| 1 |
/* RCSid $Id: rpaint.h,v 2.11 2013/11/13 23:45:54 greg Exp $ */ |
| 2 |
| 3 |
 *  rpaint.h - header file for image painting. |
| 4 |
| 5 |
#ifndef _RAD_RPAINT_H_ |
| 6 |
#define _RAD_RPAINT_H_ |
| 7 |
| 8 |
#include  "driver.h" |
| 9 |
#include  "view.h" |
| 10 |
| 11 |
#ifdef __cplusplus |
| 12 |
extern "C" { |
| 13 |
#endif |
| 14 |
| 15 |
#if defined(_WIN32) || defined(_WIN64) |
| 16 |
  /* stupid Windows name collisions */ |
| 17 |
  #undef COORD |
| 18 |
  #define COORD radCOORD |
| 19 |
  #undef RECT |
| 20 |
  #define RECT  radRECT |
| 21 |
#endif |
| 22 |
| 23 |
typedef short  COORD;           /* an image coordinate */ |
| 24 |
| 25 |
typedef struct pnode { |
| 26 |
        struct pnode  *kid;             /* children */ |
| 27 |
        COORD  x, y;                    /* position */ |
| 28 |
        COORD  xmin, ymin, xmax, ymax;  /* rectangle */ |
| 29 |
        COLOR  v;                       /* value */ |
| 30 |
}  PNODE;                       /* a paint node */ |
| 31 |
| 32 |
                                /* child ordering */ |
| 33 |
#define  DL             0               /* down left */ |
| 34 |
#define  DR             1               /* down right */ |
| 35 |
#define  UL             2               /* up left */ |
| 36 |
#define  UR             3               /* up right */ |
| 37 |
| 38 |
#define  newptree()     (PNODE *)calloc(4, sizeof(PNODE)) |
| 39 |
| 40 |
typedef struct { |
| 41 |
        COORD  l, d, r, u;              /* left, down, right, up */ |
| 42 |
}  RECT;                        /* a rectangle */ |
| 43 |
| 44 |
extern PNODE  ptrunk;           /* the base of the image tree */ |
| 45 |
| 46 |
extern VIEW  ourview;           /* current view parameters */ |
| 47 |
extern VIEW  oldview;           /* previous view parameters */ |
| 48 |
extern int  hresolu, vresolu;   /* image resolution */ |
| 49 |
| 50 |
extern int  newparam;           /* parameter setting changed */ |
| 51 |
| 52 |
extern char  *dvcname;          /* output device name */ |
| 53 |
| 54 |
extern char  rifname[];         /* rad input file name */ |
| 55 |
| 56 |
extern int  psample;            /* pixel sample size */ |
| 57 |
extern double  maxdiff;         /* max. sample difference */ |
| 58 |
| 59 |
extern int  greyscale;          /* map colors to brightness? */ |
| 60 |
| 61 |
extern int  pdepth;             /* image depth in current frame */ |
| 62 |
extern RECT  pframe;            /* current frame rectangle */ |
| 63 |
| 64 |
extern double  exposure;        /* exposure for scene */ |
| 65 |
| 66 |
extern struct driver  *dev;     /* driver functions */ |
| 67 |
| 68 |
extern int  nproc;              /* number of processes */ |
| 69 |
| 70 |
                                /* defined in rview.c */ |
| 71 |
extern void     devopen(char *dname); |
| 72 |
extern void     devclose(void); |
| 73 |
extern void     printdevices(void); |
| 74 |
extern void     command(char *prompt); |
| 75 |
extern void     rsample(void); |
| 76 |
extern int      refine(PNODE *p, int pd); |
| 77 |
                                /* defined in rv2.c */ |
| 78 |
extern void     getframe(char *s); |
| 79 |
extern void     getrepaint(char *s); |
| 80 |
extern void     getview(char *s); |
| 81 |
extern void     lastview(char *s); |
| 82 |
extern void     saveview(char *s); |
| 83 |
extern void     loadview(char *s); |
| 84 |
extern void     getfocus(char *s); |
| 85 |
extern void     getaim(char *s); |
| 86 |
extern void     getmove(char *s); |
| 87 |
extern void     getrotate(char *s); |
| 88 |
extern void     getpivot(char *s); |
| 89 |
extern void     getorigin(char *s); |
| 90 |
extern void     getexposure(char *s); |
| 91 |
extern int      getparam(char *str, char *dsc, int typ, void *p); |
| 92 |
extern void     setparam(char *s); |
| 93 |
extern void     traceray(char *s); |
| 94 |
extern void     writepict(char *s); |
| 95 |
                                /* defined in rv3.c */ |
| 96 |
extern int      getrect(char *s, RECT *r); |
| 97 |
extern int      getinterest(char *s, int direc, FVECT vec, double *mp); |
| 98 |
extern float    *greyof(COLOR col); |
| 99 |
extern int      paint(PNODE *p); |
| 100 |
extern int      waitrays(void); |
| 101 |
extern void     newimage(char *s); |
| 102 |
extern void     redraw(void); |
| 103 |
extern void     repaint(int xmin, int ymin, int xmax, int ymax); |
| 104 |
extern void     paintrect(PNODE *p, RECT *r); |
| 105 |
extern PNODE    *findrect(int x, int y, PNODE *p, int pd); |
| 106 |
extern void     compavg(PNODE *p); |
| 107 |
extern void     scalepict(PNODE *p, double sf); |
| 108 |
extern void     getpictcolrs(int yoff, COLR *scan, PNODE *p, |
| 109 |
                        int xsiz, int ysiz); |
| 110 |
extern void     freepkids(PNODE *p); |
| 111 |
extern void     newview(VIEW *vp); |
| 112 |
extern void     moveview(double angle, double elev, double mag, FVECT vc); |
| 113 |
extern void     pcopy(PNODE *p1, PNODE *p2); |
| 114 |
extern void     zoomview(VIEW *vp, double zf); |
| 115 |
| 116 |
| 117 |
| 118 |
| 119 |
#endif |
| 120 |
#endif /* _RAD_RPAINT_H_ */ |
| 121 |
