root/radiance/src/rt/m_brdf.c
Revision: 2.44
Committed: Wed Dec 18 17:57:06 2024 UTC (10 months ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.43: +2 -3 lines
perf: Minor tweaks
2 static const char RCSid[] = "$Id: m_brdf.c,v 2.43 2024/12/13 19:05:03 greg Exp $";
5 * Shading for materials with arbitrary BRDF's
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "ambient.h"
12 #include "data.h"
13 #include "source.h"
14 #include "otypes.h"
15 #include "rtotypes.h"
16 #include "func.h"
17 #include "pmapmat.h"
18
19 /*
20 * Arguments to this material include the color and specularity.
21 * String arguments include the reflection function and files.
22 * The BRDF is currently used just for the specular component to light
23 * sources. Reflectance values or data coordinates are functions
24 * of the direction to the light source. (Data modification functions
25 * are passed the source direction as args 2-4.)
26 * We orient the surface towards the incoming ray, so a single
27 * surface can be used to represent an infinitely thin object.
28 *
29 * Arguments for MAT_PFUNC and MAT_MFUNC are:
30 * 2+ func funcfile transform
31 * 0
32 * 4+ red grn blu specularity A5 ..
33 *
34 * Arguments for MAT_PDATA and MAT_MDATA are:
35 * 4+ func datafile funcfile v0 .. transform
36 * 0
37 * 4+ red grn blu specularity A5 ..
38 *
39 * Arguments for MAT_TFUNC are:
40 * 2+ func funcfile transform
41 * 0
42 * 6+ red grn blu rspec trans tspec A7 ..
43 *
44 * Arguments for MAT_TDATA are:
45 * 4+ func datafile funcfile v0 .. transform
46 * 0
47 * 6+ red grn blu rspec trans tspec A7 ..
48 *
49 * Arguments for the more general MAT_BRTDF are:
50 * 10+ rrefl grefl brefl
51 * rtrns gtrns btrns
52 * rbrtd gbrtd bbrtd
53 * funcfile transform
54 * 0
55 * 9+ rdf gdf bdf
56 * rdb gdb bdb
57 * rdt gdt bdt A10 ..
58 *
59 * In addition to the normal variables available to functions,
60 * we define the following:
61 * NxP, NyP, NzP - perturbed surface normal
62 * RdotP - perturbed ray dot product
63 * CrP, CgP, CbP - perturbed material color (or pattern)
64 */
65
66 typedef struct {
67 OBJREC *mp; /* material pointer */
68 RAY *pr; /* intersected ray */
69 DATARRAY *dp; /* data array for PDATA, MDATA or TDATA */
70 SCOLOR mcolor; /* material (or pattern) color */
71 SCOLOR rdiff; /* diffuse reflection */
72 SCOLOR tdiff; /* diffuse transmission */
73 double rspec; /* specular reflectance (1 for BRDTF) */
74 double trans; /* transmissivity (.5 for BRDTF) */
75 double tspec; /* specular transmittance (1 for BRDTF) */
76 FVECT pnorm; /* perturbed surface normal */
77 double pdot; /* perturbed dot product */
78 } BRDFDAT; /* BRDF material data */
79
80
81 static int setbrdfunc(BRDFDAT *np);
82
83
84 static void
85 dirbrdf( /* compute source contribution */
86 SCOLOR scval, /* returned coefficient */
87 void *nnp, /* material data */
88 FVECT ldir, /* light source direction */
89 double omega /* light source size */
90 )
91 {
92 BRDFDAT *np = nnp;
93 double ldot;
94 double dtmp;
95 SCOLOR sctmp;
96 COLOR ctmp;
97 FVECT ldx;
98 static double vldx[5], pt[MAXDDIM];
99 char **sa;
100 int i;
101 #define lddx (vldx+1)
102
103 scolorblack(scval);
104
105 ldot = DOT(np->pnorm, ldir);
106
107 if (ldot <= FTINY && ldot >= -FTINY)
108 return; /* too close to grazing */
109
110 if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY)
111 return; /* wrong side */
112
113 if (ldot > 0.0) {
114 /*
115 * Compute and add diffuse reflected component to returned
116 * color. The diffuse reflected component will always be
117 * modified by the color of the material.
118 */
119 copyscolor(sctmp, np->rdiff);
120 dtmp = ldot * omega / PI;
121 scalescolor(sctmp, dtmp);
122 saddscolor(scval, sctmp);
123 } else {
124 /*
125 * Diffuse transmitted component.
126 */
127 copyscolor(sctmp, np->tdiff);
128 dtmp = -ldot * omega / PI;
129 scalescolor(sctmp, dtmp);
130 saddscolor(scval, sctmp);
131 }
132 if ((ldot > 0.0 ? np->rspec <= FTINY : np->tspec <= FTINY) ||
133 ambRayInPmap(np->pr))
134 return; /* diffuse only */
135 /* set up function */
136 setbrdfunc(np);
137 sa = np->mp->oargs.sarg;
138 errno = 0;
139 /* transform light vector */
140 multv3(ldx, ldir, funcxf.xfm);
141 for (i = 0; i < 3; i++)
142 lddx[i] = ldx[i]/funcxf.sca;
143 lddx[3] = omega;
144 /* compute BRTDF */
145 if (np->mp->otype == MAT_BRTDF) {
146 if (sa[6][0] == '0' && !sa[6][1]) /* special case */
147 colval(ctmp,RED) = 0.0;
148 else
149 colval(ctmp,RED) = funvalue(sa[6], 4, lddx);
150 if (sa[7][0] == '0' && !sa[7][1])
151 colval(ctmp,GRN) = 0.0;
152 else if (!strcmp(sa[7],sa[6]))
153 colval(ctmp,GRN) = colval(ctmp,RED);
154 else
155 colval(ctmp,GRN) = funvalue(sa[7], 4, lddx);
156 if (sa[8][0] == '0' && !sa[8][1])
157 colval(ctmp,BLU) = 0.0;
158 else if (!strcmp(sa[8],sa[6]))
159 colval(ctmp,BLU) = colval(ctmp,RED);
160 else if (!strcmp(sa[8],sa[7]))
161 colval(ctmp,BLU) = colval(ctmp,GRN);
162 else
163 colval(ctmp,BLU) = funvalue(sa[8], 4, lddx);
164 dtmp = bright(ctmp);
165 } else if (np->dp == NULL) {
166 dtmp = funvalue(sa[0], 4, lddx);
167 setcolor(ctmp, dtmp, dtmp, dtmp);
168 } else {
169 for (i = 0; i < np->dp->nd; i++)
170 pt[i] = funvalue(sa[3+i], 4, lddx);
171 vldx[0] = datavalue(np->dp, pt);
172 dtmp = funvalue(sa[0], 5, vldx);
173 setcolor(ctmp, dtmp, dtmp, dtmp);
174 }
175 if ((errno == EDOM) | (errno == ERANGE)) {
176 objerror(np->mp, WARNING, "compute error");
177 return;
178 }
179 if (dtmp <= FTINY)
180 return;
181 setscolor(sctmp, colval(ctmp,RED), colval(ctmp,GRN), colval(ctmp,BLU));
182 if (ldot > 0.0) {
183 /*
184 * Compute reflected non-diffuse component.
185 */
186 if ((np->mp->otype == MAT_MFUNC) | (np->mp->otype == MAT_MDATA))
187 smultscolor(sctmp, np->mcolor);
188 dtmp = ldot * omega * np->rspec;
189 scalescolor(sctmp, dtmp);
190 saddscolor(scval, sctmp);
191 } else {
192 /*
193 * Compute transmitted non-diffuse component.
194 */
195 if ((np->mp->otype == MAT_TFUNC) | (np->mp->otype == MAT_TDATA))
196 smultscolor(sctmp, np->mcolor);
197 dtmp = -ldot * omega * np->tspec;
198 scalescolor(sctmp, dtmp);
199 saddscolor(scval, sctmp);
200 }
201 #undef lddx
202 }
203
204
205 int
206 m_brdf( /* color a ray that hit a BRDTfunc material */
207 OBJREC *m,
208 RAY *r
209 )
210 {
211 BRDFDAT nd;
212 RAY sr;
213 int hasrefl, hastrans;
214 int hastexture;
215 SCOLOR sctmp;
216 FVECT vtmp;
217 double d;
218 MFUNC *mf;
219 int i;
220 /* check arguments */
221 if ((m->oargs.nsargs < 10) | (m->oargs.nfargs < 9))
222 objerror(m, USER, "bad # arguments");
223 nd.mp = m;
224 nd.pr = r;
225 /* dummy values */
226 nd.rspec = nd.tspec = 1.0;
227 nd.trans = 0.5;
228 /* diffuse reflectance */
229 if (r->rod > 0.0)
230 setscolor(nd.rdiff, m->oargs.farg[0],
231 m->oargs.farg[1],
232 m->oargs.farg[2]);
233 else
234 setscolor(nd.rdiff, m->oargs.farg[3],
235 m->oargs.farg[4],
236 m->oargs.farg[5]);
237 /* diffuse transmittance */
238 setscolor(nd.tdiff, m->oargs.farg[6],
239 m->oargs.farg[7],
240 m->oargs.farg[8]);
241 /* get modifiers */
242 raytexture(r, m->omod);
243 hastexture = (DOT(r->pert,r->pert) > FTINY*FTINY);
244 if (hastexture) { /* perturb normal */
245 nd.pdot = raynormal(nd.pnorm, r);
246 } else {
247 VCOPY(nd.pnorm, r->ron);
248 nd.pdot = r->rod;
249 }
250 if (r->rod < 0.0) { /* orient perturbed values */
251 nd.pdot = -nd.pdot;
252 for (i = 0; i < 3; i++) {
253 nd.pnorm[i] = -nd.pnorm[i];
254 r->pert[i] = -r->pert[i];
255 }
256 }
257 copyscolor(nd.mcolor, r->pcol); /* get pattern color */
258 smultscolor(nd.rdiff, nd.mcolor); /* modify diffuse values */
259 smultscolor(nd.tdiff, nd.mcolor);
260 hasrefl = (sintens(nd.rdiff) > FTINY);
261 hastrans = (sintens(nd.tdiff) > FTINY);
262 /* load cal file */
263 nd.dp = NULL;
264 mf = getfunc(m, 9, 0x3F, 0);
265 /* compute transmitted ray */
266 setbrdfunc(&nd);
267 errno = 0;
268 setscolor(sctmp, evalue(mf->ep[3]),
269 evalue(mf->ep[4]),
270 evalue(mf->ep[5]));
271 if ((errno == EDOM) | (errno == ERANGE))
272 objerror(m, WARNING, "compute error");
273 else if (rayorigin(&sr, TRANS, r, sctmp) == 0) {
274 if (hastexture && !(r->crtype & (SHADOW|AMBIENT))) {
275 /* perturb direction */
276 VSUB(sr.rdir, r->rdir, r->pert);
277 if (normalize(sr.rdir) == 0.0) {
278 objerror(m, WARNING, "illegal perturbation");
279 VCOPY(sr.rdir, r->rdir);
280 }
281 } else {
282 VCOPY(sr.rdir, r->rdir);
283 }
284 rayvalue(&sr);
285 smultscolor(sr.rcol, sr.rcoef);
286 saddscolor(r->rcol, sr.rcol);
287 if ((!hastexture || r->crtype & (SHADOW|AMBIENT)) &&
288 nd.tspec > pbright(nd.tdiff) + pbright(nd.rdiff))
289 r->rxt = r->rot + raydistance(&sr);
290 }
291 if (r->crtype & SHADOW) /* the rest is shadow */
292 return(1);
293
294 /* compute reflected ray */
295 setbrdfunc(&nd);
296 errno = 0;
297 setscolor(sctmp, evalue(mf->ep[0]),
298 evalue(mf->ep[1]),
299 evalue(mf->ep[2]));
300 if ((errno == EDOM) | (errno == ERANGE))
301 objerror(m, WARNING, "compute error");
302 else if (rayorigin(&sr, REFLECTED, r, sctmp) == 0) {
303 VSUM(sr.rdir, r->rdir, nd.pnorm, 2.*nd.pdot);
304 checknorm(sr.rdir);
305 rayvalue(&sr);
306 smultscolor(sr.rcol, sr.rcoef);
307 copyscolor(r->mcol, sr.rcol);
308 saddscolor(r->rcol, sr.rcol);
309 r->rmt = r->rot;
310 if (r->ro != NULL && isflat(r->ro->otype) &&
311 !hastexture | (r->crtype & AMBIENT))
312 r->rmt += raydistance(&sr);
313 }
314 /* compute ambient */
315 if (hasrefl) {
316 copyscolor(sctmp, nd.rdiff);
317 multambient(sctmp, r, nd.pnorm);
318 saddscolor(r->rcol, sctmp); /* add to returned color */
319 }
320 if (hastrans) { /* from other side */
321 vtmp[0] = -nd.pnorm[0];
322 vtmp[1] = -nd.pnorm[1];
323 vtmp[2] = -nd.pnorm[2];
324 copyscolor(sctmp, nd.tdiff);
325 multambient(sctmp, r, vtmp);
326 saddscolor(r->rcol, sctmp);
327 }
328 if (hasrefl | hastrans || m->oargs.sarg[6][0] != '0')
329 direct(r, dirbrdf, &nd); /* add direct component */
330
331 return(1);
332 }
333
334
335
336 int
337 m_brdf2( /* color a ray that hit a BRDF material */
338 OBJREC *m,
339 RAY *r
340 )
341 {
342 BRDFDAT nd;
343 SCOLOR sctmp;
344 FVECT vtmp;
345 double dtmp;
346 /* always a shadow */
347 if (r->crtype & SHADOW)
348 return(1);
349 /* check for back side */
350 if (r->rod < 0.0) {
351 if (!backvis) {
352 raytrans(r);
353 return(1);
354 }
355 raytexture(r, m->omod);
356 flipsurface(r); /* reorient if backvis */
357 } else
358 raytexture(r, m->omod);
359 /* check arguments */
360 if ((m->oargs.nsargs < (hasdata(m->otype)?4:2)) | (m->oargs.nfargs <
361 ((m->otype==MAT_TFUNC)|(m->otype==MAT_TDATA)?6:4)))
362 objerror(m, USER, "bad # arguments");
363
364 nd.mp = m;
365 nd.pr = r;
366 /* get material color */
367 setscolor(nd.mcolor, m->oargs.farg[0],
368 m->oargs.farg[1],
369 m->oargs.farg[2]);
370 /* get specular component */
371 nd.rspec = m->oargs.farg[3];
372 /* compute transmittance */
373 if ((m->otype == MAT_TFUNC) | (m->otype == MAT_TDATA)) {
374 nd.trans = m->oargs.farg[4]*(1.0 - nd.rspec);
375 nd.tspec = nd.trans * m->oargs.farg[5];
376 dtmp = nd.trans - nd.tspec;
377 setscolor(nd.tdiff, dtmp, dtmp, dtmp);
378 } else {
379 nd.tspec = nd.trans = 0.0;
380 scolorblack(nd.tdiff);
381 }
382 /* compute reflectance */
383 dtmp = 1.0 - nd.trans - nd.rspec;
384 setscolor(nd.rdiff, dtmp, dtmp, dtmp);
385 nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */
386 smultscolor(nd.mcolor, r->pcol); /* modify material color */
387 smultscolor(nd.rdiff, nd.mcolor);
388 smultscolor(nd.tdiff, nd.mcolor);
389 /* load auxiliary files */
390 if (hasdata(m->otype)) {
391 nd.dp = getdata(m->oargs.sarg[1]);
392 getfunc(m, 2, 0, 0);
393 } else {
394 nd.dp = NULL;
395 getfunc(m, 1, 0, 0);
396 }
397 /* compute ambient */
398 if (nd.trans < 1.0-FTINY) {
399 copyscolor(sctmp, nd.mcolor); /* modified by material color */
400 scalescolor(sctmp, 1.0-nd.trans);
401 multambient(sctmp, r, nd.pnorm);
402 saddscolor(r->rcol, sctmp); /* add to returned color */
403 }
404 if (nd.trans > FTINY) { /* from other side */
405 vtmp[0] = -nd.pnorm[0];
406 vtmp[1] = -nd.pnorm[1];
407 vtmp[2] = -nd.pnorm[2];
408 copyscolor(sctmp, nd.mcolor);
409 scalescolor(sctmp, nd.trans);
410 multambient(sctmp, r, vtmp);
411 saddscolor(r->rcol, sctmp);
412 }
413 /* add direct component */
414 direct(r, dirbrdf, &nd);
415
416 return(1);
417 }
418
419
420 static int
421 setbrdfunc( /* set up brdf function and variables */
422 BRDFDAT *np
423 )
424 {
425 FVECT vec;
426 COLOR ctmp;
427
428 if (setfunc(np->mp, np->pr) == 0)
429 return(0); /* it's OK, setfunc says we're done */
430 /* else (re)assign special variables */
431 multv3(vec, np->pnorm, funcxf.xfm);
432 varset("NxP`", '=', vec[0]/funcxf.sca);
433 varset("NyP`", '=', vec[1]/funcxf.sca);
434 varset("NzP`", '=', vec[2]/funcxf.sca);
435 varset("RdotP`", '=', np->pdot);
436 scolor_color(ctmp, np->mcolor); /* should use scolor_rgb()? */
437 varset("CrP", '=', colval(ctmp,RED));
438 varset("CgP", '=', colval(ctmp,GRN));
439 varset("CbP", '=', colval(ctmp,BLU));
440 return(1);
441 }
