root/radiance/src/rt/oocnn.h
Revision: 2.2
Committed: Tue Sep 17 16:36:04 2024 UTC (13 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.1: +9 -2 lines
chore: Added extern "C" to headers to avoid C++ name mangling
# User Rev Content
1 rschregle 2.1 /*
2     =========================================================================
3     k-nearest neighbour lookup routines for out-of-core octree data structure
4
5     Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6     (c) Lucerne University of Applied Sciences and Arts,
7     supported by the Swiss National Science Foundation (SNSF, #147053)
8     =========================================================================
9
10 greg 2.2 $Id: oocnn.h,v 2.1 2016/05/17 17:39:47 rschregle Exp $
11 rschregle 2.1 */
12
13
14
15     #ifndef OOC_SEARCH_H
16     #define OOC_SEARCH_H
17
18     #include "oococt.h"
19
20     /* Priority queue node for octree lookups */
21     typedef struct {
22     float dist2; /* Record's *SQUARED* distance to query point */
23     unsigned idx; /* Record's index in queue buffer */
24     } OOC_SearchQueueNode;
25
26
27     /* Priority queue for octree lookups. Note that we explicitly store the
28     * NN candidates in a local in-core buffer nnRec for later retrieval
29     * without incurring additional disk I/O. */
30     typedef struct {
31     OOC_SearchQueueNode *node;
32     unsigned len, tail, recSize;
33     void *nnRec;
34     } OOC_SearchQueue;
35
36
37     /* Filter for k-NN search; records are accepted for which func(rec, data)
38     * returns nonzero */
39     typedef struct {
40     int (*func)(void *rec, void *data);
41     void *data;
42     } OOC_SearchFilter;
43
44 greg 2.2 #ifdef __cplusplus
45     extern "C" {
46     #endif
47 rschregle 2.1
48     float OOC_FindNearest (OOC_Octree *oct, OOC_Node *node,
49     OOC_DataIdx dataIdx, const FVECT org, float size,
50     const FVECT key, const OOC_SearchFilter *filter,
51     OOC_SearchQueue *queue, float maxDist2);
52     /* Find k nearest neighbours (where k = queue -> len) within a maximum
53     * SQUARED distance of maxDist2 around key. Returns the corresponding
54     * data records with their SQUARED distances in the search queue
55     * (queue -> node [0] .. queue -> node [queue -> tail - 1]), with the
56     * furthest neighbour at the queue head and queue->tail <= queue->len.
57     *
58     * This is a recursive function requiring params for the current node:
59     * DataIdx is the data offset for records in the current node, which is
60     * necessary for implied addressing into the leaf file. Org and size are
61     * the origin and size of the current node's bounding box.
62     *
63     * An optional filter may be specified; if filter != NULL, filter->func()
64     * is called for each potential nearest neighbour along with additional
65     * data provided by the caller; see OOC_SearchFilter typedef above.
66     *
67     * Return value is the SQUARED distance to furthest neighbour on success,
68     * else -1 on failure. */
69
70
71     float OOC_Find1Nearest (OOC_Octree *oct, OOC_Node *node,
72     OOC_DataIdx dataIdx, const FVECT org, float size,
73     const FVECT key, const OOC_SearchFilter *filter,
74     void *nnRec, float maxDist2);
75     /* Find single nearest neighbour within max SQUARED distance maxDist2
76     * around key and copy corresponding record in nnRec. This is an
77     * optimised version of OOC_FindNearest() without a search queue */
78
79
80     int OOC_InitNearest (OOC_SearchQueue *squeue,
81     unsigned len, unsigned recSize);
82     /* Initialise NN search queue of length len and local buffa for records
83     * of size recSize; precondition to calling OOC_FindNearest() */
84
85
86     void *OOC_GetNearest (const OOC_SearchQueue *queue, unsigned idx);
87     /* Return pointer to record at pos idx in search queue after calling
88     * OOC_FindNearest() */
89 greg 2.2
90     #ifdef __cplusplus
91     }
92     #endif
93
94 rschregle 2.1 #endif
