| 1 |
/* Copyright (c) 1996 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Routines for persistent rtrace and rpict processes.
| 9 |
| 10 |
| 11 |
#include "standard.h"
| 12 |
| 13 |
#ifdef F_SETLKW
| 14 |
#include "paths.h"
| 15 |
#include <signal.h>
| 16 |
#include <sys/types.h>
| 17 |
#include <sys/stat.h>
| 18 |
/* select call compatibility stuff */
| 19 |
#ifndef FD_SETSIZE
| 20 |
#include <sys/param.h>
| 21 |
#define FD_SETSIZE NOFILE /* maximum # select file descriptors */
| 22 |
#endif
| 23 |
#ifndef FD_SET
| 24 |
#ifndef NFDBITS
| 25 |
#define NFDBITS (8*sizeof(int)) /* number of bits per fd_mask */
| 26 |
#endif
| 27 |
#define FD_SET(n, p) ((p)->fds_bits[(n)/NFDBITS] |= (1 << ((n) % NFDBITS)))
| 28 |
#define FD_CLR(n, p) ((p)->fds_bits[(n)/NFDBITS] &= ~(1 << ((n) % NFDBITS)))
| 29 |
#define FD_ISSET(n, p) ((p)->fds_bits[(n)/NFDBITS] & (1 << ((n) % NFDBITS)))
| 30 |
#define FD_ZERO(p) bzero((char *)(p), sizeof(*(p)))
| 31 |
#endif
| 32 |
| 33 |
#ifndef TIMELIM
| 34 |
#define TIMELIM (8*3600) /* time limit for holding pattern */
| 35 |
#endif
| 36 |
| 37 |
extern char *strcpy(), *index();
| 38 |
| 39 |
extern int headismine; /* boolean true if header belongs to me */
| 40 |
| 41 |
extern char *progname; /* global program name */
| 42 |
| 43 |
extern char *errfile; /* global error file name */
| 44 |
| 45 |
static char *persistfname = NULL; /* persist file name */
| 46 |
static int persistfd = -1; /* persist file descriptor */
| 47 |
| 48 |
static char inpname[TEMPLEN+1], outpname[TEMPLEN+1], errname[TEMPLEN+1];
| 49 |
| 50 |
| 51 |
pfdetach() /* release persist (and header) resources */
| 52 |
| 53 |
if (persistfd >= 0)
| 54 |
close(persistfd);
| 55 |
persistfd = -1;
| 56 |
| 57 |
inpname[0] = '\0';
| 58 |
outpname[0] = '\0';
| 59 |
errname[0] = '\0';
| 60 |
headismine = 0;
| 61 |
| 62 |
| 63 |
| 64 |
pfclean() /* clean up persist files */
| 65 |
| 66 |
if (persistfd >= 0)
| 67 |
close(persistfd);
| 68 |
if (persistfname != NULL)
| 69 |
unlink(persistfname);
| 70 |
if (inpname[0])
| 71 |
unlink(inpname);
| 72 |
if (outpname[0])
| 73 |
unlink(outpname);
| 74 |
if (errname[0])
| 75 |
unlink(errname);
| 76 |
| 77 |
| 78 |
| 79 |
pflock(lf) /* place or release exclusive lock on file */
| 80 |
int lf;
| 81 |
| 82 |
struct flock fls;
| 83 |
| 84 |
fls.l_type = lf ? F_WRLCK : F_UNLCK;
| 85 |
fls.l_whence = 0;
| 86 |
fls.l_start = 0L;
| 87 |
fls.l_len = 0L;
| 88 |
if (fcntl(persistfd, F_SETLKW, &fls) < 0)
| 89 |
error(SYSTEM, "cannot (un)lock persist file");
| 90 |
| 91 |
| 92 |
| 93 |
persistfile(pfn) /* open persist file and lock it */
| 94 |
char *pfn;
| 95 |
| 96 |
persistfd = open(pfn, O_WRONLY|O_CREAT|O_EXCL, 0644);
| 97 |
if (persistfd >= 0) {
| 98 |
persistfname = pfn;
| 99 |
pflock(1);
| 100 |
return;
| 101 |
| 102 |
/* file exists -- switch to i/o process */
| 103 |
persistfd = open(pfn, O_RDWR);
| 104 |
if (persistfd < 0) {
| 105 |
sprintf(errmsg, "cannot open persist file \"%s\"", pfn);
| 106 |
error(SYSTEM, errmsg);
| 107 |
| 108 |
pflock(1);
| 109 |
io_process(); /* never returns */
| 110 |
| 111 |
| 112 |
| 113 |
static int got_io;
| 114 |
| 115 |
static int sig_io() { got_io++; }
| 116 |
| 117 |
static int sig_alrm() { quit(0); }
| 118 |
| 119 |
| 120 |
pfhold() /* holding pattern for idle rendering process */
| 121 |
| 122 |
int (*oldalrm)();
| 123 |
char buf[512];
| 124 |
register int n;
| 125 |
/* close input and output descriptors */
| 126 |
close(fileno(stdin));
| 127 |
close(fileno(stdout));
| 128 |
if (errfile == NULL)
| 129 |
close(fileno(stderr));
| 130 |
/* create named pipes for input and output */
| 131 |
if (mknod(mktemp(strcpy(inpname,TEMPLATE)), S_IFIFO|0600, 0) < 0)
| 132 |
goto createrr;
| 133 |
if (mknod(mktemp(strcpy(outpname,TEMPLATE)), S_IFIFO|0600, 0) < 0)
| 134 |
goto createrr;
| 135 |
if (errfile == NULL &&
| 136 |
mknod(mktemp(strcpy(errname,TEMPLATE)), S_IFIFO|0600, 0) < 0)
| 137 |
goto createrr;
| 138 |
sprintf(buf, "%s %d\n%s\n%s\n%s\n", progname, getpid(),
| 139 |
inpname, outpname, errname);
| 140 |
n = strlen(buf);
| 141 |
if (write(persistfd, buf, n) < n)
| 142 |
error(SYSTEM, "error writing persist file");
| 143 |
/* wait TIMELIM for someone to signal us */
| 144 |
got_io = 0;
| 145 |
signal(SIGIO, sig_io);
| 146 |
oldalrm = (int (*)())signal(SIGALRM, sig_alrm);
| 147 |
alarm(TIMELIM);
| 148 |
pflock(0); /* unlock persist file for attach */
| 149 |
while (!got_io)
| 150 |
pause(); /* wait for attach */
| 151 |
pflock(1); /* grab persist file right back! */
| 152 |
alarm(0); /* turn off alarm */
| 153 |
signal(SIGALRM, oldalrm);
| 154 |
signal(SIGIO, SIG_DFL);
| 155 |
if (lseek(persistfd, 0L, 0) < 0 || ftruncate(persistfd, 0L) < 0)
| 156 |
error(SYSTEM, "seek/truncate error on persist file");
| 157 |
/* someone wants us; reopen stdin and stdout */
| 158 |
if (freopen(inpname, "r", stdin) == NULL)
| 159 |
goto openerr;
| 160 |
if (freopen(outpname, "w", stdout) == NULL)
| 161 |
goto openerr;
| 162 |
if (errname[0]) {
| 163 |
if (freopen(errname, "w", stderr) == NULL)
| 164 |
goto openerr;
| 165 |
unlink(errname);
| 166 |
errname[0] = '\0';
| 167 |
| 168 |
unlink(inpname);
| 169 |
inpname[0] = '\0';
| 170 |
unlink(outpname);
| 171 |
outpname[0] = '\0';
| 172 |
return;
| 173 |
createrr:
| 174 |
error(SYSTEM, "cannot create named pipes in pfhold");
| 175 |
openerr:
| 176 |
error(SYSTEM, "cannot open named pipes in pfhold");
| 177 |
| 178 |
| 179 |
| 180 |
io_process() /* just act as go-between for actual process */
| 181 |
| 182 |
register char *cp;
| 183 |
register int nr, n;
| 184 |
char buf[BUFSIZ], *pfin, *pfout, *pferr;
| 185 |
int pid, nfds;
| 186 |
int fdin, fdout, fderr = -1;
| 187 |
fd_set readfds, writefds, excepfds;
| 188 |
/* load persist file */
| 189 |
while ((nr = read(persistfd, buf, sizeof(buf)-1)) == 0) {
| 190 |
pflock(0);
| 191 |
sleep(15); /* wait until ready */
| 192 |
pflock(1);
| 193 |
| 194 |
pfdetach(); /* close persist file */
| 195 |
if (nr < 0)
| 196 |
error(SYSTEM, "error reading persist file");
| 197 |
buf[nr] = '\0';
| 198 |
if ((cp = index(buf, ' ')) == NULL)
| 199 |
goto formerr;
| 200 |
*cp++ = '\0';
| 201 |
if ((pid = atoi(cp)) <= 0)
| 202 |
goto formerr;
| 203 |
if ((cp = index(cp, '\n')) == NULL)
| 204 |
goto formerr;
| 205 |
pfin = ++cp;
| 206 |
| 207 |
goto formerr;
| 208 |
*cp++ = '\0';
| 209 |
pfout = cp;
| 210 |
| 211 |
goto formerr;
| 212 |
*cp++ = '\0';
| 213 |
pferr = cp;
| 214 |
| 215 |
goto formerr;
| 216 |
*cp++ = '\0';
| 217 |
if (cp-buf != nr)
| 218 |
goto formerr;
| 219 |
if (strcmp(buf, progname)) {
| 220 |
sprintf(errmsg, "persist file for %s, not %s", buf, progname);
| 221 |
error(USER, errmsg);
| 222 |
| 223 |
/* wake up rendering process */
| 224 |
if (kill(pid, SIGIO) < 0)
| 225 |
error(SYSTEM, "cannot signal rendering process in io_process");
| 226 |
/* open named pipes, in order */
| 227 |
if ((fdin = open(pfin, O_WRONLY)) < 0)
| 228 |
error(SYSTEM, "cannot open input pipe in io_process");
| 229 |
if ((fdout = open(pfout, O_RDONLY)) < 0)
| 230 |
error(SYSTEM, "cannot open output pipe in io_process");
| 231 |
if (pferr[0] && (fderr = open(pferr, O_RDONLY)) < 0)
| 232 |
error(SYSTEM, "cannot open error pipe in io_process");
| 233 |
for ( ; ; ) { /* loop on select call */
| 234 |
FD_ZERO(&readfds);
| 235 |
FD_ZERO(&writefds);
| 236 |
FD_ZERO(&excepfds);
| 237 |
nfds = 0;
| 238 |
if (fdin >= 0) {
| 239 |
FD_SET(fdin, &writefds);
| 240 |
FD_SET(fdin, &excepfds);
| 241 |
nfds = fdin+1;
| 242 |
| 243 |
if (fdout >= 0) {
| 244 |
FD_SET(fdout, &readfds);
| 245 |
FD_SET(fdout, &excepfds);
| 246 |
nfds = fdout+1;
| 247 |
| 248 |
if (fderr >= 0) {
| 249 |
FD_SET(fderr, &readfds);
| 250 |
FD_SET(fderr, &excepfds);
| 251 |
nfds = fderr+1;
| 252 |
| 253 |
if (nfds == 0)
| 254 |
break; /* all done, exit */
| 255 |
if (select(nfds, &readfds, &writefds, &excepfds, NULL) < 0)
| 256 |
error(SYSTEM, "error in select call in io_process");
| 257 |
/* renderer stderr */
| 258 |
if (fderr >= 0 && (FD_ISSET(fderr, &readfds) ||
| 259 |
FD_ISSET(fderr, &excepfds))) {
| 260 |
nr = read(fderr, cp=buf, sizeof(buf));
| 261 |
if (nr < 0)
| 262 |
goto readerr;
| 263 |
if (nr == 0) {
| 264 |
close(fderr);
| 265 |
close(2);
| 266 |
fderr = -1;
| 267 |
} else
| 268 |
do { /* write it all */
| 269 |
if ((n = write(2, cp, nr)) <= 0)
| 270 |
goto writerr;
| 271 |
cp += n;
| 272 |
} while ((nr -= n) > 0);
| 273 |
| 274 |
/* renderer stdout */
| 275 |
if (fdout >= 0 && (FD_ISSET(fdout, &readfds) ||
| 276 |
FD_ISSET(fdout, &excepfds))) {
| 277 |
nr = read(fdout, cp=buf, sizeof(buf));
| 278 |
if (nr < 0)
| 279 |
goto readerr;
| 280 |
if (nr == 0) { /* EOF */
| 281 |
close(fdout);
| 282 |
close(1);
| 283 |
fdout = -1;
| 284 |
} else
| 285 |
| 286 |
if ((n = write(1, cp, nr)) <= 0)
| 287 |
goto writerr;
| 288 |
cp += n;
| 289 |
| 290 |
| 291 |
/* renderer stdin */
| 292 |
if (fdin >= 0 && (FD_ISSET(fdin, &writefds) ||
| 293 |
FD_ISSET(fdin, &excepfds))) {
| 294 |
nr = read(0, buf, 512); /* use minimal buffer */
| 295 |
if (nr < 0)
| 296 |
goto readerr;
| 297 |
if (nr == 0) {
| 298 |
close(0);
| 299 |
close(fdin);
| 300 |
fdin = -1;
| 301 |
} else if (write(fdin, buf, nr) < nr)
| 302 |
goto writerr; /* what else to do? */
| 303 |
| 304 |
| 305 |
_exit(0); /* we ought to return renderer error status! */
| 306 |
formerr:
| 307 |
error(USER, "format error in persist file");
| 308 |
readerr:
| 309 |
error(SYSTEM, "read error in io_process");
| 310 |
writerr:
| 311 |
error(SYSTEM, "write error in io_process");
| 312 |
| 313 |
| 314 |
#else
| 315 |
| 316 |
pfclean() {}
| 317 |
| 318 |
#endif
