| 1 |
/* Copyright (c) 1991 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* func.c - interface to calcomp functions.
| 9 |
| 10 |
* 4/7/86
| 11 |
| 12 |
| 13 |
#include "ray.h"
| 14 |
| 15 |
#include "otypes.h"
| 16 |
| 17 |
| 18 |
#define INITFILE "rayinit.cal"
| 19 |
#define DEFVNAME "`FILE_LOADED"
| 20 |
| 21 |
XF unitxf = { /* identity transform */
| 22 |
1.0, 0.0, 0.0, 0.0,
| 23 |
0.0, 1.0, 0.0, 0.0,
| 24 |
0.0, 0.0, 1.0, 0.0,
| 25 |
0.0, 0.0, 0.0, 1.0,
| 26 |
1.0
| 27 |
| 28 |
| 29 |
XF funcxf; /* current transformation */
| 30 |
static OBJREC *fobj = NULL; /* current function object */
| 31 |
static RAY *fray = NULL; /* current function ray */
| 32 |
| 33 |
| 34 |
setmap(m, r, bx) /* set channels for function call */
| 35 |
OBJREC *m;
| 36 |
register RAY *r;
| 37 |
XF *bx;
| 38 |
| 39 |
extern long eclock;
| 40 |
static long lastrno = -1;
| 41 |
/* check to see if already set */
| 42 |
if (m == fobj && r->rno == lastrno)
| 43 |
return(0);
| 44 |
fobj = m;
| 45 |
fray = r;
| 46 |
if (r->rox != NULL)
| 47 |
if (bx != &unitxf) {
| 48 |
funcxf.sca = r->rox->b.sca * bx->sca;
| 49 |
multmat4(funcxf.xfm, r->rox->b.xfm, bx->xfm);
| 50 |
} else
| 51 |
copystruct(&funcxf, &r->rox->b);
| 52 |
else
| 53 |
copystruct(&funcxf, bx);
| 54 |
lastrno = r->rno;
| 55 |
eclock++; /* notify expression evaluator */
| 56 |
return(1);
| 57 |
| 58 |
| 59 |
| 60 |
setfunc(m, r) /* simplified interface to setmap */
| 61 |
register OBJREC *m;
| 62 |
RAY *r;
| 63 |
| 64 |
register XF *mxf;
| 65 |
| 66 |
if ((mxf = (XF *)m->os) == NULL) {
| 67 |
register int n;
| 68 |
register char **sa;
| 69 |
| 70 |
for (n = m->oargs.nsargs, sa = m->oargs.sarg;
| 71 |
n > 0 && **sa != '-'; n--, sa++)
| 72 |
| 73 |
if (n == 0)
| 74 |
mxf = &unitxf;
| 75 |
else {
| 76 |
mxf = (XF *)malloc(sizeof(XF));
| 77 |
if (mxf == NULL)
| 78 |
goto memerr;
| 79 |
if (invxf(mxf, n, sa) != n)
| 80 |
objerror(m, USER, "bad transform");
| 81 |
if (mxf->sca < 0.0)
| 82 |
mxf->sca = -mxf->sca;
| 83 |
| 84 |
m->os = (char *)mxf;
| 85 |
| 86 |
return(setmap(m, r, mxf));
| 87 |
memerr:
| 88 |
error(SYSTEM, "out of memory in setfunc");
| 89 |
| 90 |
| 91 |
| 92 |
loadfunc(fname) /* load definition file */
| 93 |
char *fname;
| 94 |
| 95 |
extern char *libpath; /* library search path */
| 96 |
char *ffname;
| 97 |
| 98 |
if ((ffname = getpath(fname, libpath, R_OK)) == NULL) {
| 99 |
sprintf(errmsg, "cannot find function file \"%s\"", fname);
| 100 |
error(USER, errmsg);
| 101 |
| 102 |
fcompile(ffname);
| 103 |
| 104 |
| 105 |
| 106 |
double
| 107 |
l_arg() /* return nth real argument */
| 108 |
| 109 |
extern double argument();
| 110 |
register int n;
| 111 |
| 112 |
n = argument(1) + .5; /* round to integer */
| 113 |
| 114 |
if (n < 1)
| 115 |
return(fobj->oargs.nfargs);
| 116 |
| 117 |
if (n > fobj->oargs.nfargs) {
| 118 |
sprintf(errmsg, "missing real argument %d", n);
| 119 |
objerror(fobj, USER, errmsg);
| 120 |
| 121 |
return(fobj->oargs.farg[n-1]);
| 122 |
| 123 |
| 124 |
| 125 |
double
| 126 |
l_erf() /* error function */
| 127 |
| 128 |
extern double erf();
| 129 |
| 130 |
return(erf(argument(1)));
| 131 |
| 132 |
| 133 |
| 134 |
double
| 135 |
l_erfc() /* cumulative error function */
| 136 |
| 137 |
extern double erfc();
| 138 |
| 139 |
return(erfc(argument(1)));
| 140 |
| 141 |
| 142 |
| 143 |
funcfile(fname) /* set context, load file if necessary */
| 144 |
register char *fname;
| 145 |
| 146 |
extern char *setcontext();
| 147 |
static char initfile[] = INITFILE;
| 148 |
| 149 |
if (initfile[0]) { /* initialize on first call */
| 150 |
setcontext("");
| 151 |
scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
| 152 |
scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
| 153 |
scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
| 154 |
scompile("T=$10;Rdot=$11;", NULL, 0);
| 155 |
scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
| 156 |
scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
| 157 |
scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
| 158 |
scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
| 159 |
funset("arg", 1, '=', l_arg);
| 160 |
funset("erf", 1, ':', l_erf);
| 161 |
funset("erfc", 1, ':', l_erfc);
| 162 |
setnoisefuncs();
| 163 |
loadfunc(initfile);
| 164 |
initfile[0] = '\0';
| 165 |
| 166 |
if (fname[0] == '.' && fname[1] == '\0')
| 167 |
setcontext(""); /* "." means no file */
| 168 |
else {
| 169 |
setcontext(fname);
| 170 |
if (!vardefined(DEFVNAME)) {
| 171 |
loadfunc(fname);
| 172 |
varset(DEFVNAME, ':', 1.0);
| 173 |
| 174 |
| 175 |
| 176 |
| 177 |
| 178 |
double
| 179 |
chanvalue(n) /* return channel n to calcomp */
| 180 |
register int n;
| 181 |
| 182 |
double sum;
| 183 |
register RAY *r;
| 184 |
| 185 |
if (--n < 0)
| 186 |
goto badchan;
| 187 |
| 188 |
if (n < 3) /* ray direction */
| 189 |
| 190 |
return( ( fray->rdir[0]*funcxf.xfm[0][n] +
| 191 |
fray->rdir[1]*funcxf.xfm[1][n] +
| 192 |
fray->rdir[2]*funcxf.xfm[2][n] )
| 193 |
/ funcxf.sca );
| 194 |
| 195 |
if (n < 6) /* surface normal */
| 196 |
| 197 |
return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
| 198 |
fray->ron[1]*funcxf.xfm[1][n-3] +
| 199 |
fray->ron[2]*funcxf.xfm[2][n-3] )
| 200 |
/ funcxf.sca );
| 201 |
| 202 |
if (n < 9) /* intersection */
| 203 |
| 204 |
return( fray->rop[0]*funcxf.xfm[0][n-6] +
| 205 |
fray->rop[1]*funcxf.xfm[1][n-6] +
| 206 |
fray->rop[2]*funcxf.xfm[2][n-6] +
| 207 |
funcxf.xfm[3][n-6] );
| 208 |
| 209 |
if (n == 9) { /* distance */
| 210 |
| 211 |
sum = fray->rot;
| 212 |
for (r = fray->parent; r != NULL; r = r->parent)
| 213 |
sum += r->rot;
| 214 |
return(sum * funcxf.sca);
| 215 |
| 216 |
| 217 |
if (n == 10) /* dot product (range [-1,1]) */
| 218 |
return( fray->rod <= -1.0 ? -1.0 :
| 219 |
fray->rod >= 1.0 ? 1.0 :
| 220 |
fray->rod );
| 221 |
| 222 |
if (n == 11) /* scale */
| 223 |
return(funcxf.sca);
| 224 |
| 225 |
if (n < 15) /* origin */
| 226 |
return(funcxf.xfm[3][n-12]);
| 227 |
| 228 |
if (n < 18) /* i unit vector */
| 229 |
return(funcxf.xfm[0][n-15] / funcxf.sca);
| 230 |
| 231 |
if (n < 21) /* j unit vector */
| 232 |
return(funcxf.xfm[1][n-15] / funcxf.sca);
| 233 |
| 234 |
if (n < 24) /* k unit vector */
| 235 |
return(funcxf.xfm[2][n-21] / funcxf.sca);
| 236 |
badchan:
| 237 |
error(USER, "illegal channel number");
| 238 |
