root/radiance/src/util/do_options.tcl
Fri Aug 1 02:18:42 2014 UTC (11 years, 2 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Updated size of ambient values in new format
Sat Feb 22 02:07:30 2003 UTC (22 years, 7 months ago) by greg
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2
Fri May 17 13:58:35 1996 UTC (29 years, 5 months ago) by greg
moved globbing values to trad.wsh main file
Tue Oct 17 21:28:09 1995 UTC (30 years ago) by greg
Wed Feb 22 20:48:49 1995 UTC (30 years, 7 months ago) by greg
changed default of dialog box to affirmative
Tue Feb 7 12:01:17 1995 UTC (30 years, 8 months ago) by greg
made amb_delete slightly less sensitive to small ambient files
Mon Dec 5 14:29:46 1994 UTC (30 years, 10 months ago) by greg
minor spelling fix in dialog box
Fri Oct 28 20:14:36 1994 UTC (30 years, 11 months ago) by greg
Diff to previous 2.1
added local grab to some getfile procedure
Thu Oct 27 15:56:07 1994 UTC (30 years, 11 months ago) by greg
Links to HEAD: (view) (download) (as text) (annotate) Links to rad4R2P1: (view) (download) (as text) (annotate)
