root/radiance/src/rt/persist.c
Revision: 2.20
Committed: Thu Oct 16 13:49:22 1997 UTC (28 years ago) by gregl
Changes since 2.19: +2 -0 lines
added ifdef for INCL_SEL_H since not every system has it
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Routines for persistent rtrace and rpict processes.
9 */
10
11 #include "standard.h"
12
13 #ifdef F_SETLKW
14 #include "paths.h"
15 #include <signal.h>
16 #include <sys/types.h>
17 #ifdef INCL_SEL_H
18 #include <sys/select.h>
19 #endif
20 #include <sys/stat.h>
21 /* select call compatibility stuff */
22 #ifndef FD_SETSIZE
23 #include <sys/param.h>
24 #define FD_SETSIZE NOFILE /* maximum # select file descriptors */
25 #endif
26 #ifndef FD_SET
27 #ifndef NFDBITS
28 #define NFDBITS (8*sizeof(int)) /* number of bits per fd_mask */
29 #endif
30 #define FD_SET(n, p) ((p)->fds_bits[(n)/NFDBITS] |= (1 << ((n) % NFDBITS)))
31 #define FD_CLR(n, p) ((p)->fds_bits[(n)/NFDBITS] &= ~(1 << ((n) % NFDBITS)))
32 #define FD_ISSET(n, p) ((p)->fds_bits[(n)/NFDBITS] & (1 << ((n) % NFDBITS)))
33 #define FD_ZERO(p) bzero((char *)(p), sizeof(*(p)))
34 #endif
35
36 #ifndef TIMELIM
37 #define TIMELIM (8*3600) /* time limit for holding pattern */
38 #endif
39
40 extern char *strcpy(), *index();
41
42 extern int headismine; /* boolean true if header belongs to me */
43
44 extern char *progname; /* global program name */
45
46 extern char *errfile; /* global error file name */
47
48 static char *persistfname = NULL; /* persist file name */
49 static int persistfd = -1; /* persist file descriptor */
50
51 static char inpname[TEMPLEN+1], outpname[TEMPLEN+1], errname[TEMPLEN+1];
52
53
54 pfdetach() /* release persist (and header) resources */
55 {
56 if (persistfd >= 0)
57 close(persistfd);
58 persistfd = -1;
59 persistfname = NULL;
60 inpname[0] = '\0';
61 outpname[0] = '\0';
62 errname[0] = '\0';
63 headismine = 0;
64 }
65
66
67 pfclean() /* clean up persist files */
68 {
69 if (persistfd >= 0)
70 close(persistfd);
71 if (persistfname != NULL)
72 unlink(persistfname);
73 if (inpname[0])
74 unlink(inpname);
75 if (outpname[0])
76 unlink(outpname);
77 if (errname[0])
78 unlink(errname);
79 }
80
81
82 pflock(lf) /* place or release exclusive lock on file */
83 int lf;
84 {
85 struct flock fls;
86
87 fls.l_type = lf ? F_WRLCK : F_UNLCK;
88 fls.l_whence = 0;
89 fls.l_start = 0L;
90 fls.l_len = 0L;
91 if (fcntl(persistfd, F_SETLKW, &fls) < 0)
92 error(SYSTEM, "cannot (un)lock persist file");
93 }
94
95
96 persistfile(pfn) /* open persist file and lock it */
97 char *pfn;
98 {
99 persistfd = open(pfn, O_WRONLY|O_CREAT|O_EXCL, 0644);
100 if (persistfd >= 0) {
101 persistfname = pfn;
102 pflock(1);
103 return;
104 }
105 /* file exists -- switch to i/o process */
106 persistfd = open(pfn, O_RDWR);
107 if (persistfd < 0) {
108 sprintf(errmsg, "cannot open persist file \"%s\"", pfn);
109 error(SYSTEM, errmsg);
110 }
111 pflock(1);
112 io_process(); /* never returns */
113 }
114
115
116 static int got_io;
117
118 static int sig_io() { got_io++; }
119
120 static int sig_alrm() { quit(0); }
121
122
123 pfhold() /* holding pattern for idle rendering process */
124 {
125 int (*oldalrm)();
126 char buf[512];
127 register int n;
128 /* close input and output descriptors */
129 close(fileno(stdin));
130 close(fileno(stdout));
131 if (errfile == NULL)
132 close(fileno(stderr));
133 /* create named pipes for input and output */
134 if (mknod(mktemp(strcpy(inpname,TEMPLATE)), S_IFIFO|0600, 0) < 0)
135 goto createrr;
136 if (mknod(mktemp(strcpy(outpname,TEMPLATE)), S_IFIFO|0600, 0) < 0)
137 goto createrr;
138 if (errfile == NULL &&
139 mknod(mktemp(strcpy(errname,TEMPLATE)), S_IFIFO|0600, 0) < 0)
140 goto createrr;
141 sprintf(buf, "%s %d\n%s\n%s\n%s\n", progname, getpid(),
142 inpname, outpname, errname);
143 n = strlen(buf);
144 if (write(persistfd, buf, n) < n)
145 error(SYSTEM, "error writing persist file");
146 lseek(persistfd, 0L, 0);
147 /* wait TIMELIM for someone to signal us */
148 got_io = 0;
149 signal(SIGIO, sig_io);
150 oldalrm = (int (*)())signal(SIGALRM, sig_alrm);
151 alarm(TIMELIM);
152 pflock(0); /* unlock persist file for attach */
153 while (!got_io)
154 pause(); /* wait for attach */
155 alarm(0); /* turn off alarm */
156 signal(SIGALRM, oldalrm);
157 signal(SIGIO, SIG_DFL);
158 pflock(1); /* grab persist file back */
159 /* someone wants us; reopen stdin and stdout */
160 if (freopen(inpname, "r", stdin) == NULL)
161 goto openerr;
162 if (freopen(outpname, "w", stdout) == NULL)
163 goto openerr;
164 if (errname[0]) {
165 if (freopen(errname, "w", stderr) == NULL)
166 goto openerr;
167 unlink(errname);
168 errname[0] = '\0';
169 }
170 unlink(inpname);
171 inpname[0] = '\0';
172 unlink(outpname);
173 outpname[0] = '\0';
174 return;
175 createrr:
176 error(SYSTEM, "cannot create named pipes in pfhold");
177 openerr:
178 error(SYSTEM, "cannot open named pipes in pfhold");
179 }
180
181
182 io_process() /* just act as go-between for actual process */
183 {
184 register char *cp;
185 register int nr, n;
186 char buf[BUFSIZ], *pfin, *pfout, *pferr;
187 int pid, nfds;
188 int fdin, fdout, fderr = -1;
189 fd_set readfds, writefds, excepfds;
190 /* load persist file */
191 n = 40;
192 while ((nr = read(persistfd, buf, sizeof(buf)-1)) == 0) {
193 if (!n--)
194 error(USER, "unattended persist file?");
195 pflock(0);
196 sleep(15); /* wait until ready */
197 pflock(1);
198 }
199 if (nr < 0)
200 error(SYSTEM, "error reading persist file");
201 ftruncate(persistfd, 0L); /* truncate persist file */
202 pfdetach(); /* close & release persist file */
203 buf[nr] = '\0'; /* parse what we got */
204 if ((cp = index(buf, ' ')) == NULL)
205 goto formerr;
206 *cp++ = '\0';
207 if ((pid = atoi(cp)) <= 0)
208 goto formerr;
209 if ((cp = index(cp, '\n')) == NULL)
210 goto formerr;
211 pfin = ++cp;
212 if ((cp = index(cp, '\n')) == NULL)
213 goto formerr;
214 *cp++ = '\0';
215 pfout = cp;
216 if ((cp = index(cp, '\n')) == NULL)
217 goto formerr;
218 *cp++ = '\0';
219 pferr = cp;
220 if ((cp = index(cp, '\n')) == NULL)
221 goto formerr;
222 *cp++ = '\0';
223 if (cp-buf != nr)
224 goto formerr;
225 if (strcmp(buf, progname)) {
226 sprintf(errmsg, "persist file for %s, not %s", buf, progname);
227 error(USER, errmsg);
228 }
229 /* wake up rendering process */
230 if (kill(pid, SIGIO) < 0)
231 error(SYSTEM, "cannot signal rendering process in io_process");
232 /* open named pipes, in order */
233 if ((fdin = open(pfin, O_WRONLY)) < 0)
234 error(SYSTEM, "cannot open input pipe in io_process");
235 if ((fdout = open(pfout, O_RDONLY)) < 0)
236 error(SYSTEM, "cannot open output pipe in io_process");
237 if (pferr[0] && (fderr = open(pferr, O_RDONLY)) < 0)
238 error(SYSTEM, "cannot open error pipe in io_process");
239 for ( ; ; ) { /* loop on select call */
240 FD_ZERO(&readfds);
241 FD_ZERO(&writefds);
242 FD_ZERO(&excepfds);
243 nfds = 0;
244 if (fdin >= 0) {
245 FD_SET(fdin, &writefds);
246 FD_SET(fdin, &excepfds);
247 nfds = fdin+1;
248 }
249 if (fdout >= 0) {
250 FD_SET(fdout, &readfds);
251 FD_SET(fdout, &excepfds);
252 nfds = fdout+1;
253 }
254 if (fderr >= 0) {
255 FD_SET(fderr, &readfds);
256 FD_SET(fderr, &excepfds);
257 nfds = fderr+1;
258 }
259 if (nfds == 0)
260 break; /* all done, exit */
261 if (select(nfds, &readfds, &writefds, &excepfds, NULL) < 0)
262 error(SYSTEM, "error in select call in io_process");
263 /* renderer stderr */
264 if (fderr >= 0 && (FD_ISSET(fderr, &readfds) ||
265 FD_ISSET(fderr, &excepfds))) {
266 nr = read(fderr, cp=buf, sizeof(buf));
267 if (nr < 0)
268 goto readerr;
269 if (nr == 0) {
270 close(fderr);
271 /* close(2); don't close stderr! */
272 fderr = -1;
273 } else
274 do { /* write it all */
275 if ((n = write(2, cp, nr)) <= 0)
276 goto writerr;
277 cp += n;
278 } while ((nr -= n) > 0);
279 }
280 /* renderer stdout */
281 if (fdout >= 0 && (FD_ISSET(fdout, &readfds) ||
282 FD_ISSET(fdout, &excepfds))) {
283 nr = read(fdout, cp=buf, sizeof(buf));
284 if (nr < 0)
285 goto readerr;
286 if (nr == 0) { /* EOF */
287 close(fdout);
288 close(1);
289 fdout = -1;
290 } else
291 do { /* write it all */
292 if ((n = write(1, cp, nr)) <= 0)
293 goto writerr;
294 cp += n;
295 } while ((nr -= n) > 0);
296 }
297 /* renderer stdin */
298 if (fdin >= 0 && (FD_ISSET(fdin, &writefds) ||
299 FD_ISSET(fdin, &excepfds))) {
300 nr = read(0, buf, 512); /* use minimal buffer */
301 if (nr < 0)
302 goto readerr;
303 if (nr == 0) {
304 close(0);
305 close(fdin);
306 fdin = -1;
307 } else if (write(fdin, buf, nr) < nr)
308 goto writerr; /* what else to do? */
309 }
310 }
311 _exit(0); /* we ought to return renderer error status! */
312 formerr:
313 error(USER, "format error in persist file");
314 readerr:
315 error(SYSTEM, "read error in io_process");
316 writerr:
317 error(SYSTEM, "write error in io_process");
318 }
319
320 #else
321
322 pfclean() {}
323
324 #endif
