderr);
632 fputs(": error adding UVF fields\n", stderr);
633 return(0);
634 }
635 }
636 if (vfsum < 0.95)
637 fprintf(stderr,
638 "%s: warning - missing %.1f%% of energy from surface '%s'\n",
639 progname, 100.*(1.-vfsum),
640 idf_getfield(pptr,NAME_FLD)->val);
641 }
642 free(uvfa); /* clean up and return */
643 return(1);
644 }
645
646 /* Compute zone User View Factors */
647 static int
648 compute_zones(void)
649 {
650 ZONE *zptr;
651 /* temporary octree name */
652 mktemp(strcpy(temp_octree, TEMPLATE));
653 /* compute each zone */
654 for (zptr = zone_list; zptr != NULL; zptr = zptr->next) {
655 SUBPROC rcproc;
656 /* start rcontrib process */
657 if (!start_rcontrib(&rcproc, zptr))
658 return(0);
659 /* compute+add view factors */
660 if (!compute_uvfs(&rcproc, zptr))
661 return(0);
662 if (close_process(&rcproc) != 0) {
663 fputs(progname, stderr);
664 fputs(": bad return status from rcontrib\n", stderr);
665 return(0);
666 }
667 }
668 unlink(temp_octree); /* remove octree file */
669 return(1);
670 }
671
672 /* Load IDF and compute User View Factors */
673 int
674 main(int argc, char *argv[])
675 {
676 int incl_comments = 1;
677 char *origIDF, *revIDF;
678 IDF_OBJECT *pptr;
679 int i;
680
681 progname = *argv++; argc--; /* get options if any */
682 while (argc > 1 && argv[0][0] == '-')
683 switch (argv[0][1]) {
684 case 'c': /* elide comments */
685 incl_comments = -1; /* header only */
686 argv++; argc--;
687 continue;
688 case 's': /* samples */
689 nsamps = 1000*atoi(*++argv);
690 argv++; argc -= 2;
691 continue;
692 default:
693 fputs(progname, stderr);
694 fputs(": unknown option '", stderr);
695 fputs(argv[0], stderr);
696 fputs("'\n", stderr);
697 goto userr;
698 }
699 if ((argc < 1) | (argc > 2))
700 goto userr;
701 origIDF = argv[0];
702 revIDF = (argc == 1) ? argv[0] : argv[1];
703 /* load Input Data File */
704 our_idf = idf_load(origIDF);
705 if (our_idf == NULL) {
706 fputs(progname, stderr);
707 fputs(": cannot load IDF '", stderr);
708 fputs(origIDF, stderr);
709 fputs("'\n", stderr);
710 return(1);
711 }
712 /* check version (warning) */
713 if ((pptr = idf_getobject(our_idf, "Version")) != NULL &&
714 pptr->flist != NULL && atoi(pptr->flist->val) != 7) {
715 fputs(progname, stderr);
716 fputs(": warning - written for IDF version 7.x, not ",
717 stderr);
718 fputs(pptr->flist->val, stderr);
719 fputc('\n', stderr);
720 }
721 /* remove existing UVFs */
722 if ((pptr = idf_getobject(our_idf, UVF_PNAME)) != NULL) {
723 IDF_OBJECT *pnext;
724 fputs(progname, stderr);
725 fputs(": removing previous User View Factors\n", stderr);
726 do {
727 pnext = pptr->pnext;
728 idf_delobject(our_idf, pptr);
729 } while ((pptr = pnext) != NULL);
730 }
731 /* add to header */
732 if (our_idf->hrem == NULL ||
733 (i = strlen(our_idf->hrem)-strlen(ADD_HEADER)) < 0 ||
734 strcmp(our_idf->hrem+i, ADD_HEADER))
735 idf_add2hdr(our_idf, ADD_HEADER);
736 /* gather zone surfaces */
737 for (i = 0; surf_type[i].pname != NULL; i++)
738 for (pptr = idf_getobject(our_idf, surf_type[i].pname);
739 pptr != NULL; pptr = pptr->pnext) {
740 IDF_FIELD *fptr = idf_getfield(pptr,
741 surf_type[i].zone_fld);
742 if (fptr == NULL) {
743 fputs(progname, stderr);
744 fputs(": warning - missing zone field\n", stderr);
745 continue;
746 }
747 if (add2zone(pptr, fptr->val) == NULL)
748 return(1);
749 }
750 /* add subsurfaces */
751 for (pptr = idf_getobject(our_idf, SUBSURF_PNAME);
752 pptr != NULL; pptr = pptr->pnext)
753 if (add_subsurf(pptr) == NULL)
754 return(1);
755 /* run rcontrib on each zone */
756 if (!compute_zones())
757 return(1);
758 /* write out modified IDF */
759 if (!idf_write(our_idf, revIDF, incl_comments)) {
760 fputs(progname, stderr);
761 fputs(": error writing IDF '", stderr);
762 fputs(revIDF, stderr);
763 fputs("'\n", stderr);
764 return(1);
765 }
766 return(0); /* finito! */
767 userr:
768 fputs("Usage: ", stderr);
769 fputs(progname, stderr);
770 fputs(" [-c][-s Ksamps] Model.idf [Revised.idf]\n", stderr);
771 return(1);
772 }
