root/radiance/src/util/dctimestep.c
Revision: 2.50
Committed: Sat Mar 1 04:50:13 2025 UTC (7 months, 2 weeks ago) by greg
Changes since 2.49: +4 -1 lines
perf: Added flockfile() calls to reduce mutex overhead
2 static const char RCSid[] = "$Id: dctimestep.c,v 2.49 2022/03/11 02:44:33 greg Exp $";
5 * Compute time-step result using Daylight Coefficient method.
6 *
7 * G. Ward
8 */
9
10 #include <ctype.h>
11 #include "platform.h"
12 #include "standard.h"
13 #include "cmatrix.h"
14 #include "platform.h"
15 #include "resolu.h"
16
17 char *progname; /* global argv[0] */
18
19 /* Sum together a set of images and write result to fout */
20 static int
21 sum_images(const char *fspec, const CMATRIX *cv, FILE *fout)
22 {
23 int myDT = DTfromHeader;
24 COLR *scanline = NULL;
25 CMATRIX *pmat = NULL;
26 int myXR=0, myYR=0;
27 int i, y;
28
29 if (cv->ncols != 1)
30 error(INTERNAL, "expected vector in sum_images()");
31 for (i = 0; i < cv->nrows; i++) {
32 const COLORV *scv = cv_lval(cv,i);
33 int flat_file = 0;
34 char fname[1024];
35 FILE *fp;
36 long data_start;
37 int dt, xr, yr;
38 COLORV *psp;
39 char *err;
40 /* check for zero */
41 if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) &&
42 (myDT != DTfromHeader) | (i < cv->nrows-1))
43 continue;
44 /* open next picture */
45 sprintf(fname, fspec, i);
46 if ((fp = fopen(fname, "rb")) == NULL) {
47 sprintf(errmsg, "cannot open picture '%s'", fname);
48 error(SYSTEM, errmsg);
49 }
50 #ifdef getc_unlocked
51 flockfile(fp);
52 #endif
53 dt = DTfromHeader;
54 if ((err = cm_getheader(&dt, NULL, NULL, NULL, NULL, fp)) != NULL)
55 error(USER, err);
56 if ((dt != DTrgbe) & (dt != DTxyze) ||
57 !fscnresolu(&xr, &yr, fp)) {
58 sprintf(errmsg, "file '%s' not a picture", fname);
59 error(USER, errmsg);
60 }
61 if (myDT == DTfromHeader) { /* on first one */
62 myDT = dt;
63 myXR = xr; myYR = yr;
64 scanline = (COLR *)malloc(sizeof(COLR)*myXR);
65 if (scanline == NULL)
66 error(SYSTEM, "out of memory in sum_images()");
67 pmat = cm_alloc(myYR, myXR);
68 memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR);
69 /* finish header */
70 fputformat(cm_fmt_id[myDT], fout);
71 fputc('\n', fout);
72 fflush(fout);
73 } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) {
74 sprintf(errmsg, "picture '%s' format/size mismatch",
75 fname);
76 error(USER, errmsg);
77 }
78 /* flat file check */
79 if ((data_start = ftell(fp)) > 0 && fseek(fp, 0L, SEEK_END) == 0) {
80 flat_file = (ftell(fp) == data_start + sizeof(COLR)*xr*yr);
81 if (fseek(fp, data_start, SEEK_SET) < 0) {
82 sprintf(errmsg, "cannot seek on picture '%s'", fname);
83 error(SYSTEM, errmsg);
84 }
85 }
86 psp = pmat->cmem;
87 for (y = 0; y < yr; y++) { /* read it in */
88 COLOR col;
89 int x;
90 if (flat_file ? getbinary(scanline, sizeof(COLR), xr, fp) != xr :
91 freadcolrs(scanline, xr, fp) < 0) {
92 sprintf(errmsg, "error reading picture '%s'",
93 fname);
94 error(SYSTEM, errmsg);
95 }
96 /* sum in scanline */
97 for (x = 0; x < xr; x++, psp += 3) {
98 if (!scanline[x][EXP])
99 continue; /* skip zeroes */
100 colr_color(col, scanline[x]);
101 multcolor(col, scv);
102 addcolor(psp, col);
103 }
104 }
105 fclose(fp); /* done this picture */
106 }
107 free(scanline);
108 i = cm_write(pmat, myDT, fout); /* write picture */
109 cm_free(pmat); /* free data */
110 return(i);
111 }
112
113 /* adjust matrix dimensions according to user size(s) */
114 static int
115 alt_dim(CMATRIX *cm, int nr, int nc)
116 {
117 if ((nr <= 0) & (nc <= 0))
118 return(0);
119 if ((nr == cm->nrows) & (nc == cm->ncols))
120 return(0);
121 if (nr > 0) {
122 if (nc <= 0)
123 nc = cm->nrows*cm->ncols/nr;
124 if (nr*nc != cm->nrows*cm->ncols) {
125 fprintf(stderr, "Bad dimensions: %dx%d != %dx%d\n",
126 nr, nc, cm->nrows, cm->ncols);
127 return(-1);
128 }
129 } else /* nc > 0 */ {
130 nr = cm->nrows*cm->ncols/nc;
131 if (nc*nr != cm->nrows*cm->ncols) {
132 fprintf(stderr, "Bad dimensions: %d does not divide %dx%d evenly\n",
133 nc, cm->nrows, cm->ncols);
134 return(-1);
135 }
136 }
137 cm->nrows = nr;
138 cm->ncols = nc;
139 return(1);
140 }
141
142 /* check to see if a string contains a %d or %o specification */
143 static int
144 hasNumberFormat(const char *s)
145 {
146 if (s == NULL)
147 return(0);
148
149 while (*s) {
150 while (*s != '%')
151 if (!*s++)
152 return(0);
153 if (*++s == '%') { /* ignore "%%" */
154 ++s;
155 continue;
156 }
157 while (isdigit(*s)) /* field length */
158 ++s;
159 /* field we'll use? */
160 if ((*s == 'd') | (*s == 'i') | (*s == 'o') |
161 (*s == 'x') | (*s == 'X'))
162 return(1);
163 }
164 return(0); /* didn't find one */
165 }
166
167 int
168 main(int argc, char *argv[])
169 {
170 int skyfmt = DTfromHeader;
171 int outfmt = DTascii;
172 int headout = 1;
173 int nsteps = 0;
174 char *ofspec = NULL;
175 FILE *ofp = stdout;
176 int xres=0, yres=0;
177 CMATRIX *cmtx; /* component vector/matrix result */
178 char fnbuf[256];
179 int a, i;
180
181 progname = argv[0];
182 /* get options */
183 for (a = 1; a < argc && argv[a][0] == '-'; a++)
184 switch (argv[a][1]) {
185 case 'n':
186 nsteps = atoi(argv[++a]);
187 if (nsteps < 0)
188 goto userr;
189 skyfmt = nsteps ? DTascii : DTfromHeader;
190 break;
191 case 'h':
192 headout = !headout;
193 break;
194 case 'i':
195 switch (argv[a][2]) {
196 case 'f':
197 skyfmt = DTfloat;
198 break;
199 case 'd':
200 skyfmt = DTdouble;
201 break;
202 case 'a':
203 skyfmt = DTascii;
204 break;
205 default:
206 goto userr;
207 }
208 break;
209 case 'o':
210 switch (argv[a][2]) {
211 case '\0': /* output specification (not format) */
212 ofspec = argv[++a];
213 break;
214 case 'f':
215 outfmt = DTfloat;
216 break;
217 case 'd':
218 outfmt = DTdouble;
219 break;
220 case 'a':
221 outfmt = DTascii;
222 break;
223 case 'c':
224 outfmt = DTrgbe;
225 break;
226 default:
227 goto userr;
228 }
229 break;
230 case 'x':
231 xres = atoi(argv[++a]);
232 break;
233 case 'y':
234 yres = atoi(argv[++a]);
235 break;
236 default:
237 goto userr;
238 }
239 if ((argc-a < 1) | (argc-a > 4))
240 goto userr;
241
242 if (argc-a > 2) { /* VTDs expression */
243 CMATRIX *smtx, *Dmat, *Tmat, *imtx;
244 const char *ccp;
245 /* get sky vector/matrix */
246 smtx = cm_load(argv[a+3], 0, nsteps, skyfmt);
247 nsteps = smtx->ncols;
248 /* load BSDF */
249 if (argv[a+1][0] != '!' &&
250 (ccp = strrchr(argv[a+1], '.')) != NULL &&
251 !strcasecmp(ccp+1, "XML"))
252 Tmat = cm_loadBTDF(argv[a+1]);
253 else
254 Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader);
255 /* load Daylight matrix */
256 Dmat = cm_load(argv[a+2], Tmat->ncols,
257 smtx->nrows, DTfromHeader);
258 /* multiply vector through */
259 imtx = cm_multiply(Dmat, smtx);
260 cm_free(Dmat); cm_free(smtx);
261 cmtx = cm_multiply(Tmat, imtx);
262 cm_free(Tmat);
263 cm_free(imtx);
264 } else { /* sky vector/matrix only */
265 cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt);
266 nsteps = cmtx->ncols;
267 }
268 /* prepare output stream */
269 if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) {
270 sprintf(fnbuf, ofspec, 1);
271 ofspec = fnbuf;
272 }
273 if (ofspec != NULL && !hasNumberFormat(ofspec)) {
274 if ((ofp = fopen(ofspec, "w")) == NULL) {
275 fprintf(stderr, "%s: cannot open '%s' for output\n",
276 progname, ofspec);
277 return(1);
278 }
279 ofspec = NULL; /* only need to open once */
280 }
281 if (hasNumberFormat(argv[a])) { /* generating image(s) */
282 if (outfmt != DTrgbe) {
283 error(WARNING, "changing output type to -oc");
284 outfmt = DTrgbe;
285 }
286 if (ofspec == NULL) {
287 SET_FILE_BINARY(ofp);
288 newheader("RADIANCE", ofp);
289 printargs(argc, argv, ofp);
290 fputnow(ofp);
291 }
292 if (nsteps > 1) /* multiple output frames? */
293 for (i = 0; i < nsteps; i++) {
294 CMATRIX *cvec = cm_column(cmtx, i);
295 if (ofspec != NULL) {
296 sprintf(fnbuf, ofspec, i);
297 if ((ofp = fopen(fnbuf, "wb")) == NULL) {
298 fprintf(stderr,
299 "%s: cannot open '%s' for output\n",
300 progname, fnbuf);
301 return(1);
302 }
303 newheader("RADIANCE", ofp);
304 printargs(argc, argv, ofp);
305 fputnow(ofp);
306 }
307 fprintf(ofp, "FRAME=%d\n", i);
308 if (!sum_images(argv[a], cvec, ofp))
309 return(1);
310 if (ofspec != NULL) {
311 if (fclose(ofp) == EOF) {
312 fprintf(stderr,
313 "%s: error writing to '%s'\n",
314 progname, fnbuf);
315 return(1);
316 }
317 ofp = stdout;
318 }
319 cm_free(cvec);
320 }
321 else if (!sum_images(argv[a], cmtx, ofp))
322 return(1);
323 } else { /* generating vector/matrix */
324 CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader);
325 CMATRIX *rmtx = cm_multiply(Vmat, cmtx);
326 cm_free(Vmat);
327 if (ofspec != NULL) { /* multiple vector files? */
328 const char *wtype = (outfmt==DTascii) ? "w" : "wb";
329 for (i = 0; i < nsteps; i++) {
330 CMATRIX *rvec = cm_column(rmtx, i);
331 if (alt_dim(rvec, yres, xres) < 0)
332 return(1);
333 sprintf(fnbuf, ofspec, i);
334 if ((ofp = fopen(fnbuf, wtype)) == NULL) {
335 fprintf(stderr,
336 "%s: cannot open '%s' for output\n",
337 progname, fnbuf);
338 return(1);
339 }
340 #ifdef getc_unlocked
341 flockfile(ofp);
342 #endif
343 if (headout) { /* header output */
344 newheader("RADIANCE", ofp);
345 printargs(argc, argv, ofp);
346 fputnow(ofp);
347 fprintf(ofp, "FRAME=%d\n", i);
348 if ((outfmt != DTrgbe) & (outfmt != DTxyze)) {
349 fprintf(ofp, "NROWS=%d\n", rvec->nrows);
350 fprintf(ofp, "NCOLS=%d\n", rvec->ncols);
351 fputs("NCOMP=3\n", ofp);
352 }
353 if ((outfmt == DTfloat) | (outfmt == DTdouble))
354 fputendian(ofp);
355 fputformat(cm_fmt_id[outfmt], ofp);
356 fputc('\n', ofp);
357 }
358 cm_write(rvec, outfmt, ofp);
359 if (fclose(ofp) == EOF) {
360 fprintf(stderr,
361 "%s: error writing to '%s'\n",
362 progname, fnbuf);
363 return(1);
364 }
365 ofp = stdout;
366 cm_free(rvec);
367 }
368 } else {
369 #ifdef getc_unlocked
370 flockfile(ofp);
371 #endif
372 if (outfmt != DTascii)
373 SET_FILE_BINARY(ofp);
374 if (alt_dim(rmtx, yres, xres) < 0)
375 return(1);
376 if (headout) { /* header output */
377 newheader("RADIANCE", ofp);
378 printargs(argc, argv, ofp);
379 fputnow(ofp);
380 if ((outfmt != DTrgbe) & (outfmt != DTxyze)) {
381 fprintf(ofp, "NROWS=%d\n", rmtx->nrows);
382 fprintf(ofp, "NCOLS=%d\n", rmtx->ncols);
383 fputs("NCOMP=3\n", ofp);
384 }
385 if ((outfmt == DTfloat) | (outfmt == DTdouble))
386 fputendian(ofp);
387 fputformat(cm_fmt_id[outfmt], ofp);
388 fputc('\n', ofp);
389 }
390 cm_write(rmtx, outfmt, ofp);
391 }
392 cm_free(rmtx);
393 }
394 if (fflush(ofp) == EOF) { /* final clean-up */
395 fprintf(stderr, "%s: write error on output\n", progname);
396 return(1);
397 }
398 cm_free(cmtx);
399 return(0);
400 userr:
401 fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] DCspec [skyf]\n",
402 progname);
403 fprintf(stderr, " or: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] Vspec Tbsdf Dmat.dat [skyf]\n",
404 progname);
405 return(1);
406 }
