root/radiance/src/rt/pmapdata.h
Revision: 2.15
Committed: Tue Sep 17 16:36:05 2024 UTC (13 months, 2 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.14: +15 -13 lines
chore: Added extern "C" to headers to avoid C++ name mangling
# User Rev Content
1 greg 2.15 /* RCSid $Id: pmapdata.h,v 2.14 2020/04/08 15:14:21 rschregle Exp $ */
2 rschregle 2.10
3 greg 2.1 /*
4 rschregle 2.10 =========================================================================
5     Photon map types and interface to nearest neighbour lookups in underlying
6     point cloud data structure.
7
8     The default data structure is an in-core kd-tree (see pmapkdt.{h,c}).
9     This can be overriden with the PMAP_OOC compiletime switch, which enables
10     an out-of-core octree (see oococt.{h,c}).
11
12     Defining PMAP_FLOAT_FLUX stores photon flux as floats rather than packed
13     RGBE for greater precision; this may be necessary when the flux differs
14     significantly in individual colour channels, e.g. with highly saturated
15     colours.
16 greg 2.1
17     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
18     (c) Fraunhofer Institute for Solar Energy Systems,
19 rschregle 2.2 (c) Lucerne University of Applied Sciences and Arts,
20 rschregle 2.10 supported by the Swiss National Science Foundation (SNSF, #147053)
21     =========================================================================
22 greg 2.1
23 greg 2.15 $Id: pmapdata.h,v 2.14 2020/04/08 15:14:21 rschregle Exp $
24 greg 2.1 */
25
26
27 rschregle 2.10
28 greg 2.1 #ifndef PMAPDATA_H
29     #define PMAPDATA_H
30
31 rschregle 2.13 #ifndef NIX
32     #if defined(_WIN32) || defined(_WIN64)
33     #define NIX 0
34     #else
35     #define NIX 1
36     #endif
37     #endif
38 rschregle 2.11
39     #if (defined(PMAP_OOC) && !NIX)
40     #error "OOC currently only supported on NIX -- tuff luck."
41     #endif
42
43 rschregle 2.13 #ifdef PMAP_CBDM
44     /* Enable photon primary hitpoints and incident directions (see struct
45     * PhotonPrimary below). Note this will increase the size of photon
46     * primaries 9-fold (10-fold after alignment)!!! */
47     #define PMAP_PRIMARYPOS
48     #define PMAP_PRIMARYDIR
49     #endif
50 rschregle 2.11
51 rschregle 2.13 #include "ray.h"
52 greg 2.1 #include "pmaptype.h"
53 rschregle 2.11 #include "paths.h"
54 greg 2.1 #include "lookup.h"
55 rschregle 2.10 #include <stdint.h>
56 greg 2.1
57     /* Primary photon ray for light source contributions */
58     typedef struct {
59 rschregle 2.10 int16 srcIdx; /* Index of emitting light source */
60     /* !!! REDUCED FROM 32 BITS !!! */
61 rschregle 2.13 #ifdef PMAP_PRIMARYDIR
62 rschregle 2.10 int32 dir; /* Encoded ray direction */
63 rschregle 2.13 #endif
64     #ifdef PMAP_PRIMARYPOS
65 rschregle 2.10 float pos [3]; /* Hit point */
66 rschregle 2.13 #endif
67 greg 2.1 } PhotonPrimary;
68
69 rschregle 2.10 #define photonSrcIdx(pm, p) ((pm)->primaries[(p)->primary].srcIdx)
70
71
72
73     /* Photon primary ray index type and limit */
74 rschregle 2.13 typedef uint32 PhotonPrimaryIdx;
75 rschregle 2.10 #define PMAP_MAXPRIMARY UINT32_MAX
76
77     /* Macros for photon's generating subprocess field */
78 rschregle 2.11 #ifdef PMAP_OOC
79 rschregle 2.10 #define PMAP_PROCBITS 7
80 rschregle 2.13 #else
81     #define PMAP_PROCBITS 5
82 rschregle 2.10 #endif
83     #define PMAP_MAXPROC (1 << PMAP_PROCBITS)
84     #define PMAP_GETRAYPROC(r) ((r) -> crtype >> 8)
85     #define PMAP_SETRAYPROC(r,p) ((r) -> crtype |= p << 8)
86
87     /* Tolerance for photon normal check during lookups */
88     #define PMAP_NORM_TOL 0.02
89
90 greg 2.1
91
92     typedef struct {
93 rschregle 2.10 float pos [3]; /* Photon position */
94     signed char norm [3]; /* Surface normal at pos (incident
95     direction for volume photons) */
96     union {
97     struct {
98     #ifndef PMAP_OOC
99     unsigned char discr : 2; /* kd-tree discriminator axis */
100     #endif
101     unsigned char caustic : 1; /* Specularly scattered (=caustic) */
102
103     /* Photon's generating subprocess index, used for primary ray
104     * index linearisation when building contrib pmaps; note this is
105     * reduced for kd-tree to accommodate the discriminator field */
106     unsigned char proc : PMAP_PROCBITS;
107     };
108
109     unsigned char flags;
110     };
111
112     #ifdef PMAP_FLOAT_FLUX
113 rschregle 2.13 COLOR flux;
114 rschregle 2.10 #else
115 rschregle 2.13 COLR flux;
116 rschregle 2.10 #endif
117     PhotonPrimaryIdx primary; /* Index to primary ray */
118     } Photon;
119
120 greg 2.15 /* Define search queue and underlying data struct types */
121     #ifdef PMAP_OOC
122     #include "pmapooc.h"
123     #else
124     #include "pmapkdt.h"
125     #endif
126 greg 2.1
127
128 rschregle 2.10 /* Define PMAP_FLOAT_FLUX to store photon flux as floats instead of
129     * compact RGBE, which was found to improve accuracy in analytical
130     * validation. */
131     #ifdef PMAP_FLOAT_FLUX
132     #define setPhotonFlux(p,f) copycolor((p) -> flux, f)
133     #define getPhotonFlux(p,f) copycolor(f, (p) -> flux)
134     #else
135     #define setPhotonFlux(p,f) setcolr((p)->flux, (f)[0], (f)[1], (f)[2])
136     #define getPhotonFlux(p,f) colr_color(f, (p) -> flux)
137     #endif
138 greg 2.1
139
140     /* Bias compensation history node */
141 rschregle 2.13 typedef struct {
142 greg 2.1 COLOR irrad;
143     float weight;
144 rschregle 2.10 } PhotonBiasCompNode;
145
146 greg 2.1
147 rschregle 2.10 /* Forward declaration */
148     struct PhotonMap;
149 greg 2.1
150
151 rschregle 2.11 /* Mean size of heapfile write buffer, in number of photons */
152     #define PMAP_HEAPBUFSIZE 1e6
153
154     /* Mean idle time between heap locking attempts, in usec */
155     #define PMAP_HEAPBUFSLEEP 2e6
156
157     /* Temporary filename for photon heaps */
158     #define PMAP_TMPFNAME TEMPLATE
159     #define PMAP_TMPFNLEN (TEMPLEN + 1)
160
161
162 greg 2.1 typedef struct PhotonMap {
163 rschregle 2.10 PhotonMapType type; /* See pmaptype.h */
164     char *fileName; /* Photon map file */
165
166
167     /* ================================================================
168     * PRE/POST-BUILD STORAGE
169     * ================================================================ */
170     FILE *heap; /* Unsorted photon heap prior to
171     construction of store */
172 rschregle 2.11 char heapFname [sizeof(PMAP_TMPFNAME)];
173 rschregle 2.10 Photon *heapBuf; /* Write buffer for above */
174     unsigned long heapBufLen, /* Current & max size of heapBuf */
175     heapBufSize;
176 rschregle 2.11 PhotonStorage store; /* Photon storage in space
177 rschregle 2.13 subdividing data struct */
178 rschregle 2.10
179     /* ================================================================
180     * PHOTON DISTRIBUTION STUFF
181     * ================================================================ */
182     unsigned long distribTarget, /* Num stored specified by user */
183     numPhotons; /* Num actually stored */
184     float distribRatio; /* Probability of photon storage */
185     COLOR photonFlux; /* Average photon flux */
186     unsigned short randState [3]; /* Local RNG state */
187
188
189     /* ================================================================
190     * PHOTON LOOKUP STUFF
191     * ================================================================ */
192     union { /* Flags passed to findPhotons() */
193     char lookupCaustic : 1;
194     char lookupFlags;
195     };
196
197     PhotonSearchQueue squeue; /* Search queue for photon lookups */
198     unsigned minGather, /* Specified min/max photons per */
199     maxGather; /* density estimate */
200
201     /* NOTE: All distances are SQUARED */
202     float maxDist2, /* Max search radius */
203     maxDist0, /* Initial value for above */
204     maxDist2Limit, /* Hard limit for above */
205     gatherTolerance; /* Fractional deviation from minGather/
206     maxGather for short lookup */
207     void (*lookup)(struct PhotonMap*,
208     RAY*, COLOR); /* Callback for type-specific photon
209     * lookup (usually density estimate) */
210
211
212     /* ================================================================
213     * BIAS COMPENSATION STUFF
214 rschregle 2.13 * ================================================================ */
215 rschregle 2.10 PhotonBiasCompNode *biasCompHist; /* Bias compensation history */
216
217
218     /* ================================================================
219     * STATISTIX
220 rschregle 2.13 * ================================================================ */
221 rschregle 2.10 unsigned long totalGathered, /* Total photons gathered */
222     numDensity, /* Num density estimates */
223     numLookups, /* Counters for short photon lookups */
224     numShortLookups;
225
226     unsigned minGathered, /* Min/max photons actually gathered */
227     maxGathered, /* per density estimate */
228     shortLookupPct; /* % of short lookups for stats */
229
230     float minError, /* Min/max/rms density estimate error */
231     maxError,
232     rmsError,
233     CoGdist, /* Avg distance to centre of gravity */
234     maxPos [3], /* Max & min photon positions */
235     minPos [3];
236
237     FVECT CoG; /* Centre of gravity (avg photon pos) */
238
239
240     /* ================================================================
241     * PHOTON CONTRIB/COEFF STUFF
242     * ================================================================ */
243     PhotonPrimary *primaries, /* Photon primary array for rendering */
244     lastPrimary; /* Current primary for photon distrib */
245     PhotonPrimaryIdx numPrimary; /* Number of primary rays */
246     LUTAB *srcContrib; /* Lookup table for source contribs */
247 greg 2.1 } PhotonMap;
248
249
250
251     /* Photon maps by type (see PhotonMapType) */
252 rschregle 2.10 extern PhotonMap *photonMaps [];
253 greg 2.1
254     /* Macros for specific photon map types */
255 rschregle 2.10 #define globalPmap (photonMaps [PMAP_TYPE_GLOBAL])
256     #define preCompPmap (photonMaps [PMAP_TYPE_PRECOMP])
257     #define causticPmap (photonMaps [PMAP_TYPE_CAUSTIC])
258     #define volumePmap (photonMaps [PMAP_TYPE_VOLUME])
259     #define directPmap (photonMaps [PMAP_TYPE_DIRECT])
260     #define contribPmap (photonMaps [PMAP_TYPE_CONTRIB])
261
262     /* Photon map type tests */
263     #define isGlobalPmap(p) ((p) -> type == PMAP_TYPE_GLOBAL)
264     #define isCausticPmap(p) ((p) -> type == PMAP_TYPE_CAUSTIC)
265     #define isContribPmap(p) ((p) -> type == PMAP_TYPE_CONTRIB)
266     #define isVolumePmap(p) ((p) -> type == PMAP_TYPE_VOLUME)
267 greg 2.1
268 greg 2.15 #ifdef __cplusplus
269     extern "C" {
270     #endif
271 greg 2.1
272     void initPhotonMap (PhotonMap *pmap, PhotonMapType t);
273     /* Initialise empty photon map of specified type */
274
275 rschregle 2.10 int newPhoton (PhotonMap *pmap, const RAY *ray);
276     /* Create new photon with ray's direction, intersection point, and flux,
277     and append to unsorted photon heap pmap -> heap. The photon is
278     accepted with probability pmap -> distribRatio for global density
279     control; if the photon is rejected, -1 is returned, else 0. The flux
280     is scaled by ray -> rweight and 1 / pmap -> distribRatio. */
281
282     void initPhotonHeap (PhotonMap *pmap);
283     /* Open photon heap file */
284
285     void flushPhotonHeap (PhotonMap *pmap);
286     /* Flush photon heap buffa pmap -> heapBuf to heap file pmap -> heap;
287     * used by newPhoton() and to finalise heap in distribPhotons(). */
288
289     void buildPhotonMap (PhotonMap *pmap, double *photonFlux,
290     PhotonPrimaryIdx *primaryOfs, unsigned nproc);
291     /* Postpress unsorted photon heap pmap -> heap and build underlying data
292     * structure pmap -> store. This is prerequisite to photon lookups with
293     * findPhotons(). */
294
295     /* PhotonFlux is the flux per photon averaged over RGB; this is
296     * multiplied with each photon's flux during the postprocess. In the
297     * case of a contribution photon map, this is an array with a separate
298     * flux specific to each light source due to non-uniform photon emission;
299     * Otherwise it is referenced as a scalar value. Flux is not scaled if
300     * photonFlux == NULL. */
301
302     /* Photon map construction may be parallelised if nproc > 1, if
303     * supported. The heap is destroyed on return. */
304
305     /* PrimaryOfs is an array of index offsets for the primaries in pmap ->
306     * primaries generated by each of the nproc subprocesses during contrib
307     * photon distribution (see distribPhotonContrib()). These offsets are
308     * used to linearise the photon primary indices in the postprocess. This
309     * linearisation is skipped if primaryOfs == NULL. */
310 greg 2.1
311     void findPhotons (PhotonMap* pmap, const RAY *ray);
312 rschregle 2.10 /* Find pmap -> squeue.len closest photons to ray -> rop with similar
313 greg 2.1 normal. For volume photons ray -> rorg is used and the normal is
314     ignored (being the incident direction in this case). Found photons
315 rschregle 2.10 are placed search queue starting with the furthest photon at pmap ->
316     squeue.node, and pmap -> squeue.tail being the number actually found. */
317 greg 2.1
318 rschregle 2.14 Photon *find1Photon (PhotonMap *pmap, const RAY *ray, Photon *photon);
319     /* Find single closest photon to ray -> rop with similar normal.
320     Return NULL if none found, else the supplied Photon* buffer,
321     indicating that it contains a valid photon. */
322 greg 2.1
323 rschregle 2.10 void getPhoton (PhotonMap *pmap, PhotonIdx idx, Photon *photon);
324     /* Retrieve photon referenced by idx from pmap -> store */
325
326     Photon *getNearestPhoton (const PhotonSearchQueue *squeue, PhotonIdx idx);
327     /* Retrieve photon from NN search queue after calling findPhotons() */
328
329     PhotonIdx firstPhoton (const PhotonMap *pmap);
330     /* Index to first photon, to be passed to getPhoton(). Indices to
331     * subsequent photons can be optained via increment operator (++) */
332
333 greg 2.1 void deletePhotons (PhotonMap*);
334     /* Free dem mammaries... */
335
336 greg 2.15 #ifdef __cplusplus
337     }
338     #endif
339
340 greg 2.1 #endif
