| 1 | /* RCSid $Id: ray.h,v 2.21 2003/08/28 03:22:16 greg Exp $ */ |
| 2 | /* |
| 3 | *  ray.h - header file for routines using rays. |
| 4 | */ |
| 5 | #ifndef _RAD_RAY_H_ |
| 6 | #define _RAD_RAY_H_ |
| 7 |  |
| 8 | #include  "standard.h" |
| 9 | #include  "octree.h" |
| 10 | #include  "object.h" |
| 11 | #include  "color.h" |
| 12 |  |
| 13 | #ifdef __cplusplus |
| 14 | extern "C" { |
| 15 | #endif |
| 16 |  |
| 17 | #define  MAXDIM         32      /* maximum number of dimensions */ |
| 18 |  |
| 19 | /* ray type flags */ |
| 20 | #define  PRIMARY        01              /* original ray */ |
| 21 | #define  SHADOW         02              /* ray to light source */ |
| 22 | #define  REFLECTED      04              /* reflected ray */ |
| 23 | #define  REFRACTED      010             /* refracted (bent) ray */ |
| 24 | #define  TRANS          020             /* transmitted/transferred ray */ |
| 25 | #define  AMBIENT        040             /* ray scattered for interreflection */ |
| 26 | #define  SPECULAR       0100            /* ray scattered for specular */ |
| 27 |  |
| 28 | /* reflected ray types */ |
| 29 | #define  RAYREFL        (SHADOW|REFLECTED|AMBIENT|SPECULAR) |
| 30 |  |
| 31 | typedef struct ray { |
| 32 | unsigned long  rno;     /* unique ray number */ |
| 33 | int     rlvl;           /* number of reflections for this ray */ |
| 34 | float   rweight;        /* cumulative weight of this ray */ |
| 35 | short   rtype;          /* ray type */ |
| 36 | short   crtype;         /* cumulative ray type */ |
| 37 | struct ray  *parent;    /* ray this originated from */ |
| 38 | FVECT   rorg;           /* origin of ray */ |
| 39 | FVECT   rdir;           /* normalized direction of ray */ |
| 40 | double  rmax;           /* maximum distance (aft clipping plane) */ |
| 41 | int     rsrc;           /* source we're aiming for */ |
| 42 | OBJECT  *clipset;       /* set of objects currently clipped */ |
| 43 | OBJECT  *newcset;       /* next clipset, used for transmission */ |
| 44 | void    (*revf)(struct ray *);  /* evaluation function for this ray */ |
| 45 | void    (*hitf)(OBJECT *, struct ray *);        /* custom hit test */ |
| 46 | OBJECT  robj;           /* intersected object number */ |
| 47 | OBJREC  *ro;            /* intersected object (one with material) */ |
| 48 | double  rot;            /* distance to object */ |
| 49 | FVECT   rop;            /* intersection point */ |
| 50 | FVECT   ron;            /* intersection surface normal */ |
| 51 | double  rod;            /* -DOT(rdir, ron) */ |
| 52 | FULLXF  *rox;           /* object transformation */ |
| 53 | RREAL   uv[2];          /* local coordinates */ |
| 54 | FVECT   pert;           /* surface normal perturbation */ |
| 55 | COLOR   pcol;           /* pattern color */ |
| 56 | COLOR   rcol;           /* returned ray value */ |
| 57 | double  rt;             /* returned effective ray length */ |
| 58 | COLOR   cext;           /* medium extinction coefficient */ |
| 59 | COLOR   albedo;         /* medium scattering albedo */ |
| 60 | float   gecc;           /* scattering eccentricity coefficient */ |
| 61 | int     *slights;       /* list of lights to test for scattering */ |
| 62 | }  RAY; |
| 63 |  |
| 64 | #define  rayvalue(r)    (*(r)->revf)(r) |
| 65 |  |
| 66 | extern char  VersionID[];       /* Radiance version ID string */ |
| 67 |  |
| 68 | extern CUBE     thescene;       /* our scene */ |
| 69 | extern OBJECT   nsceneobjs;     /* number of objects in our scene */ |
| 70 |  |
| 71 | extern unsigned long    raynum; /* next ray ID */ |
| 72 | extern unsigned long    nrays;  /* total rays traced so far */ |
| 73 |  |
| 74 | extern OBJREC  Lamb;            /* a Lambertian surface */ |
| 75 | extern OBJREC  Aftplane;        /* aft clipping object */ |
| 76 |  |
| 77 | extern void     (*trace)();     /* global trace reporting callback */ |
| 78 |  |
| 79 | extern int      dimlist[];      /* dimension list for distribution */ |
| 80 | extern int      ndims;          /* number of dimensions so far */ |
| 81 | extern int      samplendx;      /* index for this sample */ |
| 82 |  |
| 83 | extern int      ray_savesiz;    /* size of parameter save buffer */ |
| 84 |  |
| 85 | extern int      do_irrad;       /* compute irradiance? */ |
| 86 |  |
| 87 | extern double   dstrsrc;        /* square source distribution */ |
| 88 | extern double   shadthresh;     /* shadow threshold */ |
| 89 | extern double   shadcert;       /* shadow testing certainty */ |
| 90 | extern int      directrelay;    /* number of source relays */ |
| 91 | extern int      vspretest;      /* virtual source pretest density */ |
| 92 | extern int      directvis;      /* light sources visible to eye? */ |
| 93 | extern double   srcsizerat;     /* maximum source size/dist. ratio */ |
| 94 |  |
| 95 | extern double   specthresh;     /* specular sampling threshold */ |
| 96 | extern double   specjitter;     /* specular sampling jitter */ |
| 97 |  |
| 98 | extern COLOR    cextinction;    /* global extinction coefficient */ |
| 99 | extern COLOR    salbedo;        /* global scattering albedo */ |
| 100 | extern double   seccg;          /* global scattering eccentricity */ |
| 101 | extern double   ssampdist;      /* scatter sampling distance */ |
| 102 |  |
| 103 | extern int      backvis;        /* back face visibility */ |
| 104 |  |
| 105 | extern int      maxdepth;       /* maximum recursion depth */ |
| 106 | extern double   minweight;      /* minimum ray weight */ |
| 107 |  |
| 108 | extern char     *ambfile;       /* ambient file name */ |
| 109 | extern COLOR    ambval;         /* ambient value */ |
| 110 | extern int      ambvwt;         /* initial weight for ambient value */ |
| 111 | extern double   ambacc;         /* ambient accuracy */ |
| 112 | extern int      ambres;         /* ambient resolution */ |
| 113 | extern int      ambdiv;         /* ambient divisions */ |
| 114 | extern int      ambssamp;       /* ambient super-samples */ |
| 115 | extern int      ambounce;       /* ambient bounces */ |
| 116 | extern char     *amblist[];     /* ambient include/exclude list */ |
| 117 | extern int      ambincl;        /* include == 1, exclude == 0 */ |
| 118 |  |
| 119 | extern int      ray_pnprocs;    /* number of child processes */ |
| 120 | extern int      ray_pnidle;     /* number of idle processes */ |
| 121 |  |
| 122 | #define AMBLLEN         128     /* max. ambient list length */ |
| 123 | #define AMBWORD         8       /* average word length */ |
| 124 |  |
| 125 | typedef struct {                /* rendering parameter holder */ |
| 126 | int     do_irrad; |
| 127 | double  dstrsrc; |
| 128 | double  shadthresh; |
| 129 | double  shadcert; |
| 130 | int     directrelay; |
| 131 | int     vspretest; |
| 132 | int     directvis; |
| 133 | double  srcsizerat; |
| 134 | COLOR   cextinction; |
| 135 | COLOR   salbedo; |
| 136 | double  seccg; |
| 137 | double  ssampdist; |
| 138 | double  specthresh; |
| 139 | double  specjitter; |
| 140 | int     backvis; |
| 141 | int     maxdepth; |
| 142 | double  minweight; |
| 143 | char    ambfile[512]; |
| 144 | COLOR   ambval; |
| 145 | int     ambvwt; |
| 146 | double  ambacc; |
| 147 | int     ambres; |
| 148 | int     ambdiv; |
| 149 | int     ambssamp; |
| 150 | int     ambounce; |
| 151 | int     ambincl; |
| 152 | short   amblndx[AMBLLEN+1]; |
| 153 | char    amblval[AMBLLEN*AMBWORD]; |
| 154 | } RAYPARAMS; |
| 155 |  |
| 156 | #define rpambmod(p,i)   ( (i)>=AMBLLEN||(p)->amblndx[i]<0 ? \ |
| 157 | (char *)NULL : (p)->amblval+(p)->amblndx[i] ) |
| 158 |  |
| 159 | /* defined in duphead.c */ |
| 160 | extern void     headclean(void); |
| 161 | extern void     openheader(void); |
| 162 | extern void     dupheader(void); |
| 163 | /* defined in persist.c */ |
| 164 | extern void persistfile(char *pfn); |
| 165 | extern void     pfdetach(void); |
| 166 | extern void     pfclean(void); |
| 167 | extern void     pflock(int lf); |
| 168 | extern void     pfhold(void); |
| 169 | extern void     io_process(void); |
| 170 | /* defined in freeobjmem.c */ |
| 171 | extern int      free_objs(OBJECT on, OBJECT no); |
| 172 | extern void     free_objmem(void); |
| 173 | /* defined in preload.c */ |
| 174 | extern int      load_os(OBJREC *op); |
| 175 | extern void     preload_objs(void); |
| 176 | /* defined in raycalls.c */ |
| 177 | extern void     ray_init(char *otnm); |
| 178 | extern void     ray_trace(RAY *r); |
| 179 | extern void     ray_done(int freall); |
| 180 | extern void     ray_save(RAYPARAMS *rp); |
| 181 | extern void     ray_restore(RAYPARAMS *rp); |
| 182 | extern void     ray_defaults(RAYPARAMS *rp); |
| 183 | /* defined in raypcalls.c */ |
| 184 | extern void     ray_pinit(char *otnm, int nproc); |
| 185 | extern void     ray_psend(RAY *r); |
| 186 | extern int      ray_pqueue(RAY *r); |
| 187 | extern int      ray_presult(RAY *r, int poll); |
| 188 | extern void     ray_pdone(int freall); |
| 189 | extern void     ray_popen(int nadd); |
| 190 | extern void     ray_pclose(int nsub); |
| 191 | /* defined in raytrace.c */ |
| 192 | extern int      rayorigin(RAY *r, RAY *ro, int rt, double rw); |
| 193 | extern void     rayclear(RAY *r); |
| 194 | extern void     raytrace(RAY *r); |
| 195 | extern void     rayhit(OBJECT *oset, RAY *r); |
| 196 | extern void     raycont(RAY *r); |
| 197 | extern void     raytrans(RAY *r); |
| 198 | extern int      rayshade(RAY *r, int mod); |
| 199 | extern void     rayparticipate(RAY *r); |
| 200 | extern void     raytexture(RAY *r, OBJECT mod); |
| 201 | extern int      raymixture(RAY *r, OBJECT fore, OBJECT back, double coef); |
| 202 | extern double   raydist(RAY *r, int flags); |
| 203 | extern double   raynormal(FVECT norm, RAY *r); |
| 204 | extern void     newrayxf(RAY *r); |
| 205 | extern void     flipsurface(RAY *r); |
| 206 | extern int      localhit(RAY *r, CUBE *scene); |
| 207 | /* defined in renderopts.c */ |
| 208 | extern int      getrenderopt(int ac, char *av[]); |
| 209 | extern void     print_rdefaults(void); |
| 210 | /* defined in srcdraw.c */ |
| 211 | extern void     drawsources(COLOR *pic[], float *zbf[], |
| 212 | int x0, int xsiz, int y0, int ysiz); |
| 213 | extern void init_drawsources(int rad); |
| 214 | /* defined in rt/initotypes.c */ |
| 215 | extern void initotypes(void); |
| 216 | /* module main procedures */ |
| 217 | extern void     rtrace(char *fname); |
| 218 | extern char * formstr(int  f); |
| 219 | extern void     rview(void); |
| 220 | extern void     rpict(int seq, char *pout, char *zout, char *prvr); |
| 221 |  |
| 222 |  |
| 223 | #ifdef __cplusplus |
| 224 | } |
| 225 | #endif |
| 226 | #endif /* _RAD_RAY_H_ */ |
| 227 |  |
