root/radiance/src/util/do_zone.tcl
Sat Feb 22 02:07:30 2003 UTC (22 years, 7 months ago) by greg
CVS Tags: HEAD, rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Thu May 30 16:15:27 1996 UTC (29 years, 4 months ago) by greg
minor change to message line after running getbbox.
Fri May 17 14:59:17 1996 UTC (29 years, 5 months ago) by greg
Changes since 2.4: +26 -2 lines
added "Auto" button to compute bounding box using getbbox
Tue Nov 1 20:01:58 1994 UTC (30 years, 11 months ago) by greg
minor change
Fri Oct 28 20:14:41 1994 UTC (30 years, 11 months ago) by greg
added local grab to some getfile procedure
Fri Oct 28 10:43:34 1994 UTC (30 years, 11 months ago) by greg
Changes since 2.1: +2 -3 lines
Diff to previous 2.1
fixed size defaults for smaller dispaly
Thu Oct 27 15:56:10 1994 UTC (30 years, 11 months ago) by greg
Links to HEAD: (view) (download) (as text) (annotate) Links to MAIN: (view) (download) (as text) (annotate)
