root/radiance/src/rt/func.c
Revision: 2.34
Committed: Sat May 13 00:26:27 2017 UTC (8 years, 5 months ago) by greg
CVS Tags: rad5R2, rad5R1
Changes since 2.33: +2 -1 lines
Added unnecessary but logical increment to eclock
2 static const char RCSid[] = "$Id: func.c,v 2.33 2017/05/13 00:09:53 greg Exp $";
5 * func.c - interface to calcomp functions.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "paths.h"
12 #include "otypes.h"
13 #include "func.h"
14 #include <ctype.h>
15
16
17 #define INITFILE "rayinit.cal"
18 #define CALSUF ".cal"
19 #define LCALSUF 4
20 char REFVNAME[] = "`FILE_REFCNT";
21
22 XF unitxf = { /* identity transform */
23 {{1.0, 0.0, 0.0, 0.0},
24 {0.0, 1.0, 0.0, 0.0},
25 {0.0, 0.0, 1.0, 0.0},
26 {0.0, 0.0, 0.0, 1.0}},
27 1.0
28 };
29
30 XF funcxf; /* current transformation */
31 static OBJREC *fobj = NULL; /* current function object */
32 static RAY *fray = NULL; /* current function ray */
33
34 static char rayinitcal[] = INITFILE;
35
36 static double l_erf(char *), l_erfc(char *), l_arg(char *);
37
38
39 void
40 initfunc(void) /* initialize function evaluation */
41 {
42 if (!rayinitcal[0]) /* already done? */
43 return;
44 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
45 esupport &= ~(E_OUTCHAN);
46 setcontext("");
47 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
48 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
49 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
50 scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
51 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
52 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
53 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
54 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
55 scompile("Lu=$26;Lv=$27;", NULL, 0);
56 funset("arg", 1, '=', l_arg);
57 funset("erf", 1, ':', l_erf);
58 funset("erfc", 1, ':', l_erfc);
59 setnoisefuncs();
60 setprismfuncs();
61 loadfunc(rayinitcal);
62 rayinitcal[0] = '\0';
63 }
64
65
66 /* Set parameters for current evaluation */
67 void
68 set_eparams(char *prms)
69 {
70 static char *last_params;
71 static int lplen = 0;
72 int len;
73 char vname[RMAXWORD];
74 double value;
75 char *cpd;
76 /* check if already set */
77 if (prms == NULL || !*prms)
78 return;
79 if (lplen && !strcmp(prms, last_params))
80 return;
81 len = strlen(prms); /* record new settings */
82 if ((lplen != 0) & (lplen <= len)) {
83 free(last_params);
84 lplen = 0;
85 }
86 if (!lplen) {
87 lplen = len + 100;
88 last_params = (char *)malloc(lplen);
89 if (last_params == NULL)
90 error(SYSTEM, "out of memory in set_eparams()");
91 }
92 strcpy(last_params, prms);
93 /* assign each variable */
94 while (*prms) {
95 if (isspace(*prms)) {
96 ++prms; continue;
97 }
98 if (!isalpha(*prms))
99 goto bad_params;
100 cpd = vname;
101 while (*prms && (*prms != '=') & !isspace(*prms)) {
102 if (!isid(*prms) | (cpd-vname >= RMAXWORD-1))
103 goto bad_params;
104 *cpd++ = *prms++;
105 }
106 *cpd = '\0';
107 while (isspace(*prms)) prms++;
108 if (*prms++ != '=')
109 goto bad_params;
110 value = atof(prms);
111 if ((prms = fskip(prms)) == NULL)
112 goto bad_params;
113 while (isspace(*prms)) prms++;
114 prms += (*prms == ',') | (*prms == ';');
115 varset(vname, '=', value);
116 }
117 eclock++; /* notify expression evaluator */
118 return;
119 bad_params:
120 sprintf(errmsg, "bad parameter list '%s'", last_params);
121 error(USER, errmsg);
122 }
123
124
125 MFUNC *
126 getfunc( /* get function for this modifier */
127 OBJREC *m,
128 int ff,
129 unsigned int ef,
130 int dofwd
131 )
132 {
133 char sbuf[MAXSTR];
134 char **arg;
135 MFUNC *f;
136 int ne, na;
137 int i;
138 /* check to see if done already */
139 if ((f = (MFUNC *)m->os) != NULL)
140 return(f);
141 fobj = NULL; fray = NULL;
142 if (rayinitcal[0]) /* initialize on first call */
143 initfunc();
144 if ((na = m->oargs.nsargs) <= ff)
145 goto toofew;
146 arg = m->oargs.sarg;
147 if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
148 goto memerr;
149 i = strlen(arg[ff]); /* set up context */
150 if (i == 1 && arg[ff][0] == '.') {
151 setcontext(f->ctx = ""); /* "." means no file */
152 } else {
153 strcpy(sbuf,arg[ff]); /* file name is context */
154 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
155 sbuf[i-LCALSUF] = '\0'; /* remove suffix */
156 setcontext(f->ctx = savestr(sbuf));
157 if (!vardefined(REFVNAME)) { /* file loaded? */
158 loadfunc(arg[ff]);
159 varset(REFVNAME, '=', 1.0);
160 } else /* reference_count++ */
161 varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
162 }
163 curfunc = NULL; /* parse expressions */
164 sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
165 for (i=0, ne=0; ef && i < na; i++, ef>>=1)
166 if (ef & 1) { /* flagged as an expression? */
167 if (ne >= MAXEXPR)
168 objerror(m, INTERNAL, "too many expressions");
169 initstr(arg[i], sbuf, 0);
170 f->ep[ne++] = getE1();
171 if (nextc != EOF)
172 syntax("unexpected character");
173 }
174 if (ef)
175 goto toofew;
176 if (i <= ff) /* find transform args */
177 i = ff+1;
178 while (i < na && arg[i][0] != '-')
179 i++;
180 if (i == na) { /* no transform */
181 f->fxp = f->bxp = &unitxf;
182 } else { /* get transform */
183 if ((f->bxp = (XF *)malloc(sizeof(XF))) == NULL)
184 goto memerr;
185 if (invxf(f->bxp, na-i, arg+i) != na-i)
186 objerror(m, USER, "bad transform");
187 if (f->bxp->sca < 0.0)
188 f->bxp->sca = -f->bxp->sca;
189 if (dofwd) { /* do both transforms */
190 if ((f->fxp = (XF *)malloc(sizeof(XF))) == NULL)
191 goto memerr;
192 xf(f->fxp, na-i, arg+i);
193 if (f->fxp->sca < 0.0)
194 f->fxp->sca = -f->fxp->sca;
195 }
196 }
197 m->os = (char *)f;
198 return(f);
199 toofew:
200 objerror(m, USER, "too few string arguments");
201 memerr:
202 error(SYSTEM, "out of memory in getfunc");
203 return NULL; /* pro forma return */
204 }
205
206
207 void
208 freefunc( /* free memory associated with modifier */
209 OBJREC *m
210 )
211 {
212 MFUNC *f;
213 int i;
214
215 if ((f = (MFUNC *)m->os) == NULL)
216 return;
217 for (i = 0; f->ep[i] != NULL; i++)
218 epfree(f->ep[i]);
219 if (f->ctx[0]) { /* done with definitions */
220 setcontext(f->ctx);
221 i = varvalue(REFVNAME)-.5; /* reference_count-- */
222 if (i > 0)
223 varset(REFVNAME, '=', (double)i);
224 else
225 dcleanup(2); /* remove definitions */
226 freestr(f->ctx);
227 }
228 if (f->bxp != &unitxf)
229 free((void *)f->bxp);
230 if ((f->fxp != NULL) & (f->fxp != &unitxf))
231 free((void *)f->fxp);
232 free((void *)f);
233 m->os = NULL;
234 }
235
236
237 int
238 setfunc( /* set channels for function call */
239 OBJREC *m,
240 RAY *r
241 )
242 {
243 static RNUMBER lastrno = ~0;
244 MFUNC *f;
245 /* get function if any */
246 if ((f = (MFUNC *)m->os) == NULL)
247 objerror(m, CONSISTENCY, "setfunc called before getfunc");
248
249 setcontext(f->ctx); /* set evaluator context */
250 /* check to see if matrix set */
251 if ((m == fobj) & (r->rno == lastrno))
252 return(0);
253 fobj = m;
254 fray = r;
255 if (r->rox != NULL) {
256 if (f->bxp != &unitxf) {
257 funcxf.sca = r->rox->b.sca * f->bxp->sca;
258 multmat4(funcxf.xfm, r->rox->b.xfm, f->bxp->xfm);
259 } else
260 funcxf = r->rox->b;
261 } else
262 funcxf = *f->bxp;
263 lastrno = r->rno;
264 eclock++; /* notify expression evaluator */
265 return(1);
266 }
267
268
269 int
270 worldfunc( /* special function context sans object */
271 char *ctx,
272 RAY *r
273 )
274 {
275 static RNUMBER lastrno = ~0;
276
277 if (rayinitcal[0]) /* initialize on first call */
278 initfunc();
279 /* set evaluator context */
280 setcontext(ctx);
281 /* check if ray already set */
282 if ((fobj == NULL) & (r->rno == lastrno))
283 return(0);
284 fobj = NULL;
285 fray = r;
286 funcxf = unitxf;
287 lastrno = r->rno;
288 eclock++; /* notify expression evaluator */
289 return(1);
290 }
291
292
293 void
294 loadfunc( /* load definition file */
295 char *fname
296 )
297 {
298 char *ffname;
299
300 if ((ffname = getpath(fname, getrlibpath(), R_OK)) == NULL) {
301 sprintf(errmsg, "cannot find function file \"%s\"", fname);
302 error(SYSTEM, errmsg);
303 }
304 fcompile(ffname);
305 }
306
307
308 static double
309 l_arg(char *nm) /* return nth real argument */
310 {
311 int n;
312
313 if (fobj == NULL)
314 error(INTERNAL, "arg(n) called without a modifier context");
315
316 n = argument(1) + .5; /* round to integer */
317
318 if (n < 1)
319 return(fobj->oargs.nfargs);
320
321 if (n > fobj->oargs.nfargs) {
322 sprintf(errmsg, "missing real argument %d", n);
323 objerror(fobj, USER, errmsg);
324 }
325 return(fobj->oargs.farg[n-1]);
326 }
327
328
329 static double
330 l_erf(char *nm) /* error function */
331 {
332 return(erf(argument(1)));
333 }
334
335
336 static double
337 l_erfc(char *nm) /* cumulative error function */
338 {
339 return(erfc(argument(1)));
340 }
341
342
343 double
344 chanvalue( /* return channel n to calcomp */
345 int n
346 )
347 {
348 if (fray == NULL)
349 syntax("ray parameter used in constant expression");
350
351 if (--n < 0)
352 goto badchan;
353
354 if (n <= 2) /* ray direction */
355
356 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
357 fray->rdir[1]*funcxf.xfm[1][n] +
358 fray->rdir[2]*funcxf.xfm[2][n] )
359 / funcxf.sca );
360
361 if (n <= 5) /* surface normal */
362
363 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
364 fray->ron[1]*funcxf.xfm[1][n-3] +
365 fray->ron[2]*funcxf.xfm[2][n-3] )
366 / funcxf.sca );
367
368 if (n <= 8) { /* intersection point */
369 if (fray->rot >= FHUGE)
370 return(0.0); /* XXX should be runtime error? */
371
372 return( fray->rop[0]*funcxf.xfm[0][n-6] +
373 fray->rop[1]*funcxf.xfm[1][n-6] +
374 fray->rop[2]*funcxf.xfm[2][n-6] +
375 funcxf.xfm[3][n-6] );
376 }
377
378 if (n == 9) /* total distance */
379 return(raydist(fray,PRIMARY) * funcxf.sca);
380
381 if (n == 10) /* dot product (range [-1,1]) */
382 return( fray->rod <= -1.0 ? -1.0 :
383 fray->rod >= 1.0 ? 1.0 :
384 fray->rod );
385
386 if (n == 11) /* scale */
387 return(funcxf.sca);
388
389 if (n <= 14) /* origin */
390 return(funcxf.xfm[3][n-12]);
391
392 if (n <= 17) /* i unit vector */
393 return(funcxf.xfm[0][n-15] / funcxf.sca);
394
395 if (n <= 20) /* j unit vector */
396 return(funcxf.xfm[1][n-18] / funcxf.sca);
397
398 if (n <= 23) /* k unit vector */
399 return(funcxf.xfm[2][n-21] / funcxf.sca);
400
401 if (n == 24) /* single ray (shadow) distance */
402 return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca);
403
404 if (n <= 26) /* local (u,v) coordinates */
405 return(fray->uv[n-25]);
406 badchan:
407 error(USER, "illegal channel number");
408 return(0.0);
409 }
