root/radiance/src/rt/pmcontrib2.c
Sun Nov 19 00:43:00 2023 UTC (23 months ago) by greg
CVS Tags: HEAD, rad6R0
fix: temporary patch to get photon map to compile
Thu Nov 8 00:54:07 2018 UTC (6 years, 11 months ago) by greg
CVS Tags: rad5R3, rad5R4
Fri Feb 9 14:59:08 2018 UTC (7 years, 8 months ago) by rschregle
Changes since 2.3: +27 -15 lines
Added PMAP_CBDM as group macro for PMAP_PRIMARYPOS/DIR for convenience.
Mon Aug 14 21:12:10 2017 UTC (8 years, 2 months ago) by rschregle
Changes since 2.2: +9 -2 lines
Updated photon map code for Windows; no multproc or ooC for now
Fri Sep 30 16:51:46 2016 UTC (9 years ago) by greg
Changes since 2.1: +2 -4 lines
Diff to previous 2.1
Removed Unix-only includes I sloppily copied into Windows module
Thu Sep 29 21:51:58 2016 UTC (9 years ago) by greg
Separated creation from use of contribution photon maps
