| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: p_func.c,v 2.12 2024/01/07 18:04:16 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* p_func.c - routine for procedural patterns.
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include "ray.h"
| 11 |
#include "func.h"
| 12 |
#include "random.h"
| 13 |
#include "rtotypes.h"
| 14 |
| 15 |
| 16 |
* A procedural pattern can either be a brightness or a
| 17 |
* color function. A brightness function is given as:
| 18 |
| 19 |
* modifier brightfunc name
| 20 |
* 2+ bvarname filename xf
| 21 |
* 0
| 22 |
* n A1 A2 ..
| 23 |
| 24 |
* A color function is given as:
| 25 |
| 26 |
* modifier colorfunc name
| 27 |
* 4+ rvarname gvarname bvarname filename xf
| 28 |
* 0
| 29 |
* n A1 A2 ..
| 30 |
| 31 |
* A spectral function is given as:
| 32 |
| 33 |
* modifier specfunc name
| 34 |
* 2+ sfunc filename xf
| 35 |
* 0
| 36 |
* 2+ nmA nmB A3 ..
| 37 |
| 38 |
* Filename is the name of the file where the variable definitions
| 39 |
* can be found. The list of real arguments can be accessed by
| 40 |
* definitions in the file. The xf is a transformation
| 41 |
* to get from the original coordinates to the current coordinates.
| 42 |
* For the "specfunc" primitive, sfunc(nm) is a function of wavelength
| 43 |
* and must be defined from nmA to nmB, and should average to 1 over
| 44 |
* its range.
| 45 |
| 46 |
| 47 |
| 48 |
int
| 49 |
p_bfunc( /* compute brightness pattern */
| 50 |
OBJREC *m,
| 51 |
RAY *r
| 52 |
| 53 |
| 54 |
double bval;
| 55 |
MFUNC *mf;
| 56 |
| 57 |
if (m->oargs.nsargs < 2)
| 58 |
objerror(m, USER, "bad # arguments");
| 59 |
mf = getfunc(m, 1, 0x1, 0);
| 60 |
setfunc(m, r);
| 61 |
errno = 0;
| 62 |
bval = evalue(mf->ep[0]);
| 63 |
if ((errno == EDOM) | (errno == ERANGE)) {
| 64 |
objerror(m, WARNING, "compute error");
| 65 |
return(0);
| 66 |
| 67 |
scalescolor(r->pcol, bval);
| 68 |
return(0);
| 69 |
| 70 |
| 71 |
| 72 |
int
| 73 |
p_cfunc( /* compute color pattern */
| 74 |
OBJREC *m,
| 75 |
RAY *r
| 76 |
| 77 |
| 78 |
SCOLOR scval;
| 79 |
MFUNC *mf;
| 80 |
| 81 |
if (m->oargs.nsargs < 4)
| 82 |
| 83 |
mf = getfunc(m, 3, 0x7, 0);
| 84 |
setfunc(m, r);
| 85 |
errno = 0;
| 86 |
setscolor(scval, evalue(mf->ep[0]),
| 87 |
evalue(mf->ep[1]),
| 88 |
evalue(mf->ep[2]));
| 89 |
| 90 |
| 91 |
return(0);
| 92 |
| 93 |
smultscolor(r->pcol, scval);
| 94 |
return(0);
| 95 |
| 96 |
| 97 |
| 98 |
int
| 99 |
p_specfunc( /* compute spectral pattern */
| 100 |
OBJREC *m,
| 101 |
RAY *r
| 102 |
| 103 |
| 104 |
SCOLOR scsamp;
| 105 |
SCOLOR scval;
| 106 |
double wl, wlmin, wlmax, wlstep;
| 107 |
int ns, i;
| 108 |
| 109 |
if ((m->oargs.nsargs < 2) | (m->oargs.nfargs < 2))
| 110 |
| 111 |
if (m->oargs.farg[0] < m->oargs.farg[1]) {
| 112 |
wlmin = m->oargs.farg[0];
| 113 |
wlmax = m->oargs.farg[1];
| 114 |
} else {
| 115 |
wlmin = m->oargs.farg[1];
| 116 |
wlmax = m->oargs.farg[0];
| 117 |
| 118 |
if (wlmin < WLPART[3]) wlmin = WLPART[3];
| 119 |
if (wlmax > WLPART[0]) wlmax = WLPART[0];
| 120 |
if (wlmin >= wlmax) {
| 121 |
objerror(m, WARNING, "incompatible wavelength sampling");
| 122 |
return(0);
| 123 |
| 124 |
wlstep = (wlmax - wlmin)/(double)MAXCSAMP;
| 125 |
getfunc(m, 1, 0, 0);
| 126 |
setfunc(m, r);
| 127 |
errno = 0;
| 128 |
ns = (wlmax - wlmin)/wlstep + .1;
| 129 |
wl = wlmax - .5*wlstep;
| 130 |
for (i = ns; i-- > 0; wl -= wlstep) {
| 131 |
double ws = wl + 0.9*(.5-frandom())*wlstep;
| 132 |
scsamp[i] = funvalue(m->oargs.sarg[0], 1, &ws);
| 133 |
| 134 |
| 135 |
return(0);
| 136 |
| 137 |
| 138 |
convertscolorcol(scval, scsamp, ns, wlmin, wlmax);
| 139 |
| 140 |
return(0);
| 141 |
