root/radiance/src/util/cmatrix.c
Revision: 2.5
Committed: Fri May 30 00:00:54 2014 UTC (11 years, 4 months ago) by greg
Changes since 2.4: +62 -18 lines
2 static const char RCSid[] = "$Id: cmatrix.c,v 2.4 2014/05/29 17:28:09 greg Exp $";
5 * Color matrix routines.
6 *
7 * G. Ward
8 */
9
10 #include <ctype.h>
11 #include "standard.h"
12 #include "cmatrix.h"
13 #include "platform.h"
14 #include "resolu.h"
15
16 const char *cm_fmt_id[] = {
17 "unknown", "ascii", "float", "double",
18 COLRFMT, CIEFMT
19 };
20
21 const int cm_elem_size[] = {
22 0, 0, 3*sizeof(float), 3*sizeof(double), 4, 4
23 };
24
25 /* Allocate a color coefficient matrix */
26 CMATRIX *
27 cm_alloc(int nrows, int ncols)
28 {
29 CMATRIX *cm;
30
31 if ((nrows <= 0) | (ncols <= 0))
32 error(USER, "attempt to create empty matrix");
33 cm = (CMATRIX *)malloc(sizeof(CMATRIX) +
34 sizeof(COLOR)*(nrows*ncols - 1));
35 if (cm == NULL)
36 error(SYSTEM, "out of memory in cm_alloc()");
37 cm->nrows = nrows;
38 cm->ncols = ncols;
39 return(cm);
40 }
41
42 /* Resize color coefficient matrix */
43 CMATRIX *
44 cm_resize(CMATRIX *cm, int nrows)
45 {
46 if (nrows == cm->nrows)
47 return(cm);
48 if (nrows <= 0) {
49 cm_free(cm);
50 return(NULL);
51 }
52 cm = (CMATRIX *)realloc(cm, sizeof(CMATRIX) +
53 sizeof(COLOR)*(nrows*cm->ncols - 1));
54 if (cm == NULL)
55 error(SYSTEM, "out of memory in cm_resize()");
56 cm->nrows = nrows;
57 return(cm);
58 }
59
60 typedef struct {
61 int dtype; /* data type */
62 int nrows, ncols; /* matrix size */
63 char *err; /* error message */
64 } CMINFO; /* header info record */
65
66 static int
67 get_cminfo(char *s, void *p)
68 {
69 CMINFO *ip = (CMINFO *)p;
70 char fmt[32];
71 int i;
72
73 if (!strncmp(s, "NCOMP=", 6) && atoi(s+6) != 3) {
74 ip->err = "unexpected # components (must be 3)";
75 return(-1);
76 }
77 if (!strncmp(s, "NROWS=", 6)) {
78 ip->nrows = atoi(s+6);
79 return(0);
80 }
81 if (!strncmp(s, "NCOLS=", 6)) {
82 ip->ncols = atoi(s+6);
83 return(0);
84 }
85 if (!formatval(fmt, s))
86 return(0);
87 for (i = 1; i < DTend; i++)
88 if (!strcmp(fmt, cm_fmt_id[i]))
89 ip->dtype = i;
90 return(0);
91 }
92
93 /* Load header to obtain/check data type and number of columns */
94 char *
95 cm_getheader(int *dt, int *nr, int *nc, FILE *fp)
96 {
97 CMINFO cmi;
98 /* read header */
99 cmi.dtype = DTfromHeader;
100 cmi.nrows = cmi.ncols = 0;
101 cmi.err = "unexpected EOF in header";
102 if (getheader(fp, &get_cminfo, &cmi) < 0)
103 return(cmi.err);
104 if (dt != NULL) { /* get/check data type? */
105 if (cmi.dtype == DTfromHeader) {
106 if (*dt == DTfromHeader)
107 return("missing/unknown data format in header");
108 } else if (*dt == DTfromHeader)
109 *dt = cmi.dtype;
110 else if (*dt != cmi.dtype)
111 return("unexpected data format in header");
112 }
113 if (nr != NULL) { /* get/check #rows? */
114 if (*nr <= 0)
115 *nr = cmi.nrows;
116 else if ((cmi.nrows > 0) & (*nr != cmi.nrows))
117 return("unexpected row count in header");
118 }
119 if (nc != NULL) { /* get/check #columns? */
120 if (*nc <= 0)
121 *nc = cmi.ncols;
122 else if ((cmi.ncols > 0) & (*nc != cmi.ncols))
123 return("unexpected column count in header");
124 }
125 return(NULL);
126 }
127
128 /* Allocate and load a matrix from the given file (or stdin if NULL) */
129 CMATRIX *
130 cm_load(const char *fname, int nrows, int ncols, int dtype)
131 {
132 FILE *fp = stdin;
133 CMATRIX *cm;
134
135 if (fname == NULL)
136 fname = "<stdin>";
137 else if ((fp = fopen(fname, "r")) == NULL) {
138 sprintf(errmsg, "cannot open file '%s'", fname);
139 error(SYSTEM, errmsg);
140 }
141 #ifdef getc_unlocked
142 flockfile(fp);
143 #endif
144 if (dtype != DTascii)
145 SET_FILE_BINARY(fp); /* doesn't really work */
146 if (!dtype | !ncols) { /* expecting header? */
147 char *err = cm_getheader(&dtype, &nrows, &ncols, fp);
148 if (err != NULL)
149 error(USER, err);
150 if (ncols <= 0)
151 error(USER, "unspecified number of columns");
152 }
153 switch (dtype) {
154 case DTascii:
155 case DTfloat:
156 case DTdouble:
157 break;
158 default:
159 error(USER, "unexpected data type in cm_load()");
160 }
161 if (nrows <= 0) { /* don't know length? */
162 int guessrows = 147; /* usually big enough */
163 if ((dtype != DTascii) & (fp != stdin)) {
164 long startpos = ftell(fp);
165 if (fseek(fp, 0L, SEEK_END) == 0) {
166 long endpos = ftell(fp);
167 long elemsiz = 3*(dtype==DTfloat ?
168 sizeof(float) : sizeof(double));
169
170 if ((endpos - startpos) % (ncols*elemsiz)) {
171 sprintf(errmsg,
172 "improper length for binary file '%s'",
173 fname);
174 error(USER, errmsg);
175 }
176 guessrows = (endpos - startpos)/(ncols*elemsiz);
177 if (fseek(fp, startpos, SEEK_SET) < 0) {
178 sprintf(errmsg,
179 "fseek() error on file '%s'",
180 fname);
181 error(SYSTEM, errmsg);
182 }
183 nrows = guessrows; /* we're confident */
184 }
185 }
186 cm = cm_alloc(guessrows, ncols);
187 } else
188 cm = cm_alloc(nrows, ncols);
189 if (cm == NULL) /* XXX never happens */
190 return(NULL);
191 if (dtype == DTascii) { /* read text file */
192 int maxrow = (nrows > 0 ? nrows : 32000);
193 int r, c;
194 for (r = 0; r < maxrow; r++) {
195 if (r >= cm->nrows) /* need more space? */
196 cm = cm_resize(cm, 2*cm->nrows);
197 for (c = 0; c < ncols; c++) {
198 COLORV *cv = cm_lval(cm,r,c);
199 if (fscanf(fp, COLSPEC, cv, cv+1, cv+2) != 3)
200 if ((nrows <= 0) & (r > 0) & !c) {
201 cm = cm_resize(cm, maxrow=r);
202 break;
203 } else
204 goto EOFerror;
205 }
206 }
207 while ((c = getc(fp)) != EOF)
208 if (!isspace(c)) {
209 sprintf(errmsg,
210 "unexpected data at end of ascii file %s",
211 fname);
212 error(WARNING, errmsg);
213 break;
214 }
215 } else { /* read binary file */
216 if (sizeof(COLOR) == cm_elem_size[dtype]) {
217 int nread = 0;
218 do { /* read all we can */
219 nread += fread(cm->cmem + 3*nread,
220 sizeof(COLOR),
221 cm->nrows*cm->ncols - nread,
222 fp);
223 if (nrows <= 0) { /* unknown length */
224 if (nread == cm->nrows*cm->ncols)
225 /* need more space? */
226 cm = cm_resize(cm, 2*cm->nrows);
227 else if (nread && !(nread % cm->ncols))
228 /* seem to be done */
229 cm = cm_resize(cm, nread/cm->ncols);
230 else /* ended mid-row */
231 goto EOFerror;
232 } else if (nread < cm->nrows*cm->ncols)
233 goto EOFerror;
234 } while (nread < cm->nrows*cm->ncols);
235
236 } else if (dtype == DTdouble) {
237 double dc[3]; /* load from double */
238 COLORV *cvp = cm->cmem;
239 int n = nrows*ncols;
240
241 if (n <= 0)
242 goto not_handled;
243 while (n--) {
244 if (fread(dc, sizeof(double), 3, fp) != 3)
245 goto EOFerror;
246 copycolor(cvp, dc);
247 cvp += 3;
248 }
249 } else /* dtype == DTfloat */ {
250 float fc[3]; /* load from float */
251 COLORV *cvp = cm->cmem;
252 int n = nrows*ncols;
253
254 if (n <= 0)
255 goto not_handled;
256 while (n--) {
257 if (fread(fc, sizeof(float), 3, fp) != 3)
258 goto EOFerror;
259 copycolor(cvp, fc);
260 cvp += 3;
261 }
262 }
263 if (fgetc(fp) != EOF) {
264 sprintf(errmsg,
265 "unexpected data at end of binary file %s",
266 fname);
267 error(WARNING, errmsg);
268 }
269 }
270 if (fp != stdin)
271 fclose(fp);
272 #ifdef getc_unlocked
273 else
274 funlockfile(fp);
275 #endif
276 return(cm);
277 EOFerror:
278 sprintf(errmsg, "unexpected EOF reading %s", fname);
279 error(USER, errmsg);
280 not_handled:
281 error(INTERNAL, "unhandled data size or length in cm_load()");
282 return(NULL); /* gratis return */
283 }
284
285 /* Extract a column vector from a matrix */
286 CMATRIX *
287 cm_column(const CMATRIX *cm, int c)
288 {
289 CMATRIX *cvr;
290 int dr;
291
292 if ((c < 0) | (c >= cm->ncols))
293 error(INTERNAL, "column requested outside matrix");
294 cvr = cm_alloc(cm->nrows, 1);
295 if (cvr == NULL)
296 return(NULL);
297 for (dr = 0; dr < cm->nrows; dr++) {
298 const COLORV *sp = cm_lval(cm,dr,c);
299 COLORV *dp = cv_lval(cvr,dr);
300 dp[0] = sp[0];
301 dp[1] = sp[1];
302 dp[2] = sp[2];
303 }
304 return(cvr);
305 }
306
307 /* Scale a matrix by a single value */
308 CMATRIX *
309 cm_scale(const CMATRIX *cm1, const COLOR sca)
310 {
311 CMATRIX *cmr;
312 int dr, dc;
313
314 cmr = cm_alloc(cm1->nrows, cm1->ncols);
315 if (cmr == NULL)
316 return(NULL);
317 for (dr = 0; dr < cmr->nrows; dr++)
318 for (dc = 0; dc < cmr->ncols; dc++) {
319 const COLORV *sp = cm_lval(cm1,dr,dc);
320 COLORV *dp = cm_lval(cmr,dr,dc);
321 dp[0] = sp[0] * sca[0];
322 dp[1] = sp[1] * sca[1];
323 dp[2] = sp[2] * sca[2];
324 }
325 return(cmr);
326 }
327
328 /* Multiply two matrices (or a matrix and a vector) and allocate the result */
329 CMATRIX *
330 cm_multiply(const CMATRIX *cm1, const CMATRIX *cm2)
331 {
332 char *rowcheck=NULL, *colcheck=NULL;
333 CMATRIX *cmr;
334 int dr, dc, i;
335
336 if ((cm1->ncols <= 0) | (cm1->ncols != cm2->nrows))
337 error(INTERNAL, "matrix dimension mismatch in cm_multiply()");
338 cmr = cm_alloc(cm1->nrows, cm2->ncols);
339 if (cmr == NULL)
340 return(NULL);
341 /* optimization: check for zero rows & cols */
342 if (((cm1->nrows > 5) | (cm2->ncols > 5)) & (cm1->ncols > 5)) {
343 static const COLOR czero;
344 rowcheck = (char *)calloc(cmr->nrows, 1);
345 for (dr = cm1->nrows*(rowcheck != NULL); dr--; )
346 for (dc = cm1->ncols; dc--; )
347 if (memcmp(cm_lval(cm1,dr,dc), czero, sizeof(COLOR))) {
348 rowcheck[dr] = 1;
349 break;
350 }
351 colcheck = (char *)calloc(cmr->ncols, 1);
352 for (dc = cm2->ncols*(colcheck != NULL); dc--; )
353 for (dr = cm2->nrows; dr--; )
354 if (memcmp(cm_lval(cm2,dr,dc), czero, sizeof(COLOR))) {
355 colcheck[dc] = 1;
356 break;
357 }
358 }
359 for (dr = 0; dr < cmr->nrows; dr++)
360 for (dc = 0; dc < cmr->ncols; dc++) {
361 COLORV *dp = cm_lval(cmr,dr,dc);
362 double res[3];
363 dp[0] = dp[1] = dp[2] = 0;
364 if (rowcheck != NULL && !rowcheck[dr])
365 continue;
366 if (colcheck != NULL && !colcheck[dc])
367 continue;
368 res[0] = res[1] = res[2] = 0;
369 for (i = 0; i < cm1->ncols; i++) {
370 const COLORV *cp1 = cm_lval(cm1,dr,i);
371 const COLORV *cp2 = cm_lval(cm2,i,dc);
372 res[0] += cp1[0] * cp2[0];
373 res[1] += cp1[1] * cp2[1];
374 res[2] += cp1[2] * cp2[2];
375 }
376 copycolor(dp, res);
377 }
378 if (rowcheck != NULL) free(rowcheck);
379 if (colcheck != NULL) free(colcheck);
380 return(cmr);
381 }
382
383 /* write out matrix to file (precede by resolution string if picture) */
384 int
385 cm_write(const CMATRIX *cm, int dtype, FILE *fp)
386 {
387 static const char tabEOL[2] = {'\t','\n'};
388 const COLORV *mp = cm->cmem;
389 int r, c;
390
391 switch (dtype) {
392 case DTascii:
393 for (r = 0; r < cm->nrows; r++)
394 for (c = 0; c < cm->ncols; c++, mp += 3)
395 fprintf(fp, "%.6e %.6e %.6e%c",
396 mp[0], mp[1], mp[2],
397 tabEOL[c >= cm->ncols-1]);
398 break;
399 case DTfloat:
400 case DTdouble:
401 if (sizeof(COLOR) == cm_elem_size[dtype]) {
402 r = cm->ncols*cm->nrows;
403 while (r > 0) {
404 c = fwrite(mp, sizeof(COLOR), r, fp);
405 if (c <= 0)
406 return(0);
407 mp += 3*c;
408 r -= c;
409 }
410 } else if (dtype == DTdouble) {
411 double dc[3];
412 r = cm->ncols*cm->nrows;
413 while (r--) {
414 copycolor(dc, mp);
415 if (fwrite(dc, sizeof(double), 3, fp) != 3)
416 return(0);
417 mp += 3;
418 }
419 } else /* dtype == DTfloat */ {
420 float fc[3];
421 r = cm->ncols*cm->nrows;
422 while (r--) {
423 copycolor(fc, mp);
424 if (fwrite(fc, sizeof(float), 3, fp) != 3)
425 return(0);
426 mp += 3;
427 }
428 }
429 break;
430 case DTrgbe:
431 case DTxyze:
432 fprtresolu(cm->ncols, cm->nrows, fp);
433 for (r = 0; r < cm->nrows; r++, mp += 3*cm->ncols)
434 if (fwritescan((COLOR *)mp, cm->ncols, fp) < 0)
435 return(0);
436 break;
437 default:
438 fputs("Unsupported data type in cm_write()!\n", stderr);
439 return(0);
440 }
441 return(fflush(fp) == 0);
442 }
