root/radiance/src/rt/rpict.c
Revision: 2.103
Committed: Mon Aug 12 18:57:00 2024 UTC (14 months, 1 week ago) by greg
Changes since 2.102: +3 -17 lines
fix(rpict): Fixed light source drawing in non-RGB color spaces
2 static const char RCSid[] = "$Id: rpict.c,v 2.102 2024/07/31 22:21:28 greg Exp $";
5 * rpict.c - routines and variables for picture generation.
6 */
7
8 #include "copyright.h"
9
10 #include <sys/types.h>
11
12 #include "platform.h"
13 #ifdef NON_POSIX
14 #ifdef MINGW
15 #include <sys/time.h>
16 #endif
17 #else
18 #ifdef BSD
19 #include <sys/time.h>
20 #include <sys/resource.h>
21 #else
22 #include <sys/times.h>
23 #include <unistd.h>
24 #endif
25 #endif
26
27 #include <time.h>
28 #include <signal.h>
29
30 #include "ray.h"
31 #include "paths.h"
32 #include "ambient.h"
33 #include "view.h"
34 #include "random.h"
35 #include "paths.h"
36 #include "hilbert.h"
37 #include "pmapbias.h"
38 #include "pmapdiag.h"
39
40 #define RFTEMPLATE "rfXXXXXX"
41
42 #ifndef SIGCONT
43 #ifdef SIGIO /* XXX can we live without this? */
44 #define SIGCONT SIGIO
45 #endif
46 #endif
47
48 CUBE thescene; /* our scene */
49 OBJECT nsceneobjs; /* number of objects in our scene */
50
51 extern RGBPRIMP out_prims; /* output color primitives (NULL if spectral) */
52
53 int dimlist[MAXDIM]; /* sampling dimensions */
54 int ndims = 0; /* number of sampling dimensions */
55 int samplendx; /* sample index number */
56
57 void (*addobjnotify[])() = {ambnotify, NULL};
58
59 VIEW ourview = STDVIEW; /* view parameters */
60 int hresolu = 512; /* horizontal resolution */
61 int vresolu = 512; /* vertical resolution */
62 double pixaspect = 1.0; /* pixel aspect ratio */
63
64 int psample = 4; /* pixel sample size */
65 double maxdiff = .05; /* max. difference for interpolation */
66 double dstrpix = 0.67; /* square pixel distribution */
67
68 double mblur = 0.; /* motion blur parameter */
69
70 double dblur = 0.; /* depth-of-field blur parameter */
71
72 void (*trace)() = NULL; /* trace call */
73
74 int do_irrad = 0; /* compute irradiance? */
75
76 int rand_samp = 0; /* pure Monte Carlo sampling? */
77
78 double dstrsrc = 0.0; /* square source distribution */
79 double shadthresh = .05; /* shadow threshold */
80 double shadcert = .5; /* shadow certainty */
81 int directrelay = 1; /* number of source relays */
82 int vspretest = 512; /* virtual source pretest density */
83 int directvis = 1; /* sources visible? */
84 double srcsizerat = .25; /* maximum ratio source size/dist. */
85
86 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
87 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
88 double seccg = 0.; /* global scattering eccentricity */
89 double ssampdist = 0.; /* scatter sampling distance */
90
91 double specthresh = .15; /* specular sampling threshold */
92 double specjitter = 1.; /* specular sampling jitter */
93
94 int backvis = 1; /* back face visibility */
95
96 int maxdepth = 7; /* maximum recursion depth */
97 double minweight = 1e-4; /* minimum ray weight */
98
99 char *ambfile = NULL; /* ambient file name */
100 COLOR ambval = BLKCOLOR; /* ambient value */
101 int ambvwt = 0; /* initial weight for ambient value */
102 double ambacc = 0.2; /* ambient accuracy */
103 int ambres = 64; /* ambient resolution */
104 int ambdiv = 512; /* ambient divisions */
105 int ambssamp = 128; /* ambient super-samples */
106 int ambounce = 0; /* ambient bounces */
107 char *amblist[AMBLLEN]; /* ambient include/exclude list */
108 int ambincl = -1; /* include == 1, exclude == 0 */
109
110 int ralrm = 0; /* seconds between reports */
111
112 double pctdone = 0.0; /* percentage done */
113 time_t tlastrept = 0L; /* time at last report */
114 time_t tstart; /* starting time */
115
116 #define MAXDIV 16 /* maximum sample size */
117
118 #define pixjitter() (.5+dstrpix*(.5-frandom()))
119
120 int hres, vres; /* resolution for this frame */
121
122 static VIEW lastview; /* the previous view input */
123
124 static void report(int);
125 static int nextview(FILE *fp);
126 static void render(char *zfile, char *oldfile);
127 static void fillscanline(COLOR *scanline, float *zline, char *sd, int xres,
128 int y, int xstep);
129 static void fillscanbar(COLOR *scanbar[], float *zbar[], int xres,
130 int y, int ysize);
131 static int fillsample(COLOR *colline, float *zline, int x, int y,
132 int xlen, int ylen, int b);
133 static double pixvalue(COLOR col, int x, int y);
134 static int salvage(char *oldfile);
135 static int pixnumber(int x, int y, int xres, int yres);
136
137
138
139 void
140 quit(int code) /* quit program */
141 {
142 if (code) /* report status */
143 report(0);
144 #ifndef NON_POSIX
145 headclean(); /* delete header file */
146 pfclean(); /* clean up persist files */
147 #endif
148 exit(code);
149 }
150
151
152 #ifndef NON_POSIX
153 static void
154 report(int dummy) /* report progress */
155 {
156 char bcStat [128];
157 double u, s;
158 #ifdef BSD
159 struct rusage rubuf;
160 #else
161 double period = 1.0 / 60.0;
162 struct tms tbuf;
163 #endif
164
165 tlastrept = time((time_t *)NULL);
166 #ifdef BSD
167 getrusage(RUSAGE_SELF, &rubuf);
168 u = rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec*1e-6;
169 s = rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec*1e-6;
170 getrusage(RUSAGE_CHILDREN, &rubuf);
171 u += rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec*1e-6;
172 s += rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec*1e-6;
173 #else
174 times(&tbuf);
175 #ifdef _SC_CLK_TCK
176 period = 1.0 / sysconf(_SC_CLK_TCK);
177 #endif
178 u = ( tbuf.tms_utime + tbuf.tms_cutime ) * period;
179 s = ( tbuf.tms_stime + tbuf.tms_cstime ) * period;
180 #endif
181
182 /* PMAP: Get photon map bias compensation statistics */
183 pmapBiasCompReport(bcStat);
184
185 sprintf(errmsg,
186 "%lu rays, %s%4.2f%% after %.3fu %.3fs %.3fr hours on %s (PID %d)\n",
187 nrays, bcStat, pctdone, u*(1./3600.), s*(1./3600.),
188 (tlastrept-tstart)*(1./3600.), myhostname(), getpid());
189 eputs(errmsg);
190 #ifdef SIGCONT
191 signal(SIGCONT, report);
192 #endif
193 }
194 #else
195 static void
196 report(int dummy) /* report progress */
197 {
198 char bcStat [128];
199
200 tlastrept = time((time_t *)NULL);
201
202 /* PMAP: Get photon map bias compensation statistics */
203 pmapBiasCompReport(bcStat);
204
205 sprintf(errmsg, "%lu rays, %s%4.2f%% after %5.4f hours\n",
206 nrays, bcStat, pctdone, (tlastrept-tstart)/3600.0);
207 eputs(errmsg);
208 }
209 #endif
210
211
212 void
213 rpict( /* generate image(s) */
214 int seq,
215 char *pout,
216 char *zout,
217 char *prvr
218 )
219 /*
220 * If seq is greater than zero, then we will render a sequence of
221 * images based on view parameter strings read from the standard input.
222 * If pout is NULL, then all images will be sent to the standard ouput.
223 * If seq is greater than zero and prvr is an integer, then it is the
224 * frame number at which rendering should begin. Preceeding view parameter
225 * strings will be skipped in the input.
226 * If pout and prvr are the same, prvr is renamed to avoid overwriting.
227 * Note that pout and zout should contain %d format specifications for
228 * sequenced file naming.
229 */
230 {
231 char fbuf[128], fbuf2[128];
232 int npicts;
233 char *cp;
234 RESOLU rs;
235 double pa;
236 /* check sampling */
237 if (psample < 1)
238 psample = 1;
239 else if (psample > MAXDIV) {
240 sprintf(errmsg, "pixel sampling reduced from %d to %d",
241 psample, MAXDIV);
242 error(WARNING, errmsg);
243 psample = MAXDIV;
244 }
245 /* get starting frame */
246 if (seq <= 0)
247 seq = 0;
248 else if (prvr != NULL && isint(prvr)) {
249 int rn; /* skip to specified view */
250 if ((rn = atoi(prvr)) < seq)
251 error(USER, "recover frame less than start frame");
252 if (pout == NULL)
253 error(USER, "missing output file specification");
254 for ( ; seq < rn; seq++)
255 if (nextview(stdin) == EOF)
256 error(USER, "unexpected EOF on view input");
257 setview(&ourview);
258 prvr = fbuf; /* mark for renaming */
259 }
260 if ((pout != NULL) & (prvr != NULL)) {
261 sprintf(fbuf, pout, seq);
262 if (!strcmp(prvr, fbuf)) { /* rename */
263 strcpy(fbuf2, fbuf);
264 for (cp = fbuf2; *cp; cp++)
265 ;
266 while (cp > fbuf2 && !ISDIRSEP(cp[-1]))
267 cp--;
268 strcpy(cp, RFTEMPLATE);
269 prvr = mktemp(fbuf2);
270 if (rename(fbuf, prvr) < 0) {
271 if (errno == ENOENT) { /* ghost file */
272 sprintf(errmsg,
273 "new output file \"%s\"",
274 fbuf);
275 error(WARNING, errmsg);
276 prvr = NULL;
277 } else { /* serious error */
278 sprintf(errmsg,
279 "cannot rename \"%s\" to \"%s\"",
280 fbuf, prvr);
281 error(SYSTEM, errmsg);
282 }
283 }
284 }
285 }
286 npicts = 0; /* render sequence */
287 do {
288 if (seq && nextview(stdin) == EOF)
289 break;
290 pctdone = 0.0;
291 if (pout != NULL) {
292 int myfd;
293 close(1); /* reassign stdout */
294 sprintf(fbuf, pout, seq);
295 tryagain:
296 errno = 0; /* exclusive open */
297 if ((myfd = open(fbuf, O_WRONLY|O_CREAT|O_EXCL, 0666)) < 0) {
298 if ((errno != EEXIST) | (prvr != NULL) ||
299 !strcmp(fbuf, pout)) {
300 sprintf(errmsg,
301 "cannot open output file \"%s\"",
302 fbuf);
303 error(SYSTEM, errmsg);
304 }
305 setview(&ourview);
306 continue; /* don't clobber */
307 }
308 if (myfd != 1) {
309 unlink(fbuf);
310 goto tryagain; /* leave it open */
311 }
312 SET_FD_BINARY(1);
313 dupheader();
314 }
315 hres = hresolu; vres = vresolu; pa = pixaspect;
316 if (prvr != NULL) {
317 if (viewfile(prvr, &ourview, &rs) <= 0) {
318 sprintf(errmsg,
319 "cannot recover view parameters from \"%s\"", prvr);
320 error(WARNING, errmsg);
321 } else {
322 pa = 0.0;
323 hres = scanlen(&rs);
324 vres = numscans(&rs);
325 }
326 }
327 if ((cp = setview(&ourview)) != NULL)
328 error(USER, cp);
329 normaspect(viewaspect(&ourview), &pa, &hres, &vres);
330 if (seq) {
331 if (ralrm > 0) {
332 fprintf(stderr, "FRAME %d:", seq);
333 fprintview(&ourview, stderr);
334 putc('\n', stderr);
335 fflush(stderr);
336 }
337 printf("FRAME=%d\n", seq);
338 }
339 fputs(VIEWSTR, stdout);
340 fprintview(&ourview, stdout);
341 putchar('\n');
342 if ((pa < .99) | (pa > 1.01))
343 fputaspect(pa, stdout);
344 fputnow(stdout);
345 if (out_prims == xyzprims) {
346 fputformat(CIEFMT, stdout);
347 } else {
348 fputprims(out_prims, stdout);
349 fputformat(COLRFMT, stdout);
350 }
351 putchar('\n'); /* close header */
352 if (zout != NULL)
353 sprintf(cp=fbuf, zout, seq);
354 else
355 cp = NULL;
356 render(cp, prvr);
357 prvr = NULL;
358 npicts++;
359 } while (seq++);
360 /* check that we did something */
361 if (npicts == 0)
362 error(WARNING, "no output produced");
363 }
364
365
366 static int
367 nextview( /* get next view from fp */
368 FILE *fp
369 )
370 {
371 char linebuf[256];
372
373 lastview = ourview;
374 while (fgets(linebuf, sizeof(linebuf), fp) != NULL)
375 if (isview(linebuf) && sscanview(&ourview, linebuf) > 0)
376 return(0);
377 return(EOF);
378 }
379
380
381 static void
382 render( /* render the scene */
383 char *zfile,
384 char *oldfile
385 )
386 {
387 const int srcdrawing = /* manually draw tiny light sources? */
388 (directvis && dblur <= FTINY && (mblur <= FTINY) | !lastview.type);
389 COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */
390 float *zbar[MAXDIV+1]; /* z values */
391 char *sampdens; /* previous sample density */
392 int ypos; /* current scanline */
393 int ystep; /* current y step size */
394 int hstep; /* h step size */
395 int zfd;
396 COLOR *colptr;
397 float *zptr;
398 int i;
399 /* check for empty image */
400 if ((hres <= 0) | (vres <= 0)) {
401 error(WARNING, "empty output picture");
402 fprtresolu(0, 0, stdout);
403 return;
404 }
405 /* allocate scanlines */
406 for (i = 0; i <= psample; i++) {
407 scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR));
408 if (scanbar[i] == NULL)
409 goto memerr;
410 }
411 hstep = (psample*140+49)/99; /* quincunx sampling */
412 ystep = (psample*99+70)/140;
413 if (hstep > 2) {
414 i = hres/hstep + 2;
415 if ((sampdens = (char *)malloc(i)) == NULL)
416 goto memerr;
417 while (i--)
418 sampdens[i] = hstep;
419 } else
420 sampdens = NULL;
421 /* open z-file */
422 if (zfile != NULL) {
423 if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) {
424 sprintf(errmsg, "cannot open z-file \"%s\"", zfile);
425 error(SYSTEM, errmsg);
426 }
427 SET_FD_BINARY(zfd);
428 for (i = 0; i <= psample; i++) {
429 zbar[i] = (float *)malloc(hres*sizeof(float));
430 if (zbar[i] == NULL)
431 goto memerr;
432 }
433 } else {
434 zfd = -1;
435 for (i = 0; i <= psample; i++)
436 zbar[i] = NULL;
437 }
438 /* write out boundaries */
439 fprtresolu(hres, vres, stdout);
440 /* recover file and compute first */
441 i = salvage(oldfile);
442 if (i >= vres)
443 goto alldone;
444 if ((zfd != -1) & (i > 0) &&
445 lseek(zfd, (off_t)i*hres*sizeof(float), SEEK_SET) < 0)
446 error(SYSTEM, "z-file seek error in render");
447 pctdone = 100.0*i/vres;
448 if (ralrm > 0) /* report init stats */
449 report(0);
450 #ifdef SIGCONT
451 else
452 signal(SIGCONT, report);
453 #endif
454 ypos = vres-1 - i; /* initialize sampling */
455 if (srcdrawing)
456 init_drawsources(psample);
457 fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep);
458 /* compute scanlines */
459 for (ypos -= ystep; ypos > -ystep; ypos -= ystep) {
460 /* bottom adjust? */
461 if (ypos < 0) {
462 ystep += ypos;
463 ypos = 0;
464 }
465 colptr = scanbar[ystep]; /* move base to top */
466 scanbar[ystep] = scanbar[0];
467 scanbar[0] = colptr;
468 zptr = zbar[ystep];
469 zbar[ystep] = zbar[0];
470 zbar[0] = zptr;
471 /* fill base line */
472 fillscanline(scanbar[0], zbar[0], sampdens,
473 hres, ypos, hstep);
474 /* fill bar */
475 fillscanbar(scanbar, zbar, hres, ypos, ystep);
476 if (srcdrawing) /* add bitty sources */
477 drawsources((COLORV **)scanbar, 3, zbar, 0, hres, ypos, ystep);
478 /* write it out */
479 #ifdef SIGCONT
480 signal(SIGCONT, SIG_IGN); /* don't interrupt writes */
481 #endif
482 for (i = ystep; i > 0; i--) {
483 if (zfd != -1 && write(zfd, (char *)zbar[i],
484 hres*sizeof(float))
485 < hres*sizeof(float))
486 goto writerr;
487 if (fwritescan(scanbar[i], hres, stdout) < 0)
488 goto writerr;
489 }
490 if (fflush(stdout) == EOF)
491 goto writerr;
492 /* record progress */
493 pctdone = 100.0*(vres-1-ypos)/vres;
494 if (ralrm > 0 && time((time_t *)NULL) >= tlastrept+ralrm)
495 report(0);
496 #ifdef SIGCONT
497 else
498 signal(SIGCONT, report);
499 #endif
500 }
501 /* clean up */
502 #ifdef SIGCONT
503 signal(SIGCONT, SIG_IGN);
504 #endif
505 if (zfd != -1 && write(zfd, (char *)zbar[0], hres*sizeof(float))
506 < hres*sizeof(float))
507 goto writerr;
508 fwritescan(scanbar[0], hres, stdout);
509 if (fflush(stdout) == EOF)
510 goto writerr;
511 alldone:
512 if (zfd != -1) {
513 if (close(zfd) == -1)
514 goto writerr;
515 for (i = 0; i <= psample; i++)
516 free((void *)zbar[i]);
517 }
518 for (i = 0; i <= psample; i++)
519 free((void *)scanbar[i]);
520 if (sampdens != NULL)
521 free(sampdens);
522 pctdone = 100.0;
523 if (ralrm > 0)
524 report(0);
525 #ifdef SIGCONT
526 signal(SIGCONT, SIG_DFL);
527 #endif
528 return;
529 writerr:
530 error(SYSTEM, "write error in render");
531 memerr:
532 error(SYSTEM, "out of memory in render");
533 }
534
535
536 static void
537 fillscanline( /* fill scan at y */
538 COLOR *scanline,
539 float *zline,
540 char *sd,
541 int xres,
542 int y,
543 int xstep
544 )
545 {
546 static int nc = 0; /* number of calls */
547 int bl = xstep, b = xstep;
548 double z;
549 int i;
550
551 z = pixvalue(scanline[0], 0, y);
552 if (zline) zline[0] = z;
553 /* zig-zag start for quincunx pattern */
554 for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) {
555 if (i >= xres) {
556 xstep += xres-1-i;
557 i = xres-1;
558 }
559 z = pixvalue(scanline[i], i, y);
560 if (zline) zline[i] = z;
561 if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1];
562 if (i <= xstep)
563 b = fillsample(scanline, zline, 0, y, i, 0, b/2);
564 else
565 b = fillsample(scanline+i-xstep,
566 zline ? zline+i-xstep : (float *)NULL,
567 i-xstep, y, xstep, 0, b/2);
568 if (sd) *sd++ = nc & 1 ? bl : b;
569 bl = b;
570 }
571 if (sd && nc & 1) *sd = bl;
572 }
573
574
575 static void
576 fillscanbar( /* fill interior */
577 COLOR *scanbar[],
578 float *zbar[],
579 int xres,
580 int y,
581 int ysize
582 )
583 {
584 COLOR vline[MAXDIV+1];
585 float zline[MAXDIV+1];
586 int b = ysize;
587 int i, j;
588
589 for (i = 0; i < xres; i++) {
590 copycolor(vline[0], scanbar[0][i]);
591 copycolor(vline[ysize], scanbar[ysize][i]);
592 if (zbar[0]) {
593 zline[0] = zbar[0][i];
594 zline[ysize] = zbar[ysize][i];
595 }
596 b = fillsample(vline, zbar[0] ? zline : (float *)NULL,
597 i, y, 0, ysize, b/2);
598
599 for (j = 1; j < ysize; j++)
600 copycolor(scanbar[j][i], vline[j]);
601 if (zbar[0])
602 for (j = 1; j < ysize; j++)
603 zbar[j][i] = zline[j];
604 }
605 }
606
607
608 static int
609 fillsample( /* fill interior points */
610 COLOR *colline,
611 float *zline,
612 int x,
613 int y,
614 int xlen,
615 int ylen,
616 int b
617 )
618 {
619 double ratio;
620 double z;
621 COLOR ctmp;
622 int ncut;
623 int len;
624
625 if (xlen > 0) /* x or y length is zero */
626 len = xlen;
627 else
628 len = ylen;
629
630 if (len <= 1) /* limit recursion */
631 return(0);
632
633 if (b > 0 ||
634 (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len]))
635 || bigdiff(colline[0], colline[len], maxdiff)) {
636
637 z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1));
638 if (zline) zline[len>>1] = z;
639 ncut = 1;
640 } else { /* interpolate */
641 copycolor(colline[len>>1], colline[len]);
642 ratio = (double)(len>>1) / len;
643 scalecolor(colline[len>>1], ratio);
644 if (zline) zline[len>>1] = zline[len] * ratio;
645 ratio = 1.0 - ratio;
646 copycolor(ctmp, colline[0]);
647 scalecolor(ctmp, ratio);
648 addcolor(colline[len>>1], ctmp);
649 if (zline) zline[len>>1] += zline[0] * ratio;
650 ncut = 0;
651 }
652 /* recurse */
653 ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2);
654
655 ncut += fillsample(colline+(len>>1),
656 zline ? zline+(len>>1) : (float *)NULL,
657 x+(xlen>>1), y+(ylen>>1),
658 xlen-(xlen>>1), ylen-(ylen>>1), b/2);
659
660 return(ncut);
661 }
662
663
664 static double
665 pixvalue( /* compute pixel value */
666 COLOR col, /* returned color */
667 int x, /* pixel position */
668 int y
669 )
670 {
671 RAY thisray;
672 FVECT lorg, ldir;
673 double hpos, vpos, lmax;
674 int i;
675 /* compute view ray */
676 setcolor(col, 0.0, 0.0, 0.0);
677 hpos = (x+pixjitter())/hres;
678 vpos = (y+pixjitter())/vres;
679 if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir,
680 &ourview, hpos, vpos)) < -FTINY)
681 return(0.0);
682 /* set pixel index */
683 samplendx = pixnumber(x,y,hres,vres);
684 /* optional motion blur */
685 if (lastview.type && mblur > FTINY && (lmax = viewray(lorg, ldir,
686 &lastview, hpos, vpos)) >= -FTINY) {
687 double d = mblur*(.5-urand(281+samplendx));
688
689 thisray.rmax = (1.-d)*thisray.rmax + d*lmax;
690 for (i = 3; i--; ) {
691 thisray.rorg[i] = (1.-d)*thisray.rorg[i] + d*lorg[i];
692 thisray.rdir[i] = (1.-d)*thisray.rdir[i] + d*ldir[i];
693 }
694 if (normalize(thisray.rdir) == 0.0)
695 return(0.0);
696 }
697 /* depth-of-field */
698 if (!jitteraperture(thisray.rorg, thisray.rdir, &ourview, dblur))
699 return(0.0);
700
701 rayorigin(&thisray, PRIMARY, NULL, NULL);
702
703 rayvalue(&thisray); /* trace ray */
704 /* -> color */
705 scolor_out(col, out_prims, thisray.rcol);
706
707 return(raydistance(&thisray)); /* return distance */
708 }
709
710
711 static int
712 salvage( /* salvage scanlines from killed program */
713 char *oldfile
714 )
715 {
716 COLR *scanline;
717 FILE *fp;
718 int x, y;
719
720 if (oldfile == NULL)
721 goto gotzip;
722
723 if ((fp = fopen(oldfile, "r")) == NULL) {
724 sprintf(errmsg, "cannot open recover file \"%s\"", oldfile);
725 error(WARNING, errmsg);
726 goto gotzip;
727 }
728 SET_FILE_BINARY(fp);
729 /* discard header */
730 getheader(fp, NULL, NULL);
731 /* get picture size */
732 if (!fscnresolu(&x, &y, fp)) {
733 sprintf(errmsg, "bad recover file \"%s\" - not removed",
734 oldfile);
735 error(WARNING, errmsg);
736 fclose(fp);
737 goto gotzip;
738 }
739
740 if ((x != hres) | (y != vres)) {
741 sprintf(errmsg, "resolution mismatch in recover file \"%s\"",
742 oldfile);
743 error(USER, errmsg);
744 }
745
746 scanline = (COLR *)malloc(hres*sizeof(COLR));
747 if (scanline == NULL)
748 error(SYSTEM, "out of memory in salvage");
749 for (y = 0; y < vres; y++) {
750 if (freadcolrs(scanline, hres, fp) < 0)
751 break;
752 if (fwritecolrs(scanline, hres, stdout) < 0)
753 goto writerr;
754 }
755 if (fflush(stdout) == EOF)
756 goto writerr;
757 free((void *)scanline);
758 fclose(fp);
759 unlink(oldfile);
760 return(y);
761 gotzip:
762 if (fflush(stdout) == EOF)
763 error(SYSTEM, "error writing picture header");
764 return(0);
765 writerr:
766 sprintf(errmsg, "write error during recovery of \"%s\"", oldfile);
767 error(SYSTEM, errmsg);
768 return -1; /* pro forma return */
769 }
770
771 static int
772 pixnumber( /* compute pixel index (screen door) */
773 int x,
774 int y,
775 int xres,
776 int yres
777 )
778 {
779 unsigned nbits = 0;
780 bitmask_t coord[2];
781
782 if (xres < yres) xres = yres;
783 while (xres > 0) {
784 xres >>= 1;
785 ++nbits;
786 }
787 coord[0] = x; coord[1] = y;
788 return ((int)hilbert_c2i(2, nbits, coord));
789 }
