root/radiance/src/rt/oocnn.h
Revision: 2.2
Committed: Tue Sep 17 16:36:04 2024 UTC (12 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.1: +9 -2 lines
chore: Added extern "C" to headers to avoid C++ name mangling
1 /*
2 =========================================================================
3 k-nearest neighbour lookup routines for out-of-core octree data structure
4
5 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
6 (c) Lucerne University of Applied Sciences and Arts,
7 supported by the Swiss National Science Foundation (SNSF, #147053)
8 =========================================================================
9
10 $Id: oocnn.h,v 2.1 2016/05/17 17:39:47 rschregle Exp $
11 */
12
13
14
15 #ifndef OOC_SEARCH_H
16 #define OOC_SEARCH_H
17
18 #include "oococt.h"
19
20 /* Priority queue node for octree lookups */
21 typedef struct {
22 float dist2; /* Record's *SQUARED* distance to query point */
23 unsigned idx; /* Record's index in queue buffer */
24 } OOC_SearchQueueNode;
25
26
27 /* Priority queue for octree lookups. Note that we explicitly store the
28 * NN candidates in a local in-core buffer nnRec for later retrieval
29 * without incurring additional disk I/O. */
30 typedef struct {
31 OOC_SearchQueueNode *node;
32 unsigned len, tail, recSize;
33 void *nnRec;
34 } OOC_SearchQueue;
35
36
37 /* Filter for k-NN search; records are accepted for which func(rec, data)
38 * returns nonzero */
39 typedef struct {
40 int (*func)(void *rec, void *data);
41 void *data;
42 } OOC_SearchFilter;
43
44 #ifdef __cplusplus
45 extern "C" {
46 #endif
47
48 float OOC_FindNearest (OOC_Octree *oct, OOC_Node *node,
49 OOC_DataIdx dataIdx, const FVECT org, float size,
50 const FVECT key, const OOC_SearchFilter *filter,
51 OOC_SearchQueue *queue, float maxDist2);
52 /* Find k nearest neighbours (where k = queue -> len) within a maximum
53 * SQUARED distance of maxDist2 around key. Returns the corresponding
54 * data records with their SQUARED distances in the search queue
55 * (queue -> node [0] .. queue -> node [queue -> tail - 1]), with the
56 * furthest neighbour at the queue head and queue->tail <= queue->len.
57 *
58 * This is a recursive function requiring params for the current node:
59 * DataIdx is the data offset for records in the current node, which is
60 * necessary for implied addressing into the leaf file. Org and size are
61 * the origin and size of the current node's bounding box.
62 *
63 * An optional filter may be specified; if filter != NULL, filter->func()
64 * is called for each potential nearest neighbour along with additional
65 * data provided by the caller; see OOC_SearchFilter typedef above.
66 *
67 * Return value is the SQUARED distance to furthest neighbour on success,
68 * else -1 on failure. */
69
70
71 float OOC_Find1Nearest (OOC_Octree *oct, OOC_Node *node,
72 OOC_DataIdx dataIdx, const FVECT org, float size,
73 const FVECT key, const OOC_SearchFilter *filter,
74 void *nnRec, float maxDist2);
75 /* Find single nearest neighbour within max SQUARED distance maxDist2
76 * around key and copy corresponding record in nnRec. This is an
77 * optimised version of OOC_FindNearest() without a search queue */
78
79
80 int OOC_InitNearest (OOC_SearchQueue *squeue,
81 unsigned len, unsigned recSize);
82 /* Initialise NN search queue of length len and local buffa for records
83 * of size recSize; precondition to calling OOC_FindNearest() */
84
85
86 void *OOC_GetNearest (const OOC_SearchQueue *queue, unsigned idx);
87 /* Return pointer to record at pos idx in search queue after calling
88 * OOC_FindNearest() */
89
90 #ifdef __cplusplus
91 }
92 #endif
93
94 #endif
