root/radiance/src/rt/freeobjmem.c
Revision: 2.7
Committed: Tue Mar 30 16:13:01 2004 UTC (21 years, 6 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9
Changes since 2.6: +15 -10 lines
2 static const char RCSid[] = "$Id: freeobjmem.c,v 2.6 2003/07/10 03:47:00 greg Exp $";
5 * Free memory associated with object(s)
6 *
7 * External symbols declared in ray.h
8 */
9
10 #include "copyright.h"
11
12 #include "ray.h"
13 #include "otypes.h"
14 #include "rtotypes.h"
15 #include "face.h"
16 #include "cone.h"
17 #include "instance.h"
18 #include "data.h"
19 #include "font.h"
20 #include "func.h"
21 #include "mesh.h"
22
23
24 extern int
25 free_os( /* free unneeded memory for object */
26 register OBJREC *op
27 )
28 {
29 if (op->os == NULL)
30 return(0);
31 if (hasfunc(op->otype)) {
32 freefunc(op);
33 return(1);
34 }
35 switch (op->otype) {
36 case OBJ_FACE: /* polygon */
37 freeface(op);
38 return(1);
39 case OBJ_CONE: /* cone */
40 case OBJ_RING: /* disk */
41 case OBJ_CYLINDER: /* cylinder */
42 case OBJ_CUP: /* inverted cone */
43 case OBJ_TUBE: /* inverted cylinder */
44 freecone(op);
45 return(1);
46 case OBJ_INSTANCE: /* octree instance */
47 freeinstance(op);
48 return(1);
49 case OBJ_MESH: /* mesh instance */
50 freemeshinst(op);
51 return(1);
52 case PAT_BTEXT: /* monochromatic text */
53 case PAT_CTEXT: /* colored text */
54 case MIX_TEXT: /* mixing text */
55 freetext(op);
56 return(1);
57 case MAT_CLIP: /* clipping surface */
58 case MAT_SPOT: /* spot light source */
59 free((void *)op->os);
60 op->os = NULL;
61 return(1);
62 }
63 #ifdef DEBUG
64 objerror(op, WARNING, "cannot free structure");
65 #endif
66 return(0);
67 }
68
69
70 extern int
71 free_objs( /* free some object structures */
72 register OBJECT on,
73 OBJECT no
74 )
75 {
76 int nfreed;
77 register OBJREC *op;
78
79 for (nfreed = 0; no-- > 0; on++) {
80 op = objptr(on);
81 if (op->os != NULL)
82 nfreed += free_os(op);
83 }
84 return(nfreed);
85 }
86
87
88 extern void
89 free_objmem(void) /* free all object cache memory */
90 {
91 free_objs(0, nobjects);
92 freedata(NULL);
93 freefont(NULL);
94 }
