root/radiance/src/rt/m_bsdf.c
Tue Aug 21 23:31:01 2018 UTC (7 years, 2 months ago) by greg
Changes since 2.54: +6 -2 lines
Diff to previous 2.54
Added balancing calls to SDfreeCache()
Wed Aug 8 04:15:18 2018 UTC (7 years, 2 months ago) by greg
Changes since 2.53: +1 -2 lines
Diff to previous 2.53
Removed removal of cosine factor, which was actually in error(!)
Thu Aug 2 22:44:35 2018 UTC (7 years, 2 months ago) by greg
Changes since 2.52: +13 -9 lines
Diff to previous 2.52
Switched to minimum solid angle rather than local SA for over-counting test
Tue Jun 26 14:42:18 2018 UTC (7 years, 3 months ago) by greg
Changes since 2.51: +7 -7 lines
Diff to previous 2.51
Decided to go with "aBSDF" for "aperture BSDF" rather than "sBSDF"
Mon Jun 25 23:04:06 2018 UTC (7 years, 3 months ago) by greg
Changes since 2.50: +4 -2 lines
Diff to previous 2.50
Fixed bug in direct calculation for BSDF introduced in last change
Mon Jun 25 20:49:10 2018 UTC (7 years, 3 months ago) by greg
Changes since 2.49: +45 -30 lines
Diff to previous 2.49
Sat May 12 02:32:10 2018 UTC (7 years, 5 months ago) by greg
Changes since 2.48: +3 -1 lines
Diff to previous 2.48
Some paranoia to avoid infinite loops
Fri May 11 14:26:24 2018 UTC (7 years, 5 months ago) by greg
Changes since 2.47: +6 -4 lines
Diff to previous 2.47
Avoid loss of specular sampling for low-weight daughter rays
Mon Feb 12 23:20:31 2018 UTC (7 years, 8 months ago) by greg
Changes since 2.46: +7 -7 lines
Diff to previous 2.46
Reverted previous change and added 1.5 fudge factor to avoid over-counting
Mon Feb 12 18:46:29 2018 UTC (7 years, 8 months ago) by greg
Changes since 2.45: +8 -8 lines
Diff to previous 2.45
Fixed issue with under-counting specular
Fri Jan 5 02:47:46 2018 UTC (7 years, 9 months ago) by greg
Changes since 2.44: +3 -3 lines
Diff to previous 2.44
Tweaked peak extraction code to improve results
Sat Dec 2 16:13:04 2017 UTC (7 years, 10 months ago) by greg
Changes since 2.43: +7 -4 lines
Diff to previous 2.43
Made it so weighted average only kicks in for small sources
Fri Dec 1 02:45:14 2017 UTC (7 years, 10 months ago) by greg
Changes since 2.42: +11 -7 lines
Diff to previous 2.42
Added cosine correction for through component and improved accuracy of direct specular component
Tue Nov 28 22:17:00 2017 UTC (7 years, 10 months ago) by greg
Changes since 2.41: +4 -1 lines
Diff to previous 2.41
Fixed occasional issue with zero BSDF regions
Tue Jul 18 21:33:14 2017 UTC (8 years, 3 months ago) by greg
Changes since 2.40: +14 -14 lines
Diff to previous 2.40
Minor change should not affect behavior
Mon Jul 17 00:14:28 2017 UTC (8 years, 3 months ago) by greg
Changes since 2.39: +75 -53 lines
Diff to previous 2.39
Implemented view component for BTDFs
Fri Jun 2 18:10:11 2017 UTC (8 years, 4 months ago) by greg
Changes since 2.38: +22 -19 lines
Diff to previous 2.38
Fixed over-counting error introduced in revision 2.31
Fri May 19 15:13:41 2017 UTC (8 years, 5 months ago) by greg
Changes since 2.37: +7 -4 lines
Diff to previous 2.37
Fixed issue with indirect under-estimation in proxied BSDF transmitters
Thu May 18 17:59:37 2017 UTC (8 years, 5 months ago) by greg
Changes since 2.36: +19 -16 lines
Diff to previous 2.36
Further tweak to make sure we never double-count
Tue May 16 20:06:40 2017 UTC (8 years, 5 months ago) by greg
Changes since 2.35: +13 -13 lines
Diff to previous 2.35
Fixed issue with variable-resolution BSDF sampling of direct component
Tue May 16 02:52:15 2017 UTC (8 years, 5 months ago) by greg
Changes since 2.34: +16 -12 lines
Diff to previous 2.34
Fixed comments and changed threshold to 0.7% for "through" shadow testing
Mon May 15 22:50:33 2017 UTC (8 years, 5 months ago) by greg
Changes since 2.33: +108 -13 lines
Diff to previous 2.33
Made shadow testing work through BSDF's with through component (Thanks to David G-M)
Sun Feb 19 17:22:18 2017 UTC (8 years, 8 months ago) by greg
Changes since 2.32: +11 -11 lines
Diff to previous 2.32
Renamed direct sampling routine for clarity
Sat Feb 18 19:12:49 2017 UTC (8 years, 8 months ago) by greg
Changes since 2.31: +44 -8 lines
Diff to previous 2.31
Corrected double-counting of diffuse contributions
Fri Feb 17 23:24:56 2017 UTC (8 years, 8 months ago) by greg
Changes since 2.30: +31 -57 lines
Diff to previous 2.30
Simplified handling of diffuse components
Wed Sep 2 18:59:01 2015 UTC (10 years, 1 month ago) by greg
Changes since 2.29: +8 -1 lines
Diff to previous 2.29
Had to reinstate ambRayInPmap() macro to avoid over-counting bug
Sat Aug 1 23:27:04 2015 UTC (10 years, 2 months ago) by greg
Diff to previous 2.28
Tue May 26 13:21:07 2015 UTC (10 years, 5 months ago) by greg
Changes since 2.27: +1 -7 lines
Diff to previous 2.27
Removed deprecated ambRayInPmap() macro from code
Tue Feb 24 19:39:26 2015 UTC (10 years, 7 months ago) by greg
Changes since 2.26: +7 -1 lines
Diff to previous 2.26
Sat Jan 25 18:27:39 2014 UTC (11 years, 8 months ago) by greg
Changes since 2.25: +8 -9 lines
Diff to previous 2.25
Wed Jan 22 16:39:57 2014 UTC (11 years, 9 months ago) by greg
Changes since 2.24: +2 -1 lines
Diff to previous 2.24
Added missing call to set function context
Thu Jul 4 15:14:45 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.23: +4 -2 lines
Diff to previous 2.23
Added extra checks where projected solid angle is undefined
Tue Apr 9 16:55:15 2013 UTC (12 years, 6 months ago) by greg
Changes since 2.22: +5 -1 lines
Diff to previous 2.22
Fixed bug for BSDF materials included via octree or mesh instances
Sun Sep 2 15:33:15 2012 UTC (13 years, 1 month ago) by greg
Changes since 2.21: +8 -4 lines
Diff to previous 2.21
Sat Jun 9 07:16:47 2012 UTC (13 years, 4 months ago) by greg
Changes since 2.20: +4 -4 lines
Diff to previous 2.20
Tue Apr 24 15:53:41 2012 UTC (13 years, 6 months ago) by greg
Changes since 2.19: +8 -11 lines
Diff to previous 2.19
Further refinements in error testing/reporting
Tue Apr 24 15:36:40 2012 UTC (13 years, 6 months ago) by greg
Changes since 2.18: +6 -3 lines
Diff to previous 2.18
Improved error reporting for illegal orientation vector
Fri Mar 30 15:08:40 2012 UTC (13 years, 6 months ago) by greg
Diff to previous 2.17
Fixed serious bug in transmitting proxy material ambient sampling
Thu Sep 22 02:15:56 2011 UTC (14 years, 1 month ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16
Minor optimizations
Wed Aug 24 04:31:13 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.15: +6 -6 lines
Diff to previous 2.15
Improved oversampling check
Mon Aug 22 16:00:47 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.14: +24 -23 lines
Diff to previous 2.14
Further improved sampling method
Sun Aug 21 22:38:12 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.13: +14 -13 lines
Diff to previous 2.13
Minor improvements to direct specular sampling
Sun Aug 21 21:24:30 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.12: +54 -32 lines
Diff to previous 2.12
Vastly improved direct specular sampling
Sun Aug 21 16:55:29 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.11: +7 -7 lines
Minor fix to through component calculation
Wed Jun 8 15:37:46 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.10: +16 -21 lines
Stratified specular sampling with -ss > 1
Sun Apr 24 19:39:21 2011 UTC (14 years, 6 months ago) by greg
Partial implementation of variable-resolution BSDFs
Tue Apr 19 21:31:22 2011 UTC (14 years, 6 months ago) by greg
Changes since 2.8: +39 -28 lines
Fixed interface for determining BSDF solid angles
Wed Apr 6 00:14:26 2011 UTC (14 years, 6 months ago) by greg
Improved output efficiency by reducing number of calls to fwrite()
Tue Feb 22 05:41:02 2011 UTC (14 years, 8 months ago) by greg
Changes since 2.6: +39 -43 lines
Fixed problem with double-counting through component in indirect
Sun Feb 20 17:43:43 2011 UTC (14 years, 8 months ago) by greg
Changes since 2.5: +12 -10 lines
Fixed bug in source sampling for proxies
Sun Feb 20 06:34:19 2011 UTC (14 years, 8 months ago) by greg
Changes since 2.4: +171 -41 lines
Made BSDF proxy behavior consistent for shadowing, reflection and transmission
Sat Feb 19 23:42:09 2011 UTC (14 years, 8 months ago) by greg
Changes since 2.3: +53 -19 lines
Fixes to BSDF including blurring of angle boundaries
Sat Feb 19 01:48:59 2011 UTC (14 years, 8 months ago) by greg
Changes since 2.2: +15 -18 lines
Minor changes and fixes -- first working version of BSDF material
Fri Feb 18 02:41:55 2011 UTC (14 years, 8 months ago) by greg
Changes since 2.1: +6 -31 lines
Minor fixes and adjustments
Fri Feb 18 00:40:25 2011 UTC (14 years, 8 months ago) by greg
