| 1 |
/* RCSid $Id: pmapparm.h,v 2.10 2021/04/14 11:26:25 rschregle Exp $ */ |
| 2 |
| 3 |
| 4 |
| 5 |
Parameters for photon map generation and rendering; used by mkpmap |
| 6 |
and rpict/rvu/rtrace. |
| 7 |
| 8 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com} |
| 9 |
(c) Fraunhofer Institute for Solar Energy Systems, |
| 10 |
supported by the German Research Foundation |
| 11 |
(DFG LU-204/10-2, "Fassadenintegrierte Regelsysteme" (FARESYS)) |
| 12 |
(c) Lucerne University of Applied Sciences and Arts, |
| 13 |
supported by the Swiss National Science Foundation |
| 14 |
(SNSF #147053, "Daylight Redirecting Components") |
| 15 |
| 16 |
| 17 |
$Id: pmapparm.h,v 2.10 2021/04/14 11:26:25 rschregle Exp $ |
| 18 |
| 19 |
| 20 |
| 21 |
#ifndef PMAPPARAMS_H |
| 22 |
#define PMAPPARAMS_H |
| 23 |
| 24 |
#include "pmaptype.h" |
| 25 |
| 26 |
#ifdef __cplusplus |
| 27 |
extern "C" { |
| 28 |
#endif |
| 29 |
| 30 |
/* Struct for passing params per photon map from rpict/rtrace/rvu */ |
| 31 |
typedef struct { |
| 32 |
char *fileName; /* Photon map file */ |
| 33 |
unsigned minGather, maxGather; /* Num photons to gather */ |
| 34 |
unsigned long distribTarget; /* Num photons to store */ |
| 35 |
} PhotonMapParams; |
| 36 |
| 37 |
/* Region of interest */ |
| 38 |
typedef struct { |
| 39 |
/* siz [1], siz [2] <= 0 --> sphere, else rectangle */ |
| 40 |
float pos [3], siz [3]; |
| 41 |
} PhotonMapROI; |
| 42 |
| 43 |
#define PMAP_ROI_ISSPHERE(roi) ((roi)->siz[1] <= 0 && (roi)->siz[2] <= 0) |
| 44 |
#define PMAP_ROI_SETSPHERE(roi) ((roi)->siz[1] = (roi)->siz[2] = -1) |
| 45 |
| 46 |
| 47 |
extern PhotonMapParams pmapParams [NUM_PMAP_TYPES]; |
| 48 |
| 49 |
/* Macros for type specific photon map parameters */ |
| 50 |
#define globalPmapParams (pmapParams [PMAP_TYPE_GLOBAL]) |
| 51 |
#define preCompPmapParams (pmapParams [PMAP_TYPE_PRECOMP]) |
| 52 |
#define causticPmapParams (pmapParams [PMAP_TYPE_CAUSTIC]) |
| 53 |
#define volumePmapParams (pmapParams [PMAP_TYPE_VOLUME]) |
| 54 |
#define directPmapParams (pmapParams [PMAP_TYPE_DIRECT]) |
| 55 |
#define contribPmapParams (pmapParams [PMAP_TYPE_CONTRIB]) |
| 56 |
| 57 |
| 58 |
extern float pdfSamples, preDistrib, finalGather, |
| 59 |
gatherTolerance, maxDistFix, pmapMaxDist, |
| 60 |
photonMaxDist; |
| 61 |
extern unsigned long photonHeapSizeInc, photonMaxBounce; |
| 62 |
extern unsigned photonRepTime, maxPreDistrib, defaultGather, |
| 63 |
verbose; |
| 64 |
| 65 |
extern unsigned pmapNumROI; |
| 66 |
extern PhotonMapROI *pmapROI; |
| 67 |
| 68 |
#ifdef PMAP_OOC |
| 69 |
extern float pmapCachePageSize; |
| 70 |
extern unsigned long pmapCacheSize; |
| 71 |
#endif |
| 72 |
| 73 |
| 74 |
struct PhotonMap; |
| 75 |
| 76 |
int setPmapParam (struct PhotonMap **pm, const PhotonMapParams *parm); |
| 77 |
/* Allocate photon map and set its parameters from parm */ |
| 78 |
| 79 |
unsigned long parseMultiplier (const char *num); |
| 80 |
/* Evaluate numeric parameter string with optional multiplier suffix |
| 81 |
(G = 10^9, M = 10^6, K = 10^3). Returns 0 if parsing fails. */ |
| 82 |
| 83 |
| 84 |
| 85 |
#endif |
| 86 |
| 87 |
#endif |
