root/radiance/src/rt/raypcalls.c
Wed Feb 20 05:21:29 2008 UTC (17 years, 7 months ago) by greg
Changes since 2.18: +6 -9 lines
Diff to previous 2.18
Changed back to old queuing behavior
Fri Feb 8 18:27:31 2008 UTC (17 years, 8 months ago) by greg
Changes since 2.17: +3 -5 lines
Diff to previous 2.17
Created stub routines as placeholder for Windows version of raypcalls
Tue Sep 18 19:10:02 2007 UTC (18 years, 1 month ago) by greg
Diff to previous 2.16
Fixed potential bug where send queue gets jammed in ray_pqueue()
Sat Sep 15 02:47:56 2007 UTC (18 years, 1 month ago) by greg
Changes since 2.15: +4 -1 lines
Diff to previous 2.15
Eliminated unnecessary call to select(2) for single process
Wed Sep 12 03:57:00 2007 UTC (18 years, 1 month ago) by greg
Changes since 2.14: +5 -1 lines
Diff to previous 2.14
Added check for parent process to close children before exit
Wed Dec 21 17:36:06 2005 UTC (19 years, 9 months ago) by greg
Changes since 2.13: +9 -13 lines
Diff to previous 2.13
Minor cosmetic changes
Tue Dec 20 20:36:44 2005 UTC (19 years, 9 months ago) by greg
Changes since 2.12: +14 -13 lines
Diff to previous 2.12
Added ambient file synchronization and minor fixes
Sat Dec 17 22:17:51 2005 UTC (19 years, 10 months ago) by greg
Changes since 2.11: +6 -7 lines
Fixed bug in reading of ray buffers
Tue Apr 19 01:15:06 2005 UTC (20 years, 6 months ago) by greg
Fri Apr 15 04:44:51 2005 UTC (20 years, 6 months ago) by greg
Mon Sep 20 16:26:58 2004 UTC (21 years ago) by greg
Fri Sep 17 21:43:50 2004 UTC (21 years, 1 month ago) by greg
Fri Sep 17 14:27:33 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.6: +14 -10 lines
Fixed up comments in header
Tue Mar 30 16:13:01 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 2.5: +45 -29 lines
Sun Jul 27 22:12:03 2003 UTC (22 years, 2 months ago) by schorsch
Mon Jul 21 22:30:19 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 2.3: +8 -8 lines
Thu Jul 3 15:00:19 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.2: +34 -34 lines
Tue Feb 25 02:47:23 2003 UTC (22 years, 7 months ago) by greg
Sat Feb 22 02:07:29 2003 UTC (22 years, 7 months ago) by greg
