| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rxcmain.cpp,v 2.12 2024/12/23 18:14:20 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* rxcmain.c - main for rxcontrib ray contribution tracer
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <signal.h>
| 11 |
#include <time.h>
| 12 |
#include <ctype.h>
| 13 |
#include "RcontribSimulManager.h"
| 14 |
#include "platform.h"
| 15 |
#include "func.h"
| 16 |
| 17 |
const char *sigerr[NSIG]; /* signal error messages */
| 18 |
| 19 |
int nproc = 1; /* number of processes requested */
| 20 |
| 21 |
int inpfmt = 'a'; /* input format */
| 22 |
int outfmt = 'f'; /* output format */
| 23 |
| 24 |
int report_intvl = 0; /* reporting interval (seconds) */
| 25 |
| 26 |
extern char * progname; // global argv[0]
| 27 |
| 28 |
RcontribSimulManager myRCmanager; // global rcontrib simulation manager
| 29 |
| 30 |
#define RCONTRIB_FEATURES "Multiprocessing\n" \
| 31 |
"Accumulation\nRecovery\n" \
| 32 |
"ImmediateIrradiance\n" \
| 33 |
"ProgressReporting\nDistanceLimiting\n" \
| 34 |
"InputFormats=a,f,d\nOutputFormats=f,d,c\n" \
| 35 |
"Outputs=V,W\n" \
| 36 |
"OutputCS=RGB,spec\n"
| 37 |
| 38 |
static void rxcontrib(const int rstart = 0);
| 39 |
| 40 |
static void
| 41 |
printdefaults(void) /* print default values to stdout */
| 42 |
| 43 |
printf("-c %-5d\t\t\t# accumulated rays per record\n", myRCmanager.accum);
| 44 |
printf(myRCmanager.HasFlag(RCcontrib) ?
| 45 |
"-V+\t\t\t\t# output contributions\n" :
| 46 |
"-V-\t\t\t\t# output coefficients\n");
| 47 |
if (myRCmanager.HasFlag(RTimmIrrad))
| 48 |
printf("-I+\t\t\t\t# immediate irradiance on\n");
| 49 |
printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
| 50 |
if (myRCmanager.xres > 0)
| 51 |
printf("-x %-9d\t\t\t# x resolution\n", myRCmanager.xres);
| 52 |
printf("-y %-9d\t\t\t# y resolution\n", myRCmanager.yres);
| 53 |
printf(myRCmanager.HasFlag(RTlimDist) ?
| 54 |
"-ld+\t\t\t\t# limit distance on\n" :
| 55 |
"-ld-\t\t\t\t# limit distance off\n");
| 56 |
printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
| 57 |
inpfmt, outfmt, formstr(inpfmt), formstr(outfmt));
| 58 |
if (report_intvl > 0)
| 59 |
printf("-t %-9d\t\t\t# time between reports\n", report_intvl);
| 60 |
printf(erract[WARNING].pf != NULL ?
| 61 |
"-w+\t\t\t\t# warning messages on\n" :
| 62 |
"-w-\t\t\t\t# warning messages off\n");
| 63 |
print_rdefaults();
| 64 |
| 65 |
| 66 |
| 67 |
static void
| 68 |
onsig( /* fatal signal */
| 69 |
int signo
| 70 |
| 71 |
| 72 |
static int gotsig = 0;
| 73 |
| 74 |
if (gotsig++) /* two signals and we're gone! */
| 75 |
_exit(signo);
| 76 |
| 77 |
#ifdef SIGALRM
| 78 |
alarm(180); /* allow 3 minutes to clean up */
| 79 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */
| 80 |
#endif
| 81 |
eputs("signal - ");
| 82 |
eputs(sigerr[signo]);
| 83 |
eputs("\n");
| 84 |
quit(3);
| 85 |
| 86 |
| 87 |
| 88 |
static void
| 89 |
sigdie( /* set fatal signal */
| 90 |
int signo,
| 91 |
const char *msg
| 92 |
| 93 |
| 94 |
if (signal(signo, onsig) == SIG_IGN)
| 95 |
signal(signo, SIG_IGN);
| 96 |
sigerr[signo] = msg;
| 97 |
| 98 |
| 99 |
/* set input/output format */
| 100 |
static void
| 101 |
setformat(const char *fmt)
| 102 |
| 103 |
switch (fmt[0]) {
| 104 |
case 'f':
| 105 |
case 'd':
| 106 |
SET_FILE_BINARY(stdin);
| 107 |
/* fall through */
| 108 |
case 'a':
| 109 |
inpfmt = fmt[0];
| 110 |
break;
| 111 |
default:
| 112 |
goto fmterr;
| 113 |
| 114 |
switch (fmt[1]) {
| 115 |
case '\0':
| 116 |
if (inpfmt == 'a')
| 117 |
goto fmterr;
| 118 |
outfmt = inpfmt;
| 119 |
return;
| 120 |
case 'f':
| 121 |
case 'd':
| 122 |
case 'c':
| 123 |
outfmt = fmt[1];
| 124 |
break;
| 125 |
default:
| 126 |
goto fmterr;
| 127 |
| 128 |
if (!fmt[2])
| 129 |
return;
| 130 |
fmterr:
| 131 |
sprintf(errmsg, "Unsupported i/o format: -f%s", fmt);
| 132 |
error(USER, errmsg);
| 133 |
| 134 |
| 135 |
/* Set default options */
| 136 |
static void
| 137 |
default_options(void)
| 138 |
| 139 |
rand_samp = 1;
| 140 |
dstrsrc = 0.9;
| 141 |
directrelay = 3;
| 142 |
vspretest = 512;
| 143 |
srcsizerat = .2;
| 144 |
specthresh = .02;
| 145 |
specjitter = 1.;
| 146 |
maxdepth = -10;
| 147 |
minweight = 2e-3;
| 148 |
ambres = 256;
| 149 |
ambdiv = 350;
| 150 |
ambounce = 1;
| 151 |
| 152 |
| 153 |
/* Set overriding options */
| 154 |
static void
| 155 |
override_options(void)
| 156 |
| 157 |
shadthresh = 0;
| 158 |
ambssamp = 0;
| 159 |
ambacc = 0;
| 160 |
| 161 |
| 162 |
int
| 163 |
main(int argc, char *argv[])
| 164 |
| 165 |
#define check(ol,al) if (argv[i][ol] || \
| 166 |
badarg(argc-i-1,argv+i+1,al)) \
| 167 |
goto badopt
| 168 |
#define check_bool(olen,var) switch (argv[i][olen]) { \
| 169 |
case '\0': var = !var; break; \
| 170 |
case 'y': case 'Y': case 't': case 'T': \
| 171 |
case '+': case '1': var = 1; break; \
| 172 |
case 'n': case 'N': case 'f': case 'F': \
| 173 |
case '-': case '0': var = 0; break; \
| 174 |
default: goto badopt; }
| 175 |
int force_open = 0;
| 176 |
int recover = 0;
| 177 |
char *curout = NULL;
| 178 |
char *prms = NULL;
| 179 |
char *binval = NULL;
| 180 |
int bincnt = 0;
| 181 |
int rval;
| 182 |
int i;
| 183 |
/* global program name */
| 184 |
progname = argv[0];
| 185 |
/* feature check only? */
| 186 |
strcat(RFeatureList, RCONTRIB_FEATURES);
| 187 |
if (argc > 1 && !strcmp(argv[1], "-features"))
| 188 |
return feature_status(argc-2, argv+2);
| 189 |
/* initialize calcomp routines early */
| 190 |
initfunc();
| 191 |
calcontext(RCCONTEXT);
| 192 |
/* set rcontrib defaults */
| 193 |
default_options();
| 194 |
/* option city */
| 195 |
for (i = 1; i < argc; i++) {
| 196 |
/* expand arguments */
| 197 |
while ((rval = expandarg(&argc, &argv, i)) > 0)
| 198 |
| 199 |
if (rval < 0) {
| 200 |
sprintf(errmsg, "cannot expand '%s'", argv[i]);
| 201 |
error(SYSTEM, errmsg);
| 202 |
| 203 |
if (argv[i] == NULL || argv[i][0] != '-')
| 204 |
break; /* break from options */
| 205 |
if (!strcmp(argv[i], "-version")) {
| 206 |
puts(VersionID);
| 207 |
quit(0);
| 208 |
| 209 |
if (!strcmp(argv[i], "-defaults") ||
| 210 |
!strcmp(argv[i], "-help")) {
| 211 |
override_options();
| 212 |
printdefaults();
| 213 |
quit(0);
| 214 |
| 215 |
rval = getrenderopt(argc-i, argv+i);
| 216 |
if (rval >= 0) {
| 217 |
i += rval;
| 218 |
continue;
| 219 |
| 220 |
switch (argv[i][1]) {
| 221 |
case 'n': /* number of processes */
| 222 |
check(2,"i");
| 223 |
nproc = atoi(argv[++i]);
| 224 |
if (nproc < 0 && (nproc += RadSimulManager::GetNCores()) <= 0)
| 225 |
nproc = 1;
| 226 |
break;
| 227 |
case 'V': /* output contributions? */
| 228 |
rval = myRCmanager.HasFlag(RCcontrib);
| 229 |
check_bool(2,rval);
| 230 |
myRCmanager.SetFlag(RCcontrib, rval);
| 231 |
break;
| 232 |
case 'x': /* x resolution */
| 233 |
check(2,"i");
| 234 |
myRCmanager.xres = atoi(argv[++i]);
| 235 |
break;
| 236 |
case 'y': /* y resolution */
| 237 |
check(2,"i");
| 238 |
myRCmanager.yres = atoi(argv[++i]);
| 239 |
break;
| 240 |
case 'w': /* warnings on/off */
| 241 |
rval = (erract[WARNING].pf != NULL);
| 242 |
check_bool(2,rval);
| 243 |
if (rval) erract[WARNING].pf = wputs;
| 244 |
else erract[WARNING].pf = NULL;
| 245 |
break;
| 246 |
case 'e': /* .cal expression */
| 247 |
check(2,"s");
| 248 |
scompile(argv[++i], NULL, 0);
| 249 |
break;
| 250 |
case 'l': /* limit distance */
| 251 |
if (argv[i][2] != 'd')
| 252 |
goto badopt;
| 253 |
rval = myRCmanager.HasFlag(RTlimDist);
| 254 |
check_bool(3,rval);
| 255 |
myRCmanager.SetFlag(RTlimDist, rval);
| 256 |
break;
| 257 |
case 'I': /* immed. irradiance */
| 258 |
rval = myRCmanager.HasFlag(RTimmIrrad);
| 259 |
check_bool(2,rval);
| 260 |
myRCmanager.SetFlag(RTimmIrrad, rval);
| 261 |
break;
| 262 |
case 'f': /* .cal file or force or format */
| 263 |
if (!argv[i][2]) {
| 264 |
check(2,"s");
| 265 |
loadfunc(argv[++i]);
| 266 |
break;
| 267 |
| 268 |
if (argv[i][2] == 'o') {
| 269 |
check_bool(3,force_open);
| 270 |
break;
| 271 |
| 272 |
setformat(argv[i]+2);
| 273 |
myRCmanager.SetDataFormat(outfmt);
| 274 |
break;
| 275 |
case 'o': /* output file */
| 276 |
check(2,"s");
| 277 |
curout = argv[++i];
| 278 |
break;
| 279 |
case 'r': /* recover output */
| 280 |
check_bool(2,recover);
| 281 |
break;
| 282 |
case 'p': /* parameter setting(s) */
| 283 |
check(2,"s");
| 284 |
set_eparams(prms = argv[++i]);
| 285 |
break;
| 286 |
case 'c': /* sample count */
| 287 |
check(2,"i");
| 288 |
myRCmanager.accum = atoi(argv[++i]);
| 289 |
break;
| 290 |
case 'b': /* bin expression/count */
| 291 |
if (argv[i][2] == 'n') {
| 292 |
check(3,"s");
| 293 |
bincnt = (int)(eval(argv[++i]) + .5);
| 294 |
break;
| 295 |
| 296 |
check(2,"s");
| 297 |
binval = argv[++i];
| 298 |
break;
| 299 |
case 'm': /* modifier name */
| 300 |
check(2,"s");
| 301 |
myRCmanager.AddModifier(argv[++i], curout, prms, binval, bincnt);
| 302 |
break;
| 303 |
case 'M': /* file of modifier names */
| 304 |
check(2,"s");
| 305 |
myRCmanager.AddModFile(argv[++i], curout, prms, binval, bincnt);
| 306 |
break;
| 307 |
case 't': /* reporting interval */
| 308 |
check(2,"i");
| 309 |
report_intvl = atoi(argv[++i]);
| 310 |
break;
| 311 |
default:
| 312 |
goto badopt;
| 313 |
| 314 |
| 315 |
if (i != argc-1)
| 316 |
error(USER, "expected single octree argument");
| 317 |
| 318 |
override_options(); /* override some option settings */
| 319 |
| 320 |
if (!myRCmanager.GetOutput()) // check that we have work to do
| 321 |
error(USER, "missing required modifier argument");
| 322 |
// get ready to rock...
| 323 |
if (setspectrsamp(CNDX, WLPART) < 0)
| 324 |
error(USER, "unsupported spectral sampling");
| 325 |
/* set up signal handling */
| 326 |
sigdie(SIGINT, "Interrupt");
| 327 |
#ifdef SIGHUP
| 328 |
sigdie(SIGHUP, "Hangup");
| 329 |
#endif
| 330 |
sigdie(SIGTERM, "Terminate");
| 331 |
#ifdef SIGPIPE
| 332 |
sigdie(SIGPIPE, "Broken pipe");
| 333 |
#endif
| 334 |
#ifdef SIGALRM
| 335 |
sigdie(SIGALRM, "Alarm clock");
| 336 |
#endif
| 337 |
#ifdef SIGXCPU
| 338 |
sigdie(SIGXCPU, "CPU limit exceeded");
| 339 |
sigdie(SIGXFSZ, "File size exceeded");
| 340 |
#endif
| 341 |
#ifdef NICE
| 342 |
nice(NICE); /* lower priority */
| 343 |
#endif
| 344 |
// load octree
| 345 |
myRCmanager.LoadOctree(argv[argc-1]);
| 346 |
// add to header
| 347 |
myRCmanager.AddHeader(argc-1, argv);
| 348 |
// prepare output files
| 349 |
if (recover)
| 350 |
myRCmanager.outOp = RCOrecover;
| 351 |
else if (force_open)
| 352 |
myRCmanager.outOp = RCOforce;
| 353 |
else
| 354 |
myRCmanager.outOp = RCOnew;
| 355 |
// rval = # rows recovered
| 356 |
rval = myRCmanager.PrepOutput();
| 357 |
// check if recovered everything
| 358 |
if (rval >= myRCmanager.GetRowMax()) {
| 359 |
error(WARNING, "nothing left to compute");
| 360 |
quit(0);
| 361 |
| 362 |
rxcontrib(rval); /* trace ray contributions (loop) */
| 363 |
| 364 |
quit(0); /* exit clean */
| 365 |
| 366 |
badopt:
| 367 |
fprintf(stderr,
| 368 |
"Usage: %s [-V][-c count][-r][-e expr][-f source][-o ospec][-p p1=V1,p2=V2][-b binv][-bn N] {-m mod | -M file} [rtrace options] octree\n",
| 369 |
progname);
| 370 |
sprintf(errmsg, "command line error at '%s'", argv[i]);
| 371 |
| 372 |
return(1); /* pro forma return */
| 373 |
| 374 |
#undef check
| 375 |
#undef check_bool
| 376 |
| 377 |
| 378 |
| 379 |
// skip specified number of bytes, return false if EOF
| 380 |
static bool
| 381 |
skipBytes(int n2skip)
| 382 |
| 383 |
while (n2skip-- > 0)
| 384 |
if (getchar() == EOF)
| 385 |
return false;
| 386 |
return true;
| 387 |
| 388 |
| 389 |
| 390 |
// skip specified number of whitespace-separated words, return false if EOF
| 391 |
static bool
| 392 |
skipWords(int n2skip)
| 393 |
| 394 |
int c;
| 395 |
| 396 |
while (n2skip-- > 0) {
| 397 |
do {
| 398 |
c = getchar();
| 399 |
} while (isspace(c));
| 400 |
do {
| 401 |
if (c == EOF) return false;
| 402 |
c = getchar();
| 403 |
} while (!isspace(c));
| 404 |
| 405 |
return true;
| 406 |
| 407 |
| 408 |
| 409 |
// read a bundle of myRCmanager.accum ray origins and directions
| 410 |
static bool
| 411 |
getRayBundle(FVECT *orig_dir = NULL)
| 412 |
| 413 |
int n2go = myRCmanager.accum;
| 414 |
| 415 |
switch (inpfmt) {
| 416 |
case 'a': // ASCII input
| 417 |
if (!orig_dir)
| 418 |
return skipWords(6*n2go);
| 419 |
while (n2go-- > 0) {
| 420 |
if (scanf(FVFORMAT, &orig_dir[0][0],
| 421 |
&orig_dir[0][1], &orig_dir[0][2]) != 3)
| 422 |
return false;
| 423 |
if (scanf(FVFORMAT, &orig_dir[1][0],
| 424 |
&orig_dir[1][1], &orig_dir[1][2]) != 3)
| 425 |
return false;
| 426 |
orig_dir += 2;
| 427 |
| 428 |
break;
| 429 |
case 'f': // float input
| 430 |
if (!orig_dir)
| 431 |
return skipBytes(6*sizeof(float)*n2go);
| 432 |
#ifdef SMLFLT
| 433 |
if (getbinary(orig_dir, sizeof(FVECT), 2*n2go, stdin) != 2*n2go)
| 434 |
return false;
| 435 |
orig_dir += 2*n2go;
| 436 |
#else
| 437 |
| 438 |
float fvecs[6];
| 439 |
if (getbinary(fvecs, sizeof(fvecs), 1, stdin) != 1)
| 440 |
return false;
| 441 |
for (int i = 6; i--; )
| 442 |
orig_dir[0][i] = fvecs[i];
| 443 |
orig_dir += 2;
| 444 |
| 445 |
#endif
| 446 |
break;
| 447 |
case 'd': // double input
| 448 |
if (!orig_dir)
| 449 |
return skipBytes(6*sizeof(double)*n2go);
| 450 |
#ifndef SMLFLT
| 451 |
| 452 |
return false;
| 453 |
orig_dir += 2*n2go;
| 454 |
#else
| 455 |
| 456 |
double dvecs[6];
| 457 |
if (getbinary(dvecs, sizeof(dvecs), 1, stdin) != 1)
| 458 |
return false;
| 459 |
| 460 |
orig_dir[0][i] = dvecs[i];
| 461 |
orig_dir += 2;
| 462 |
| 463 |
#endif
| 464 |
break;
| 465 |
default:
| 466 |
error(INTERNAL, "unsupported format in getRayBundle()");
| 467 |
return false;
| 468 |
| 469 |
n2go = myRCmanager.accum; // normalize directions
| 470 |
| 471 |
orig_dir -= 2;
| 472 |
normalize(orig_dir[1]);
| 473 |
| 474 |
return true;
| 475 |
| 476 |
| 477 |
| 478 |
// Run loop to load data, report progress, etc.
| 479 |
void
| 480 |
rxcontrib(const int rstart)
| 481 |
| 482 |
const int totRows = myRCmanager.GetRowMax();
| 483 |
FVECT * odarr = (FVECT *)emalloc(sizeof(FVECT)*2*myRCmanager.accum);
| 484 |
time_t tstart, last_report;
| 485 |
int r = 0;
| 486 |
| 487 |
while (r < rstart) { // skip input rays already done
| 488 |
if (!getRayBundle())
| 489 |
goto readerr;
| 490 |
r++;
| 491 |
| 492 |
if (report_intvl > 0) { // set up reporting
| 493 |
if (r > 0) {
| 494 |
sprintf(errmsg, "recovered %.2f%% of total\n",
| 495 |
100.*r/totRows);
| 496 |
eputs(errmsg);
| 497 |
| 498 |
last_report = tstart = time(0);
| 499 |
| 500 |
// start children as requested
| 501 |
myRCmanager.SetThreadCount(nproc);
| 502 |
| 503 |
while (r < totRows) { // loop until done
| 504 |
time_t tnow;
| 505 |
if (!getRayBundle(odarr))
| 506 |
goto readerr;
| 507 |
if (myRCmanager.ComputeRecord(odarr) <= 0)
| 508 |
return; // error reported, hopefully...
| 509 |
r++;
| 510 |
if (report_intvl <= 0)
| 511 |
continue;
| 512 |
if (r == totRows) // need to finish up?
| 513 |
myRCmanager.SetThreadCount(1);
| 514 |
tnow = time(0);
| 515 |
if ((r < totRows) & (tnow < last_report+report_intvl))
| 516 |
continue;
| 517 |
sprintf(errmsg, "%.2f%% done after %.3f hours\n",
| 518 |
100.*myRCmanager.GetRowFinished()/totRows,
| 519 |
(1./3600.)*(tnow - tstart));
| 520 |
eputs(errmsg);
| 521 |
last_report = tnow;
| 522 |
| 523 |
efree(odarr);
| 524 |
return;
| 525 |
readerr:
| 526 |
sprintf(errmsg, "unexpected EOF on standard input (record %d of %d)",
| 527 |
r, totRows);
| 528 |
| 529 |
| 530 |
| 531 |
| 532 |
void
| 533 |
wputs( /* warning output function */
| 534 |
const char *s
| 535 |
| 536 |
| 537 |
if (!erract[WARNING].pf) return;
| 538 |
int lasterrno = errno;
| 539 |
eputs(s);
| 540 |
errno = lasterrno;
| 541 |
| 542 |
| 543 |
| 544 |
void
| 545 |
eputs( /* put string to stderr */
| 546 |
const char *s
| 547 |
| 548 |
| 549 |
static int midline = 0;
| 550 |
| 551 |
if (!*s)
| 552 |
return;
| 553 |
if (!midline++) {
| 554 |
fputs(progname, stderr);
| 555 |
fputs(": ", stderr);
| 556 |
| 557 |
fputs(s, stderr);
| 558 |
if (s[strlen(s)-1] == '\n') {
| 559 |
fflush(stderr);
| 560 |
midline = 0;
| 561 |
| 562 |
| 563 |
| 564 |
| 565 |
/* Exit program */
| 566 |
void
| 567 |
quit(
| 568 |
int code
| 569 |
| 570 |
| 571 |
if (!code && myRCmanager.Ready()) // clean up on normal exit
| 572 |
code = myRCmanager.Cleanup();
| 573 |
| 574 |
exit(code);
| 575 |
