| 1 |
/* RCSid $Id: pmapsrc.h,v 2.7 2020/08/07 01:21:13 rschregle Exp $ */ |
| 2 |
| 3 |
| 4 |
| 5 |
Photon map support routines for emission from light sources |
| 6 |
| 7 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
| 8 |
(c) Fraunhofer Institute for Solar Energy Systems, |
| 9 |
supported by the German Research Foundation (DFG) |
| 10 |
under the FARESYS project. |
| 11 |
(c) Lucerne University of Applied Sciences and Arts, |
| 12 |
supported by the Swiss National Science Foundation (SNSF #147053). |
| 13 |
(c) Tokyo University of Science, |
| 14 |
supported by the JSPS KAKENHI Grant Number JP19KK0115. |
| 15 |
| 16 |
| 17 |
$Id: pmapsrc.h,v 2.7 2020/08/07 01:21:13 rschregle Exp $ |
| 18 |
| 19 |
| 20 |
| 21 |
| 22 |
#ifndef PMAPSRC_H |
| 23 |
#define PMAPSRC_H |
| 24 |
| 25 |
#include "ray.h" |
| 26 |
#include "source.h" |
| 27 |
| 28 |
#ifdef __cplusplus |
| 29 |
extern "C" { |
| 30 |
#endif |
| 31 |
| 32 |
| 33 |
/* Data structures for photon emission */ |
| 34 |
typedef struct { |
| 35 |
unsigned theta, phi; /* Direction indices */ |
| 36 |
COLOR pdf; /* Probability of emission in this |
| 37 |
direction per RGB */ |
| 38 |
float cdf; /* Cumulative probability up to |
| 39 |
this sample */ |
| 40 |
} EmissionSample; |
| 41 |
| 42 |
typedef struct { |
| 43 |
unsigned numTheta, numPhi; /* Num divisions in theta & phi */ |
| 44 |
RREAL cosThetaMax; /* cos(source aperture) */ |
| 45 |
FVECT uh, vh, wh; /* Emission aperture axes at origin, |
| 46 |
w is normal*/ |
| 47 |
FVECT us, vs, ws; /* Source surface axes at origin, |
| 48 |
w is normal */ |
| 49 |
FVECT photonOrg; /* Current photon origin */ |
| 50 |
EmissionSample *samples; /* PDF samples for photon emission |
| 51 |
directions */ |
| 52 |
unsigned long numPartitions; /* Number of surface partitions */ |
| 53 |
RREAL partArea; /* Area covered by each partition */ |
| 54 |
SRCREC *src, *port; /* Current source and port */ |
| 55 |
unsigned long partitionCnt, /* Current surface partition */ |
| 56 |
maxPartitions, /* Max allocated partitions */ |
| 57 |
numSamples; /* Number of PDF samples */ |
| 58 |
unsigned char* partitions; /* Source surface partitions */ |
| 59 |
COLOR partFlux; /* Total flux emitted by partition */ |
| 60 |
float cdf; /* Cumulative probability */ |
| 61 |
} EmissionMap; |
| 62 |
| 63 |
| 64 |
| 65 |
/* Photon port flags (orientation relative to surface normal): |
| 66 |
* Forward, backward, both (bidirectional). */ |
| 67 |
#define PMAP_PORTFWD 1 |
| 68 |
#define PMAP_PORTBWD 2 |
| 69 |
#define PMAP_PORTBI (PMAP_PORTFWD | PMAP_PORTBWD) |
| 70 |
| 71 |
| 72 |
/* Photon ports for emission from geometry en lieu of light sources */ |
| 73 |
extern char *photonPortList [MAXSET + 1]; |
| 74 |
extern SRCREC *photonPorts; |
| 75 |
extern unsigned numPhotonPorts; |
| 76 |
| 77 |
/* Dispatch tables for partitioning light source surfaces and generating |
| 78 |
an origin for photon emission */ |
| 79 |
extern void (*photonPartition []) (EmissionMap*); |
| 80 |
extern void (*photonOrigin []) (EmissionMap*); |
| 81 |
| 82 |
| 83 |
| 84 |
void getPhotonPorts (char **portList); |
| 85 |
/* Find geometry declared as photon ports from modifiers in portList */ |
| 86 |
| 87 |
void initPhotonEmissionFuncs (); |
| 88 |
/* Init photonPartition[] and photonOrigin[] dispatch tables with source |
| 89 |
specific emission routines */ |
| 90 |
| 91 |
void initPhotonEmission (EmissionMap *emap, float numPdfSamples); |
| 92 |
/* Initialize photon emission from partitioned light source emap -> src; |
| 93 |
* this involves integrating the flux emitted from the current photon |
| 94 |
* origin emap -> photonOrg and setting up a PDF to sample the emission |
| 95 |
* distribution with numPdfSamples samples */ |
| 96 |
| 97 |
void emitPhoton (const EmissionMap*, RAY* ray); |
| 98 |
/* Emit photon from current source partition based on emission |
| 99 |
distribution and return new photon ray */ |
| 100 |
| 101 |
void multDirectPmap (RAY *r); |
| 102 |
/* Factor irradiance from direct photons into r -> rcol; interface to |
| 103 |
* direct() */ |
| 104 |
| 105 |
void inscatterVolumePmap (RAY *r, COLOR inscatter); |
| 106 |
/* Add inscattering from volume photon map; interface to srcscatter() */ |
| 107 |
| 108 |
| 109 |
| 110 |
#endif |
| 111 |
| 112 |
#endif |
