root/radiance/src/rt/pmapdump.c
Fri Aug 7 01:21:13 2020 UTC (5 years, 4 months ago) by rschregle
Changes since 2.16: +5 -7 lines
Diff to previous 2.16
feat(mkpmap): Extended -apo option to reorient photon ports.
Tue Jul 21 16:10:42 2020 UTC (5 years, 5 months ago) by rschregle
Changes since 2.15: +10 -4 lines
Diff to previous 2.15
fix(pmapdump): fixed potential string overflow after warnings related to
strncat().
Wed Aug 14 18:02:11 2019 UTC (6 years, 4 months ago) by rschregle
Changes since 2.14: +8 -3 lines
Diff to previous 2.14
Photon flux is scaled by the fraction of dumped photons when using -f.
Tue Jan 22 18:28:23 2019 UTC (6 years, 11 months ago) by rschregle
Changes since 2.13: +85 -70 lines
Diff to previous 2.13
Added -a option to dump ASCII point list for 3D point cloud import.
Thu Jan 10 17:32:39 2019 UTC (6 years, 11 months ago) by rschregle
Changes since 2.12: +101 -56 lines
Diff to previous 2.12
Added -f option to colour photons according to their RGB flux. Spheres now output with 'glow' modifier. Adjusted global photon default colour (blue) for improved visibility.
Wed Nov 21 19:30:59 2018 UTC (7 years, 1 month ago) by rschregle
Changes since 2.11: +37 -20 lines
Added -c option to specify custom sphere colours
Thu Aug 2 18:33:49 2018 UTC (7 years, 5 months ago) by greg
Thu Feb 8 19:55:02 2018 UTC (7 years, 10 months ago) by rschregle
Changes since 2.9: +8 -4 lines
Made photon primary incident dirs optional via PMAP_PRIMARYDIR, bumped PMAP_FILEVER
Sat Dec 9 18:40:43 2017 UTC (8 years ago) by rschregle
Changes since 2.8: +19 -10 lines
Fixed sphere radius for coplanar (and even colinear!) photon distribs
Mon Aug 14 21:12:10 2017 UTC (8 years, 4 months ago) by rschregle
Changes since 2.7: +7 -3 lines
Updated photon map code for Windows; no multproc or ooC for now
Tue May 17 17:39:47 2016 UTC (9 years, 7 months ago) by rschregle
Changes since 2.6: +69 -32 lines
Thu Feb 4 19:39:10 2016 UTC (9 years, 11 months ago) by rschregle
Fixed SEGFAULTs when pmapdump fails to identify newer pmap formats
Tue Sep 1 16:27:52 2015 UTC (10 years, 4 months ago) by greg
Tue Aug 18 18:45:55 2015 UTC (10 years, 4 months ago) by greg
Changes since 2.3: +5 -2 lines
Fri May 8 13:20:23 2015 UTC (10 years, 7 months ago) by rschregle
Changes since 2.2: +5 -4 lines
Tue Apr 21 19:16:51 2015 UTC (10 years, 8 months ago) by greg
Changes since 2.1: +4 -3 lines
Fixes for Windows and photon map
Tue Feb 24 19:39:27 2015 UTC (10 years, 10 months ago) by greg
