root/radiance/src/util/do_action.tcl
Revision: 2.13
Committed: Fri Jun 1 22:55:14 2012 UTC (13 years, 4 months ago) by greg
Content type: application/x-tcl
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R2P1, rad4R2P2, HEAD
Changes since 2.12: +35 -21 lines
Added number of processes control to trad
# User Rev Content
1 greg 2.13 # RCSid: $Id: do_action.tcl,v 2.12 2005/02/16 05:40:12 greg Exp $
2 greg 2.1 #
3     # Action screen for trad
4     #
5
6 greg 2.6 set batch_fmt "Process %d on %s started"
7     set hostname [exec hostname]
8 greg 2.13 set nproc 1
9 greg 2.6
10 greg 2.1 proc make_script {} { # make run script
11     global scname rpview curmess
12 greg 2.12 set rfn /tmp/rf[pid]
13 greg 2.1 if {! [save_vars $rfn]} {
14     beep
15     set curmess "Cannot save variables to temporary file!"
16     return
17     }
18     set radcom {rad -n}
19     if {"$rpview" != " ALL"} {
20     lappend radcom -v $rpview
21     }
22     if {"$scname" == {}} {
23 greg 2.12 set rof /tmp/ro[pid]
24 greg 2.1 } else {
25     set rof $scname
26     }
27     lappend radcom $rfn > $rof
28     set badrun [catch "exec $radcom" curmess]
29     if {"$scname" == {}} {
30     if {! $badrun} {
31     view_txt $rof
32     }
33     exec rm $rof
34     }
35     exec rm $rfn
36     }
37
38     proc make_oct args { # Make octree file ($args is {-t} or {})
39     global radvar curmess
40     if {"$radvar(scene)" == {} && "$radvar(illum)" == {}} {
41     set fi [open "|make $radvar(OCTREE) $args" r]
42     while {[gets $fi curmess] >= 0} { update ; after 1000 }
43     catch {close $fi} curmess
44     }
45     if {"$args" == {}} {
46     run_rad -v 0
47     } else {
48     run_rad $args
49     }
50     }
51
52 greg 2.13 proc set_nproc v { # set number of processes
53     global nproc
54     set nproc $v
55     }
56
57 greg 2.1 proc run_rad args { # Run rad command with given arguments
58     global curmess
59 greg 2.12 set rfn /tmp/rf[pid]
60 greg 2.1 if {! [save_vars $rfn]} {
61     beep
62     set curmess "Cannot save variables to temporary file!"
63     return
64     }
65     set ot [file mtime $rfn]
66     set fi [open "|rad $args $rfn" r]
67     while {[gets $fi curmess] >= 0} { update ; after 1000 }
68     if {! [catch {close $fi} curmess] && [file mtime $rfn] > $ot} {
69     load_vars $rfn {view}
70     make_vmenus
71     }
72     exec rm $rfn
73     }
74
75     proc run_batch {} { # start rendering in background
76 greg 2.13 global rpview bfname batch_pid curmess rifname mywin batch_fmt hostname nproc
77 greg 2.1 if {! [chksave]} {return}
78     if [catch {set fo [open $bfname w]} curmess] {
79     return
80     }
81     # Make space for PID to be written later
82 greg 2.7 puts $fo \
83     " "
84 greg 2.1 if {$rpview == " ALL"} {
85 greg 2.13 set radcom "rad -N $nproc"
86 greg 2.1 } else {
87 greg 2.13 set radcom "rad -v $rpview -N $nproc"
88 greg 2.1 }
89     lappend radcom "[file tail $rifname]"
90     # Put out command
91     puts $fo $radcom
92     flush $fo
93     # Execute in background
94     set batch_pid [eval exec $radcom >>& $bfname &]
95     # Now, write PID and close file
96     seek $fo 0
97 greg 2.6 puts -nonewline $fo "[format $batch_fmt $batch_pid $hostname]\
98     [exec date]"
99 greg 2.1 close $fo
100     set curmess "Batch rendering process $batch_pid started."
101     # Correct button stati
102     $mywin.rbst configure -state disabled
103     $mywin.rbki configure -state normal
104     $mywin.rbce configure -state normal
105     $mywin.rbvmb configure -state disabled
106     }
107
108     proc kill_batch {} { # kill batch rendering
109     global batch_pid env curmess mywin
110     # Kill batch process and children
111     switch -glob [exec uname] {
112     SunOS -
113     ULTRIX {set ps "ps -lg"}
114 greg 2.4 default {set ps "ps -lu $env(LOGNAME)"}
115 greg 2.1 }
116     set fi [open "|$ps" r]
117     gets $fi li
118     regexp -indices -nocase { *PID} $li pidsec
119     regexp -indices -nocase { *PPID} $li ppidsec
120     while {[gets $fi li] >= 0} {
121     lappend plist "[eval string range {$li} $pidsec]\
122     [eval string range {$li} $ppidsec]"
123     }
124     if [catch {close $fi} curmess] {
125     return
126     }
127     set plist [lsort $plist]
128     set procs $batch_pid
129     # Two passes required when process id's go into recycling
130     for {set i 0} {$i < 2} {incr i} {
131     foreach pp $plist {
132     if {[lsearch -exact $procs [lindex $pp 1]] >= 0 &&
133     ($i == 0 || [lsearch -exact $procs \
134     [lindex $pp 0]] < 0)} {
135     lappend procs [lindex $pp 0]
136     }
137     }
138     }
139     if {! [catch {eval exec kill $procs} curmess]} {
140     set curmess "Batch process $batch_pid and children killed."
141     }
142     # change modes
143     $mywin.rbki configure -state disabled
144     $mywin.rbst configure -state normal
145     $mywin.rbvmb configure -state normal
146     set batch_pid 0
147     }
148
149     proc make_vmenus {} { # make/update view menus
150     global mywin radvar rvview
151     if {"$radvar(view)" == {}} {
152     set rvview X
153     } else {
154     set rvview [lindex [lindex $radvar(view) 0] 0]
155     }
156     catch {destroy $mywin.rivmb.m}
157 greg 2.2 catch {destroy $mywin.rbvmb.m}
158 greg 2.1 if {[llength $radvar(view)] < 2} {
159     $mywin.rivmb configure -state disabled
160 greg 2.2 return
161 greg 2.1 }
162 greg 2.2 menu $mywin.rivmb.m
163     $mywin.rivmb configure -menu $mywin.rivmb.m -state normal
164     foreach v $radvar(view) {
165     $mywin.rivmb.m add radiobutton -label [lindex $v 0] \
166     -variable rvview -value [lindex $v 0]
167     }
168     menu $mywin.rbvmb.m
169 greg 2.5 $mywin.rbvmb configure -menu $mywin.rbvmb.m
170 greg 2.2 $mywin.rbvmb.m add radiobutton -label ALL \
171     -variable rpview -value " ALL"
172     $mywin.rbvmb.m add separator
173     foreach v $radvar(view) {
174     $mywin.rbvmb.m add radiobutton -label [lindex $v 0] \
175     -variable rpview -value [lindex $v 0]
176 greg 2.1 }
177     }
178
179     proc do_action w { # Action screen
180 greg 2.13 global rifname rvview rpview radvar bfname batch_pid nproc \
181 greg 2.6 curmess scname mywin alldone batch_fmt hostname
182 greg 2.1 if {"$w" == "done"} {
183 greg 2.8 unset rvview rpview bfname batch_pid mywin
184 greg 2.1 return
185     }
186     set bfname [file rootname [file tail $rifname]].err
187     frame $w
188     set mywin $w
189     # Generate octree
190     label $w.octl -text {Compile scene only}
191     place $w.octl -relx .1429 -rely .0610
192     button $w.octb -text oconv -relief raised -command make_oct
193     place $w.octb -relwidth .1071 -relheight .0610 -relx .4643 -rely .0610
194     helplink $w.octb trad action oconv
195     button $w.octt -text Touch -relief raised -command {make_oct -t}
196     place $w.octt -relwidth .1071 -relheight .0610 -relx .7143 -rely .0610
197     helplink $w.octt trad action touch
198     button $w.octf -text Force -relief raised -command \
199     {catch {exec rm -f $radvar(OCTREE)} ; make_oct}
200     place $w.octf -relwidth .1071 -relheight .0610 -relx .5893 -rely .0610
201     helplink $w.octf trad action force
202     # Render interactively
203     label $w.ril -text {Render interactively}
204 greg 2.13 place $w.ril -relx .1429 -rely .2329
205 greg 2.11 button $w.rirv -text rvu -relief raised \
206 greg 2.13 -command {run_rad -v $rvview -o x11 -N $nproc}
207     place $w.rirv -relwidth .1071 -relheight .0610 -relx .4643 -rely .2329
208 greg 2.11 helplink $w.rirv trad action rvu
209 greg 2.1 label $w.rivl -text View:
210 greg 2.13 place $w.rivl -relx .6072 -rely .2329
211 greg 2.1 menubutton $w.rivmb -textvariable rvview -anchor w -relief raised
212 greg 2.13 place $w.rivmb -relwidth .1071 -relheight .0610 -relx .7143 -rely .2329
213 greg 2.1 helplink $w.rivmb trad action view
214 greg 2.13 # Number of processes
215     label $w.rnpl -text {Number of processes:}
216     place $w.rnpl -relx .1429 -rely .3394
217     scale $w.rnps -showvalue yes -from 1 -to 64 \
218     -orient horizontal -command set_nproc
219     $w.rnps set $nproc
220     place $w.rnps -relwidth .5550 -relheight .1200 -relx .3683 -rely .3000
221     helplink $w.rnps trad action processes
222 greg 2.1 # Render in background
223     label $w.rbl -text {Render in background}
224 greg 2.13 place $w.rbl -relx .1429 -rely .4458
225 greg 2.1 button $w.rbst -text Start -relief raised -command run_batch
226 greg 2.13 place $w.rbst -relwidth .1071 -relheight .0610 -relx .4643 -rely .4458
227 greg 2.1 helplink $w.rbst trad action start
228     label $w.rbvl -text View:
229 greg 2.13 place $w.rbvl -relx .6072 -rely .4458
230 greg 2.1 menubutton $w.rbvmb -textvariable rpview -anchor w -relief raised
231 greg 2.13 place $w.rbvmb -relwidth .1071 -relheight .0610 -relx .7143 -rely .4458
232 greg 2.1 helplink $w.rbvmb trad action view
233     button $w.rbki -text Kill -relief raised -command kill_batch
234 greg 2.13 place $w.rbki -relwidth .1071 -relheight .0610 -relx .4643 -rely .5668
235 greg 2.1 helplink $w.rbki trad action kill
236     button $w.rbce -text "Check errors" -relief raised \
237     -command {view_txt $bfname}
238 greg 2.13 place $w.rbce -relwidth .1786 -relheight .0610 -relx .6429 -rely .5668
239 greg 2.1 helplink $w.rbce trad action checkerr
240 greg 2.9 if [file isfile $bfname] {
241 greg 2.1 set fi [open $bfname r]
242 greg 2.8 if {[scan [gets $fi] $batch_fmt batch_pid batch_host] != 2} {
243     set batch_host unknown
244     set radcom {}
245     } else {
246     gets $fi radcom
247     }
248 greg 2.1 close $fi
249 greg 2.6 if [string match "rad -v *" $radcom] {
250     set rpview [lindex $radcom 2]
251     } else {
252     set rpview " ALL"
253     }
254     if {"$hostname" != "$batch_host"} {
255 greg 2.1 if $alldone {
256 greg 2.6 set curmess "Batch rendering finished\
257 greg 2.7 on $batch_host."
258 greg 2.6 } else {
259 greg 2.7 set curmess "Batch rendering on\
260     $batch_host -- status UNKNOWN."
261 greg 2.6 $w.rbst configure -state disabled
262     $w.rbvmb configure -state disabled
263     }
264     set batch_pid 0
265     $w.rbki configure -state disabled
266     } elseif {[catch {exec /bin/kill -0 $batch_pid}]} {
267     if $alldone {
268 greg 2.1 set curmess "Batch rendering finished."
269     } else {
270     set curmess "Batch rendering stopped."
271     }
272     set batch_pid 0
273     set rpview " ALL"
274     $w.rbki configure -state disabled
275     } else {
276     set curmess "Batch rendering process $batch_pid running."
277     $w.rbst configure -state disabled
278     $w.rbvmb configure -state disabled
279     }
280     } else {
281     set curmess "No batch rendering in progress."
282     set batch_pid 0
283     set rpview " ALL"
284     $w.rbki configure -state disabled
285     $w.rbce configure -state disabled
286     }
287     make_vmenus
288     # Dry run
289     label $w.drl -text {Dry run}
290 greg 2.13 place $w.drl -relx .1429 -rely .7357
291 greg 2.1 button $w.drsc -text Script -relief raised -command make_script
292 greg 2.13 place $w.drsc -relwidth .1071 -relheight .0610 -relx .4643 -rely .7357
293 greg 2.1 entry $w.drsf -textvariable scname -relief sunken
294 greg 2.13 place $w.drsf -relwidth .2143 -relheight .0610 -relx .6429 -rely .7357
295 greg 2.1 helplink "$w.drsc $w.drsf" trad action script
296     button $w.drvw -text Edit -relief raised -command {view_txt $scname}
297 greg 2.13 place $w.drvw -relwidth .1071 -relheight .0610 -relx .4643 -rely .8577
298 greg 2.1 helplink $w.drvw trad action edit
299     button $w.drdel -text Delete -relief raised \
300     -command {catch {exec rm $scname < /dev/null} curmess}
301 greg 2.13 place $w.drdel -relwidth .1071 -relheight .0610 -relx .6429 -rely .8577
302 greg 2.1 helplink $w.drdel trad action delete
303     }
