| 1 | rschregle | 2.1 | /* |
| 2 |  |  | ======================================================================= |
| 3 |  |  | Header for building out-of-core octree data structure |
| 4 |  |  |  |
| 5 |  |  | Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
| 6 |  |  | (c) Lucerne University of Applied Sciences and Arts, |
| 7 |  |  | supported by the Swiss National Science Foundation (SNSF, #147053) |
| 8 |  |  | ======================================================================= |
| 9 |  |  |  |
| 10 |  |  | $Id: oocbuild.h,v 1.5 2015/08/05 17:29:01 taschreg Exp $ |
| 11 |  |  | */ |
| 12 |  |  |  |
| 13 |  |  |  |
| 14 |  |  | #ifndef OOC_BUILD_H |
| 15 |  |  | #define OOC_BUILD_H |
| 16 |  |  |  |
| 17 |  |  | /* Bottom-up construction of out-of-core octree in postorder traversal. |
| 18 |  |  | * The octree oct is assumed to be initialised with its origin (oct -> |
| 19 |  |  | * org), size (oct -> size), key callback (oct -> key), and its |
| 20 |  |  | * associated leaf file (oct -> leafFile). |
| 21 |  |  |  |
| 22 |  |  | * Records are read from the leafFile and assumed to be sorted in |
| 23 |  |  | * Z-order, which defines an octree leaf ordering.  Leaves (terminal |
| 24 |  |  | * nodes) are constructed such that they contain <= leafMax records and |
| 25 |  |  | * have a maximum depth of maxDepth. |
| 26 |  |  |  |
| 27 |  |  | * Note that the following limits apply: |
| 28 |  |  | *    leafMax  <= OOC_OCTCNT_MAX     (see oococt.h) |
| 29 |  |  | *    maxDepth <= OOC_MORTON_BITS    (see oocsort.h) |
| 30 |  |  |  |
| 31 |  |  | * The maxDepth limit arises from the fact that the Z-ordering has a |
| 32 |  |  | * limited resolution and will map node coordinates beyond a depth of |
| 33 |  |  | * OOC_MORTON_BITS to the same Z-index, causing nodes to be potentially |
| 34 |  |  | * read out of sequence and winding up in the wrong octree nodes. |
| 35 |  |  |  |
| 36 |  |  | * On success, the octree pointer oct is returned, with the constructed |
| 37 |  |  | * nodes in oct -> nodes, and the node count in oct -> numNodes.  On |
| 38 |  |  | * failure, NULL is returned.  */ |
| 39 |  |  | OOC_Octree *OOC_Build (OOC_Octree *oct, unsigned leafMax, |
| 40 |  |  | unsigned maxDepth); |
| 41 |  |  | #endif |
| 42 |  |  |  |
