| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: oocsort.c,v 2.4 2017/08/14 21:12:10 rschregle Exp $";
| 3 |
#endif
| 4 |
| 5 |
| 6 |
| 7 |
| 8 |
N-way out-of-core merge sort for records with 3D keys. Recursively
| 9 |
subdivides input into N blocks until these are of sufficiently small size
| 10 |
to be sorted in-core according to Z-order (Morton code), then N-way
| 11 |
merging them out-of-core using a priority queue as the stack unwinds.
| 12 |
| 13 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
| 14 |
(c) Lucerne University of Applied Sciences and Arts,
| 15 |
supported by the Swiss National Science Foundation (SNSF, #147053)
| 16 |
| 17 |
| 18 |
| 19 |
| 20 |
| 21 |
| 22 |
#if !defined(_WIN32) && !defined(_WIN64) || defined(PMAP_OOC)
| 23 |
/* No Windoze support for now */
| 24 |
| 25 |
#include "oocsort.h"
| 26 |
#include "oocmorton.h"
| 27 |
#include <stdio.h>
| 28 |
#include <stdlib.h>
| 29 |
#include <unistd.h>
| 30 |
#include <fcntl.h>
| 31 |
#include <sys/wait.h>
| 32 |
| 33 |
| 34 |
/* Priority queue node */
| 35 |
typedef struct {
| 36 |
OOC_MortonIdx pri; /* Record's priority (sort key) */
| 37 |
unsigned blk; /* Block containing record */
| 38 |
} OOC_SortQueueNode;
| 39 |
| 40 |
| 41 |
/* Priority queue */
| 42 |
typedef struct {
| 43 |
OOC_SortQueueNode *node;
| 44 |
unsigned len, tail;
| 45 |
} OOC_SortQueue;
| 46 |
| 47 |
| 48 |
/* Additional data for qsort() compare function. We resort to instancing
| 49 |
* this as a global variable instead of passing it to the compare func via
| 50 |
* qsort_r(), since the latter is a non-portable GNU extension. */
| 51 |
typedef struct {
| 52 |
RREAL *(*key)(const void*); /* Callback to access 3D key in record */
| 53 |
FVECT bbOrg; /* Origin of bbox containing keys */
| 54 |
RREAL mortonScale; /* Scale for generating Morton code */
| 55 |
} OOC_KeyData;
| 56 |
| 57 |
static OOC_KeyData keyData;
| 58 |
| 59 |
| 60 |
| 61 |
static int OOC_KeyCompare (const void *rec1, const void *rec2)
| 62 |
/* Comparison function for in-core quicksort */
| 63 |
| 64 |
OOC_MortonIdx pri1, pri2;
| 65 |
| 66 |
if (!rec1 || !rec2)
| 67 |
return 0;
| 68 |
| 69 |
pri1 = OOC_Key2Morton(keyData.key(rec1), keyData.bbOrg,
| 70 |
keyData.mortonScale);
| 71 |
pri2 = OOC_Key2Morton(keyData.key(rec2), keyData.bbOrg,
| 72 |
| 73 |
| 74 |
if (pri1 < pri2)
| 75 |
return -1;
| 76 |
else if (pri1 > pri2)
| 77 |
return 1;
| 78 |
else
| 79 |
return 0;
| 80 |
| 81 |
| 82 |
| 83 |
| 84 |
static int OOC_SortRead (FILE *file, unsigned recSize, char *rec)
| 85 |
/* Read next record from file; return 0 and record in rec on success,
| 86 |
* else -1 */
| 87 |
| 88 |
if (!rec || feof(file) || !fread(rec, recSize, 1, file))
| 89 |
return -1;
| 90 |
| 91 |
return 0;
| 92 |
| 93 |
| 94 |
| 95 |
| 96 |
static int OOC_SortPeek (FILE *file, unsigned recSize, char *rec)
| 97 |
/* Return next record from file WITHOUT advancing file position;
| 98 |
* return 0 and record in rec on success, else -1 */
| 99 |
| 100 |
const unsigned long filePos = ftell(file);
| 101 |
| 102 |
if (OOC_SortRead(file, recSize, rec))
| 103 |
return -1;
| 104 |
| 105 |
/* Workaround; fseek(file, -recSize, SEEK_CUR) causes subsequent
| 106 |
* fread()'s to fail until rewind() */
| 107 |
rewind(file);
| 108 |
if (fseek(file, filePos, SEEK_SET) < 0)
| 109 |
return -1;
| 110 |
| 111 |
return 0;
| 112 |
| 113 |
| 114 |
| 115 |
| 116 |
static int OOC_SortWrite (FILE *file, unsigned recSize, const char *rec)
| 117 |
/* Output record to file; return 0 on success, else -1 */
| 118 |
| 119 |
if (!rec || !fwrite(rec, recSize, 1, file))
| 120 |
return -1;
| 121 |
| 122 |
return 0;
| 123 |
| 124 |
| 125 |
| 126 |
| 127 |
#ifdef DEBUG_OOC_SORT
| 128 |
static int OOC_SortQueueCheck (OOC_SortQueue *pq, unsigned root)
| 129 |
/* Priority queue sanity check */
| 130 |
| 131 |
unsigned kid;
| 132 |
| 133 |
if (root < pq -> tail) {
| 134 |
if ((kid = (root << 1) + 1) < pq -> tail) {
| 135 |
if (pq -> node [kid].pri < pq -> node [root].pri)
| 136 |
return -1;
| 137 |
else return OOC_SortQueueCheck(pq, kid);
| 138 |
| 139 |
| 140 |
if ((kid = kid + 1) < pq -> tail) {
| 141 |
| 142 |
return -1;
| 143 |
| 144 |
| 145 |
| 146 |
| 147 |
return 0;
| 148 |
| 149 |
#endif
| 150 |
| 151 |
| 152 |
| 153 |
static int OOC_SortPush (OOC_SortQueue *pq, OOC_MortonIdx pri, unsigned blk)
| 154 |
/* Insert specified block index into priority queue; return block index
| 155 |
* or -1 if queue is full */
| 156 |
| 157 |
OOC_SortQueueNode *pqn = pq -> node;
| 158 |
unsigned kid, root;
| 159 |
| 160 |
if (pq -> tail >= pq -> len)
| 161 |
/* Queue full */
| 162 |
return -1;
| 163 |
| 164 |
/* Append node at tail and re-sort */
| 165 |
kid = pq -> tail++;
| 166 |
| 167 |
while (kid) {
| 168 |
root = (kid - 1) >> 1;
| 169 |
| 170 |
/* Compare with parent node and swap if necessary, else terminate */
| 171 |
if (pri < pqn [root].pri) {
| 172 |
pqn [kid].pri = pqn [root].pri;
| 173 |
pqn [kid].blk = pqn [root].blk;
| 174 |
kid = root;
| 175 |
| 176 |
else break;
| 177 |
| 178 |
| 179 |
pqn [kid].pri = pri;
| 180 |
pqn [kid].blk = blk;
| 181 |
| 182 |
| 183 |
if (OOC_SortQueueCheck(pq, 0) < 0) {
| 184 |
fprintf(stderr, "OOC_Sort: priority queue inconsistency\n");
| 185 |
return -1;
| 186 |
| 187 |
#endif
| 188 |
| 189 |
return blk;
| 190 |
| 191 |
| 192 |
| 193 |
| 194 |
static int OOC_SortPop (OOC_SortQueue *pq)
| 195 |
/* Remove head of priority queue and return its block index
| 196 |
or -1 if queue empty */
| 197 |
| 198 |
| 199 |
OOC_MortonIdx pri;
| 200 |
unsigned kid, kid2, root = 0, blk, res;
| 201 |
| 202 |
if (!pq -> tail)
| 203 |
/* Queue empty */
| 204 |
return -1;
| 205 |
| 206 |
res = pqn -> blk;
| 207 |
pri = pqn [--pq -> tail].pri;
| 208 |
blk = pqn [pq -> tail].blk;
| 209 |
| 210 |
/* Replace head with tail node and re-sort */
| 211 |
while ((kid = (root << 1) + 1) < pq -> tail) {
| 212 |
/* Compare with smaller kid and swap if necessary, else terminate */
| 213 |
if ((kid2 = (kid + 1)) < pq -> tail && pqn [kid2].pri < pqn [kid].pri)
| 214 |
kid = kid2;
| 215 |
| 216 |
if (pri > pqn [kid].pri) {
| 217 |
pqn [root].pri = pqn [kid].pri;
| 218 |
pqn [root].blk = pqn [kid].blk;
| 219 |
| 220 |
else break;
| 221 |
| 222 |
root = kid;
| 223 |
| 224 |
| 225 |
pqn [root].pri = pri;
| 226 |
pqn [root].blk = blk;
| 227 |
| 228 |
| 229 |
| 230 |
| 231 |
return -1;
| 232 |
| 233 |
#endif
| 234 |
| 235 |
return res;
| 236 |
| 237 |
| 238 |
| 239 |
| 240 |
/* Active subprocess counter updated by parent process; must persist when
| 241 |
* recursing into OOC_SortRecurse(), hence global */
| 242 |
static unsigned procCnt = 0;
| 243 |
| 244 |
static int OOC_SortRecurse (FILE *in, unsigned long blkLo,
| 245 |
unsigned long blkHi, FILE *out,
| 246 |
unsigned numBlk, unsigned long maxBlkSize,
| 247 |
unsigned numProc, unsigned recSize,
| 248 |
char *sortBuf, OOC_SortQueue *pqueue,
| 249 |
const OOC_KeyData *keyData)
| 250 |
/* Recursive part of OOC_Sort(). Reads block of records from input file
| 251 |
* within the interval [blkLo, blkHi] and divides it into numBlk blocks
| 252 |
* until the size (in bytes) does not exceed maxBlkSize, then quicksorts
| 253 |
* each block into a temporary file. These files are then mergesorted via a
| 254 |
* priority queue to the output file as the stack unwinds. NOTE: Critical
| 255 |
* sections are prepended with '!!!'
| 256 |
| 257 |
* Parameters are as follows:
| 258 |
* in Input file containing unsorted records (assumed to be open)
| 259 |
* blkLo Start of current block in input file, in number of records
| 260 |
* blkHi End of current block in input file, in number of records
| 261 |
* out Output file containing sorted records (assumed to be open)
| 262 |
* numBlk Number of blocks to divide into / merge from
| 263 |
* maxBlkSize Max block size and size of in-core sort buffer, in bytes
| 264 |
* numProc Number of parallel processes for in-core sort
| 265 |
* recSize Size of input records in bytes
| 266 |
* sortBuf Preallocated in-core sort buffer of size maxBlkSize
| 267 |
* pqueue Preallocated priority queue of length numBlk for block merge
| 268 |
* keyData Aggregate data for Morton code generation and comparison
| 269 |
| 270 |
| 271 |
const unsigned long blkLen = blkHi - blkLo + 1,
| 272 |
blkSize = blkLen * recSize;
| 273 |
int stat;
| 274 |
| 275 |
if (!blkLen || blkHi < blkLo)
| 276 |
return 0;
| 277 |
| 278 |
if (blkSize > maxBlkSize) {
| 279 |
unsigned long blkLo2 = blkLo, blkHi2 = blkLo, blkSize2;
| 280 |
const double blkLen2 = (double)blkLen / numBlk;
| 281 |
FILE *blkFile [numBlk]; /* Violates C89! */
| 282 |
char rec [recSize]; /* Ditto */
| 283 |
OOC_MortonIdx pri;
| 284 |
int b, pid;
| 285 |
| 286 |
unsigned long pqCnt = 0;
| 287 |
#endif
| 288 |
| 289 |
| 290 |
* Block too large for in-core sort -> divide into numBlk
| 291 |
* subblocks and recurse
| 292 |
| 293 |
| 294 |
| 295 |
fprintf(stderr, "OOC_Sort: splitting block [%lu - %lu]\n",
| 296 |
blkLo, blkHi);
| 297 |
#endif
| 298 |
| 299 |
for (b = 0; b < numBlk; b++) {
| 300 |
/* Open temporary file as output for subblock */
| 301 |
if (!(blkFile [b] = tmpfile())) {
| 302 |
perror("OOC_Sort: failed opening temporary block file");
| 303 |
return -1;
| 304 |
| 305 |
| 306 |
/* Subblock interval [blkLo2, blkHi2] of size blkSize2 */
| 307 |
blkHi2 = blkLo + (b + 1) * blkLen2 - 1;
| 308 |
blkSize2 = (blkHi2 - blkLo2 + 1) * recSize;
| 309 |
| 310 |
if (blkSize2 <= maxBlkSize) {
| 311 |
/* !!! Will be in-core sorted on recursion -> fork kid process,
| 312 |
* !!! but don't fork more than numProc kids; wait if necessary */
| 313 |
while (procCnt >= numProc && wait(&stat) >= 0) {
| 314 |
if (!WIFEXITED(stat) || WEXITSTATUS(stat))
| 315 |
return -1;
| 316 |
| 317 |
procCnt--;
| 318 |
| 319 |
| 320 |
/* Now fork kid process */
| 321 |
if (!(pid = fork())) {
| 322 |
/* Recurse on subblocks with new input filehandle; */
| 323 |
if (OOC_SortRecurse(in, blkLo2, blkHi2, blkFile [b], numBlk,
| 324 |
maxBlkSize, numProc, recSize, sortBuf,
| 325 |
pqueue, keyData))
| 326 |
exit(-1);
| 327 |
| 328 |
/* !!! Apparently the parent's tmpfile isn't deleted when the
| 329 |
* !!! child exits (which is what we want), though some
| 330 |
* !!! sources suggest using _Exit() instead; is this
| 331 |
* !!! implementation specific? */
| 332 |
exit(0);
| 333 |
| 334 |
else if (pid < 0) {
| 335 |
perror("OOC_Sort: failed to fork subprocess");
| 336 |
return -1;
| 337 |
| 338 |
| 339 |
#ifdef DEBUG_OOC_FORK
| 340 |
fprintf(stderr, "OOC_Sort: forking kid %d for block %d\n",
| 341 |
procCnt, b);
| 342 |
#endif
| 343 |
| 344 |
/* Parent continues here */
| 345 |
procCnt++;
| 346 |
| 347 |
else {
| 348 |
/* Recurse on subblock; without forking */
| 349 |
| 350 |
| 351 |
pqueue, keyData))
| 352 |
return -1;
| 353 |
| 354 |
| 355 |
/* Prepare for next block */
| 356 |
blkLo2 = blkHi2 + 1;
| 357 |
| 358 |
| 359 |
/* !!! Wait for any forked processes to terminate */
| 360 |
while (procCnt && wait(&stat) >= 0) {
| 361 |
| 362 |
return -1;
| 363 |
| 364 |
procCnt--;
| 365 |
| 366 |
| 367 |
| 368 |
* Subblocks are now sorted; prepare priority queue by peeking and
| 369 |
* enqueueing first record from corresponding temporary file
| 370 |
| 371 |
| 372 |
| 373 |
fprintf(stderr, "OOC_Sort: merging block [%lu - %lu]\n", blkLo, blkHi);
| 374 |
#endif
| 375 |
| 376 |
| 377 |
| 378 |
fseek(blkFile [b], 0, SEEK_END);
| 379 |
if (ftell(blkFile [b]) % recSize) {
| 380 |
fprintf(stderr, "OOC_Sort: truncated record in tmp block "
| 381 |
"file %d\n", b);
| 382 |
return -1;
| 383 |
| 384 |
| 385 |
fprintf(stderr, "OOC_Sort: tmp block file %d contains %ld rec\n",
| 386 |
b, ftell(blkFile [b]) / recSize);
| 387 |
#endif
| 388 |
| 389 |
rewind(blkFile [b]);
| 390 |
| 391 |
if (OOC_SortPeek(blkFile [b], recSize, rec)) {
| 392 |
fprintf(stderr, "OOC_Sort: error reading from block file\n");
| 393 |
return -1;
| 394 |
| 395 |
| 396 |
/* Enqueue record along with its Morton code as priority */
| 397 |
pri = OOC_Key2Morton(keyData -> key(rec), keyData -> bbOrg,
| 398 |
keyData -> mortonScale);
| 399 |
| 400 |
if (OOC_SortPush(pqueue, pri, b) < 0) {
| 401 |
fprintf(stderr, "OOC_Sort: failed priority queue insertion\n");
| 402 |
return -1;
| 403 |
| 404 |
| 405 |
| 406 |
| 407 |
* Subblocks now sorted and priority queue filled; merge from
| 408 |
* temporary files
| 409 |
| 410 |
| 411 |
do {
| 412 |
/* Get next node in priority queue, read next record in corresponding
| 413 |
* block, and send to output */
| 414 |
b = OOC_SortPop(pqueue);
| 415 |
| 416 |
if (b >= 0) {
| 417 |
/* Priority queue non-empty */
| 418 |
if (OOC_SortRead(blkFile [b], recSize, rec)) {
| 419 |
/* Corresponding record should still be in the input block */
| 420 |
fprintf(stderr, "OOC_Sort: unexpected end reading block file\n");
| 421 |
return -1;
| 422 |
| 423 |
| 424 |
if (OOC_SortWrite(out, recSize, rec)) {
| 425 |
fprintf(stderr, "OOC_Sort; error writing output file\n");
| 426 |
return -1;
| 427 |
| 428 |
| 429 |
| 430 |
pqCnt++;
| 431 |
#endif
| 432 |
| 433 |
/* Peek next record from same block and insert in priority queue */
| 434 |
if (!OOC_SortPeek(blkFile [b], recSize, rec)) {
| 435 |
/* Block not exhausted */
| 436 |
| 437 |
| 438 |
| 439 |
| 440 |
fprintf(stderr, "OOC_Sort: failed priority queue insert\n");
| 441 |
return -1;
| 442 |
| 443 |
| 444 |
| 445 |
} while (b >= 0);
| 446 |
| 447 |
| 448 |
fprintf(stderr, "OOC_Sort: dequeued %lu rec\n", pqCnt);
| 449 |
fprintf(stderr, "OOC_Sort: merged file contains %lu rec\n",
| 450 |
ftell(out) / recSize);
| 451 |
#endif
| 452 |
| 453 |
/* Priority queue now empty -> done; close temporary subblock files,
| 454 |
* causing them to be automatically deleted. */
| 455 |
| 456 |
fclose(blkFile [b]);
| 457 |
| 458 |
| 459 |
/* !!! Commit output file to disk before caller reads it; omitting
| 460 |
* !!! this apparently leads to corrupted files (race condition?) when
| 461 |
* !!! the caller tries to read them! */
| 462 |
fflush(out);
| 463 |
fsync(fileno(out));
| 464 |
| 465 |
| 466 |
else {
| 467 |
| 468 |
* Block is small enough for in-core sort
| 469 |
| 470 |
int ifd = fileno(in), ofd = fileno(out);
| 471 |
| 472 |
| 473 |
fprintf(stderr, "OOC_Sort: Proc %d (%d/%d) sorting block [%lu - %lu]\n",
| 474 |
getpid(), procCnt, numProc - 1, blkLo, blkHi);
| 475 |
| 476 |
#endif
| 477 |
| 478 |
/* Atomically seek and read block into in-core sort buffer */
| 479 |
/* !!! Unbuffered I/O via pread() avoids potential race conditions
| 480 |
* !!! and buffer corruption which can occur with lseek()/fseek()
| 481 |
* !!! followed by read()/fread(). */
| 482 |
if (pread(ifd, sortBuf, blkSize, blkLo * recSize) != blkSize) {
| 483 |
perror("OOC_Sort: error reading from input file");
| 484 |
return -1;
| 485 |
| 486 |
| 487 |
/* Quicksort block in-core and write to output file */
| 488 |
qsort(sortBuf, blkLen, recSize, OOC_KeyCompare);
| 489 |
| 490 |
if (write(ofd, sortBuf, blkSize) != blkSize) {
| 491 |
perror("OOC_Sort: error writing to block file");
| 492 |
return -1;
| 493 |
| 494 |
| 495 |
fsync(ofd);
| 496 |
| 497 |
| 498 |
fprintf(stderr, "OOC_Sort: proc %d wrote %ld records\n",
| 499 |
getpid(), lseek(ofd, 0, SEEK_END) / recSize);
| 500 |
#endif
| 501 |
| 502 |
| 503 |
return 0;
| 504 |
| 505 |
| 506 |
| 507 |
| 508 |
int OOC_Sort (FILE *in, FILE *out, unsigned numBlk,
| 509 |
unsigned long blkSize, unsigned numProc, unsigned recSize,
| 510 |
FVECT bbOrg, RREAL bbSize, RREAL *(*key)(const void*))
| 511 |
/* Sort records in inFile and append to outFile by subdividing inFile into
| 512 |
* small blocks, sorting these in-core, and merging them out-of-core via a
| 513 |
* priority queue.
| 514 |
| 515 |
* This is implemented as a recursive (numBlk)-way sort; the input is
| 516 |
* successively split into numBlk smaller blocks until these are of size <=
| 517 |
* blkSize, i.e. small enough for in-core sorting, then merging the sorted
| 518 |
* blocks as the stack unwinds. The in-core sort is parallelised over
| 519 |
* numProx processes.
| 520 |
| 521 |
| 522 |
* inFile Opened input file containing unsorted records
| 523 |
* outFile Opened output file containing sorted records
| 524 |
| 525 |
* blkSize Max block size and size of in-core sort buffer, in bytes
| 526 |
| 527 |
| 528 |
* bbOrg Origin of bounding box containing record keys for Morton code
| 529 |
* bbSize Extent of bounding box containing record keys for Morton code
| 530 |
* key Callback to access 3D coords from records for Morton code
| 531 |
| 532 |
| 533 |
unsigned long numRec;
| 534 |
OOC_SortQueue pqueue;
| 535 |
char *sortBuf = NULL;
| 536 |
int stat;
| 537 |
| 538 |
if (numBlk < 1)
| 539 |
numBlk = 1;
| 540 |
| 541 |
/* Open input file & get size in number of records */
| 542 |
if (fseek(in, 0, SEEK_END) < 0) {
| 543 |
fputs("OOC_Sort: failed seek in input file\n", stderr);
| 544 |
return -1;
| 545 |
| 546 |
| 547 |
if (!(numRec = ftell(in) / recSize)) {
| 548 |
fputs("OOC_Sort: empty input file\n", stderr);
| 549 |
return -1;
| 550 |
| 551 |
| 552 |
/* Allocate & init priority queue */
| 553 |
if (!(pqueue.node = calloc(numBlk, sizeof(OOC_SortQueueNode)))) {
| 554 |
fputs("OOC_Sort: failure allocating priority queue\n", stderr);
| 555 |
return -1;
| 556 |
| 557 |
pqueue.tail = 0;
| 558 |
pqueue.len = numBlk;
| 559 |
| 560 |
/* Allocate in-core sort buffa */
| 561 |
if (!(sortBuf = malloc(blkSize))) {
| 562 |
fprintf(stderr, "OOC_Sort: failure allocating in-core sort buffer");
| 563 |
return -1;
| 564 |
| 565 |
| 566 |
/* Set up key data to pass to qsort()'s comparison func */
| 567 |
keyData.key = key;
| 568 |
keyData.mortonScale = OOC_MORTON_MAX / bbSize;
| 569 |
VCOPY(keyData.bbOrg, bbOrg);
| 570 |
| 571 |
stat = OOC_SortRecurse(in, 0, numRec - 1, out, numBlk, blkSize, numProc,
| 572 |
recSize, sortBuf, &pqueue, &keyData);
| 573 |
| 574 |
/* Cleanup */
| 575 |
free(pqueue.node);
| 576 |
free(sortBuf);
| 577 |
| 578 |
return stat;
| 579 |
| 580 |
| 581 |
#endif /* NIX / PMAP_OOC */
