root/radiance/src/util/do_results3.6.tcl
Sat Feb 22 02:07:30 2003 UTC (22 years, 8 months ago) by greg
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9
Tue Oct 17 21:28:12 1995 UTC (30 years ago) by greg
Thu Oct 5 13:35:31 1995 UTC (30 years ago) by greg
added -C option to ra_ps conversion
Thu Sep 28 14:11:53 1995 UTC (30 years ago) by greg
Changes since 2.8: +11 -8 lines
added color PostScript output
Thu Sep 21 10:51:30 1995 UTC (30 years, 1 month ago) by greg
Changes since 2.7: +6 -8 lines
minor fixes for RAWFILE variable
Thu Sep 21 10:19:54 1995 UTC (30 years, 1 month ago) by greg
Changes since 2.6: +6 -8 lines
Wed Sep 13 14:24:16 1995 UTC (30 years, 1 month ago) by greg
made changes appropriate for addition of RAWFILE and ZFILE to rad
Wed Sep 13 13:34:02 1995 UTC (30 years, 1 month ago) by greg
Changes since 2.4: +35 -11 lines
Tue Mar 14 10:16:46 1995 UTC (30 years, 7 months ago) by greg
added update of "alldone" to "list_views" procedure
Wed Feb 22 20:48:51 1995 UTC (30 years, 8 months ago) by greg
changed default of dialog box to affirmative
Sun Nov 6 21:35:52 1994 UTC (30 years, 11 months ago) by greg
fixed message update when screen resizing is necessary
Thu Oct 27 15:56:08 1994 UTC (30 years, 11 months ago) by greg
Links to HEAD: (view) (download) (as text) (annotate) Links to rad3R6: (view) (download) (as text) (annotate)
