root/radiance/src/rt/m_wgmdf.c
Fri Jun 20 18:05:30 2025 UTC (3 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.13: +6 -6 lines
Diff to previous 2.13
refactor: Changed macros to function type for clarity
Fri Jun 20 16:48:39 2025 UTC (3 months, 3 weeks ago) by greg
Diff to previous 2.12
fix: Last change would have caused array underrun
Fri Jun 20 16:34:23 2025 UTC (3 months, 3 weeks ago) by greg
fix: Avoid array bounds errors in dimlist[] in deep ray trees
Sat May 31 00:54:34 2025 UTC (4 months, 2 weeks ago) by greg
Changes since 2.10: +9 -5 lines
perf: Avoid calling objndx() multiple times for multiple modifiers
Fri May 23 17:09:26 2025 UTC (4 months, 3 weeks ago) by greg
perf: Removed unnecessary randomization in call to getperpendicular()
Fri Dec 20 16:29:50 2024 UTC (9 months, 3 weeks ago) by greg
perf: Adjustment to source spread in lobe speculars that accounts for -dj
Thu Dec 19 23:25:28 2024 UTC (9 months, 3 weeks ago) by greg
fix: Issue with textured surfaces and source scattering
Wed Dec 18 18:34:13 2024 UTC (9 months, 4 weeks ago) by greg
Changes since 2.6: +15 -20 lines
perf: Further minor tweaks
Wed Dec 18 17:57:06 2024 UTC (9 months, 4 weeks ago) by greg
Changes since 2.5: +14 -15 lines
perf: Minor tweaks
Tue Dec 17 20:03:13 2024 UTC (9 months, 4 weeks ago) by greg
Changes since 2.4: +40 -13 lines
feat: Added setting of RdotP, NxP, NyP, and NzP variables
Wed Dec 11 18:32:26 2024 UTC (10 months ago) by greg
fix: Dangerous typo!
Wed Dec 11 17:34:03 2024 UTC (10 months ago) by greg
fix: Was over-estimating diffuse reflection with Fresnel effect
Tue Dec 10 03:16:13 2024 UTC (10 months ago) by greg
Changes since 2.1: +7 -4 lines
perf: Optimized initialization order for early shadow testing
Mon Dec 9 00:44:29 2024 UTC (10 months, 1 week ago) by greg
