root/radiance/src/util/dctimestep.c
Revision: 2.55
Committed: Sat Jun 7 05:09:46 2025 UTC (4 months ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.54: +1 -2 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.55 static const char RCSid[] = "$Id: dctimestep.c,v 2.54 2025/06/06 19:11:21 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Compute time-step result using Daylight Coefficient method.
6     *
7     * G. Ward
8     */
9
10     #include <ctype.h>
11 schorsch 2.37 #include "platform.h"
12 greg 2.1 #include "standard.h"
13 greg 2.28 #include "cmatrix.h"
14 greg 2.1 #include "platform.h"
15     #include "resolu.h"
16
17 greg 2.24 /* Sum together a set of images and write result to fout */
18 greg 2.1 static int
19 greg 2.13 sum_images(const char *fspec, const CMATRIX *cv, FILE *fout)
20 greg 2.1 {
21 greg 2.53 static int runcnt = 0;
22 greg 2.1 int myDT = DTfromHeader;
23 greg 2.38 COLR *scanline = NULL;
24 greg 2.24 CMATRIX *pmat = NULL;
25     int myXR=0, myYR=0;
26 greg 2.1 int i, y;
27
28     if (cv->ncols != 1)
29 greg 2.35 error(INTERNAL, "expected vector in sum_images()");
30 greg 2.53 for (i = cv->nrows; i-- > 0; ) {
31     const int r = runcnt&1 ? i : cv->nrows-1 - i;
32     const COLORV *scv = cv_lval(cv,r);
33 greg 2.39 int flat_file = 0;
34 greg 2.1 char fname[1024];
35     FILE *fp;
36 greg 2.39 long data_start;
37 greg 2.1 int dt, xr, yr;
38     COLORV *psp;
39 greg 2.31 char *err;
40 greg 2.14 /* check for zero */
41 greg 2.19 if ((scv[RED] == 0) & (scv[GRN] == 0) & (scv[BLU] == 0) &&
42 greg 2.53 (myDT != DTfromHeader) | (i > 0))
43 greg 2.14 continue;
44 greg 2.1 /* open next picture */
45 greg 2.53 sprintf(fname, fspec, r);
46 greg 2.31 if ((fp = fopen(fname, "rb")) == NULL) {
47 greg 2.1 sprintf(errmsg, "cannot open picture '%s'", fname);
48     error(SYSTEM, errmsg);
49     }
50 greg 2.50 #ifdef getc_unlocked
51     flockfile(fp);
52     #endif
53 greg 2.31 dt = DTfromHeader;
54 greg 2.45 if ((err = cm_getheader(&dt, NULL, NULL, NULL, NULL, fp)) != NULL)
55 greg 2.31 error(USER, err);
56 greg 2.1 if ((dt != DTrgbe) & (dt != DTxyze) ||
57     !fscnresolu(&xr, &yr, fp)) {
58     sprintf(errmsg, "file '%s' not a picture", fname);
59     error(USER, errmsg);
60     }
61     if (myDT == DTfromHeader) { /* on first one */
62     myDT = dt;
63     myXR = xr; myYR = yr;
64 greg 2.38 scanline = (COLR *)malloc(sizeof(COLR)*myXR);
65 greg 2.1 if (scanline == NULL)
66     error(SYSTEM, "out of memory in sum_images()");
67     pmat = cm_alloc(myYR, myXR);
68     memset(pmat->cmem, 0, sizeof(COLOR)*myXR*myYR);
69 greg 2.2 /* finish header */
70 greg 2.46 fputformat(cm_fmt_id[myDT], fout);
71 greg 2.13 fputc('\n', fout);
72     fflush(fout);
73 greg 2.1 } else if ((dt != myDT) | (xr != myXR) | (yr != myYR)) {
74     sprintf(errmsg, "picture '%s' format/size mismatch",
75     fname);
76     error(USER, errmsg);
77     }
78 greg 2.39 /* flat file check */
79     if ((data_start = ftell(fp)) > 0 && fseek(fp, 0L, SEEK_END) == 0) {
80 greg 2.51 flat_file = (ftell(fp) >= data_start + sizeof(COLR)*xr*yr);
81 greg 2.39 if (fseek(fp, data_start, SEEK_SET) < 0) {
82     sprintf(errmsg, "cannot seek on picture '%s'", fname);
83     error(SYSTEM, errmsg);
84     }
85     }
86 greg 2.1 psp = pmat->cmem;
87     for (y = 0; y < yr; y++) { /* read it in */
88 greg 2.38 COLOR col;
89 greg 2.1 int x;
90 greg 2.39 if (flat_file ? getbinary(scanline, sizeof(COLR), xr, fp) != xr :
91     freadcolrs(scanline, xr, fp) < 0) {
92 greg 2.1 sprintf(errmsg, "error reading picture '%s'",
93     fname);
94     error(SYSTEM, errmsg);
95     }
96     /* sum in scanline */
97     for (x = 0; x < xr; x++, psp += 3) {
98 greg 2.38 if (!scanline[x][EXP])
99     continue; /* skip zeroes */
100     colr_color(col, scanline[x]);
101     multcolor(col, scv);
102     addcolor(psp, col);
103 greg 2.1 }
104     }
105     fclose(fp); /* done this picture */
106     }
107     free(scanline);
108 greg 2.30 i = cm_write(pmat, myDT, fout); /* write picture */
109     cm_free(pmat); /* free data */
110 greg 2.53 ++runcnt; /* for zig-zagging */
111 greg 2.30 return(i);
112 greg 2.1 }
113
114 greg 2.49 /* adjust matrix dimensions according to user size(s) */
115     static int
116     alt_dim(CMATRIX *cm, int nr, int nc)
117     {
118     if ((nr <= 0) & (nc <= 0))
119     return(0);
120     if ((nr == cm->nrows) & (nc == cm->ncols))
121     return(0);
122     if (nr > 0) {
123     if (nc <= 0)
124     nc = cm->nrows*cm->ncols/nr;
125     if (nr*nc != cm->nrows*cm->ncols) {
126     fprintf(stderr, "Bad dimensions: %dx%d != %dx%d\n",
127     nr, nc, cm->nrows, cm->ncols);
128     return(-1);
129     }
130     } else /* nc > 0 */ {
131     nr = cm->nrows*cm->ncols/nc;
132     if (nc*nr != cm->nrows*cm->ncols) {
133     fprintf(stderr, "Bad dimensions: %d does not divide %dx%d evenly\n",
134     nc, cm->nrows, cm->ncols);
135     return(-1);
136     }
137     }
138     cm->nrows = nr;
139     cm->ncols = nc;
140     return(1);
141     }
142
143 greg 2.11 /* check to see if a string contains a %d or %o specification */
144     static int
145     hasNumberFormat(const char *s)
146 greg 2.1 {
147 greg 2.24 if (s == NULL)
148     return(0);
149
150 greg 2.18 while (*s) {
151     while (*s != '%')
152     if (!*s++)
153     return(0);
154     if (*++s == '%') { /* ignore "%%" */
155     ++s;
156     continue;
157     }
158     while (isdigit(*s)) /* field length */
159     ++s;
160     /* field we'll use? */
161     if ((*s == 'd') | (*s == 'i') | (*s == 'o') |
162     (*s == 'x') | (*s == 'X'))
163     return(1);
164     }
165     return(0); /* didn't find one */
166 greg 2.1 }
167
168     int
169     main(int argc, char *argv[])
170     {
171 greg 2.34 int skyfmt = DTfromHeader;
172 greg 2.30 int outfmt = DTascii;
173 greg 2.34 int headout = 1;
174     int nsteps = 0;
175 greg 2.24 char *ofspec = NULL;
176     FILE *ofp = stdout;
177 greg 2.47 int xres=0, yres=0;
178 greg 2.24 CMATRIX *cmtx; /* component vector/matrix result */
179     char fnbuf[256];
180     int a, i;
181 greg 2.54 /* set global progname */
182     fixargv0(argv[0]);
183 greg 2.24 /* get options */
184 greg 2.25 for (a = 1; a < argc && argv[a][0] == '-'; a++)
185     switch (argv[a][1]) {
186 greg 2.24 case 'n':
187     nsteps = atoi(argv[++a]);
188 greg 2.31 if (nsteps < 0)
189 greg 2.24 goto userr;
190 greg 2.34 skyfmt = nsteps ? DTascii : DTfromHeader;
191     break;
192     case 'h':
193     headout = !headout;
194 greg 2.24 break;
195 greg 2.25 case 'i':
196     switch (argv[a][2]) {
197     case 'f':
198     skyfmt = DTfloat;
199     break;
200     case 'd':
201     skyfmt = DTdouble;
202     break;
203     case 'a':
204     skyfmt = DTascii;
205     break;
206     default:
207     goto userr;
208     }
209     break;
210 greg 2.30 case 'o':
211     switch (argv[a][2]) {
212     case '\0': /* output specification (not format) */
213     ofspec = argv[++a];
214     break;
215     case 'f':
216     outfmt = DTfloat;
217     break;
218     case 'd':
219     outfmt = DTdouble;
220     break;
221     case 'a':
222     outfmt = DTascii;
223     break;
224 greg 2.43 case 'c':
225     outfmt = DTrgbe;
226     break;
227 greg 2.30 default:
228     goto userr;
229     }
230     break;
231 greg 2.47 case 'x':
232     xres = atoi(argv[++a]);
233     break;
234     case 'y':
235     yres = atoi(argv[++a]);
236     break;
237 greg 2.24 default:
238     goto userr;
239     }
240     if ((argc-a < 1) | (argc-a > 4))
241     goto userr;
242 greg 2.1
243 greg 2.24 if (argc-a > 2) { /* VTDs expression */
244 greg 2.36 CMATRIX *smtx, *Dmat, *Tmat, *imtx;
245     const char *ccp;
246 greg 2.24 /* get sky vector/matrix */
247 greg 2.25 smtx = cm_load(argv[a+3], 0, nsteps, skyfmt);
248 greg 2.35 nsteps = smtx->ncols;
249 greg 2.12 /* load BSDF */
250 greg 2.36 if (argv[a+1][0] != '!' &&
251 greg 2.52 (ccp = strrchr(argv[a+1], '.')) > argv[a+1] &&
252 greg 2.36 !strcasecmp(ccp+1, "XML"))
253     Tmat = cm_loadBTDF(argv[a+1]);
254     else
255     Tmat = cm_load(argv[a+1], 0, 0, DTfromHeader);
256 greg 2.5 /* load Daylight matrix */
257 greg 2.36 Dmat = cm_load(argv[a+2], Tmat->ncols,
258 greg 2.24 smtx->nrows, DTfromHeader);
259 greg 2.1 /* multiply vector through */
260 greg 2.24 imtx = cm_multiply(Dmat, smtx);
261     cm_free(Dmat); cm_free(smtx);
262 greg 2.29 cmtx = cm_multiply(Tmat, imtx);
263     cm_free(Tmat);
264 greg 2.24 cm_free(imtx);
265     } else { /* sky vector/matrix only */
266 greg 2.25 cmtx = cm_load(argv[a+1], 0, nsteps, skyfmt);
267 greg 2.35 nsteps = cmtx->ncols;
268 greg 2.24 }
269     /* prepare output stream */
270     if ((ofspec != NULL) & (nsteps == 1) && hasNumberFormat(ofspec)) {
271 greg 2.52 sprintf(fnbuf, ofspec, 0);
272 greg 2.24 ofspec = fnbuf;
273     }
274     if (ofspec != NULL && !hasNumberFormat(ofspec)) {
275     if ((ofp = fopen(ofspec, "w")) == NULL) {
276     fprintf(stderr, "%s: cannot open '%s' for output\n",
277     progname, ofspec);
278     return(1);
279     }
280     ofspec = NULL; /* only need to open once */
281 greg 2.12 }
282 greg 2.52 if (hasNumberFormat(argv[a])) { /* loading image vector(s) */
283 greg 2.44 if (outfmt != DTrgbe) {
284     error(WARNING, "changing output type to -oc");
285     outfmt = DTrgbe;
286     }
287 greg 2.24 if (ofspec == NULL) {
288     SET_FILE_BINARY(ofp);
289     newheader("RADIANCE", ofp);
290     printargs(argc, argv, ofp);
291     fputnow(ofp);
292     }
293     if (nsteps > 1) /* multiple output frames? */
294     for (i = 0; i < nsteps; i++) {
295     CMATRIX *cvec = cm_column(cmtx, i);
296     if (ofspec != NULL) {
297 greg 2.40 sprintf(fnbuf, ofspec, i);
298 greg 2.24 if ((ofp = fopen(fnbuf, "wb")) == NULL) {
299     fprintf(stderr,
300     "%s: cannot open '%s' for output\n",
301     progname, fnbuf);
302     return(1);
303     }
304     newheader("RADIANCE", ofp);
305     printargs(argc, argv, ofp);
306     fputnow(ofp);
307     }
308 greg 2.40 fprintf(ofp, "FRAME=%d\n", i);
309 greg 2.24 if (!sum_images(argv[a], cvec, ofp))
310     return(1);
311     if (ofspec != NULL) {
312     if (fclose(ofp) == EOF) {
313     fprintf(stderr,
314     "%s: error writing to '%s'\n",
315     progname, fnbuf);
316     return(1);
317     }
318     ofp = stdout;
319     }
320     cm_free(cvec);
321     }
322     else if (!sum_images(argv[a], cmtx, ofp))
323 greg 2.1 return(1);
324 greg 2.52 } else { /* loading view matrix */
325 greg 2.24 CMATRIX *Vmat = cm_load(argv[a], 0, cmtx->nrows, DTfromHeader);
326     CMATRIX *rmtx = cm_multiply(Vmat, cmtx);
327 greg 2.1 cm_free(Vmat);
328 greg 2.30 if (ofspec != NULL) { /* multiple vector files? */
329     const char *wtype = (outfmt==DTascii) ? "w" : "wb";
330 greg 2.24 for (i = 0; i < nsteps; i++) {
331     CMATRIX *rvec = cm_column(rmtx, i);
332 greg 2.49 if (alt_dim(rvec, yres, xres) < 0)
333     return(1);
334 greg 2.40 sprintf(fnbuf, ofspec, i);
335 greg 2.30 if ((ofp = fopen(fnbuf, wtype)) == NULL) {
336 greg 2.24 fprintf(stderr,
337     "%s: cannot open '%s' for output\n",
338     progname, fnbuf);
339     return(1);
340     }
341 greg 2.31 #ifdef getc_unlocked
342     flockfile(ofp);
343     #endif
344 greg 2.34 if (headout) { /* header output */
345     newheader("RADIANCE", ofp);
346     printargs(argc, argv, ofp);
347     fputnow(ofp);
348 greg 2.40 fprintf(ofp, "FRAME=%d\n", i);
349 greg 2.47 if ((outfmt != DTrgbe) & (outfmt != DTxyze)) {
350     fprintf(ofp, "NROWS=%d\n", rvec->nrows);
351     fprintf(ofp, "NCOLS=%d\n", rvec->ncols);
352 greg 2.52 fputncomp(3, ofp);
353 greg 2.47 }
354     if ((outfmt == DTfloat) | (outfmt == DTdouble))
355 greg 2.42 fputendian(ofp);
356 greg 2.46 fputformat(cm_fmt_id[outfmt], ofp);
357 greg 2.34 fputc('\n', ofp);
358     }
359 greg 2.30 cm_write(rvec, outfmt, ofp);
360 greg 2.24 if (fclose(ofp) == EOF) {
361     fprintf(stderr,
362     "%s: error writing to '%s'\n",
363     progname, fnbuf);
364     return(1);
365     }
366     ofp = stdout;
367     cm_free(rvec);
368     }
369 greg 2.30 } else {
370 greg 2.31 #ifdef getc_unlocked
371     flockfile(ofp);
372     #endif
373 greg 2.30 if (outfmt != DTascii)
374     SET_FILE_BINARY(ofp);
375 greg 2.49 if (alt_dim(rmtx, yres, xres) < 0)
376     return(1);
377 greg 2.34 if (headout) { /* header output */
378 greg 2.30 newheader("RADIANCE", ofp);
379     printargs(argc, argv, ofp);
380     fputnow(ofp);
381 greg 2.47 if ((outfmt != DTrgbe) & (outfmt != DTxyze)) {
382     fprintf(ofp, "NROWS=%d\n", rmtx->nrows);
383     fprintf(ofp, "NCOLS=%d\n", rmtx->ncols);
384 greg 2.52 fputncomp(3, ofp);
385 greg 2.47 }
386     if ((outfmt == DTfloat) | (outfmt == DTdouble))
387 greg 2.42 fputendian(ofp);
388 greg 2.46 fputformat(cm_fmt_id[outfmt], ofp);
389 greg 2.30 fputc('\n', ofp);
390     }
391     cm_write(rmtx, outfmt, ofp);
392     }
393 greg 2.24 cm_free(rmtx);
394     }
395     if (fflush(ofp) == EOF) { /* final clean-up */
396     fprintf(stderr, "%s: write error on output\n", progname);
397     return(1);
398 greg 2.1 }
399 greg 2.24 cm_free(cmtx);
400 greg 2.1 return(0);
401 greg 2.24 userr:
402 greg 2.48 fprintf(stderr, "Usage: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] DCspec [skyf]\n",
403 greg 2.24 progname);
404 greg 2.48 fprintf(stderr, " or: %s [-n nsteps][-o ospec][-x xr][-y yr][-i{f|d|h}][-o{f|d|c}] Vspec Tbsdf Dmat.dat [skyf]\n",
405 greg 2.24 progname);
406     return(1);
407 greg 2.1 }
