root/radiance/src/rt/oocbuild.c
Revision: 2.4
Committed: Mon Aug 14 21:12:10 2017 UTC (8 years, 1 month ago) by rschregle
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1, rad6R0, HEAD
Changes since 2.3: +12 -2 lines
Updated photon map code for Windows; no multproc or ooC for now
4
5
6 /*
7 =======================================================================
8 Routines for building out-of-core octree data structure
9
10 Adapted from: Kontkanen J., Tabellion E. and Overbeck R.S.,
11 "Coherent Out-of-Core Point-Based Global Illumination",
12 EGSR 2011.
13
14 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
15 (c) Lucerne University of Applied Sciences and Arts,
16 supported by the Swiss National Science Foundation (SNSF, #147053)
17 =======================================================================
18
19 $Id: oocbuild.c,v 2.3 2016/05/17 17:39:47 rschregle Exp $
20 */
21
22
23 #if !defined(_WIN32) && !defined(_WIN64) || defined(PMAP_OOC)
24 /* No Windoze support for now */
25
26 #include "oococt.h"
27 #include "oocsort.h"
28 #include <stdlib.h>
29 #include <string.h>
30
31
32 /* Test for empty/full input queue, return pointer to head/tail */
33 #define QueueFull(q) ((q) -> len == (q) -> cap)
34 #define QueueEmpty(q) (!(q) -> len)
35 #define QueueHead(q) ((q) -> data + (q) -> head * (q) -> recSize)
36 #define QueueTail(q) ((q) -> data + \
37 ((q)->head + (q)->len-1) % (q)->cap * (q)->recSize)
38
39
40
41 /* Input queue for bottom-up octree construction */
42 typedef struct {
43 void *data;
44 unsigned head, len, cap, recSize; /* Queue head, length (from head),
45 capacity and record size */
46 FILE *in; /* Input file for data records */
47 } OOC_BuildQueue;
48
49
50 static OOC_BuildQueue *QueueInit (OOC_BuildQueue *q, unsigned recSize,
51 unsigned capacity)
52 /* Initialise queue of #capacity records of size recSize each; returns queue
53 * pointer or NULL if failed. */
54 {
55 if (!(q && (q -> data = calloc(capacity, recSize))))
56 return NULL;
57
58 q -> cap = capacity;
59 q -> recSize = recSize;
60 q -> head = q -> len = 0;
61
62 return q;
63 }
64
65
66 static int QueuePush (OOC_BuildQueue *q, const void *rec)
67 /* Append record to queue tail; return new queue length or -1 on failure */
68 {
69 if (!q || !rec || QueueFull(q))
70 return -1;
71
72 ++q->len;
73 memcpy(QueueTail(q), rec, q -> recSize);
74
75 return q -> len;
76 }
77
78
79 static int QueuePop (OOC_BuildQueue *q, void *rec)
80 /* Remove record from queue head and return in rec if not NULL; return new
81 * queue length or -1 on failure */
82 {
83 if (!q || QueueEmpty(q))
84 return -1;
85
86 /* Return head if rec != NULL */
87 if (rec)
88 memcpy(rec, QueueHead(q), q -> recSize);
89
90 q -> head = (q -> head + 1) % q -> cap;
91
92 return --q -> len;
93 }
94
95
96 static int QueueFill (OOC_BuildQueue *q)
97 /* Read records from q -> in until the queue is full; return queue
98 * length or -1 on failure */
99 {
100 static void *rec = NULL;
101
102 if (!rec && !(rec = malloc(q -> recSize)))
103 return -1;
104
105 while (!QueueFull(q) && !feof(q -> in) &&
106 fread(rec, q -> recSize, 1, q -> in))
107 QueuePush(q, rec);
108
109 return q -> len;
110 }
111
112
113
114 static OOC_DataIdx OOC_BuildRecurse (OOC_Octree *oct, OOC_Node* node,
115 FVECT org, RREAL size, unsigned depth,
116 OOC_BuildQueue *queue)
117 /* Recursive part of OOC_Build(); insert records from input queue into
118 * octree node and subdivide into kids if necessary. Returns number of
119 * records in subtree or OOC_DATAIDX_ERR if failed. */
120 {
121 int k;
122 const RREAL kidSize = size * 0.5;
123
124 if (!oct || !node)
125 return OOC_DATAIDX_ERR;
126
127 if (QueueEmpty(queue) ||
128 !OOC_InBBox(oct, org, size, oct -> key(QueueHead(queue))))
129 /* Input exhausted or queue head outside node */
130 return 0;
131
132 if (QueueFull(queue) && depth < oct -> maxDepth &&
133 OOC_InBBox(oct, org, size, oct -> key(QueueTail(queue)))) {
134 /*************************** SUBDIVIDE NODE *************************
135 * At least leafMax + 1 records (since the queue is full) lie inside
136 * the current node's bounding box, and maxDepth has not been reached
137 * ==> subdivide this node.
138 * (Note it suffices to only test the queue tail against the bounding
139 * box, as the records are in Z-order)
140 ********************************************************************/
141 OOC_Node kid [8];
142 OOC_DataIdx dataCnt;
143 FVECT kidOrg;
144
145 #ifdef DEBUG_OOC_BUILD
146 FVECT key;
147 unsigned k2 = 0;
148 #endif
149
150 /* We recurse on the nonempty kids first, then finalise their nodes so
151 * they are ordered consecutively, since the parent only indexes the 1st kid */
152 for (k = 0; k < 8; k++) {
153 /* Clear kid node and get its octant origin */
154 OOC_CLEARNODE(kid + k);
155
156 VCOPY(kidOrg, org);
157 OOC_OCTORIGIN(kidOrg, k, kidSize);
158
159 /* Recurse on kid and check for early bailout */
160 if (OOC_BuildRecurse(oct, kid + k, kidOrg, kidSize,
161 depth + 1, queue) == OOC_DATAIDX_ERR)
162 return OOC_DATAIDX_ERR;
163
164 #ifdef DEBUG_OOC_BUILD
165 if (!QueueEmpty(queue)) {
166 VCOPY(key, oct -> key(QueueHead(queue)));
167 k2 = OOC_Branch(oct, org, kidSize, key, NULL);
168 if (OOC_InBBox(oct, org, size, key) && k2 < k) {
169 fprintf(stderr,
170 "OOC_BuildRecurse, node subdiv: unsorted key [%f, %f, %f] with "
171 "octant %d (last %d with bbox [%f-%f, %f-%f, %f-%f])\n",
172 key [0], key [1], key [2], k2, k,
173 kidOrg [0], kidOrg [0] + kidSize, kidOrg [1], kidOrg [1] + kidSize,
174 kidOrg [2], kidOrg [2] + kidSize);
175 }}
176 #endif
177 }
178
179 /* Now finalise consecutive kid nodes, skipping empty ones */
180 for (k = 0; k < 8; k++)
181 if ((dataCnt = OOC_DATACNT(kid + k))) {
182 /* Nonzero kid ==> allocate and set node */
183 if (!NewNode(oct)) {
184 fputs("OOC_BuildRecurse: failed to allocate new node\n",
185 stderr);
186 return OOC_DATAIDX_ERR;
187 }
188 OOC_SETROOT(oct, kid + k);
189
190 /* Sum kid's data count to parent's and check for overflow */
191 if ((dataCnt += node -> node.num) <= OOC_DATAIDX_MAX)
192 node -> node.num = dataCnt;
193 else {
194 fputs("OOC_BuildRecurse: data count overflow in node\n",
195 stderr);
196 return OOC_DATAIDX_ERR;
197 }
198
199 /* Set kid index in parent (if first kid) and corresponding
200 * branch bit. The kid is the most recent node and thus at the
201 * end of the node array, which coincides with the current
202 * subtree root */
203 if (!node -> node.branch)
204 node -> node.kid = OOC_ROOTIDX(oct);
205
206 OOC_SETBRANCH(node, k);
207 }
208 }
209 else {
210 /****************************** MAKE LEAF ****************************
211 * Queue contains no more than leafMax records, queue tail lies
212 * outside node's bounding box, or maxDepth reached
213 * ==> make this node a leaf.
214 *********************************************************************/
215 RREAL *key;
216
217 #ifdef DEBUG_OOC_BUILD
218 OOC_MortonIdx zIdx, lastzIdx = 0;
219 FVECT /* key, */
220 lastKey, kidOrg;
221 unsigned lastk = 0;
222 #endif
223
224 /* Mark as leaf (note it's been cleared by the parent call) */
225 OOC_SETLEAF(node);
226
227 while (!QueueEmpty(queue) &&
228 OOC_InBBox(oct, org, size, (key = oct->key(QueueHead(queue))))) {
229 /* Record lies inside leaf; increment data counter for octant
230 * containing record. */
231
232 if ((k = OOC_Branch(oct, org, kidSize, key, NULL)) < 0) {
233 /* Shouldn't happen, as key tested within bbox above */
234 fprintf(stderr, "OOC_BuildRecurse: buggered Morton code, "
235 "disruption in space-time continuum?\n");
236 return OOC_DATAIDX_ERR;
237 }
238
239 if (node -> leaf.num [k] == OOC_OCTCNT_MAX) {
240 /* Currently we're buggered here; merge records instead? */
241 fprintf(stderr, "OOC_BuildRecurse: data count overflow in "
242 "leaf: depth = %d, count = %d\n",
243 depth, node -> leaf.num [k]);
244 return OOC_DATAIDX_ERR;
245 }
246
247 ++node -> leaf.num [k];
248
249 #ifdef DEBUG_OOC_BUILD
250 /* VCOPY(key, oct -> key(QueueHead(queue))); */
251 if ((zIdx = OOC_KEY2MORTON(key, oct)) < lastzIdx) {
252 fprintf(stderr, "OOC_BuildRecurse, make leaf: unsorted zIdx %020ld for "
253 "key [%f, %f, %f] (previous zIdx %020ld for "
254 "key [%f, %f, %f]\n", zIdx, key [0], key [1], key [2],
255 lastzIdx, lastKey [0], lastKey [1], lastKey [2]);
256 }
257
258 VCOPY(kidOrg, org);
259 OOC_OCTORIGIN(kidOrg, k, kidSize);
260 if (k < lastk || zIdx < lastzIdx) {
261 fprintf(stderr,
262 "OOC_BuildRecurse, make leaf: unsorted octant %d (last %d) with "
263 "bbox [%f-%f, %f-%f, %f-%f] for key [%f, %f, %f] with zIdx %020ld "
264 "(last [%f, %f, %f], zIdx %020ld)\n",
265 k, lastk, kidOrg [0], kidOrg [0] + kidSize,
266 kidOrg [1], kidOrg [1] + kidSize, kidOrg [2], kidOrg [2] + kidSize,
267 key [0], key [1], key [2], zIdx,
268 lastKey [0], lastKey [1], lastKey [2], lastzIdx);
269 }
270 lastk = k;
271 lastzIdx = zIdx;
272 VCOPY(lastKey, key);
273 #endif
274
275 /* Remove record from queue */
276 QueuePop(queue, NULL);
277 }
278
279 /* Refill queue for next node(s) */
280 if (QueueFill(queue) < 0) {
281 fputs("OOC_Build: failed input queue fill\n", stderr);
282 return OOC_DATAIDX_ERR;
283 }
284 }
285
286 return OOC_DATACNT(node);
287 }
288
289
290
291 OOC_Octree *OOC_Build (OOC_Octree *oct, unsigned leafMax, unsigned maxDepth)
292 /* Bottom-up construction of out-of-core octree in postorder traversal. The
293 * octree oct is assumed to be initialised with its origin (oct -> org),
294 * size (oct -> size), key callback (oct -> key), and its associated leaf
295 * file (oct -> leafFile).
296
297 * Records are read from the leafFile and assumed to be sorted in Z-order,
298 * which defines an octree leaf ordering. Leaves (terminal nodes) are
299 * constructed such that they contain <= leafMax records and have a maximum
300 * depth of maxDepth.
301
302 * Note that the following limits apply:
303 * leafMax <= OOC_OCTCNT_MAX (see oococt.h)
304 * maxDepth <= OOC_MORTON_BITS (see oocsort.h)
305
306 * The maxDepth limit arises from the fact that the Z-ordering has a limited
307 * resolution and will map node coordinates beyond a depth of
308 * OOC_MORTON_BITS to the same Z-index, causing nodes to be potentially read
309 * out of sequence and winding up in the wrong octree nodes.
310
311 * On success, the octree pointer oct is returned, with the constructed
312 * nodes in oct -> nodes, and the node count in oct -> numNodes. On
313 * failure, NULL is returned. */
314 {
315 OOC_BuildQueue queue;
316 OOC_Node root;
317
318 if (!oct || !oct -> size) {
319 fputs("OOC_Build: octree not initialised", stderr);
320 return NULL;
321 }
322
323 if (!oct -> leafFile) {
324 fputs("OOC_Build: empty leaf file", stderr);
325 return NULL;
326 }
327
328 oct -> leafMax = leafMax;
329 oct -> maxDepth = maxDepth;
330 queue.in = oct -> leafFile;
331 rewind(queue.in);
332
333 /* Init queue and fill from leaf file */
334 if (!QueueInit(&queue, oct -> recSize, leafMax + 1) ||
335 QueueFill(&queue) < 0) {
336 fputs("OOC_Build: failed input queue init\n", stderr);
337 return NULL;
338 }
339
340 /* Clear octree root and recurse */
341 OOC_CLEARNODE(&root);
342 if (OOC_BuildRecurse(oct, &root, oct -> org, oct -> size, 0, &queue) ==
343 OOC_DATAIDX_ERR)
344 return NULL;
345
346 /* Finalise octree root */
347 if (!NewNode(oct)) {
348 fputs("OOC_Build: failed to allocate octree root\n", stderr);
349 return NULL;
350 }
351 OOC_SETROOT(oct, &root);
352 /* Passing OOC_ROOT(oct) avoids annoying compiler warnings about (&root)
353 * always evaluating to true when calling OOC_DATAIDX() */
354 oct -> numData = OOC_DATACNT(OOC_ROOT(oct));
355
356 return oct;
357 }
358
359 #endif /* NIX / PMAP_OOC */
