root/radiance/src/rt/o_mesh.c
Revision: 2.16
Committed: Wed Jun 18 22:16:31 2025 UTC (4 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.15: +4 -2 lines
fix: Forgot to reset r->rox on intersection
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.16 static const char RCSid[] = "$Id: o_mesh.c,v 2.15 2019/03/01 02:03:33 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Routines for computing ray intersections with meshes.
6     *
7     * Intersection with a triangle mesh is based on Segura and Feito's
8     * WSCG 2001 paper, "Algorithms to Test Ray-Triangle Intersection,
9     * Comparative Study." This method avoids additional storage
10     * requirements, floating divides, and allows some savings by
11     * caching ray-edge comparisons that are otherwise repeated locally
12     * in typical mesh geometries. (This is our own optimization.)
13     *
14     * The code herein is quite similar to that in o_instance.c, the
15     * chief differences being the custom triangle intersection routines
16     * and the fact that an "OBJECT" in the mesh octree is not an index
17     * into the Radiance OBJREC list, but a mesh triangle index. We still
18     * utilize the standard octree traversal code by setting the hitf
19     * function pointer in the RAY struct to our custom mesh_hit() call.
20     */
21
22     #include "copyright.h"
23
24 schorsch 2.8 #include <string.h>
25
26 greg 2.1 #include "ray.h"
27     #include "mesh.h"
28     #include "tmesh.h"
29 schorsch 2.10 #include "rtotypes.h"
30 greg 2.1
31
32 greg 2.2 #define EDGE_CACHE_SIZ 251 /* length of mesh edge cache */
33 greg 2.1
34     #define curmi (edge_cache.mi)
35     #define curmsh (curmi->msh)
36
37
38     /* Cache of signed volumes for this ray and this mesh */
39     struct EdgeCache {
40     OBJREC *o; /* mesh object */
41     MESHINST *mi; /* current mesh instance */
42     struct EdgeSide {
43 greg 2.6 int32 v1i, v2i; /* vertex indices (lowest first) */
44 greg 2.1 short signum; /* signed volume */
45     } cache[EDGE_CACHE_SIZ];
46     } edge_cache;
47
48
49     static void
50     prep_edge_cache(o) /* get instance and clear edge cache */
51     OBJREC *o;
52     {
53     /* get mesh instance */
54     edge_cache.mi = getmeshinst(edge_cache.o = o, IO_ALL);
55     /* clear edge cache */
56 schorsch 2.8 memset((void *)edge_cache.cache, '\0', sizeof(edge_cache.cache));
57 greg 2.1 }
58
59
60     static int
61 greg 2.11 volume_sign(r, v1, v2) /* get signed volume for ray and edge */
62 greg 2.14 RAY *r;
63 greg 2.6 int32 v1, v2;
64 greg 2.1 {
65 greg 2.14 int reversed = 0;
66     struct EdgeSide *ecp;
67 greg 2.1
68     if (v1 > v2) {
69 greg 2.6 int32 t = v2; v2 = v1; v1 = t;
70 greg 2.1 reversed = 1;
71     }
72 greg 2.2 ecp = &edge_cache.cache[((v2<<11 ^ v1) & 0x7fffffff) % EDGE_CACHE_SIZ];
73 greg 2.11 if ((ecp->v1i != v1) | (ecp->v2i != v2)) {
74 greg 2.1 MESHVERT tv1, tv2; /* compute signed volume */
75 greg 2.4 FVECT v2d;
76 greg 2.1 double vol;
77 greg 2.11 if (!getmeshvert(&tv1, edge_cache.mi->msh, v1, MT_V) |
78 greg 2.2 !getmeshvert(&tv2, edge_cache.mi->msh, v2, MT_V))
79 greg 2.1 objerror(edge_cache.o, INTERNAL,
80 greg 2.11 "missing mesh vertex in volume_sign");
81 greg 2.4 VSUB(v2d, tv2.v, r->rorg);
82 greg 2.1 vol = (tv1.v[0] - r->rorg[0]) *
83 greg 2.4 (v2d[1]*r->rdir[2] - v2d[2]*r->rdir[1]);
84 greg 2.1 vol += (tv1.v[1] - r->rorg[1]) *
85 greg 2.4 (v2d[2]*r->rdir[0] - v2d[0]*r->rdir[2]);
86 greg 2.1 vol += (tv1.v[2] - r->rorg[2]) *
87 greg 2.4 (v2d[0]*r->rdir[1] - v2d[1]*r->rdir[0]);
88 greg 2.11 /* don't generate 0 */
89     ecp->signum = vol > .0 ? 1 : -1;
90 greg 2.1 ecp->v1i = v1;
91     ecp->v2i = v2;
92     }
93     return(reversed ? -ecp->signum : ecp->signum);
94     }
95
96
97     static void
98     mesh_hit(oset, r) /* intersect ray with mesh triangle(s) */
99     OBJECT *oset;
100     RAY *r;
101     {
102 greg 2.6 int32 tvi[3];
103 greg 2.1 int sv1, sv2, sv3;
104     MESHVERT tv[3];
105 greg 2.5 OBJECT tmod;
106 greg 2.1 FVECT va, vb, nrm;
107     double d;
108     int i;
109     /* check each triangle */
110     for (i = oset[0]; i > 0; i--) {
111 greg 2.5 if (!getmeshtrivid(tvi, &tmod, curmsh, oset[i]))
112 greg 2.1 objerror(edge_cache.o, INTERNAL,
113 greg 2.2 "missing triangle vertices in mesh_hit");
114 greg 2.11 sv1 = volume_sign(r, tvi[0], tvi[1]);
115     sv2 = volume_sign(r, tvi[1], tvi[2]);
116 greg 2.13 if (sv1 != sv2) /* compare volume signs */
117     continue;
118 greg 2.11 sv3 = volume_sign(r, tvi[2], tvi[0]);
119 greg 2.13 if (sv2 != sv3)
120 greg 2.11 continue;
121 greg 2.1 /* compute intersection */
122     getmeshvert(&tv[0], curmsh, tvi[0], MT_V);
123     getmeshvert(&tv[1], curmsh, tvi[1], MT_V);
124     getmeshvert(&tv[2], curmsh, tvi[2], MT_V);
125     VSUB(va, tv[0].v, tv[2].v);
126     VSUB(vb, tv[1].v, tv[0].v);
127     VCROSS(nrm, va, vb);
128     d = DOT(r->rdir, nrm);
129     if (d == 0.0)
130     continue; /* ray is tangent */
131     VSUB(va, tv[0].v, r->rorg);
132     d = DOT(va, nrm) / d;
133 greg 2.15 if ((d <= FTINY) | (d >= r->rot))
134 greg 2.1 continue; /* not good enough */
135     r->robj = oset[i]; /* else record hit */
136     r->ro = edge_cache.o;
137     r->rot = d;
138     VSUM(r->rop, r->rorg, r->rdir, d);
139     VCOPY(r->ron, nrm);
140 greg 2.2 /* normalize(r->ron) called & r->rod set in o_mesh() */
141 greg 2.1 }
142     }
143
144
145 greg 2.14 int
146 schorsch 2.10 o_mesh( /* compute ray intersection with a mesh */
147     OBJREC *o,
148 greg 2.14 RAY *r
149 schorsch 2.10 )
150 greg 2.1 {
151     RAY rcont;
152     int flags;
153     MESHVERT tv[3];
154 greg 2.5 OBJECT tmod;
155 schorsch 2.7 RREAL wt[3];
156 greg 2.1 int i;
157     /* get the mesh instance */
158     prep_edge_cache(o);
159     /* copy and transform ray */
160 schorsch 2.9 rcont = *r;
161 greg 2.1 multp3(rcont.rorg, r->rorg, curmi->x.b.xfm);
162     multv3(rcont.rdir, r->rdir, curmi->x.b.xfm);
163     for (i = 0; i < 3; i++)
164     rcont.rdir[i] /= curmi->x.b.sca;
165     rcont.rmax *= curmi->x.b.sca;
166     /* clear and trace ray */
167     rayclear(&rcont);
168     rcont.hitf = mesh_hit;
169     if (!localhit(&rcont, &curmi->msh->mcube))
170     return(0); /* missed */
171     if (rcont.rot * curmi->x.f.sca >= r->rot)
172     return(0); /* not close enough */
173     /* transform ray back */
174     r->rot = rcont.rot * curmi->x.f.sca;
175     multp3(r->rop, rcont.rop, curmi->x.f.xfm);
176     multv3(r->ron, rcont.ron, curmi->x.f.xfm);
177     normalize(r->ron);
178     r->rod = -DOT(r->rdir, r->ron);
179 greg 2.5 /* get triangle */
180     flags = getmeshtri(tv, &tmod, curmsh, rcont.robj, MT_ALL);
181 greg 2.1 if (!(flags & MT_V))
182     objerror(o, INTERNAL, "missing mesh vertices in o_mesh");
183 greg 2.5 r->robj = objndx(o); /* set object and material */
184 greg 2.15 if ((o->omod == OVOID) & (tmod != OVOID)) {
185 greg 2.5 r->ro = getmeshpseudo(curmsh, tmod);
186     r->rox = &curmi->x;
187 greg 2.16 } else {
188 greg 2.5 r->ro = o;
189 greg 2.16 r->rox = NULL;
190     }
191 greg 2.5 /* compute barycentric weights */
192 greg 2.1 if (flags & (MT_N|MT_UV))
193     if (get_baryc(wt, rcont.rop, tv[0].v, tv[1].v, tv[2].v) < 0) {
194     objerror(o, WARNING, "bad triangle in o_mesh");
195     flags &= ~(MT_N|MT_UV);
196     }
197     if (flags & MT_N) { /* interpolate normal */
198     for (i = 0; i < 3; i++)
199     rcont.pert[i] = wt[0]*tv[0].n[i] +
200     wt[1]*tv[1].n[i] +
201     wt[2]*tv[2].n[i];
202     multv3(r->pert, rcont.pert, curmi->x.f.xfm);
203     if (normalize(r->pert) != 0.0)
204 greg 2.12 VSUB(r->pert, r->pert, r->ron);
205 greg 2.3 } else
206     r->pert[0] = r->pert[1] = r->pert[2] = .0;
207
208 greg 2.1 if (flags & MT_UV) /* interpolate uv coordinates */
209     for (i = 0; i < 2; i++)
210     r->uv[i] = wt[0]*tv[0].uv[i] +
211     wt[1]*tv[1].uv[i] +
212     wt[2]*tv[2].uv[i];
213 greg 2.3 else
214     r->uv[0] = r->uv[1] = .0;
215 greg 2.15
216     return(1); /* return hit */
217 greg 2.1 }
