root/radiance/src/rt/pmap.h
Revision: 2.9
Committed: Wed Jan 24 19:39:05 2018 UTC (7 years, 8 months ago) by rschregle
CVS Tags: rad5R4, rad5R2, rad5R3
Changes since 2.8: +6 -5 lines
Hack to render contrib pmap as regular global pmap with rpict/rtrace/rvu
1 /* RCSid $Id: pmap.h,v 2.8 2017/08/14 21:12:10 rschregle Exp $ */
2
3 /*
4 ======================================================================
5 Photon map main header
6
7 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
8 (c) Fraunhofer Institute for Solar Energy Systems,
9 (c) Lucerne University of Applied Sciences and Arts,
10 supported by the Swiss National Science Foundation (SNSF, #147053)
11 ======================================================================
12
13 $Id: pmap.h,v 2.8 2017/08/14 21:12:10 rschregle Exp $
14 */
15
16
17 #ifndef PMAP_H
18 #define PMAP_H
19
20 #ifndef NIX
21 #if defined(_WIN32) || defined(_WIN64)
22 #define NIX 0
23 #else
24 #define NIX 1
25 #endif
26 #endif
27
28 #include "pmapparm.h"
29 #include "pmapdata.h"
30
31
32 #ifndef min
33 #define min(a, b) ((a) < (b) ? (a) : (b))
34 #endif
35
36 #ifndef max
37 #define max(a, b) ((a) > (b) ? (a) : (b))
38 #endif
39
40 #define sqr(a) ((a) * (a))
41
42 /* Average over colour channels */
43 #define colorAvg(col) ((col [0] + col [1] + col [2]) / 3)
44
45 /* Macros to test for enabled photon maps */
46 #define photonMapping (globalPmap || preCompPmap || \
47 causticPmap || contribPmap)
48 #define causticPhotonMapping (causticPmap != NULL)
49 #define directPhotonMapping (directPmap != NULL)
50 #define volumePhotonMapping (volumePmap != NULL)
51 /* #define contribPhotonMapping (contribPmap && contribPmap -> srcContrib)
52 */
53 #define contribPhotonMapping (contribPmap)
54
55
56 extern void (*pmapLookup [])(PhotonMap*, RAY*, COLOR);
57 /* Photon map lookup functions per type */
58
59 void loadPmaps (PhotonMap **pmaps, const PhotonMapParams *params);
60 /* Load photon and set their respective parameters, checking timestamps
61 * relative to octree for possible staleness */
62
63 void savePmaps (const PhotonMap **pmaps, int argc, char **argv);
64 /* Save all defined photon maps with specified command line */
65
66 void cleanUpPmaps (PhotonMap **pmaps);
67 /* Trash all photon maps after processing is complete */
68
69 void distribPhotons (PhotonMap **pmaps, unsigned numProc);
70 /* Emit photons from light sources and build photon maps for non-NULL
71 * entries in photon map array */
72
73 void tracePhoton (RAY*);
74 /* Follow photon as it bounces around the scene. Analogon to
75 * raytrace(). */
76
77 void photonDensity (PhotonMap*, RAY*, COLOR irrad);
78 /* Perform surface density estimate from incoming photon flux at
79 ray's intersection point. Returns irradiance from found photons. */
80
81 void photonPreCompDensity (PhotonMap *pmap, RAY *r, COLOR irrad);
82 /* Returns precomputed photon density estimate at ray -> rop. */
83
84 void volumePhotonDensity (PhotonMap*, RAY*, COLOR);
85 /* Perform volume density estimate from incoming photon flux at
86 ray's intersection point. Returns irradiance. */
87
88 void colorNorm (COLOR);
89 /* Normalise colour channels to average of 1 */
90
91 #endif
