root/radiance/src/rt/rxtmain.cpp
Sun Aug 3 18:20:44 2025 UTC (2 months, 1 week ago) by greg
Diff to previous 2.14
fix(rxpiece,rxpict,rxtrace): Added missing i/o -features
Thu Jun 5 18:26:46 2025 UTC (4 months, 1 week ago) by greg
CVS Tags: rad6R0
Changes since 2.13: +1 -3 lines
Diff to previous 2.13
fix: Removed unnecessary or redundant progname declarations
Tue Apr 22 17:12:25 2025 UTC (5 months, 3 weeks ago) by greg
Diff to previous 2.12
Wed Mar 5 18:56:28 2025 UTC (7 months, 1 week ago) by greg
Changes since 2.11: +9 -3 lines
feat(rtrace,rxtrace): Improved header output
Tue Nov 19 16:27:21 2024 UTC (10 months, 3 weeks ago) by greg
fix(rxtrace): The -I option wasn't being set properly
Thu Oct 31 19:02:38 2024 UTC (11 months, 1 week ago) by greg
fix(rxtrace): fixed -features output
Mon Sep 16 19:20:09 2024 UTC (12 months, 3 weeks ago) by greg
refactor: Changed name of GetHeader() to GetHeadStr()
Wed Aug 14 22:51:21 2024 UTC (13 months, 4 weeks ago) by greg
fix(rxtrace): match eputs() to prototype so that it actually gets called
Wed Aug 14 20:05:23 2024 UTC (13 months, 4 weeks ago) by greg
Sat Aug 3 21:33:15 2024 UTC (14 months, 1 week ago) by greg
Changes since 2.5: +2 -3 lines
feat(rxtrace): changed GetHeader() to return empty string if no header
Sat Aug 3 01:54:46 2024 UTC (14 months, 1 week ago) by greg
Changes since 2.4: +4 -6 lines
feat(rxtrace): Added header manipulation to base class
Wed May 1 22:06:09 2024 UTC (17 months, 1 week ago) by greg
Changes since 2.3: +11 -2 lines
fix(rxtrace): Fixed spectral sampling set-up
Tue Apr 30 23:16:23 2024 UTC (17 months, 2 weeks ago) by greg
Changes since 2.2: +101 -8 lines
feat(rxtrace): Added multi-processing and spectral color
Tue Mar 12 16:54:51 2024 UTC (19 months ago) by greg
Changes since 2.1: +1 -3 lines
perf: added datavector() call for quicker spectral interpolation
Mon Aug 21 22:39:05 2023 UTC (2 years, 1 month ago) by greg
Renamed ratrace to rxtrace
