root/radiance/src/rt/srcobstr.c
Sat Dec 12 00:03:42 2009 UTC (15 years, 10 months ago) by greg
Diff to previous 2.14
Mon Oct 8 18:07:57 2007 UTC (18 years ago) by greg
Diff to previous 2.13
Wed Jul 25 04:12:36 2007 UTC (18 years, 2 months ago) by greg
Changes since 2.12: +39 -1 lines
Diff to previous 2.12
Tue Apr 19 01:15:07 2005 UTC (20 years, 6 months ago) by greg
Mon Oct 25 17:07:35 2004 UTC (20 years, 11 months ago) by greg
CVS Tags: rad3R6P1
Fixed Mark Stock's abort error caused by source & mist combination
Fri Sep 10 17:08:36 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.9: +9 -8 lines
Fixed bug in last fix -- distant sources weren't working
Fri Sep 10 16:05:07 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.8: +9 -2 lines
Wed Sep 8 17:10:16 2004 UTC (21 years, 1 month ago) by greg
Wed Sep 8 06:07:52 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.6: +25 -18 lines
Made source obstructor cache initialization more robust
Wed Sep 8 01:48:50 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.5: +12 -6 lines
Added local caching of obstruction index
Tue Jun 22 13:40:54 2004 UTC (21 years, 3 months ago) by greg
Added isopaque() macro to otspecial.h
Tue Mar 30 16:13:01 2004 UTC (21 years, 6 months ago) by schorsch
Fri Jan 9 05:37:12 2004 UTC (21 years, 9 months ago) by greg
Changes since 2.2: +9 -4 lines
Bug fix in source substructuring test and added debug bounds checking
Thu Jan 1 19:31:46 2004 UTC (21 years, 9 months ago) by greg
Wed Dec 31 19:38:27 2003 UTC (21 years, 9 months ago) by greg
