root/radiance/src/rt/glass.c
Revision: 2.22
Committed: Sat May 10 17:43:01 2014 UTC (11 years, 5 months ago) by greg
Changes since 2.21: +7 -6 lines
Fixed virtual distance so as not to undermine ambient calculation
2 static const char RCSid[] = "$Id: glass.c,v 2.21 2014/01/25 18:27:39 greg Exp $";
5 * glass.c - simpler shading function for thin glass surfaces.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "otypes.h"
12 #include "rtotypes.h"
13
14 /*
15 * This definition of glass provides for a quick calculation
16 * using a single surface where two closely spaced parallel
17 * dielectric surfaces would otherwise be used. The chief
18 * advantage to using this material is speed, since internal
19 * reflections are avoided.
20 *
21 * The specification for glass is as follows:
22 *
23 * modifier glass id
24 * 0
25 * 0
26 * 3+ red grn blu [refractive_index]
27 *
28 * The color is used for the transmission at normal incidence.
29 * To compute transmissivity (tn) from transmittance (Tn) use:
30 *
31 * tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn
32 *
33 * The transmissivity of standard 88% transmittance glass is 0.96.
34 * A refractive index other than the default can be used by giving
35 * it as the fourth real argument. The above formula no longer applies.
36 *
37 * If we appear to hit the back side of the surface, then we
38 * turn the normal around.
39 */
40
41 #define RINDEX 1.52 /* refractive index of glass */
42
43
44 int
45 m_glass( /* color a ray which hit a thin glass surface */
46 OBJREC *m,
47 RAY *r
48 )
49 {
50 COLOR mcolor;
51 double pdot;
52 FVECT pnorm;
53 double rindex=0, cos2;
54 COLOR trans, refl;
55 int hastexture, hastrans;
56 double d, r1e, r1m;
57 double transtest, transdist;
58 double mirtest, mirdist;
59 RAY p;
60 int i;
61 /* check arguments */
62 if (m->oargs.nfargs == 3)
63 rindex = RINDEX; /* default value of n */
64 else if (m->oargs.nfargs == 4)
65 rindex = m->oargs.farg[3]; /* use their value */
66 else
67 objerror(m, USER, "bad arguments");
68 /* check back face visibility */
69 if (!backvis && r->rod <= 0.0) {
70 raytrans(r);
71 return(1);
72 }
73 /* check transmission */
74 setcolor(mcolor, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]);
75 if ((hastrans = (intens(mcolor) > 1e-15))) {
76 for (i = 0; i < 3; i++)
77 if (colval(mcolor,i) < 1e-15)
78 colval(mcolor,i) = 1e-15;
79 } else if (r->crtype & SHADOW)
80 return(1);
81 /* get modifiers */
82 raytexture(r, m->omod);
83 if (r->rod < 0.0) /* reorient if necessary */
84 flipsurface(r);
85 mirtest = transtest = 0;
86 mirdist = transdist = r->rot;
87 /* perturb normal */
88 if ( (hastexture = (DOT(r->pert,r->pert) > FTINY*FTINY)) ) {
89 pdot = raynormal(pnorm, r);
90 } else {
91 VCOPY(pnorm, r->ron);
92 pdot = r->rod;
93 }
94 /* angular transmission */
95 cos2 = sqrt( (1.0-1.0/(rindex*rindex)) +
96 pdot*pdot/(rindex*rindex) );
97 if (hastrans)
98 setcolor(mcolor, pow(colval(mcolor,RED), 1.0/cos2),
99 pow(colval(mcolor,GRN), 1.0/cos2),
100 pow(colval(mcolor,BLU), 1.0/cos2));
101
102 /* compute reflection */
103 r1e = (pdot - rindex*cos2) / (pdot + rindex*cos2);
104 r1e *= r1e;
105 r1m = (1.0/pdot - rindex/cos2) / (1.0/pdot + rindex/cos2);
106 r1m *= r1m;
107 /* compute transmission */
108 if (hastrans) {
109 for (i = 0; i < 3; i++) {
110 d = colval(mcolor, i);
111 colval(trans,i) = .5*(1.0-r1e)*(1.0-r1e)*d /
112 (1.0-r1e*r1e*d*d);
113 colval(trans,i) += .5*(1.0-r1m)*(1.0-r1m)*d /
114 (1.0-r1m*r1m*d*d);
115 }
116 multcolor(trans, r->pcol); /* modify by pattern */
117 /* transmitted ray */
118 if (rayorigin(&p, TRANS, r, trans) == 0) {
119 if (!(r->crtype & (SHADOW|AMBIENT)) && hastexture) {
120 VSUM(p.rdir, r->rdir, r->pert, 2.*(1.-rindex));
121 if (normalize(p.rdir) == 0.0) {
122 objerror(m, WARNING, "bad perturbation");
123 VCOPY(p.rdir, r->rdir);
124 }
125 } else {
126 VCOPY(p.rdir, r->rdir);
127 transtest = 2;
128 }
129 rayvalue(&p);
130 multcolor(p.rcol, p.rcoef);
131 addcolor(r->rcol, p.rcol);
132 transtest *= bright(p.rcol);
133 transdist = r->rot + p.rt;
134 }
135 }
136 if (r->crtype & SHADOW) { /* skip reflected ray */
137 r->rt = transdist;
138 return(1);
139 }
140 /* compute reflectance */
141 for (i = 0; i < 3; i++) {
142 d = colval(mcolor, i);
143 d *= d;
144 colval(refl,i) = .5*r1e*(1.0+(1.0-2.0*r1e)*d)/(1.0-r1e*r1e*d);
145 colval(refl,i) += .5*r1m*(1.0+(1.0-2.0*r1m)*d)/(1.0-r1m*r1m*d);
146 }
147 /* reflected ray */
148 if (rayorigin(&p, REFLECTED, r, refl) == 0) {
149 VSUM(p.rdir, r->rdir, pnorm, 2.*pdot);
150 checknorm(p.rdir);
151 rayvalue(&p);
152 multcolor(p.rcol, p.rcoef);
153 addcolor(r->rcol, p.rcol);
154 if (r->ro != NULL && isflat(r->ro->otype) &&
155 !hastexture | (r->crtype & AMBIENT)) {
156 mirtest = 2.0*bright(p.rcol);
157 mirdist = r->rot + p.rt;
158 }
159 }
160 /* check distance */
161 d = bright(r->rcol);
162 if (transtest > d)
163 r->rt = transdist;
164 else if (mirtest > d)
165 r->rt = mirdist;
166 return(1);
167 }
