root/radiance/src/util/SConscript
Revision: 1.23
Committed: Mon Jan 8 13:38:37 2018 UTC (7 years, 10 months ago) by schorsch
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, HEAD
Changes since 1.22: +12 -8 lines
1 from __future__ import division, print_function, unicode_literals
2
3 import os
4
5 Import('env') # inherit from parent
6
7 mlib = ['$RAD_MLIB']
8 progs = []
9
10 # compose paths
11 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
12 def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
13 def tclscr(name): return os.path.join('$RAD_BUILDRLIB', 'tcl', name)
14
15 cmatrix = env.Object(source='cmatrix.c')
16 cmbsdf = env.Object(source='cmbsdf.c')
17
18 # standard targets
19 PROGS = [
20 ('findglare', Split('findglare.c glareval.c glaresrc.c setscan.c'), ['rtrad']),
21 ('glarendx', Split('glarendx.c'), ['rtrad']),
22 ('vwright', Split('vwright.c'), ['rtrad']),
23 ('vwrays', Split('vwrays.c'), ['rtrad']),
24 ('rad', Split('rad.c'), ['rtrad']),
25 ('rpiece', Split('rpiece.c') + [env.version], ['rtrad']),
26 ('ranimate', ['ranimate.c', '$RAD_NETCOMPAT'], ['rtrad', '$RAD_SOCKETLIB']),
27 ('dctimestep', Split('dctimestep.c')+[cmatrix, cmbsdf], ['rtrad']),
28 ('rttree_reduce', Split('rttree_reduce.c'), ['rtrad']),
29 ('rcollate', Split('rcollate.c'), ['rtrad']),
30 ('eplus_adduvf', Split('eplus_adduvf.c eplus_idf.c'), ['rtrad']),
31 ('rfluxmtx', Split('rfluxmtx.c'), ['rtrad']),
32 ('rmtxop', Split('rmtxop.c rmatrix.c')+[cmatrix, cmbsdf], ['rtrad']),
33 ('wrapBSDF', Split('wrapBSDF.c'), ['rtrad']),
34 ('evalglare', Split('evalglare.c pictool.c'), ['rtrad', 'reetz']),
35 ]
36
37 for p in PROGS:
38 prog = env.Program(target=radbin(p[0]), source=p[1], LIBS=p[2]+mlib)
39 progs.append(prog)
40
41 # targets with different includes/libs
42 rs = Split('ranimove.c ranimove1.c ranimove2.c')
43 ranimove = env.Program(target=radbin('ranimove'), source=rs,
44 CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
45 LIBS=['raycalls','rttrace','rtrad'] + mlib)
46 progs.append(ranimove)
47 rsensor = env.Program(target=radbin('rsensor'), source='rsensor.c',
48 CPPPATH=env.get('CPPPATH', [])+ ['#src/rt'],
49 LIBS=['raycalls','rttrace','rtrad'] + mlib)
50 progs.append(rsensor)
51
52 getinfo = env.Program(target=radbin('getinfo'), source='getinfo.c',
53 LIBS=['rtrad'])
54 progs.append(getinfo)
55
56
57 # X11 targets
58 if env.has_key('X11LIB'):
59 addobj = env.get('ADDOBJNOTIFY')
60 xincl = env.get('CPPPATH', []) + ['$X11INCLUDE']
61 xlibp = env.get('LIBPATH', []) + ['$X11LIB']
62 xglaresrc = env.Program(target=radbin('xglaresrc'),
63 source=Split('xglaresrc.c') + [env.x11findwind], # XXX remote magic
64 LIBPATH=xlibp, CPPPATH=xincl,
65 LIBS=['rtrad', 'X11']+ mlib)
66 progs.append(xglaresrc)
67
68 # OpenGL targets that also depend on X11
69 if env.has_key('OGL'):
70 glrad = env.Program(target=radbin('glrad'),
71 source=['glrad.c', addobj],
72 CPPFLAGS=env.get('CPPFLAGS', []) + ['$RAD_STEREO'],
73 LIBPATH=xlibp, CPPPATH=xincl,
74 LIBS=['rgl','rtrad','GL', 'GLU','X11'] + mlib,)
75 progs.append(glrad)
76
77 pyscripts = Split('''rlux''')
78 if os.name == 'posix':
79 for s in Split('''objline glare dayfact
80 debugcal raddepend compamb vinfo fieldcomb'''):
81 Default(env.InstallScript(radbin(s), s + '.csh'))
82 for s in Split('''objview objpict
83 genambpos genklemsamp genskyvec genBSDF bsdfview ltview ltpict'''):
84 Default(env.InstallScript(radbin(s), s + '.pl'))
85 for s in Split('''do_action.tcl do_file.tcl do_options.tcl do_results.tcl
86 do_scene.tcl do_views.tcl do_zone.tcl file.hlp getfile.tcl gethelp.tcl
87 help.hlp tclIndex trad.hlp trad.icon util.tcl'''):
88 Default(env.InstallScript(tclscr(s), s))
89 Default(env.InstallTCLScript(radbin('trad'), 'trad.wsh'))
90 for s in pyscripts:
91 Default(env.InstallScript(radbin(s), s + '.py'))
92 else:
93 for s in pyscripts:
94 Default(env.InstallScript(radbin(s + '.py'), s + '.py'))
95
96
97 Default('#src/util')
98 env.Install('$RAD_BINDIR', progs)
99
100 # vim: set syntax=python:
101 # vi: set ts=4 sw=4 :
