| 1 |
#ifndef lint |
| 2 |
static const char RCSid[] = "$Id: rtmain.c,v 2.60 2025/06/20 03:43:17 greg Exp $"; |
| 3 |
#endif |
| 4 |
| 5 |
* rtmain.c - main for rtrace per-ray calculation program |
| 6 |
| 7 |
| 8 |
#include "copyright.h" |
| 9 |
| 10 |
#include <signal.h> |
| 11 |
| 12 |
#include "platform.h" |
| 13 |
#include "rtprocess.h" /* getpid() */ |
| 14 |
#include "resolu.h" |
| 15 |
#include "ray.h" |
| 16 |
#include "func.h" |
| 17 |
#include "source.h" |
| 18 |
#include "ambient.h" |
| 19 |
#include "random.h" |
| 20 |
#include "pmapray.h" |
| 21 |
/* persistent processes define */ |
| 22 |
#ifdef F_SETLKW |
| 23 |
#define PERSIST 1 /* normal persist */ |
| 24 |
#define PARALLEL 2 /* parallel persist */ |
| 25 |
#define PCHILD 3 /* child of normal persist */ |
| 26 |
#endif |
| 27 |
| 28 |
char *sigerr[NSIG]; /* signal error messages */ |
| 29 |
char *errfile = NULL; /* error output file */ |
| 30 |
| 31 |
int nproc = 1; /* number of processes */ |
| 32 |
| 33 |
extern int setrtoutput(void); /* set output values */ |
| 34 |
| 35 |
int inform = 'a'; /* input format */ |
| 36 |
int outform = 'a'; /* output format */ |
| 37 |
char *outvals = "v"; /* output specification */ |
| 38 |
| 39 |
int hresolu = 0; /* horizontal (scan) size */ |
| 40 |
int vresolu = 0; /* vertical resolution */ |
| 41 |
| 42 |
extern int castonly; /* only doing ray-casting? */ |
| 43 |
| 44 |
int imm_irrad = 0; /* compute immediate irradiance? */ |
| 45 |
int lim_dist = 0; /* limit distance? */ |
| 46 |
| 47 |
#ifndef MAXMODLIST |
| 48 |
#define MAXMODLIST 1024 /* maximum modifiers we'll track */ |
| 49 |
#endif |
| 50 |
| 51 |
extern void (*addobjnotify[])(); /* object notification calls */ |
| 52 |
extern void tranotify(OBJECT obj); |
| 53 |
| 54 |
char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */ |
| 55 |
int traincl = -1; /* include == 1, exclude == 0 */ |
| 56 |
| 57 |
double (*sens_curve)(const SCOLOR scol) = NULL; /* spectral conversion for 1-channel */ |
| 58 |
double out_scalefactor = 1; /* output calibration scale factor */ |
| 59 |
RGBPRIMP out_prims = stdprims; /* output color primitives (NULL if spectral) */ |
| 60 |
static RGBPRIMS our_prims; /* private output color primitives */ |
| 61 |
| 62 |
static int loadflags = ~IO_FILES; /* what to load from octree */ |
| 63 |
| 64 |
static void onsig(int signo); |
| 65 |
static void sigdie(int signo, char *msg); |
| 66 |
static void printdefaults(void); |
| 67 |
| 68 |
#ifdef PERSIST |
| 69 |
#define RTRACE_FEATURES "Persist\nParallelPersist\nMultiprocessing\n" \ |
| 70 |
"IrradianceCalc\nImmediateIrradiance\nDistanceLimiting\n" \ |
| 71 |
"ParticipatingMedia=Mist\n" \ |
| 72 |
"HessianAmbientCache\nAmbientAveraging\n" \ |
| 73 |
"AmbientValueSharing\nAdaptiveShadowTesting\n" \ |
| 74 |
"InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \ |
| 75 |
"Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" \ |
| 76 |
"OutputCS=RGB,XYZ,Y,S,M,prims,spec\n" |
| 77 |
#else |
| 78 |
#define RTRACE_FEATURES "IrradianceCalc\nIrradianceCalc\nDistanceLimiting\n" \ |
| 79 |
| 80 |
| 81 |
| 82 |
| 83 |
| 84 |
| 85 |
#endif |
| 86 |
| 87 |
| 88 |
int |
| 89 |
main(int argc, char *argv[]) |
| 90 |
| 91 |
#define check(ol,al) if (argv[i][ol] || \ |
| 92 |
badarg(argc-i-1,argv+i+1,al)) \ |
| 93 |
goto badopt |
| 94 |
#define check_bool(olen,var) switch (argv[i][olen]) { \ |
| 95 |
case '\0': var = !var; break; \ |
| 96 |
case 'y': case 'Y': case 't': case 'T': \ |
| 97 |
case '+': case '1': var = 1; break; \ |
| 98 |
case 'n': case 'N': case 'f': case 'F': \ |
| 99 |
case '-': case '0': var = 0; break; \ |
| 100 |
default: goto badopt; } |
| 101 |
extern char *octname; |
| 102 |
int persist = 0; |
| 103 |
char *octnm = NULL; |
| 104 |
char **tralp = NULL; |
| 105 |
int duped1 = -1; |
| 106 |
int rval; |
| 107 |
int i; |
| 108 |
/* global program name */ |
| 109 |
progname = argv[0] = fixargv0(argv[0]); |
| 110 |
/* feature check only? */ |
| 111 |
strcat(RFeatureList, RTRACE_FEATURES); |
| 112 |
if (argc > 1 && !strcmp(argv[1], "-features")) |
| 113 |
return feature_status(argc-2, argv+2); |
| 114 |
/* initialize calcomp routines */ |
| 115 |
initfunc(); |
| 116 |
/* add trace notify function */ |
| 117 |
for (i = 0; addobjnotify[i] != NULL; i++) |
| 118 |
| 119 |
addobjnotify[i] = tranotify; |
| 120 |
/* option city */ |
| 121 |
for (i = 1; i < argc; i++) { |
| 122 |
/* expand arguments */ |
| 123 |
while ((rval = expandarg(&argc, &argv, i)) > 0) |
| 124 |
| 125 |
if (rval < 0) { |
| 126 |
sprintf(errmsg, "cannot expand '%s'", argv[i]); |
| 127 |
error(SYSTEM, errmsg); |
| 128 |
| 129 |
if (argv[i] == NULL || argv[i][0] != '-') |
| 130 |
break; /* break from options */ |
| 131 |
if (!strcmp(argv[i], "-version")) { |
| 132 |
puts(VersionID); |
| 133 |
quit(0); |
| 134 |
| 135 |
if (!strcmp(argv[i], "-defaults") || |
| 136 |
!strcmp(argv[i], "-help")) { |
| 137 |
printdefaults(); |
| 138 |
quit(0); |
| 139 |
| 140 |
rval = getrenderopt(argc-i, argv+i); |
| 141 |
if (rval >= 0) { |
| 142 |
i += rval; |
| 143 |
continue; |
| 144 |
| 145 |
switch (argv[i][1]) { |
| 146 |
case 'n': /* number of cores */ |
| 147 |
check(2,"i"); |
| 148 |
nproc = atoi(argv[++i]); |
| 149 |
if (nproc <= 0) |
| 150 |
error(USER, "bad number of processes"); |
| 151 |
break; |
| 152 |
case 'x': /* x resolution */ |
| 153 |
check(2,"i"); |
| 154 |
hresolu = atoi(argv[++i]); |
| 155 |
break; |
| 156 |
case 'y': /* y resolution */ |
| 157 |
check(2,"i"); |
| 158 |
vresolu = atoi(argv[++i]); |
| 159 |
break; |
| 160 |
case 'w': /* warnings & spectral */ |
| 161 |
rval = erract[WARNING].pf != NULL; |
| 162 |
check_bool(2,rval); |
| 163 |
if (rval) erract[WARNING].pf = wputs; |
| 164 |
else erract[WARNING].pf = NULL; |
| 165 |
break; |
| 166 |
case 'e': /* error file */ |
| 167 |
check(2,"s"); |
| 168 |
errfile = argv[++i]; |
| 169 |
break; |
| 170 |
case 'l': /* limit distance */ |
| 171 |
if (argv[i][2] != 'd') |
| 172 |
goto badopt; |
| 173 |
check_bool(3,lim_dist); |
| 174 |
break; |
| 175 |
case 'I': /* immed. irradiance */ |
| 176 |
check_bool(2,imm_irrad); |
| 177 |
break; |
| 178 |
case 'f': /* format i/o */ |
| 179 |
switch (argv[i][2]) { |
| 180 |
case 'a': /* ascii */ |
| 181 |
case 'f': /* float */ |
| 182 |
case 'd': /* double */ |
| 183 |
inform = argv[i][2]; |
| 184 |
break; |
| 185 |
default: |
| 186 |
goto badopt; |
| 187 |
| 188 |
switch (argv[i][3]) { |
| 189 |
case '\0': |
| 190 |
outform = inform; |
| 191 |
break; |
| 192 |
| 193 |
| 194 |
| 195 |
case 'c': /* color */ |
| 196 |
check(4,""); |
| 197 |
outform = argv[i][3]; |
| 198 |
break; |
| 199 |
default: |
| 200 |
goto badopt; |
| 201 |
| 202 |
break; |
| 203 |
case 'o': /* output */ |
| 204 |
outvals = argv[i]+2; |
| 205 |
break; |
| 206 |
case 'h': /* header output */ |
| 207 |
rval = loadflags & IO_INFO; |
| 208 |
| 209 |
loadflags = rval ? loadflags | IO_INFO : |
| 210 |
loadflags & ~IO_INFO; |
| 211 |
break; |
| 212 |
case 't': /* trace */ |
| 213 |
| 214 |
case 'i': /* include */ |
| 215 |
case 'I': |
| 216 |
check(3,"s"); |
| 217 |
if (traincl != 1) { |
| 218 |
traincl = 1; |
| 219 |
tralp = tralist; |
| 220 |
| 221 |
if (argv[i][2] == 'I') { /* file */ |
| 222 |
rval = wordfile(tralp, MAXMODLIST-(tralp-tralist), |
| 223 |
getpath(argv[++i],getrlibpath(),R_OK)); |
| 224 |
if (rval < 0) { |
| 225 |
sprintf(errmsg, |
| 226 |
"cannot open trace include file \"%s\"", |
| 227 |
argv[i]); |
| 228 |
| 229 |
| 230 |
tralp += rval; |
| 231 |
} else { |
| 232 |
*tralp++ = argv[++i]; |
| 233 |
*tralp = NULL; |
| 234 |
| 235 |
break; |
| 236 |
case 'e': /* exclude */ |
| 237 |
case 'E': |
| 238 |
check(3,"s"); |
| 239 |
if (traincl != 0) { |
| 240 |
traincl = 0; |
| 241 |
tralp = tralist; |
| 242 |
| 243 |
if (argv[i][2] == 'E') { /* file */ |
| 244 |
| 245 |
| 246 |
if (rval < 0) { |
| 247 |
sprintf(errmsg, |
| 248 |
"cannot open trace exclude file \"%s\"", |
| 249 |
argv[i]); |
| 250 |
| 251 |
| 252 |
tralp += rval; |
| 253 |
} else { |
| 254 |
| 255 |
*tralp = NULL; |
| 256 |
| 257 |
break; |
| 258 |
default: |
| 259 |
goto badopt; |
| 260 |
| 261 |
break; |
| 262 |
case 'p': /* value output */ |
| 263 |
| 264 |
case 'R': /* standard RGB output */ |
| 265 |
if (strcmp(argv[i]+2, "RGB")) |
| 266 |
goto badopt; |
| 267 |
out_prims = stdprims; |
| 268 |
out_scalefactor = 1; |
| 269 |
sens_curve = NULL; |
| 270 |
break; |
| 271 |
case 'X': /* XYZ output */ |
| 272 |
if (strcmp(argv[i]+2, "XYZ")) |
| 273 |
goto badopt; |
| 274 |
out_prims = xyzprims; |
| 275 |
out_scalefactor = WHTEFFICACY; |
| 276 |
| 277 |
break; |
| 278 |
case 'c': { |
| 279 |
int j; |
| 280 |
check(3,"ffffffff"); |
| 281 |
rval = 0; |
| 282 |
for (j = 0; j < 8; j++) { |
| 283 |
our_prims[0][j] = atof(argv[++i]); |
| 284 |
rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001; |
| 285 |
| 286 |
if (rval) { |
| 287 |
if (!colorprimsOK(our_prims)) |
| 288 |
error(USER, "illegal primary chromaticities"); |
| 289 |
out_prims = our_prims; |
| 290 |
} else |
| 291 |
| 292 |
| 293 |
| 294 |
} break; |
| 295 |
case 'Y': /* photopic response */ |
| 296 |
if (argv[i][3]) |
| 297 |
goto badopt; |
| 298 |
sens_curve = scolor_photopic; |
| 299 |
| 300 |
break; |
| 301 |
case 'S': /* scotopic response */ |
| 302 |
if (argv[i][3]) |
| 303 |
goto badopt; |
| 304 |
sens_curve = scolor_scotopic; |
| 305 |
out_scalefactor = WHTSCOTOPIC; |
| 306 |
break; |
| 307 |
case 'M': /* melanopic response */ |
| 308 |
if (argv[i][3]) |
| 309 |
goto badopt; |
| 310 |
sens_curve = scolor_melanopic; |
| 311 |
out_scalefactor = WHTMELANOPIC; |
| 312 |
break; |
| 313 |
default: |
| 314 |
goto badopt; |
| 315 |
| 316 |
break; |
| 317 |
#if MAXCSAMP>3 |
| 318 |
case 'c': /* output spectral results */ |
| 319 |
if (argv[i][2] != 'o') |
| 320 |
goto badopt; |
| 321 |
rval = (out_prims == NULL) & (sens_curve == NULL); |
| 322 |
check_bool(3,rval); |
| 323 |
if (rval) { |
| 324 |
out_prims = NULL; |
| 325 |
| 326 |
} else if (out_prims == NULL) |
| 327 |
| 328 |
break; |
| 329 |
#endif |
| 330 |
#ifdef PERSIST |
| 331 |
case 'P': /* persist file */ |
| 332 |
if (argv[i][2] == 'P') { |
| 333 |
check(3,"s"); |
| 334 |
persist = PARALLEL; |
| 335 |
} else { |
| 336 |
check(2,"s"); |
| 337 |
persist = PERSIST; |
| 338 |
| 339 |
persistfile(argv[++i]); |
| 340 |
break; |
| 341 |
#endif |
| 342 |
default: |
| 343 |
goto badopt; |
| 344 |
| 345 |
| 346 |
/* set/check spectral sampling */ |
| 347 |
rval = setspectrsamp(CNDX, WLPART); |
| 348 |
if (rval < 0) |
| 349 |
error(USER, "unsupported spectral sampling"); |
| 350 |
if (sens_curve != NULL) |
| 351 |
out_prims = NULL; |
| 352 |
else if (out_prims != NULL) { |
| 353 |
if (!rval) |
| 354 |
error(WARNING, "spectral range incompatible with color output"); |
| 355 |
} else if (NCSAMP == 3) |
| 356 |
out_prims = stdprims; /* 3 samples do not a spectrum make */ |
| 357 |
if (nproc > 1 && persist) |
| 358 |
error(USER, "multiprocessing incompatible with persist file"); |
| 359 |
/* initialize object types */ |
| 360 |
initotypes(); |
| 361 |
/* initialize urand */ |
| 362 |
reset_random(); |
| 363 |
/* set up signal handling */ |
| 364 |
sigdie(SIGINT, "Interrupt"); |
| 365 |
#ifdef SIGHUP |
| 366 |
sigdie(SIGHUP, "Hangup"); |
| 367 |
#endif |
| 368 |
sigdie(SIGTERM, "Terminate"); |
| 369 |
#ifdef SIGPIPE |
| 370 |
sigdie(SIGPIPE, "Broken pipe"); |
| 371 |
#endif |
| 372 |
#ifdef SIGALRM |
| 373 |
sigdie(SIGALRM, "Alarm clock"); |
| 374 |
#endif |
| 375 |
#ifdef SIGXCPU |
| 376 |
sigdie(SIGXCPU, "CPU limit exceeded"); |
| 377 |
sigdie(SIGXFSZ, "File size exceeded"); |
| 378 |
#endif |
| 379 |
/* open error file */ |
| 380 |
if (errfile != NULL) { |
| 381 |
if (freopen(errfile, "a", stderr) == NULL) |
| 382 |
quit(2); |
| 383 |
fprintf(stderr, "**************\n*** PID %5d: ", |
| 384 |
getpid()); |
| 385 |
printargs(argc, argv, stderr); |
| 386 |
putc('\n', stderr); |
| 387 |
fflush(stderr); |
| 388 |
| 389 |
#ifdef NICE |
| 390 |
nice(NICE); /* lower priority */ |
| 391 |
#endif |
| 392 |
/* get octree */ |
| 393 |
if (i == argc) |
| 394 |
octnm = NULL; |
| 395 |
else if (i == argc-1) |
| 396 |
octnm = argv[i]; |
| 397 |
else |
| 398 |
goto badopt; |
| 399 |
if (octnm == NULL) |
| 400 |
error(USER, "missing octree argument"); |
| 401 |
/* set up output */ |
| 402 |
#ifdef PERSIST |
| 403 |
if (persist) { |
| 404 |
duped1 = dup(fileno(stdout)); /* don't lose our output */ |
| 405 |
openheader(); |
| 406 |
| 407 |
#endif |
| 408 |
if (outform != 'a') |
| 409 |
SET_FILE_BINARY(stdout); |
| 410 |
rval = setrtoutput(); |
| 411 |
octname = savqstr(octnm); |
| 412 |
readoct(octname, loadflags, &thescene, NULL); |
| 413 |
nsceneobjs = nobjects; |
| 414 |
| 415 |
if (loadflags & IO_INFO) { /* print header */ |
| 416 |
printargs(i, argv, stdout); |
| 417 |
printf("SOFTWARE= %s\n", VersionID); |
| 418 |
fputnow(stdout); |
| 419 |
if (rval > 0) /* saved from setrtoutput() call */ |
| 420 |
fputncomp(rval, stdout); |
| 421 |
if (NCSAMP > 3) |
| 422 |
fputwlsplit(WLPART, stdout); |
| 423 |
if ((out_prims != stdprims) & (out_prims != NULL)) |
| 424 |
fputprims(out_prims, stdout); |
| 425 |
if ((outform == 'f') | (outform == 'd')) |
| 426 |
fputendian(stdout); |
| 427 |
fputformat(formstr(outform), stdout); |
| 428 |
fputc('\n', stdout); /* end of header */ |
| 429 |
| 430 |
| 431 |
if (!castonly) { /* any actual ray traversal to do? */ |
| 432 |
| 433 |
ray_init_pmap(); /* PMAP: set up & load photon maps */ |
| 434 |
| 435 |
marksources(); /* find and mark sources */ |
| 436 |
| 437 |
setambient(); /* initialize ambient calculation */ |
| 438 |
} else |
| 439 |
distantsources(); /* else mark only distant sources */ |
| 440 |
| 441 |
fflush(stdout); /* in case we're duplicating header */ |
| 442 |
| 443 |
#ifdef PERSIST |
| 444 |
if (persist) { |
| 445 |
/* reconnect stdout */ |
| 446 |
dup2(duped1, fileno(stdout)); |
| 447 |
close(duped1); |
| 448 |
if (persist == PARALLEL) { /* multiprocessing */ |
| 449 |
cow_memshare(); /* preloads scene */ |
| 450 |
while ((rval=fork()) == 0) { /* keep on forkin' */ |
| 451 |
pflock(1); |
| 452 |
pfhold(); |
| 453 |
ambsync(); /* load new values */ |
| 454 |
| 455 |
if (rval < 0) |
| 456 |
error(SYSTEM, "cannot fork child for persist function"); |
| 457 |
pfdetach(); /* parent will run then exit */ |
| 458 |
| 459 |
| 460 |
runagain: |
| 461 |
if (persist) |
| 462 |
dupheader(); /* send header to stdout */ |
| 463 |
#endif |
| 464 |
/* trace rays */ |
| 465 |
rtrace(NULL, nproc); |
| 466 |
/* flush ambient file */ |
| 467 |
ambsync(); |
| 468 |
#ifdef PERSIST |
| 469 |
if (persist == PERSIST) { /* first run-through */ |
| 470 |
if ((rval=fork()) == 0) { /* child loops until killed */ |
| 471 |
pflock(1); |
| 472 |
persist = PCHILD; |
| 473 |
} else { /* original process exits */ |
| 474 |
if (rval < 0) |
| 475 |
| 476 |
pfdetach(); /* parent exits */ |
| 477 |
| 478 |
| 479 |
if (persist == PCHILD) { /* wait for a signal then go again */ |
| 480 |
pfhold(); |
| 481 |
raynum = nrays = 0; /* reinitialize */ |
| 482 |
goto runagain; |
| 483 |
| 484 |
#endif |
| 485 |
| 486 |
ray_done_pmap(); /* PMAP: free photon maps */ |
| 487 |
| 488 |
quit(0); |
| 489 |
| 490 |
badopt: |
| 491 |
sprintf(errmsg, "command line error at '%s'", argv[i]); |
| 492 |
error(USER, errmsg); |
| 493 |
return 1; /* pro forma return */ |
| 494 |
| 495 |
#undef check |
| 496 |
#undef check_bool |
| 497 |
| 498 |
| 499 |
| 500 |
void |
| 501 |
wputs( /* warning output function */ |
| 502 |
const char *s |
| 503 |
| 504 |
| 505 |
int lasterrno = errno; |
| 506 |
if (erract[WARNING].pf == NULL) |
| 507 |
return; /* called by calcomp or someone */ |
| 508 |
eputs(s); |
| 509 |
errno = lasterrno; |
| 510 |
| 511 |
| 512 |
| 513 |
void |
| 514 |
eputs( /* put string to stderr */ |
| 515 |
const char *s |
| 516 |
| 517 |
| 518 |
static int midline = 0; |
| 519 |
| 520 |
if (!*s) |
| 521 |
return; |
| 522 |
if (!midline++) { |
| 523 |
fputs(progname, stderr); |
| 524 |
fputs(": ", stderr); |
| 525 |
| 526 |
fputs(s, stderr); |
| 527 |
if (s[strlen(s)-1] == '\n') { |
| 528 |
fflush(stderr); |
| 529 |
midline = 0; |
| 530 |
| 531 |
| 532 |
| 533 |
| 534 |
static void |
| 535 |
onsig( /* fatal signal */ |
| 536 |
int signo |
| 537 |
| 538 |
| 539 |
static int gotsig = 0; |
| 540 |
| 541 |
if (gotsig++) /* two signals and we're gone! */ |
| 542 |
_exit(signo); |
| 543 |
| 544 |
#ifdef SIGALRM |
| 545 |
alarm(15); /* allow 15 seconds to clean up */ |
| 546 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */ |
| 547 |
#endif |
| 548 |
eputs("signal - "); |
| 549 |
eputs(sigerr[signo]); |
| 550 |
eputs("\n"); |
| 551 |
quit(3); |
| 552 |
| 553 |
| 554 |
| 555 |
static void |
| 556 |
sigdie( /* set fatal signal */ |
| 557 |
int signo, |
| 558 |
char *msg |
| 559 |
| 560 |
| 561 |
if (signal(signo, onsig) == SIG_IGN) |
| 562 |
signal(signo, SIG_IGN); |
| 563 |
sigerr[signo] = msg; |
| 564 |
| 565 |
| 566 |
| 567 |
static void |
| 568 |
printdefaults(void) /* print default values to stdout */ |
| 569 |
| 570 |
char *cp; |
| 571 |
| 572 |
printf(erract[WARNING].pf != NULL ? |
| 573 |
"-w+\t\t\t\t# warning messages on\n" : |
| 574 |
"-w-\t\t\t\t# warning messages off\n"); |
| 575 |
if (imm_irrad) |
| 576 |
printf("-I+\t\t\t\t# immediate irradiance on\n"); |
| 577 |
printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc); |
| 578 |
printf("-x %-9d\t\t\t# %s\n", hresolu, |
| 579 |
vresolu && hresolu ? "x resolution" : "flush interval"); |
| 580 |
printf("-y %-9d\t\t\t# y resolution\n", vresolu); |
| 581 |
printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" : |
| 582 |
"-ld-\t\t\t\t# limit distance off\n"); |
| 583 |
printf(loadflags & IO_INFO ? "-h+\t\t\t\t# output header\n" : |
| 584 |
"-h-\t\t\t\t# no header\n"); |
| 585 |
printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n", |
| 586 |
inform, outform, formstr(inform), formstr(outform)); |
| 587 |
printf("-o%-9s\t\t\t# output", outvals); |
| 588 |
for (cp = outvals; *cp; cp++) |
| 589 |
switch (*cp) { |
| 590 |
case 't': case 'T': printf(" trace"); break; |
| 591 |
case 'o': printf(" origin"); break; |
| 592 |
case 'd': printf(" direction"); break; |
| 593 |
case 'r': printf(" reflect_contrib"); break; |
| 594 |
case 'R': printf(" reflect_length"); break; |
| 595 |
case 'x': printf(" unreflect_contrib"); break; |
| 596 |
case 'X': printf(" unreflect_length"); break; |
| 597 |
case 'v': printf(" value"); break; |
| 598 |
case 'V': printf(" contribution"); break; |
| 599 |
case 'l': printf(" length"); break; |
| 600 |
case 'L': printf(" first_length"); break; |
| 601 |
case 'p': printf(" point"); break; |
| 602 |
case 'n': printf(" normal"); break; |
| 603 |
case 'N': printf(" unperturbed_normal"); break; |
| 604 |
case 's': printf(" surface"); break; |
| 605 |
case 'w': printf(" weight"); break; |
| 606 |
case 'W': printf(" coefficient"); break; |
| 607 |
case 'm': printf(" modifier"); break; |
| 608 |
case 'M': printf(" material"); break; |
| 609 |
case '~': printf(" tilde"); break; |
| 610 |
| 611 |
fputc('\n', stdout); |
| 612 |
if (sens_curve == scolor_photopic) |
| 613 |
printf("-pY\t\t\t\t# photopic output\n"); |
| 614 |
else if (sens_curve == scolor_scotopic) |
| 615 |
printf("-pS\t\t\t\t# scotopic output\n"); |
| 616 |
else if (sens_curve == scolor_melanopic) |
| 617 |
printf("-pM\t\t\t\t# melanopic output\n"); |
| 618 |
else if (out_prims == stdprims) |
| 619 |
printf("-pRGB\t\t\t\t# standard RGB color output\n"); |
| 620 |
else if (out_prims == xyzprims) |
| 621 |
printf("-pXYZ\t\t\t\t# CIE XYZ color output\n"); |
| 622 |
else if (out_prims != NULL) |
| 623 |
printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n", |
| 624 |
out_prims[RED][0], out_prims[RED][1], |
| 625 |
out_prims[GRN][0], out_prims[GRN][1], |
| 626 |
out_prims[BLU][0], out_prims[BLU][1], |
| 627 |
out_prims[WHT][0], out_prims[WHT][1]); |
| 628 |
if ((sens_curve == NULL) & (NCSAMP > 3)) |
| 629 |
printf(out_prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" : |
| 630 |
"-co+\t\t\t\t# output spectral values\n"); |
| 631 |
print_rdefaults(); |
| 632 |
