root/radiance/src/rt/rpmain.c
Revision: 2.41
Committed: Sat Jun 7 05:09:46 2025 UTC (3 months, 4 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.40: +1 -2 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.41 static const char RCSid[] = "$Id: rpmain.c,v 2.40 2025/06/05 18:26:46 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * rpmain.c - main for rpict batch rendering program
6     */
7
8 greg 2.2 #include "copyright.h"
9 greg 2.1
10 greg 2.10 #include <time.h>
11 schorsch 2.3 #include <signal.h>
12
13     #include "platform.h"
14 schorsch 2.6 #include "rtprocess.h" /* getpid() */
15 greg 2.1 #include "ray.h"
16 greg 2.38 #include "func.h"
17 greg 2.1 #include "source.h"
18     #include "ambient.h"
19     #include "random.h"
20     #include "view.h"
21 greg 2.16 #include "pmapray.h"
22 greg 2.1
23     /* persistent processes define */
24     #ifdef F_SETLKW
25     #define PERSIST 1 /* normal persist */
26     #define PARALLEL 2 /* parallel persist */
27     #define PCHILD 3 /* child of normal persist */
28     #endif
29
30     char *octname; /* octree name */
31     char *sigerr[NSIG]; /* signal error messages */
32     char *errfile = NULL; /* error output file */
33 greg 2.37
34 greg 2.1 extern time_t tstart; /* start time */
35
36     extern int ralrm; /* seconds between reports */
37
38     extern VIEW ourview; /* viewing parameters */
39
40     extern int hresolu; /* horizontal resolution */
41     extern int vresolu; /* vertical resolution */
42     extern double pixaspect; /* pixel aspect ratio */
43
44     extern int psample; /* pixel sample size */
45     extern double maxdiff; /* max. sample difference */
46     extern double dstrpix; /* square pixel distribution */
47
48     extern double mblur; /* motion blur parameter */
49
50 greg 2.9 extern double dblur; /* depth-of-field blur parameter */
51
52 greg 2.28 RGBPRIMP out_prims = stdprims; /* output color primitives */
53     static RGBPRIMS our_prims; /* private output color primitives */
54
55 schorsch 2.8 static void onsig(int signo);
56     static void sigdie(int signo, char *msg);
57     static void printdefaults(void);
58 greg 2.21 /* rpict additional features */
59     #ifdef PERSIST
60     #define RPICT_FEATURES "Persist\nParallelPersist\n" \
61 greg 2.29 "ParticipatingMedia=Mist\n" \
62 greg 2.22 "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
63     "HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
64     "PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \
65     "SmallSourceDrawing\nViewSequence\nProgressReporting\n" \
66 greg 2.32 "AdaptiveShadowTesting\nOutputs=v,l\n" \
67 greg 2.33 "OutputCS=RGB,XYZ,prims\n"
68 greg 2.21 #else
69     #define RPICT_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
70 greg 2.29 "ParticipatingMedia=Mist\n" \
71 greg 2.22 "HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
72     "PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \
73     "SmallSourceDrawing\nViewSequence\nProgressReporting\n" \
74 greg 2.32 "AdaptiveShadowTesting\nOutputs=v,l\n" \
75 greg 2.33 "OutputCS=RGB,XYZ,prims\n"
76 greg 2.21 #endif
77 greg 2.1
78
79     int
80 schorsch 2.8 main(int argc, char *argv[])
81 greg 2.1 {
82     #define check(ol,al) if (argv[i][ol] || \
83     badarg(argc-i-1,argv+i+1,al)) \
84     goto badopt
85 schorsch 2.18 #define check_bool(olen,var) switch (argv[i][olen]) { \
86 greg 2.1 case '\0': var = !var; break; \
87     case 'y': case 'Y': case 't': case 'T': \
88     case '+': case '1': var = 1; break; \
89     case 'n': case 'N': case 'f': case 'F': \
90     case '-': case '0': var = 0; break; \
91     default: goto badopt; }
92     char *err;
93     char *recover = NULL;
94     char *outfile = NULL;
95     char *zfile = NULL;
96     int loadflags = ~IO_FILES;
97     int seqstart = 0;
98     int persist = 0;
99 greg 2.15 int duped1 = -1;
100 greg 2.1 int rval;
101     int i;
102     /* record start time */
103     tstart = time((time_t *)NULL);
104     /* global program name */
105     progname = argv[0] = fixargv0(argv[0]);
106 greg 2.21 /* feature check only? */
107     strcat(RFeatureList, RPICT_FEATURES);
108 greg 2.25 if (argc > 1 && !strcmp(argv[1], "-features"))
109 greg 2.21 return feature_status(argc-2, argv+2);
110 greg 2.38 /* initialize calcomp routines */
111     initfunc();
112 greg 2.1 /* option city */
113     for (i = 1; i < argc; i++) {
114     /* expand arguments */
115     while ((rval = expandarg(&argc, &argv, i)) > 0)
116     ;
117     if (rval < 0) {
118     sprintf(errmsg, "cannot expand '%s'", argv[i]);
119     error(SYSTEM, errmsg);
120     }
121     if (argv[i] == NULL || argv[i][0] != '-')
122     break; /* break from options */
123     if (!strcmp(argv[i], "-version")) {
124     puts(VersionID);
125     quit(0);
126     }
127     if (!strcmp(argv[i], "-defaults") ||
128     !strcmp(argv[i], "-help")) {
129     printdefaults();
130     quit(0);
131     }
132     rval = getrenderopt(argc-i, argv+i);
133     if (rval >= 0) {
134     i += rval;
135     continue;
136     }
137     rval = getviewopt(&ourview, argc-i, argv+i);
138     if (rval >= 0) {
139     i += rval;
140     continue;
141     }
142     /* rpict options */
143     switch (argv[i][1]) {
144     case 'v': /* view file */
145     if (argv[i][2] != 'f')
146     goto badopt;
147     check(3,"s");
148     rval = viewfile(argv[++i], &ourview, NULL);
149     if (rval < 0) {
150     sprintf(errmsg,
151     "cannot open view file \"%s\"",
152     argv[i]);
153     error(SYSTEM, errmsg);
154     } else if (rval == 0) {
155     sprintf(errmsg,
156     "bad view file \"%s\"",
157     argv[i]);
158     error(USER, errmsg);
159     }
160     break;
161     case 'p': /* pixel */
162     switch (argv[i][2]) {
163     case 's': /* sample */
164     check(3,"i");
165     psample = atoi(argv[++i]);
166     break;
167     case 't': /* threshold */
168     check(3,"f");
169     maxdiff = atof(argv[++i]);
170     break;
171     case 'j': /* jitter */
172     check(3,"f");
173     dstrpix = atof(argv[++i]);
174     break;
175     case 'a': /* aspect */
176     check(3,"f");
177     pixaspect = atof(argv[++i]);
178     break;
179     case 'm': /* motion */
180     check(3,"f");
181     mblur = atof(argv[++i]);
182     break;
183 greg 2.9 case 'd': /* aperture */
184     check(3,"f");
185     dblur = atof(argv[++i]);
186     break;
187 greg 2.28 case 'R': /* standard RGB output */
188     if (strcmp(argv[i]+2, "RGB"))
189     goto badopt;
190     out_prims = stdprims;
191     break;
192     case 'X': /* XYZ output */
193     if (strcmp(argv[i]+2, "XYZ"))
194     goto badopt;
195     out_prims = xyzprims;
196     break;
197     case 'c': { /* chromaticities */
198     int j;
199     check(3,"ffffffff");
200     rval = 0;
201     for (j = 0; j < 8; j++) {
202     our_prims[0][j] = atof(argv[++i]);
203     rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
204     }
205     if (rval) {
206     if (!colorprimsOK(our_prims))
207     error(USER, "illegal primary chromaticities");
208     out_prims = our_prims;
209     } else
210     out_prims = stdprims;
211     } break;
212 greg 2.1 default:
213     goto badopt;
214     }
215     break;
216     case 'x': /* x resolution */
217     check(2,"i");
218     hresolu = atoi(argv[++i]);
219     break;
220     case 'y': /* y resolution */
221     check(2,"i");
222     vresolu = atoi(argv[++i]);
223     break;
224     case 'S': /* slave index */
225     check(2,"i");
226     seqstart = atoi(argv[++i]);
227     break;
228     case 'o': /* output file */
229     check(2,"s");
230     outfile = argv[++i];
231     break;
232     case 'z': /* z file */
233     check(2,"s");
234     zfile = argv[++i];
235     break;
236     case 'r': /* recover file */
237     if (argv[i][2] == 'o') { /* +output */
238     check(3,"s");
239     outfile = argv[i+1];
240     } else
241     check(2,"s");
242     recover = argv[++i];
243     break;
244     #ifdef PERSIST
245     case 'P': /* persist file */
246     if (argv[i][2] == 'P') {
247     check(3,"s");
248     persist = PARALLEL;
249     } else {
250     check(2,"s");
251     persist = PERSIST;
252     }
253     persistfile(argv[++i]);
254     break;
255     #endif
256 greg 2.36 case 't': /* timer */
257     check(2,"i");
258     ralrm = atoi(argv[++i]);
259     break;
260 greg 2.1 case 'w': /* warnings */
261     rval = erract[WARNING].pf != NULL;
262 schorsch 2.18 check_bool(2,rval);
263 greg 2.1 if (rval) erract[WARNING].pf = wputs;
264     else erract[WARNING].pf = NULL;
265     break;
266     case 'e': /* error file */
267     check(2,"s");
268     errfile = argv[++i];
269     break;
270     default:
271     goto badopt;
272     }
273     }
274 greg 2.30 /* set/check spectral sampling */
275 greg 2.31 if (setspectrsamp(CNDX, WLPART) <= 0)
276 greg 2.30 error(USER, "unsupported spectral sampling");
277
278 greg 2.1 err = setview(&ourview); /* set viewing parameters */
279     if (err != NULL)
280     error(USER, err);
281     /* initialize object types */
282     initotypes();
283     /* initialize urand */
284 greg 2.12 if (rand_samp) {
285     srandom((long)time(0));
286     initurand(0);
287     } else {
288     srandom(0L);
289     initurand(2048);
290     }
291 greg 2.1 /* set up signal handling */
292     sigdie(SIGINT, "Interrupt");
293 schorsch 2.4 #ifdef SIGHUP
294 greg 2.1 sigdie(SIGHUP, "Hangup");
295 schorsch 2.4 #endif
296 greg 2.1 sigdie(SIGTERM, "Terminate");
297 schorsch 2.4 #ifdef SIGPIPE
298 greg 2.1 sigdie(SIGPIPE, "Broken pipe");
299 schorsch 2.4 #endif
300     #ifdef SIGALRM
301 greg 2.1 sigdie(SIGALRM, "Alarm clock");
302 schorsch 2.4 #endif
303 greg 2.1 #ifdef SIGXCPU
304     sigdie(SIGXCPU, "CPU limit exceeded");
305     sigdie(SIGXFSZ, "File size exceeded");
306     #endif
307     /* open error file */
308     if (errfile != NULL) {
309     if (freopen(errfile, "a", stderr) == NULL)
310     quit(2);
311     fprintf(stderr, "**************\n*** PID %5d: ",
312     getpid());
313     printargs(argc, argv, stderr);
314     putc('\n', stderr);
315     fflush(stderr);
316     }
317     #ifdef NICE
318     nice(NICE); /* lower priority */
319     #endif
320     /* get octree */
321     if (i == argc)
322     octname = NULL;
323     else if (i == argc-1)
324     octname = argv[i];
325     else
326     goto badopt;
327     if (seqstart > 0 && octname == NULL)
328     error(USER, "missing octree argument");
329     /* set up output */
330     #ifdef PERSIST
331     if (persist) {
332     if (recover != NULL)
333     error(USER, "persist option used with recover file");
334     if (seqstart <= 0)
335     error(USER, "persist option only for sequences");
336     if (outfile == NULL)
337     duped1 = dup(fileno(stdout)); /* don't lose our output */
338     openheader();
339     } else
340     #endif
341     if (outfile != NULL)
342     openheader();
343 schorsch 2.3 SET_FILE_BINARY(stdout);
344 greg 2.1 if (octname == NULL)
345 schorsch 2.3 SET_FILE_BINARY(stdin);
346 greg 2.1 readoct(octname, loadflags, &thescene, NULL);
347     nsceneobjs = nobjects;
348
349     if (loadflags & IO_INFO) { /* print header */
350     printargs(i, argv, stdout);
351     printf("SOFTWARE= %s\n", VersionID);
352     }
353 greg 2.16
354     ray_init_pmap(); /* PMAP: set up & load photon maps */
355 greg 2.1
356     marksources(); /* find and mark sources */
357     setambient(); /* initialize ambient calculation */
358 greg 2.16
359 greg 2.20 fflush(stdout); /* in case we're duplicating header */
360
361 greg 2.1 #ifdef PERSIST
362     if (persist) {
363     if (outfile == NULL) { /* reconnect stdout */
364     dup2(duped1, fileno(stdout));
365     close(duped1);
366     }
367     if (persist == PARALLEL) { /* multiprocessing */
368 greg 2.34 cow_memshare(); /* preloads scene */
369 greg 2.1 while ((rval=fork()) == 0) { /* keep on forkin' */
370     pflock(1);
371     pfhold();
372     tstart = time((time_t *)NULL);
373 greg 2.13 ambsync(); /* load new values */
374 greg 2.1 }
375     if (rval < 0)
376     error(SYSTEM, "cannot fork child for persist function");
377 greg 2.13 pfdetach(); /* parent will run then exit */
378 greg 2.1 }
379     }
380     runagain:
381 schorsch 2.7 if (persist) {
382 greg 2.1 if (outfile == NULL) /* if out to stdout */
383     dupheader(); /* send header */
384     else /* if out to file */
385     duped1 = dup(fileno(stdout)); /* hang onto pipe */
386 schorsch 2.7 }
387 greg 2.1 #endif
388     /* batch render picture(s) */
389     rpict(seqstart, outfile, zfile, recover);
390     /* flush ambient file */
391     ambsync();
392     #ifdef PERSIST
393     if (persist == PERSIST) { /* first run-through */
394     if ((rval=fork()) == 0) { /* child loops until killed */
395     pflock(1);
396     persist = PCHILD;
397     } else { /* original process exits */
398     if (rval < 0)
399     error(SYSTEM, "cannot fork child for persist function");
400     pfdetach(); /* parent exits */
401     }
402     }
403     if (persist == PCHILD) { /* wait for a signal then go again */
404     if (outfile != NULL)
405     close(duped1); /* release output handle */
406     pfhold();
407     tstart = time((time_t *)NULL); /* reinitialize */
408     raynum = nrays = 0;
409     goto runagain;
410     }
411     #endif
412 greg 2.16
413
414     ray_done_pmap(); /* PMAP: free photon maps */
415
416 greg 2.1 quit(0);
417
418     badopt:
419     sprintf(errmsg, "command line error at '%s'", argv[i]);
420     error(USER, errmsg);
421 schorsch 2.8 return 1; /* pro forma return */
422 greg 2.1
423     #undef check
424 schorsch 2.18 #undef check_bool
425 greg 2.1 }
426
427
428     void
429 schorsch 2.8 wputs( /* warning output function */
430 greg 2.26 const char *s
431 schorsch 2.8 )
432 greg 2.1 {
433     int lasterrno = errno;
434 greg 2.35 if (erract[WARNING].pf == NULL)
435     return; /* called by calcomp or someone */
436 greg 2.1 eputs(s);
437     errno = lasterrno;
438     }
439
440
441     void
442 schorsch 2.8 eputs( /* put string to stderr */
443 greg 2.26 const char *s
444 schorsch 2.8 )
445 greg 2.1 {
446     static int midline = 0;
447
448     if (!*s)
449     return;
450     if (!midline++) {
451     fputs(progname, stderr);
452     fputs(": ", stderr);
453     }
454     fputs(s, stderr);
455     if (s[strlen(s)-1] == '\n') {
456     fflush(stderr);
457     midline = 0;
458     }
459     }
460
461
462 schorsch 2.8 static void
463     onsig( /* fatal signal */
464     int signo
465     )
466 greg 2.1 {
467     static int gotsig = 0;
468
469     if (gotsig++) /* two signals and we're gone! */
470     _exit(signo);
471
472 schorsch 2.4 #ifdef SIGALRM /* XXX how critical is this? */
473 greg 2.1 alarm(15); /* allow 15 seconds to clean up */
474     signal(SIGALRM, SIG_DFL); /* make certain we do die */
475 schorsch 2.4 #endif
476 greg 2.1 eputs("signal - ");
477     eputs(sigerr[signo]);
478     eputs("\n");
479     quit(3);
480     }
481
482
483 schorsch 2.8 static void
484     sigdie( /* set fatal signal */
485     int signo,
486     char *msg
487     )
488 greg 2.1 {
489     if (signal(signo, onsig) == SIG_IGN)
490     signal(signo, SIG_IGN);
491     sigerr[signo] = msg;
492     }
493
494
495 schorsch 2.8 static void
496     printdefaults(void) /* print default values to stdout */
497 greg 2.1 {
498     printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
499     ourview.type==VT_PER ? "perspective" :
500     ourview.type==VT_PAR ? "parallel" :
501     ourview.type==VT_HEM ? "hemispherical" :
502     ourview.type==VT_ANG ? "angular" :
503     ourview.type==VT_CYL ? "cylindrical" :
504 greg 2.14 ourview.type==VT_PLS ? "planisphere" :
505 greg 2.1 "unknown");
506     printf("-vp %f %f %f\t# view point\n",
507     ourview.vp[0], ourview.vp[1], ourview.vp[2]);
508     printf("-vd %f %f %f\t# view direction\n",
509     ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
510     printf("-vu %f %f %f\t# view up\n",
511     ourview.vup[0], ourview.vup[1], ourview.vup[2]);
512     printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
513     printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
514     printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
515     printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
516     printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
517     printf("-vl %f\t\t\t# view lift\n", ourview.voff);
518     printf("-x %-9d\t\t\t# x resolution\n", hresolu);
519     printf("-y %-9d\t\t\t# y resolution\n", vresolu);
520 greg 2.28 if (out_prims == stdprims)
521     printf("-pRGB\t\t\t\t# standard RGB color output\n");
522     else if (out_prims == xyzprims)
523     printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
524     else if (out_prims != NULL)
525     printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
526     out_prims[RED][0], out_prims[RED][1],
527     out_prims[GRN][0], out_prims[GRN][1],
528     out_prims[BLU][0], out_prims[BLU][1],
529     out_prims[WHT][0], out_prims[WHT][1]);
530 greg 2.1 printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
531     printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
532     printf("-pm %f\t\t\t# pixel motion\n", mblur);
533 greg 2.9 printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur);
534 greg 2.1 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
535     printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
536     printf("-t %-9d\t\t\t# time between reports\n", ralrm);
537     printf(erract[WARNING].pf != NULL ?
538     "-w+\t\t\t\t# warning messages on\n" :
539     "-w-\t\t\t\t# warning messages off\n");
540     print_rdefaults();
541     }
