| 1 |
greg |
2.19 |
{ RCSid $Id: rayinit.cal,v 2.18 2018/11/30 18:43:57 greg Exp $ } |
| 2 |
greg |
1.1 |
| 3 |
        Initialization file for Radiance. |
| 4 |
| 5 |
        The following are predefined: |
| 6 |
| 7 |
        Dx, Dy, Dz                      - ray direction |
| 8 |
        Nx, Ny, Nz                      - surface normal |
| 9 |
        Px, Py, Pz                      - intersection point |
| 10 |
        T                               - distance from start |
| 11 |
greg |
2.3 |
        Ts                              - single ray (shadow) distance |
| 12 |
greg |
1.1 |
        Rdot                            - ray dot product |
| 13 |
        S                               - world scale |
| 14 |
        Tx, Ty, Tz                      - world origin |
| 15 |
        Ix, Iy, Iz                      - world i unit vector |
| 16 |
        Jx, Jy, Jz                      - world j unit vector |
| 17 |
        Kx, Ky, Kz                      - world k unit vector |
| 18 |
        arg(n)                          - real arguments, arg(0) is count |
| 19 |
greg |
2.14 |
| 20 |
        For mesh objects, the following are available: |
| 21 |
| 22 |
        Lu, Lv                          - local (u,v) coordinates |
| 23 |
greg |
1.1 |
| 24 |
greg |
2.15 |
        For *func & *data materials, the following are also available: |
| 25 |
greg |
1.1 |
| 26 |
        NxP, NyP, NzP                   - perturbed surface normal |
| 27 |
        RdotP                           - perturbed ray dot product |
| 28 |
        CrP, CgP, CbP                   - perturbed material color |
| 29 |
| 30 |
greg |
2.9 |
        For prism1 and prism2 types, the following are available: |
| 31 |
| 32 |
        DxA, DyA, DzA                   - direction to target light source |
| 33 |
| 34 |
greg |
1.1 |
        Library functions: |
| 35 |
| 36 |
        if(a, b, c)                     - if a positive, return b, else c |
| 37 |
| 38 |
        select(N, a1, a2, ..)           - return aN |
| 39 |
| 40 |
greg |
2.19 |
        min(a1, a2, ..)                 - return minimum argument |
| 41 |
        max(a1, a2, ..)                 - return maximum argument |
| 42 |
| 43 |
greg |
1.1 |
        sqrt(x)                         - square root function |
| 44 |
| 45 |
        sin(x), cos(x), tan(x), |
| 46 |
        asin(x), acos(x), |
| 47 |
greg |
2.15 |
        atan(x), atan2(y,x)             - standard trig functions (radians) |
| 48 |
greg |
1.1 |
| 49 |
        floor(x), ceil(x)               - g.l.b. & l.u.b. |
| 50 |
| 51 |
        exp(x), log(x), log10(x)        - exponent and log functions |
| 52 |
| 53 |
        erf(z), erfc(z)                 - error functions |
| 54 |
| 55 |
        rand(x)                         - pseudo-random function (0 to 1) |
| 56 |
| 57 |
greg |
2.11 |
        noise3(x,y,z), noise3x(x,y,z), |
| 58 |
        noise3y(x,y,z), noise3z(x,y,z)  - noise function with gradient (-1 to 1) |
| 59 |
greg |
1.1 |
| 60 |
        fnoise3(x,y,z)                  - fractal noise function (-1 to 1) |
| 61 |
| 62 |
| 63 |
                        { Backward compatibility } |
| 64 |
AC = arg(0); |
| 65 |
A1 = arg(1); A2 = arg(2); A3 = arg(3); A4 = arg(4); A5 = arg(5); |
| 66 |
A6 = arg(6); A7 = arg(7); A8 = arg(8); A9 = arg(9); A10 = arg(10); |
| 67 |
| 68 |
greg |
2.11 |
noise3a(x,y,z) : noise3x(x,y,z); |
| 69 |
noise3b(x,y,z) : noise3y(x,y,z); |
| 70 |
noise3c(x,y,z) : noise3z(x,y,z); |
| 71 |
| 72 |
greg |
1.1 |
                        { Forward compatibility (?) } |
| 73 |
D(i) = select(i, Dx, Dy, Dz); |
| 74 |
N(i) = select(i, Nx, Ny, Nz); |
| 75 |
P(i) = select(i, Px, Py, Pz); |
| 76 |
greg |
2.11 |
noise3d(i,x,y,z) : select(i, noise3x(x,y,z), noise3y(x,y,z), noise3z(x,y,z)); |
| 77 |
greg |
1.1 |
| 78 |
                        { More robust versions of library functions } |
| 79 |
bound(a,x,b) : if(a-x, a, if(x-b, b, x)); |
| 80 |
Acos(x) : acos(bound(-1,x,1)); |
| 81 |
Asin(x) : asin(bound(-1,x,1)); |
| 82 |
greg |
2.8 |
Atan2(y,x) : if(x*x+y*y, atan2(y,x), 0); |
| 83 |
greg |
2.2 |
Exp(x) : if(-x-100, 0, exp(x)); |
| 84 |
greg |
1.1 |
Sqrt(x) : if(x, sqrt(x), 0); |
| 85 |
| 86 |
                        { Useful constants } |
| 87 |
PI : 3.14159265358979323846; |
| 88 |
DEGREE : PI/180; |
| 89 |
FTINY : 1e-7; |
| 90 |
| 91 |
                        { Useful functions } |
| 92 |
and(a,b) : if( a, b, a ); |
| 93 |
or(a,b) : if( a, a, b ); |
| 94 |
not(a) : if( a, -1, 1 ); |
| 95 |
greg |
2.13 |
xor(a,b) : if( a, not(b), b ); |
| 96 |
greg |
1.1 |
abs(x) : if( x, x, -x ); |
| 97 |
sgn(x) : if( x, 1, if(-x, -1, 0) ); |
| 98 |
sq(x) : x*x; |
| 99 |
inside(a,x,b) : and(x-a,b-x); |
| 100 |
frac(x) : x - floor(x); |
| 101 |
mod(n,d) : n - floor(n/d)*d; |
| 102 |
tri(n,d) : abs( d - mod(n-d,2*d) ); |
| 103 |
linterp(t,p0,p1) : (1-t)*p0 + t*p1; |
| 104 |
| 105 |
gwlarson |
2.12 |
noop(v) : v; |
| 106 |
clip(v) : bound(0,v,1); |
| 107 |
noneg(v) : if(v,v,0); |
| 108 |
red(r,g,b) : if(r,r,0); |
| 109 |
green(r,g,b) : if(g,g,0); |
| 110 |
blue(r,g,b) : if(b,b,0); |
| 111 |
grey(r,g,b) : noneg(.265074126*r + .670114631*g + .064811243*b); |
| 112 |
clip_r(r,g,b) : bound(0,r,1); |
| 113 |
clip_g(r,g,b) : bound(0,g,1); |
| 114 |
clip_b(r,g,b) : bound(0,b,1); |
| 115 |
clipgrey(r,g,b) : min(grey(r,g,b),1); |
| 116 |
greg |
1.1 |
| 117 |
dot(v1,v2) : v1(1)*v2(1) + v1(2)*v2(2) + v1(3)*v2(3); |
| 118 |
cross(i,v1,v2) : select(i,      v1(2)*v2(3) - v1(3)*v2(2), |
| 119 |
                                v1(3)*v2(1) - v1(1)*v2(3), |
| 120 |
                                v1(1)*v2(2) - v1(2)*v2(1)); |
| 121 |
| 122 |
gwlarson |
2.12 |
fade(near_val,far_val,dist) : far_val + |
| 123 |
greg |
1.1 |
                if (16-dist, (near_val-far_val)/(1+dist*dist), 0); |
| 124 |
| 125 |
greg |
2.16 |
hermite(p0,p1,r0,r1,t) :        p0 * ((2*t-3)*t*t+1) + |
| 126 |
                                p1 * (-2*t+3)*t*t + |
| 127 |
                                r0 * (((t-2)*t+1)*t) + |
| 128 |
                                r1 * ((t-1)*t*t); |
| 129 |
| 130 |
gwlarson |
2.12 |
bezier(p1, p2, p3, p4, t) :     p1 * (1+t*(-3+t*(3-t))) + |
| 131 |
greg |
1.1 |
                                p2 * 3*t*(1+t*(-2+t)) + |
| 132 |
                                p3 * 3*t*t*(1-t) + |
| 133 |
                                p4 * t*t*t ; |
| 134 |
| 135 |
gwlarson |
2.12 |
bspline(pp, p0, p1, pn, t) :    pp * (1/6+t*(-.5+t*(.5-1/6*t))) + |
| 136 |
greg |
1.1 |
                                p0 * (2/3+t*t*(-1+.5*t)) + |
| 137 |
                                p1 * (1/6+t*(.5+t*(.5-.5*t))) + |
| 138 |
                                pn * (1/6*t*t*t) ; |
| 139 |
| 140 |
gwlarson |
2.12 |
turbulence(x,y,z,s) : if( s-1.01, 0, abs(noise3(x/s,y/s,z/s)*s) + |
| 141 |
greg |
1.1 |
                                                turbulence(x,y,z,2*s) ); |
| 142 |
gwlarson |
2.12 |
turbulencex(x,y,z,s) : if( s-1.01, 0, |
| 143 |
greg |
2.11 |
                        sgn(noise3(x/s,y/s,z/s))*noise3x(x/s,y/s,z/s) + |
| 144 |
gwlarson |
2.12 |
                        turbulencex(x,y,z,2*s) ); |
| 145 |
turbulencey(x,y,z,s) : if( s-1.01, 0, |
| 146 |
greg |
2.11 |
                        sgn(noise3(x/s,y/s,z/s))*noise3y(x/s,y/s,z/s) + |
| 147 |
gwlarson |
2.12 |
                        turbulencey(x,y,z,2*s) ); |
| 148 |
turbulencez(x,y,z,s) : if( s-1.01, 0, |
| 149 |
greg |
2.11 |
                        sgn(noise3(x/s,y/s,z/s))*noise3z(x/s,y/s,z/s) + |
| 150 |
gwlarson |
2.12 |
                        turbulencez(x,y,z,2*s) ); |
| 151 |
greg |
1.2 |
| 152 |
greg |
1.3 |
                        { Normal distribution from uniform range (0,1) } |
| 153 |
| 154 |
greg |
2.17 |
un2`P.(t) : t - (2.515517+t*(.802853+t*.010328))/ |
| 155 |
greg |
1.3 |
                (1+t*(1.432788+t*(.189269+t*.001308))) ; |
| 156 |
greg |
2.17 |
un1`P.(p) : un2`P.(sqrt(-2*log(p))) ; |
| 157 |
greg |
1.3 |
| 158 |
greg |
2.17 |
unif2norm(p) : if( .5-p, -un1`P.(p), un1`P.(1-p) ) ; |
| 159 |
greg |
1.3 |
| 160 |
nrand(x) = unif2norm(rand(x)); |
| 161 |
| 162 |
greg |
1.2 |
                        { Local (u,v) coordinates for planar surfaces } |
| 163 |
greg |
2.17 |
crosslen`P. = Nx*Nx + Ny*Ny; |
| 164 |
greg |
2.7 |
                        { U is distance from projected Z-axis } |
| 165 |
greg |
2.17 |
U = if( crosslen`P. - FTINY, |
| 166 |
                (Py*Nx - Px*Ny)/crosslen`P., |
| 167 |
greg |
1.2 |
                Px); |
| 168 |
                        { V is defined so that N = U x V } |
| 169 |
greg |
2.17 |
V = if( crosslen`P. - FTINY, |
| 170 |
                Pz - Nz*(Px*Nx + Py*Ny)/crosslen`P., |
| 171 |
greg |
1.2 |
                Py); |
| 172 |
greg |
2.18 |
| 173 |
                        { Local hemisphere direction for *func & *data types } |
| 174 |
                        { last 3 real args = unnormalized up-vector } |
| 175 |
Vux`P. = arg(AC-1)*NzP - arg(AC)*NyP; |
| 176 |
Vuy`P. = arg(AC)*NxP - arg(AC-2)*NzP; |
| 177 |
Vuz`P. = arg(AC-2)*NyP - arg(AC-1)*NxP; |
| 178 |
vnorm`P. = 1/sqrt(Vux`P.*Vux`P. + Vuy`P.*Vuy`P. + Vuz`P.*Vuz`P.); |
| 179 |
Vnx`P. = Vux`P.*vnorm`P.; |
| 180 |
Vny`P. = Vuy`P.*vnorm`P.; |
| 181 |
Vnz`P. = Vuz`P.*vnorm`P.; |
| 182 |
Unx`P. = NyP*Vnz`P. - NzP*Vny`P.; |
| 183 |
Uny`P. = NzP*Vnx`P. - NxP*Vnz`P.; |
| 184 |
Unz`P. = NxP*Vny`P. - NyP*Vnx`P.; |
| 185 |
                        { Transform vectors, normalized (dx,dy,dz) away from surf } |
| 186 |
Ldx(dx,dy,dz) = dx*Unx`P. + dy*Uny`P. + dz*Unz`P.; |
| 187 |
Ldy(dx,dy,dz) = dx*Vnx`P. + dy*Vny`P. + dz*Vnz`P.; |
| 188 |
Ldz(dx,dy,dz) = dx*NxP + dy*NyP + dz*NzP; |
| 189 |
                        { Incident vector transformed to our coords } |
| 190 |
Idx = Ldx(-Dx,-Dy,-Dz); |
| 191 |
Idy = Ldy(-Dx,-Dy,-Dz); |
| 192 |
Idz = RdotP; |
